[PATCH v2 1/2] km: adapt defines and variables for new memory layout
Due to increasing kernel image sizes we get problems when decompressing the kernel image. To fix this we need to change the addresses where we load and where we extract the kernel. Also we need to adapt the address where to load the CRAMFS image and where to load the DTB file. While at it also harmonize all boards for PPC and ARM to have the same values. Also we add a new variable "env_version", so that the userspace is able to detect if this is a u-boot binary with updated values or not.
CC: Valentin Longchamp valentin.longchamp@hitachi-powergrids.com CC: Heiko Schocher hs@denx.de CC: Tom Rini trini@konsulko.com Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com --- board/keymile/Kconfig | 12 +++--------- include/configs/km/keymile-common.h | 1 + include/configs/km/km-powerpc.h | 4 ++++ include/configs/km/km_arm.h | 3 +++ 4 files changed, 11 insertions(+), 9 deletions(-)
diff --git a/board/keymile/Kconfig b/board/keymile/Kconfig index e20c017436..e5906906f3 100644 --- a/board/keymile/Kconfig +++ b/board/keymile/Kconfig @@ -37,26 +37,20 @@ config KM_RESERVED_PRAM
config KM_CRAMFS_ADDR hex "CRAMFS Address" - default 0x2400000 if ARCH_KIRKWOOD - default 0xC00000 if MPC83xx - default 0x2000000 if MPC85xx + default 0x3000000 depends on !ARCH_SOCFPGA help Start address of the CRAMFS containing the Linux kernel.
config KM_KERNEL_ADDR hex "Kernel Load Address" - default 0x2000000 if ARCH_KIRKWOOD - default 0x400000 if MPC83xx - default 0x1000000 if MPC85xx || ARCH_SOCFPGA + default 0x2000000 help Address where to load Linux kernel in RAM.
config KM_FDT_ADDR hex "FDT Load Address" - default 0x23E0000 if ARCH_KIRKWOOD || ARCH_SOCFPGA - default 0xB80000 if MPC83xx - default 0x1F80000 if MPC85xx + default 0x2FC0000 help Address where to load flattened device tree in RAM.
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index e9e3981060..6a8c41529f 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -160,6 +160,7 @@ "pnvramsize=" __stringify(CONFIG_KM_PNVRAM) "\0" \ "testbootcmd=setenv boot_bank ${test_bank}; " \ "run ${subbootcmds}; reset\0" \ + "env_version=1\0" \ ""
#ifndef CONFIG_KM_DEF_ENV diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index fde8487178..7bfe12fecb 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -21,6 +21,9 @@ /* Reserve 4 MB for malloc */ #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
+/* Increase max size of compressed kernel */ +#define CONFIG_SYS_BOOTM_LEN 0x2000000 /* 32 MB */ + /****************************************************************************** * (PRAM usage) * ... ------------------------------------------------------- @@ -53,6 +56,7 @@ "protect on " __stringify(BOOTFLASH_START) " +${filesize}\0"\ "set_fdthigh=true\0" \ "checkfdt=true\0" \ + "bootm_mapsize=" __stringify(CONFIG_SYS_BOOTM_LEN) "\0" \ ""
#endif /* __CONFIG_KEYMILE_POWERPC_H */ diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 79edfa728a..98e0ce1c24 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -35,6 +35,9 @@ /* Reserve 4 MB for malloc */ #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
+/* Increase max size of compressed kernel */ +#define CONFIG_SYS_BOOTM_LEN (32 << 20) + #include "asm/arch/config.h"
#define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */
Instead having a hard coded value for "cramfsaddr" after compile time, we change it to take the variable "cramfsaddr" for the ubicopy variable. This makes sure that ubicopy uses the right address, even when the value for "cramfsaddr" has changed.
CC: Valentin Longchamp valentin.longchamp@hitachi-powergrids.com CC: Heiko Schocher hs@denx.de CC: Tom Rini trini@konsulko.com Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com --- include/configs/km/keymile-common.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 6a8c41529f..c1968048a7 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -143,8 +143,7 @@ #define CONFIG_KM_DEF_ENV_FLASH_BOOT \ "cramfsaddr=" __stringify(CONFIG_KM_CRAMFS_ADDR) "\0" \ "cramfsloadkernel=cramfsload ${load_addr_r} ${uimage}\0" \ - "ubicopy=ubi read "__stringify(CONFIG_KM_CRAMFS_ADDR) \ - " bootfs${boot_bank}\0" \ + "ubicopy=ubi read ${cramfsaddr} bootfs${boot_bank}\0" \ "uimage=" CONFIG_KM_UIMAGE_NAME \ CONFIG_KM_DEV_ENV_FLASH_BOOT_UBI
Hello Holger,
Am 09.10.2020 um 17:21 schrieb Holger Brunck:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
CC: Valentin Longchamp valentin.longchamp@hitachi-powergrids.com CC: Heiko Schocher hs@denx.de CC: Tom Rini trini@konsulko.com Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com Reviewed-by: Heiko Schocher hs@denx.de
Hello Holger,
Nitpick: Version history missing... see: https://www.denx.de/wiki/U-Boot/Patches#Sending_updated_patch_versions
Tip: may you want to use u-boot:/tools/patman/README
bye, Heiko
Heiko Schocher
Holger Brunck
