[U-Boot] [PATCH 0/7] LS1046A SMMU enabling patches
This patch series adds the required devices setup and device tree fixups for SMMU enablement on LS1046A chips. The approach taken tries to mimic the implementation of PAMU LIODN setup on booke powerpc.
First 4 patches contain some fixes and add some missing bits & pieces. Last 3 patches add the actual infrastructure for ICID setup, qman portal and fman ICID configuration.
Laurentiu Tudor (7): armv8: fsl-layerscape: add configs for missing register blocks addresses armv8: ls1046a: advertise QMan v3 in configuration misc: fsl_portals: setup QMAN_BAR{E} also on ARM platforms armv8: fsl-layerscape: add missing debug stream ID armv8: ls1046a: initial icid setup support armv8: ls1046a: add icid setup for qman portals armv8: ls1046a: setup fman ports ICIDs and device tree
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/icid.c | 193 ++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 75 +++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 3 + .../include/asm/arch-fsl-layerscape/config.h | 1 + .../asm/arch-fsl-layerscape/fsl_icid.h | 90 ++++++++ .../asm/arch-fsl-layerscape/fsl_portals.h | 23 +++ .../asm/arch-fsl-layerscape/immap_lsch2.h | 3 + .../asm/arch-fsl-layerscape/stream_id_lsch2.h | 1 + board/freescale/ls1046aqds/ls1046aqds.c | 2 + board/freescale/ls1046ardb/ls1046ardb.c | 3 + drivers/misc/fsl_portals.c | 50 ++++- scripts/config_whitelist.txt | 3 + 13 files changed, 439 insertions(+), 9 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/icid.c create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h
Add config defines with the sata, edma and qdma register block base addresses. Also white list the newly introduced defines.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 3 +++ scripts/config_whitelist.txt | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 5b4767e0fe..301b3fe642 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -32,9 +32,12 @@ #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011c0600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_IMMR + 0x011d0500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_IMMR + 0x011d0600) +#define CONFIG_SYS_EDMA_ADDR (CONFIG_SYS_IMMR + 0x01c00000) #define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) #define CONFIG_SYS_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) #define CONFIG_SYS_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_FSL_SATA_ADDR (CONFIG_SYS_IMMR + 0x02200000) +#define CONFIG_SYS_QDMA_ADDR (CONFIG_SYS_IMMR + 0x07380000) #define CONFIG_SYS_EHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x07600000) #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1a54337594..46abb27e13 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2557,6 +2557,7 @@ CONFIG_SYS_DSPI_CTAR7 CONFIG_SYS_DV_NOR_BOOT_CFG CONFIG_SYS_EBI_CFGR_VAL CONFIG_SYS_EBI_CSA_VAL +CONFIG_SYS_EDMA_ADDR CONFIG_SYS_EEPROM_BASE CONFIG_SYS_EEPROM_BUS_NUM CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE @@ -2914,6 +2915,7 @@ CONFIG_SYS_FSL_RAID_ENGINE_OFFSET CONFIG_SYS_FSL_RCPM_ADDR CONFIG_SYS_FSL_RMU CONFIG_SYS_FSL_RST_ADDR +CONFIG_SYS_FSL_SATA_ADDR CONFIG_SYS_FSL_SCFG_ADDR CONFIG_SYS_FSL_SCFG_IODSECR1_ADDR CONFIG_SYS_FSL_SCFG_IODSECR1_OFFSET @@ -4064,6 +4066,7 @@ CONFIG_SYS_PTCPAR CONFIG_SYS_PTDPAR CONFIG_SYS_PTV CONFIG_SYS_PUAPAR +CONFIG_SYS_QDMA_ADDR CONFIG_SYS_QE_FMAN_FW_IN_MMC CONFIG_SYS_QE_FMAN_FW_IN_NAND CONFIG_SYS_QE_FMAN_FW_IN_NOR
I don't think this will go through. You can't add new config macros. Use other than CONFIG_ names, or Kconfig.
