[U-Boot] [PATCH 4/5] mpc83xx: mpc8360emds: Use RGMII mode, add workarounds for rev. 2.1 CPUs
This patch fixes various ethernet issues with gigabit links handling in U-Boot. The workarounds originally implemented by Kim Phillips for Linux kernel.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com --- board/freescale/mpc8360emds/mpc8360emds.c | 56 +++++++++++++++++++++++++--- include/configs/MPC8360EMDS.h | 4 +- 2 files changed, 52 insertions(+), 8 deletions(-)
diff --git a/board/freescale/mpc8360emds/mpc8360emds.c b/board/freescale/mpc8360emds/mpc8360emds.c index 769eb2f..54f2989 100644 --- a/board/freescale/mpc8360emds/mpc8360emds.c +++ b/board/freescale/mpc8360emds/mpc8360emds.c @@ -21,12 +21,14 @@ #endif #include <spd_sdram.h> #include <asm/mmu.h> +#include <asm/io.h> #if defined(CONFIG_OF_LIBFDT) #include <libfdt.h> #endif #if defined(CONFIG_PQ_MDS_PIB) #include "../common/pq-mds-pib.h" #endif +#include "../../../drivers/qe/uec.h"
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ @@ -89,11 +91,19 @@ const qe_iop_conf_t qe_iop_conf_tab[] = { {0, 0, 0, 0, QE_IOP_TAB_END}, /* END of table */ };
-int board_early_init_f(void) +/* Handle "mpc8360ea rev.2.1 erratum 2: RGMII Timing"? */ +static int board_handle_erratum2(void) { + const immap_t *immr = (immap_t *)CONFIG_SYS_IMMR;
- u8 *bcsr = (u8 *)CONFIG_SYS_BCSR; + return REVID_MAJOR(immr->sysconf.spridr) == 2 && + REVID_MINOR(immr->sysconf.spridr) == 1; +} + +int board_early_init_f(void) +{ const immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + u8 *bcsr = (u8 *)CONFIG_SYS_BCSR;
/* Enable flash write */ bcsr[0xa] &= ~0x04; @@ -105,6 +115,21 @@ int board_early_init_f(void) /* Enable second UART */ bcsr[0x9] &= ~0x01;
+ if (board_handle_erratum2()) { + void *immap = (immap_t *)(CONFIG_SYS_IMMR + 0x14a8); + + /* + * IMMR + 0x14A8[4:5] = 11 (clk delay for UCC 2) + * IMMR + 0x14A8[18:19] = 11 (clk delay for UCC 1) + */ + setbits_be32(immap, 0x0c003000); + + /* + * IMMR + 0x14AC[20:27] = 10101010 + * (data delay for both UCC's) + */ + clrsetbits_be32(immap + 4, 0xff0, 0xaa0); + } return 0; }
@@ -116,6 +141,28 @@ int board_early_init_r(void) return 0; }
+#ifdef CONFIG_UEC_ETH +static uec_info_t uec_info[] = { +#ifdef CONFIG_UEC_ETH1 + STD_UEC_INFO(1), +#endif +#ifdef CONFIG_UEC_ETH2 + STD_UEC_INFO(2), +#endif +}; + +int board_eth_init(bd_t *bd) +{ + if (board_handle_erratum2()) { + int i; + + for (i = 0; i < ARRAY_SIZE(uec_info); i++) + uec_info[i].enet_interface = ENET_1000_RGMII_RXID; + } + return uec_eth_init(bd, uec_info, ARRAY_SIZE(uec_info)); +} +#endif /* CONFIG_UEC_ETH */ + #if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void ddr_enable_ecc(unsigned int dram_size); #endif @@ -312,8 +359,6 @@ static int sdram_init(unsigned int base) { return 0; } #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { - const immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - ft_cpu_setup(blob, bd); #ifdef CONFIG_PCI ft_pci_setup(blob, bd); @@ -323,8 +368,7 @@ void ft_board_setup(void *blob, bd_t *bd) * if on mpc8360ea rev. 2.1, * change both ucc phy-connection-types from rgmii-id to rgmii-rxid */ - if ((REVID_MAJOR(immr->sysconf.spridr) == 