[U-Boot] [PATCH] ARM: omap3_logic: Use DEFAULT_LINUX_BOOT_ENV from ti_armv7_common
Since we're including ti_armv7_common, let's pull in DEFAULT_LINUX_BOOT_ENV and remove unnecessary duplicative definitions. This patch also renames a few environmental variables to match what is inside ti_armv7_common. This should help future-proof any subsequent memory or memory location changes.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index b38811e..71ae2be 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -31,7 +31,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING /* cmd line edit/history */
/* Hardware drivers */
@@ -124,9 +123,7 @@ "saveenv;"
#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=0x81000000\0" \ - "uimage=uImage\0" \ - "zimage=zImage\0" \ + DEFAULT_LINUX_BOOT_ENV \ "mtdids=" MTDIDS_DEFAULT "\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "mmcdev=0\0" \ @@ -156,18 +153,17 @@ "${optargs};" \ "run addmtdparts; " \ "run vrfb_arg\0" \ - "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ + "loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo 'Running bootscript from mmc ...'; " \ "source ${loadaddr}\0" \ "loaduimage=mmc rescan; " \ - "fatload mmc ${mmcdev} ${loadaddr} ${uimage}\0" \ + "load mmc ${mmcdev} ${loadaddr} uImage\0" \ "loadzimage=mmc rescan; " \ - "fatload mmc ${mmcdev} ${loadaddr} ${zimage}\0" \ + "load mmc ${mmcdev} ${loadaddr} zImage\0" \ "ramdisksize=64000\0" \ - "ramdiskaddr=0x82000000\0" \ "ramdiskimage=rootfs.ext2.gz.uboot\0" \ "loadramdisk=mmc rescan; " \ - "fatload mmc ${mmcdev} ${ramdiskaddr} ${ramdiskimage}\0" \ + "load mmc ${mmcdev} ${rdaddr} ${ramdiskimage}\0" \ "ramargs=run setconsole; setenv bootargs console=${console} " \ "root=/dev/ram rw ramdisk_size=${ramdisksize}\0" \ "mmcargs=run setconsole; setenv bootargs console=${console} " \ @@ -184,15 +180,14 @@ "ip=${ipaddr}:${tftpserver}:${gatewayip}:${netmask}::eth0:off\0" \ "nfsrootpath=/opt/nfs-exports/omap\0" \ "autoload=no\0" \ - "fdtaddr=0x86000000\0" \ - "loadfdtimage=mmc rescan; " \ - "fatload mmc ${mmcdev} ${fdtaddr} ${fdtimage}\0" \ + "loadfdt=mmc rescan; " \ + "load mmc ${mmcdev} ${fdtaddr} ${fdtimage}\0" \ "mmcbootz=echo Booting with DT from mmc${mmcdev} ...; " \ "run mmcargs; " \ "run common_bootargs; " \ "run dump_bootargs; " \ "run loadzimage; " \ - "run loadfdtimage; " \ + "run loadfdt; " \ "bootz ${loadaddr} - ${fdtaddr}\0" \ "mmcramboot=echo 'Booting uImage kernel from mmc w/ramdisk...'; " \ "run ramargs; " \ @@ -200,22 +195,22 @@ "run dump_bootargs; " \ "run loaduimage; " \ "run loadramdisk; " \ - "bootm ${loadaddr} ${ramdiskaddr}\0" \ + "bootm ${loadaddr} ${rdaddr}\0" \ "mmcrambootz=echo 'Booting zImage kernel from mmc w/ramdisk...'; " \ "run ramargs; " \ "run common_bootargs; " \ "run dump_bootargs; " \ "run loadzimage; " \ "run loadramdisk; " \ - "run loadfdtimage; " \ - "bootz ${loadaddr} ${ramdiskaddr} ${fdtaddr};\0" \ + "run loadfdt; " \ + "bootz ${loadaddr} ${rdaddr} ${fdtaddr};\0" \ "tftpboot=echo 'Booting kernel/ramdisk rootfs from tftp...'; " \ "run ramargs; " \ "run common_bootargs; " \ "run dump_bootargs; " \ "tftpboot ${loadaddr} ${zimage}; " \ - "tftpboot ${ramdiskaddr} ${ramdiskimage}; " \ - "bootm ${loadaddr} ${ramdiskaddr}\0" \ + "tftpboot ${rdaddr} ${ramdiskimage}; " \ + "bootm ${loadaddr} ${rdaddr}\0" \ "tftpbootz=echo 'Booting kernel NFS rootfs...'; " \ "dhcp;" \ "run nfsargs;" \ @@ -228,7 +223,6 @@ "run autoboot"
/* Miscellaneous configurable options */ -#define CONFIG_AUTO_COMPLETE
/* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0)
Adam Ford