York
Hi York,
-----Original Message----- From: York Sun Sent: Thursday, June 28, 2018 6:18 PM
Understood. I'm thinking of putting these SoC specific defines in a Kconfig but I'm having trouble finding which one would best fit.
--- Best Regards, Laurentiu
The QMan IP block in this SoC is version 3.2 so advertise this in the SoC configuration header.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 23faffd9fc..8a05148136 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -257,6 +257,7 @@
#elif defined(CONFIG_ARCH_LS1046A) #define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_FSL_QMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 2
QMAN_BAR{E} register setup was disabled on ARM platforms, however the register does need to be set. Add code that sets it up on ARMs.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- drivers/misc/fsl_portals.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c index 7c22b8d209..5b1233740b 100644 --- a/drivers/misc/fsl_portals.c +++ b/drivers/misc/fsl_portals.c @@ -24,14 +24,19 @@ void setup_qbman_portals(void) CONFIG_SYS_BMAN_SWP_ISDR_REG; void __iomem *qpaddr = (void *)CONFIG_SYS_QMAN_CINH_BASE + CONFIG_SYS_QMAN_SWP_ISDR_REG; -#ifdef CONFIG_PPC struct ccsr_qman *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR;
/* Set the Qman initiator BAR to match the LAW (for DQRR stashing) */ +#ifdef CONFIG_PPC32 #ifdef CONFIG_PHYS_64BIT out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); #endif out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); +#else +#ifdef CONFIG_PHYS_64BIT + out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_BASE >> 32)); +#endif + out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_BASE); #endif #ifdef CONFIG_FSL_CORENET int i;
Add a define with a value for the missing debug stream ID.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h index 61c6e533c6..1b02d484d9 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h @@ -50,6 +50,7 @@ #define FSL_QDMA_STREAM_ID 7 #define FSL_EDMA_STREAM_ID 8 #define FSL_ETR_STREAM_ID 9 +#define FSL_DEBUG_STREAM_ID 10
/* PCI - programmed in PEXn_LUT */ #define FSL_PEX_STREAM_ID_START 11
Add infrastructure for ICID setup and device tree fixup on ARM platforms. This include basic ICID setup for several devices.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/icid.c | 111 ++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 29 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 3 + .../asm/arch-fsl-layerscape/fsl_icid.h | 80 +++++++++++++ board/freescale/ls1046aqds/ls1046aqds.c | 2 + board/freescale/ls1046ardb/ls1046ardb.c | 3 + 7 files changed, 229 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/icid.c create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 1e9e4680fe..5d6f68aad6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -37,6 +37,7 @@ endif
ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o +obj-y += icid.o ls1046_ids.o endif
ifneq ($(CONFIG_ARCH_LS1088A),) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c new file mode 100644 index 0000000000..8694bd6fa1 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <linux/libfdt.h> +#include <fdt_support.h> + +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> + +static void set_icid(struct icid_id_table *tbl, int size) +{ + int i; + + for (i = 0; i < size; i++) + out_be32((u32 *)(tbl[i].reg_addr), tbl[i].reg); +} + +void set_icids(void) +{ + /* setup general icid offsets */ + set_icid(icid_tbl, icid_tbl_sz); +} + +int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) +{ + int i, ret; + u32 prop[8]; + + for (i = 0; i < num_ids; i++) { + prop[i * 2] = cpu_to_fdt32(smmu_ph); + prop[i * 2 + 1] = cpu_to_fdt32(ids[i]); + } + ret = fdt_setprop(blob, off, "iommus", + prop, sizeof(u32) * num_ids * 2); + if (ret > 0) { + printf("WARNING unable to set iommus: %s\n", fdt_strerror(off)); + return off; + } + ret = fdt_setprop_empty(blob, off, "dma-coherent"); + if (ret > 0) { + printf("WARNING unable to set dma-coherent: %s\n", + fdt_strerror(off)); + return off; + } + + return 0; +} + +int fdt_fixup_icid_tbl(void *blob, int smmu_ph, + struct icid_id_table *tbl, int size) +{ + int i, err, off; + + for (i = 0; i < size; i++) { + if (!tbl[i].compat) + continue; + + off = fdt_node_offset_by_compat_reg(blob, + tbl[i].compat, + tbl[i].compat_addr); + if (off > 0) { + err = fdt_set_iommu_prop(blob, off, smmu_ph, + &tbl[i].id, 1); + if (err) + return err; + } else { + printf("WARNING could not find node %s: %s.\n", + tbl[i].compat, fdt_strerror(off)); + } + } + + return 0; +} + +int fdt_get_smmu_phandle(void *blob) +{ + int noff, smmu_ph; + + noff = fdt_node_offset_by_compatible(blob, -1, "arm,mmu-500"); + if (noff < 0) { + printf("WARNING failed to get smmu node: %s\n", + fdt_strerror(noff)); + return noff; + } + + smmu_ph = fdt_get_phandle(blob, noff); + if (!smmu_ph) { + smmu_ph = fdt_create_phandle(blob, noff); + if (!smmu_ph) { + printf("WARNING failed to get smmu phandle\n"); + return -1; + } + } + + return smmu_ph; +} + +void fdt_fixup_icid(void *blob) +{ + int smmu_ph; + + smmu_ph = fdt_get_smmu_phandle(blob); + if (smmu_ph < 0) + return; + + fdt_fixup_icid_tbl(blob, smmu_ph, icid_tbl, icid_tbl_sz); +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c new file mode 100644 index 0000000000..d9e03fcb89 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <asm/arch-fsl-layerscape/immap_lsch2.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> + +struct icid_id_table icid_tbl[] = { +#ifdef CONFIG_SYS_DPAA_QBMAN + SET_QMAN_ICID(FSL_DPAA1_STREAM_ID_START), + SET_BMAN_ICID(FSL_DPAA1_STREAM_ID_START + 1), +#endif + + SET_SDHC_ICID(FSL_SDHC_STREAM_ID), + + SET_USB_ICID(1, "snps,dwc3", FSL_USB1_STREAM_ID), + SET_USB_ICID(2, "snps,dwc3", FSL_USB2_STREAM_ID), + SET_USB_ICID(3, "snps,dwc3", FSL_USB3_STREAM_ID), + + SET_SATA_ICID(FSL_SATA_STREAM_ID), + SET_QDMA_ICID(FSL_QDMA_STREAM_ID), + SET_EDMA_ICID(FSL_EDMA_STREAM_ID), + SET_ETR_ICID(FSL_ETR_STREAM_ID), + SET_DEBUG_ICID(FSL_DEBUG_STREAM_ID), +}; + +int icid_tbl_sz = ARRAY_SIZE(icid_tbl); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index bfd663942a..5c5df5b7ef 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <asm/global_data.h> #include <asm/arch-fsl-layerscape/config.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #ifdef CONFIG_LAYERSCAPE_NS_ACCESS #include <fsl_csu.h> #endif @@ -674,6 +675,8 @@ void fsl_lsch2_early_init_f(void) erratum_a009798(); erratum_a008997(); erratum_a009007(); + + set_icids(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h new file mode 100644 index 0000000000..4f285e3f99 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -0,0 +1,80 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef _FSL_ICID_H_ +#define _FSL_ICID_H_ + +#include <asm/types.h> +#include <fsl_qbman.h> + +struct icid_id_table { + const char *compat; + u32 id; + u32 reg; + phys_addr_t compat_addr; + phys_addr_t reg_addr; +}; + +u32 get_ppid_icid(int ppid_tbl_idx, int ppid); +int fdt_get_smmu_phandle(void *blob); +int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); +void