[U-Boot] [PATCH] ARM: mxs: tools: Fix errno handling in strtoul() invocation
According to NOTE in strtoul(3), the errno must be zeroed before strtoul() is called. Zero the errno. The NOTE reads as such:
Since strtoul() can legitimately return 0 or ULONG_MAX (ULLONG_MAX for strtoull()) on both success and failure, the calling program should set errno to 0 before the call, and then determine if an error occurred by checking whether errno has a nonzero value after the call.
This issue was detected on Fedora 19 with glibc 2.17 .
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@ti.com --- tools/mxsimage.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 5db19b2..7bd9dee 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -502,6 +502,7 @@ static int sb_token_to_long(char *tok, uint32_t *rid)
tok += 2;
+ errno = 0; id = strtoul(tok, &endptr, 16); if ((errno == ERANGE && id == ULONG_MAX) || (errno != 0 && id == 0)) { fprintf(stderr, "ERR: Value can't be decoded!\n");
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Stefano Babic
