[PATCH u-boot-mvebu] watchdog: armada_37xx: Probe driver also when watchdog is already running
If Armada 37xx watchdog is started before U-Boot then CNTR_CTRL_ACTIVE bit is set, U-Boot armada-37xx-wdt.c driver fails to initialize and so U-Boot is unable to use or kick this watchdog.
Do not check for CNTR_CTRL_ACTIVE bit and always initialize watchdog. Same behavior is implemented in Linux kernel driver.
This change allows to activate watchdog in firmware which loads U-Boot.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/watchdog/armada-37xx-wdt.c | 17 +++-------------- 1 file changed, 3 insertions(+), 14 deletions(-)
diff --git a/drivers/watchdog/armada-37xx-wdt.c b/drivers/watchdog/armada-37xx-wdt.c index 2e119b9b5aad..bacebbc7926a 100644 --- a/drivers/watchdog/armada-37xx-wdt.c +++ b/drivers/watchdog/armada-37xx-wdt.c @@ -58,13 +58,11 @@ static void counter_disable(struct a37xx_wdt *priv, int id) clrbits_le32(priv->reg + CNTR_CTRL(id), CNTR_CTRL_ENABLE); }
-static int init_counter(struct a37xx_wdt *priv, int id, u32 mode, u32 trig_src) +static void init_counter(struct a37xx_wdt *priv, int id, u32 mode, u32 trig_src) { u32 reg;
reg = readl(priv->reg + CNTR_CTRL(id)); - if (reg & CNTR_CTRL_ACTIVE) - return -EBUSY;
reg &= ~(CNTR_CTRL_MODE_MASK | CNTR_CTRL_PRESCALE_MASK | CNTR_CTRL_TRIG_SRC_MASK); @@ -79,8 +77,6 @@ static int init_counter(struct a37xx_wdt *priv, int id, u32 mode, u32 trig_src) reg |= trig_src;
writel(reg, priv->reg + CNTR_CTRL(id)); - - return 0; }
static int a37xx_wdt_reset(struct udevice *dev) @@ -116,16 +112,9 @@ static int a37xx_wdt_expire_now(struct udevice *dev, ulong flags) static int a37xx_wdt_start(struct udevice *dev, u64 ms, ulong flags) { struct a37xx_wdt *priv = dev_get_priv(dev); - int err; - - err = init_counter(priv, 0, CNTR_CTRL_MODE_ONESHOT, 0); - if (err < 0) - return err;
- err = init_counter(priv, 1, CNTR_CTRL_MODE_HWSIG, - CNTR_CTRL_TRIG_SRC_PREV_CNTR); - if (err < 0) - return err; + init_counter(priv, 0, CNTR_CTRL_MODE_ONESHOT, 0); + init_counter(priv, 1, CNTR_CTRL_MODE_HWSIG, CNTR_CTRL_TRIG_SRC_PREV_CNTR);
priv->timeout = ms * priv->clk_rate / 1000 / CNTR_CTRL_PRESCALE_MIN;
Reviewed-by: Marek Behún marek.behun@nic.cz
Thanks, Stefan
return -EBUSY;
return 0; }
int err;
if (err < 0)
return err;
if (err < 0)
return err;
Viele Grüße, Stefan Roese
Applied to u-boot-watchdog/master
Thanks, Stefan
return -EBUSY;
return 0; }
int err;
if (err < 0)
return err;
if (err < 0)
return err;
Marek Behún
Pali Rohár
Stefan Roese