set_icids(void); +void fdt_fixup_icid(void *blob); + +#define SET_ICID_ENTRY(name, idA, regA, addr, compataddr) \ + { .compat = name, \ + .id = idA, \ + .reg = regA, \ + .compat_addr = compataddr, \ + .reg_addr = addr, \ + } + +#define SET_SCFG_ICID(compat, icid, name, compataddr) \ + SET_ICID_ENTRY(compat, icid, (((icid) << 24) | (1 << 23)), \ + offsetof(struct ccsr_scfg, name) + CONFIG_SYS_FSL_SCFG_ADDR, \ + compataddr) + +#define SET_USB_ICID(usb_num, compat, icid) \ + SET_SCFG_ICID(compat, icid, usb##usb_num##_icid,\ + CONFIG_SYS_XHCI_USB##usb_num##_ADDR) + +#define SET_SATA_ICID(icid) \ + SET_SCFG_ICID("fsl,ls1046a-ahci", icid, sata_icid,\ + CONFIG_SYS_FSL_SATA_ADDR) + +#define SET_SDHC_ICID(icid) \ + SET_SCFG_ICID("fsl,esdhc", icid, sdhc_icid,\ + CONFIG_SYS_FSL_ESDHC_ADDR) + +#define SET_QDMA_ICID(icid) \ + SET_SCFG_ICID("fsl,ls1046a-qdma", icid, dma_icid,\ + CONFIG_SYS_QDMA_ADDR) + +#define SET_EDMA_ICID(icid) \ + SET_SCFG_ICID("fsl,vf610-edma", icid, edma_icid,\ + CONFIG_SYS_EDMA_ADDR) + +#define SET_ETR_ICID(icid) \ + SET_SCFG_ICID(NULL, icid, etr_icid, 0) + +#define SET_DEBUG_ICID(icid) \ + SET_SCFG_ICID(NULL, icid, debug_icid, 0) + +#define SET_QMAN_ICID(icid) \ + SET_ICID_ENTRY("fsl,qman", icid, icid, \ + offsetof(struct ccsr_qman, liodnr) + \ + CONFIG_SYS_FSL_QMAN_ADDR, \ + CONFIG_SYS_FSL_QMAN_ADDR) + +#define SET_BMAN_ICID(icid) \ + SET_ICID_ENTRY("fsl,bman", icid, icid, \ + offsetof(struct ccsr_bman, liodnr) + \ + CONFIG_SYS_FSL_BMAN_ADDR, \ + CONFIG_SYS_FSL_BMAN_ADDR) + +extern struct icid_id_table icid_tbl[]; +extern int icid_tbl_sz; + +#endif diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index b765f07f85..072f8c37a5 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -309,6 +309,8 @@ int ft_board_setup(void *blob, bd_t *bd) fdt_fixup_board_enet(blob); #endif
+ fdt_fixup_icid(blob); + reg = QIXIS_READ(brdcfg[0]); reg = (reg & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT;
diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index feb5c2448a..0a73fe859d 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -11,6 +11,7 @@ #include <asm/arch/fsl_serdes.h> #include <asm/arch/ppa.h> #include <asm/arch/soc.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #include <hwconfig.h> #include <ahci.h> #include <mmc.h> @@ -174,6 +175,8 @@ int ft_board_setup(void *blob, bd_t *bd) fdt_fixup_fman_ethernet(blob); #endif
+ fdt_fixup_icid(blob); + return 0; } #endif
Add support for ICID setting of qman portals and the required device tree fixups. Also fix an endiness issue in portal setup code.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 16 +++++++ .../asm/arch-fsl-layerscape/fsl_portals.h | 23 ++++++++++ drivers/misc/fsl_portals.c | 43 +++++++++++++++---- 3 files changed, 74 insertions(+), 8 deletions(-) create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index d9e03fcb89..62bad3ab9c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -6,6 +6,22 @@ #include <common.h> #include <asm/arch-fsl-layerscape/immap_lsch2.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <asm/arch-fsl-layerscape/fsl_portals.h> + +#ifdef CONFIG_SYS_DPAA_QBMAN +struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), +}; +#endif