2) && - (REVID_MINOR(immr->sysconf.spridr) == 1)) { + if (board_handle_erratum2()) { int nodeoffset; const char *prop; int path; diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index b072e84..30a8d45 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -397,7 +397,7 @@ #define CONFIG_SYS_UEC1_TX_CLK QE_CLK9 #define CONFIG_SYS_UEC1_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC1_PHY_ADDR 0 -#define CONFIG_SYS_UEC1_INTERFACE_MODE ENET_1000_GMII +#define CONFIG_SYS_UEC1_INTERFACE_MODE ENET_1000_RGMII #endif
#define CONFIG_UEC_ETH2 /* GETH2 */ @@ -408,7 +408,7 @@ #define CONFIG_SYS_UEC2_TX_CLK QE_CLK4 #define CONFIG_SYS_UEC2_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC2_PHY_ADDR 1 -#define CONFIG_SYS_UEC2_INTERFACE_MODE ENET_1000_GMII +#define CONFIG_SYS_UEC2_INTERFACE_MODE ENET_1000_RGMII #endif
On Wed, 16 Sep 2009 23:21:59 +0400 Anton Vorontsov avorontsov@ru.mvista.com wrote:
sorry, can't accept - this breaks r1.1 based boards:
U-Boot 2009.08-00210-g089732e (Sep 18 2009 - 17:25:22) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c1, MPC8360E, Rev: 1.1 at 528 MHz, CSB: 264 MHz Board: Freescale MPC8360EMDS I2C: ready DRAM: 256 MB (DDR1, 64-bit, ECC off, 264 MHz) SDRAM: 64 MB (local bus) FLASH: 16 MB In: serial Out: serial Err: serial Net: FSL UEC0, FSL UEC1 Hit any key to stop autoboot: 0 => tftp $loadaddr $uboot UEC: PHY is Marvell 88E11x1 (1410cc2) FSL UEC0: Full Duplex FSL UEC0: Speed 1000BT FSL UEC0: Link is up Using FSL UEC0 device TFTP from server 192.168.1.1; our IP address is 192.168.1.118 Filename 'kimphill/u-boot.MPC8360EMDS'. Load address: 0x800000 Loading: T T T T T T T T T T Retry count exceeded; starting again UEC: PHY is Marvell 88E11x1 (1410cc2) warning: FSL UEC1: timeout on PHY link FSL UEC0: Link is down
Kim
Oops. Thanks a lot for testing.
I think I know why it breaks, we should use RGMII_ID for < 2.1 revs (at least that's what we have in Linux by default). I don't have r1.1 CPUs, can you please try this patch on top of the current patch set?
If it'll work, I'll repost a fixed version of this patch.
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index dab0173..62cf13b 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -399,7 +399,7 @@ #define CONFIG_SYS_UEC1_TX_CLK QE_CLK9 #define CONFIG_SYS_UEC1_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC1_PHY_ADDR 0 -#define CONFIG_SYS_UEC1_INTERFACE_MODE ENET_1000_RGMII +#define CONFIG_SYS_UEC1_INTERFACE_MODE ENET_1000_RGMII_ID #endif
#define CONFIG_UEC_ETH2 /* GETH2 */ @@ -410,7 +410,7 @@ #define CONFIG_SYS_UEC2_TX_CLK QE_CLK4 #define CONFIG_SYS_UEC2_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC2_PHY_ADDR 1 -#define CONFIG_SYS_UEC2_INTERFACE_MODE ENET_1000_RGMII +#define CONFIG_SYS_UEC2_INTERFACE_MODE ENET_1000_RGMII_ID #endif
On Sat, 19 Sep 2009 03:29:17 +0400 Anton Vorontsov avorontsov@ru.mvista.com wrote:
that worked, thanks.
I fixed up the original commit; I'll push shortly.
Ben, I'm picking up 1-2/5 (unless you have already; I'm behind on the list) - hope you don't mind.
Kim
Kim
Fine by me. I have some catching up to do too.
Ben
Great, thanks a lot Kim.
Anton Vorontsov
Ben Warren
Kim Phillips
