[QUESTION] Device tree for gmii-to-rgmii phy driver
Hi Siva Durga Prasad Paladugu,
we want to add rgmii-id support to the gmiitorgmii phy driver. How does the correct device tree for the gmiitorgmii looks like? The converter sits between the MAC and the external PHY (MAC <==> GMII2RGMII <==> RGMII_PHY) which would mean that the phy-handle of the MAC should point to the GMII2RGMII and the GMII2RGMII to RGMII_PHY:
&gem0 { phy-handle = <&gmiitorgmii0>; phy-mode = "gmii";
mdio { ethphy0: ethernet-phy@1 { };
gmiitorgmii0: gmiitorgmii@8 { compatible = "xlnx,gmii-to-rgmii-1.0"; phy-handle = <ðphy0>; phy-mode = "rgmii-id"; }; }; };
This device tree snippet does not work in the kernel. The kernel gmii2rgmii driver does not use a phy driver as base and manipulates the functions of the external phy object instead. It requires the following device tree snippet:
&gem0 { phy-handle = <ðphy0>; phy-mode = "rgmii-id";
This does not work in u-boot because the phy framework ignores the phy-handle of the MAC for the gmii2rgmii but the gmii2rgmii driver itself checks the phy-mode of the MAC.
What is the correct device tree and thereby proper implementation?
Regards Stefan
It is known issue for some time and U-Boot description is correct. Linux needs to be fixed. I remember there were any issue with framework not supporting it that's why unfortunately different description needs to be used. I am CCing Harini. Here team should work on getting this fixed.
Thanks, Michal
Michal Simek
