[U-Boot-Users] [PATCH] tftp: don't implicity trust the format of recevied packets
The TFTP OACK code trusts that the incoming packet is formated as ASCII text and can be processed by string functions. It also as a loop limit overflow bug where if the packet length is less than 8, it ends up looping over *all* of memory to find the 'blksize' string.
This patch solves the problem by forcing the packet to be null terminated and using strstr() to search for the sub string.
Signed-off-by: Grant Likely grant.likely@secretlab.ca ---
net/tftp.c | 20 ++++++++++---------- 1 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index fb2f505..27f5e88 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -238,9 +238,9 @@ TftpSend (void) static void TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) { + char * blksize; ushort proto; ushort *s; - int i;
if (dest != TftpOurPort) { #ifdef CONFIG_MCAST_TFTP @@ -272,22 +272,22 @@ TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len)
case TFTP_OACK: #ifdef ET_DEBUG - printf("Got OACK: %s %s\n", pkt, pkt+strlen(pkt)+1); + printf("Got OACK:\n"); + print_buffer (0, pkt, 1, len, 16); #endif TftpState = STATE_OACK; TftpServerPort = src; + /* Check for 'blksize' option */ - for (i=0;i<len-8;i++) { - if (strcmp ((char*)pkt+i,"blksize") == 0) { - TftpBlkSize = (unsigned short) - simple_strtoul((char*)pkt+i+8,NULL,10); + pkt[len] = 0; /* NULL terminate so string ops work */ + blksize = strstr((char*)pkt, "blksize"); + if ((blksize) && (blksize + 8 < (char*)pkt + len)) { + TftpBlkSize = simple_strtoul(blksize + 8, NULL, 10); #ifdef ET_DEBUG - printf ("Blocksize ack: %s, %d\n", - (char*)pkt+i+8,TftpBlkSize); + printf("Blocksize ack: %d\n", TftpBlkSize); #endif - break; - } } + #ifdef CONFIG_MCAST_TFTP parse_multicast_oack((char *)pkt,len-1); if ((Multicast) && (!MasterClient))
In message 20070830002624.4040.18733.stgit@trillian.cg.shawcable.net you wrote:
Thanks a lot. Applied.
Grant Likely
