[U-Boot] [PATCH][v1] ppc/85x/86xxx: Device tree fixup for number of cores
Fixing the number of cores in the device tree based on the actual number of cores on the system. With this same device tree image can be used for dual core and single core members of otherwise exactly same SOC. For example P2020RDB and P2010RDB P1020RDB and P1011RDB
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- applies on git.am.freescale.net/mirrors/u-boot.git cpu/mpc85xx/fdt.c | 2 + cpu/mpc86xx/fdt.c | 3 ++ cpu/mpc8xxx/Makefile | 1 + cpu/mpc8xxx/fdt.c | 55 ++++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 61 insertions(+), 0 deletions(-) create mode 100644 cpu/mpc8xxx/fdt.c
diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index a692529..4eef170 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -31,6 +31,7 @@ DECLARE_GLOBAL_DATA_PTR;
extern void ft_qe_setup(void *blob); +extern void ft_fixup_num_cores(void *blob);
#ifdef CONFIG_MP #include "mp.h" @@ -324,6 +325,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_MP ft_fixup_cpu(blob, (u64)bd->bi_memstart + (u64)bd->bi_memsize); #endif + ft_fixup_num_cores(blob);
ft_fixup_cache(blob); } diff --git a/cpu/mpc86xx/fdt.c b/cpu/mpc86xx/fdt.c index a36ee30..51f3f4c 100644 --- a/cpu/mpc86xx/fdt.c +++ b/cpu/mpc86xx/fdt.c @@ -13,6 +13,8 @@
+extern void ft_fixup_num_cores(void *blob); + void ft_cpu_setup(void *blob, bd_t *bd) { #ifdef CONFIG_MP @@ -54,4 +56,5 @@ void ft_cpu_setup(void *blob, bd_t *bd) if (off < 0) printf("%s: %s\n", __FUNCTION__, fdt_strerror(off)); #endif + ft_fixup_num_cores(blob); } diff --git a/cpu/mpc8xxx/Makefile b/cpu/mpc8xxx/Makefile index 430a75f..9817d1b 100644 --- a/cpu/mpc8xxx/Makefile +++ b/cpu/mpc8xxx/Makefile @@ -11,6 +11,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib8xxx.a
COBJS-y += cpu.o +COBJS-$(CONFIG_OF_LIBFDT) += fdt.o
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) diff --git a/cpu/mpc8xxx/fdt.c b/cpu/mpc8xxx/fdt.c new file mode 100644 index 0000000..0777231 --- /dev/null +++ b/cpu/mpc8xxx/fdt.c @@ -0,0 +1,55 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * This file is derived from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c. + * Basically this file contains cpu specific common code for 85xx/86xx + * processors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> + +void ft_fixup_num_cores(void *blob) { + int i, off, num_cores, del_cores; + + del_cores = 0; + num_cores = cpu_numcores(); + + off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); + while (off != -FDT_ERR_NOTFOUND) { + u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0); + + /* if we find a cpu node outside of what we expect delete it + * and reset the offset back to the start since we can't + * trust the offsets anymore + */ + if (*reg > num_cores-1) { + fdt_del_node(blob, off); + del_cores++; + off = -1; + } + off = fdt_node_offset_by_prop_value(blob, off, + "device_type", "cpu", 4); + } + debug ("%x core system found\n", num_cores); + debug ("deleted %d extra core entry entries from device tree\n", + del_cores); +}
applies on git.am.freescale.net/mirrors/u-boot.git cpu/mpc85xx/fdt.c | 2 + cpu/mpc86xx/fdt.c | 3 ++ cpu/mpc8xxx/Makefile | 1 + cpu/mpc8xxx/fdt.c | 55 +++++++++++++++++++++++++++++++++++++++++ +++++++++ 4 files changed, 61 insertions(+), 0 deletions(-) create mode 100644 cpu/mpc8xxx/fdt.c
applied to 85xx
- K
Kumar Gala
Poonam Aggrwal
