[PATCH v1] net: eth-uclass: Fix eth_halt
eth_device_priv maybe unaccessable after @stop handler due to eth device is removed in @stop. Setting private data before @stop handler.
This also fix data abort bug when run dhcp or tftp command via usbnet.
Signed-off-by: qianfan Zhao qianfanguijin@163.com --- net/eth-uclass.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 58c308f332..c6eb1bc8f8 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -338,9 +338,14 @@ void eth_halt(void) if (!priv || !priv->running) return;
- eth_get_ops(current)->stop(current); - priv->state = ETH_STATE_PASSIVE; + /* Make sure setting private data before @stop handler, it may remove + * ethernet device and will cause @priv unaccessable. + * eg: + * usb_eth_stop -> usb_gadget_release -> device_remove + */ priv->running = false; + + eth_get_ops(current)->stop(current); }
int eth_is_active(struct udevice *dev)
Why did you delete this line ?
* eg:
2.17.1
在 2022/4/2 3:26, Ramon Fried 写道:
As we all konw priv->state can't set after @stop handler. But some eth driver such as drivers/net/ldpaa_eth/ldpaa_eth.c check @priv->state in @stop handler, do noting if state is ETH_STATE_PASSIVE. So I delete this.
But I think it's a mistake when I check source code again. Should get private again after @stop handler and set state to ETH_STATE_PASSIVE if private data available.
I will send new patch later.
* eg:
-- 2.17.1
qianfan
Ramon Fried
