[PATCH] warp7: Remove UART initialization code
With DM_SERIAL selected, it is no longer needed board code to initialize the UART.
Describe the nodes that require dm-pre-reloc, which allows the DM model to configure the UART pinctrl early.
Remove the now unneeded board UART initialization.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx7s-warp-u-boot.dtsi | 16 ++++++++++++++++ arch/arm/dts/imx7s.dtsi | 2 +- board/warp7/warp7.c | 20 -------------------- configs/warp7_defconfig | 1 + 4 files changed, 18 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/imx7s-warp-u-boot.dtsi b/arch/arm/dts/imx7s-warp-u-boot.dtsi index 6319840b1ce3..bc4b5745fc7c 100644 --- a/arch/arm/dts/imx7s-warp-u-boot.dtsi +++ b/arch/arm/dts/imx7s-warp-u-boot.dtsi @@ -8,3 +8,19 @@ stdout-path = &uart1; }; }; + +&aips3 { + u-boot,dm-pre-reloc; +}; + +&pinctrl_uart1 { + u-boot,dm-pre-reloc; +}; + +&soc { + u-boot,dm-pre-reloc; +}; + +&uart1 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi index 483824fc06e6..cf0206dd0f08 100644 --- a/arch/arm/dts/imx7s.dtsi +++ b/arch/arm/dts/imx7s.dtsi @@ -184,7 +184,7 @@ <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; };
- soc { + soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index c5c5433048dd..95b8e82dd1cc 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -27,9 +27,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU100KOHM | \ - PAD_CTL_HYS) - int dram_init(void) { gd->ram_size = PHYS_SDRAM_SIZE; @@ -46,23 +43,6 @@ static iomux_v3_cfg_t const wdog_pads[] = { MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B | MUX_PAD_CTRL(NO_PAD_CTRL), };
-static iomux_v3_cfg_t const uart1_pads[] = { - MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static void setup_iomux_uart(void) -{ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); -}; - -int board_early_init_f(void) -{ - setup_iomux_uart(); - - return 0; -} - #ifdef CONFIG_DM_PMIC int power_init_board(void) { diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index a76565edfd4a..be69174217b0 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -19,6 +19,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then run do_bootscript_hab;if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; fi; fi; fi" +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTZ=y
Hi Fabio,
+&aips3 {
- u-boot,dm-pre-reloc;
+&pinctrl_uart1 {
+&soc {
+&uart1 {
- soc {
- soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus";
PAD_CTL_HYS)
Added the same to warp7_bl33_defconfig by merging.
Regards, Stefano
From: Fabio Estevam festevam@denx.de With DM_SERIAL selected, it is no longer needed board code to initialize the UART. Describe the nodes that require dm-pre-reloc, which allows the DM model to configure the UART pinctrl early. Remove the now unneeded board UART initialization. Signed-off-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
Stefano Babic
