[PATCH] cmd: xtrace: Convert to bool
This variable is a boolean, not a string.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
cmd/Kconfig | 2 +- configs/bcm_ns3_defconfig | 2 +- configs/taurus_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 928a2a0a2d..09e638fafe 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -65,7 +65,7 @@ config SYS_PROMPT_HUSH_PS2 to complete a command. Usually "> ".
config SYS_XTRACE - string "Command execution tracer" + bool "Command execution tracer" depends on CMDLINE default y if CMDLINE help diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index d060097d74..5fb82e9479 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -19,7 +19,7 @@ CONFIG_SILENT_U_BOOT_ONLY=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="u-boot> " -CONFIG_SYS_XTRACE="n" +CONFIG_SYS_XTRACE=n CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_MMC=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 6198159107..1f7e342229 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -44,7 +44,7 @@ CONFIG_SPL_NAND_BASE=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " -CONFIG_SYS_XTRACE="n" +CONFIG_SYS_XTRACE=n # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Sean Anderson