struct icid_id_table icid_tbl[] = { #ifdef CONFIG_SYS_DPAA_QBMAN diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h new file mode 100644 index 0000000000..bd8d3fb49a --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef _FSL_PORTALS_H_ +#define _FSL_PORTALS_H_ + +struct qportal_info { + u16 dicid; /* DQRR ICID */ + u16 ficid; /* frame data ICID */ + u16 icid; + u8 sdest; +}; + +#define SET_QP_INFO(_icid, dest) \ + { .dicid = _icid, .ficid = _icid, .icid = _icid, .sdest = dest } + +extern struct qportal_info qp_info[]; +void fdt_portal(void *blob, const char *compat, const char *container, + u64 addr, u32 size); + +#endif diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c index 5b1233740b..da174fc7e2 100644 --- a/drivers/misc/fsl_portals.c +++ b/drivers/misc/fsl_portals.c @@ -13,6 +13,9 @@ #ifdef CONFIG_PPC #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h> +#else +#include <asm/arch-fsl-layerscape/fsl_portals.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #endif #include <fsl_qbman.h>
@@ -52,6 +55,22 @@ void setup_qbman_portals(void) /* set frame liodn */ out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | fliodn); } +#else +#ifdef CONFIG_ARM + int i; + + for (i = 0; i < CONFIG_SYS_QMAN_NUM_PORTALS; i++) { + u8 sdest = qp_info[i].sdest; + u16 ficid = qp_info[i].ficid; + u16 dicid = qp_info[i].dicid; + u16 icid = qp_info[i].icid; + + out_be32(&qman->qcsp[i].qcsp_lio_cfg, (icid << 16) | + dicid); + /* set frame icid */ + out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | ficid); + } +#endif #endif
/* Change default state of BMan ISDR portals to all 1s */ @@ -185,6 +204,10 @@ void fdt_fixup_qportals(void *blob) char compat[64]; int compat_len;
+#ifndef CONFIG_PPC + int smmu_ph = fdt_get_smmu_phandle(blob); +#endif + maj = (rev_1 >> 8) & 0xff; min = rev_1 & 0xff; ip_cfg = rev_2 & 0xff; @@ -195,7 +218,6 @@ void fdt_fixup_qportals(void *blob)
off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); while (off != -FDT_ERR_NOTFOUND) { -#ifdef CONFIG_PPC #ifdef CONFIG_FSL_CORENET u32 liodns[2]; #endif @@ -205,12 +227,7 @@ void fdt_fixup_qportals(void *blob) if (!ci) goto err;
- i = *ci; -#ifdef CONFIG_SYS_DPAA_FMAN - int j; -#endif - -#endif /* CONFIG_PPC */ + i = fdt32_to_cpu(*ci); err = fdt_setprop(blob, off, "compatible", compat, compat_len); if (err < 0) goto err; @@ -242,7 +259,7 @@ void fdt_fixup_qportals(void *blob) #endif
#ifdef CONFIG_SYS_DPAA_FMAN - for (j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { + for (int j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { char name[] = "fman@0";
name[sizeof(name) - 2] = '0' + j; @@ -258,6 +275,16 @@ void fdt_fixup_qportals(void *blob) if (err < 0) goto err; #endif +#else + if (smmu_ph >= 0) { + u32 icids[3]; + + icids[0] = qp_info[i].icid; + icids[1] = qp_info[i].dicid; + icids[2] = qp_info[i].ficid; + + fdt_set_iommu_prop(blob, off, smmu_ph, icids, 3); + } #endif /* CONFIG_PPC */
err:
Add support for ICID setting of fman ports and the required device tree fixups.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 82 +++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 30 +++++++ .../asm/arch-fsl-layerscape/fsl_icid.h | 10 +++ 3 files changed, 122 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c index 8694bd6fa1..9502f83ac8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/icid.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -10,6 +10,7 @@ #include <asm/io.h> #include <asm/processor.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <fsl_fman.h>
static void set_icid(struct icid_id_table *tbl, int size) { @@ -19,10 +20,27 @@ static void set_icid(struct icid_id_table *tbl, int size) out_be32((u32 *)(tbl[i].reg_addr), tbl[i].reg); }
+#ifdef CONFIG_SYS_FMAN_V3 +void set_fman_icids(struct fman_icid_id_table *tbl, int size) +{ + int i; + ccsr_fman_t *fm = (void *)CONFIG_SYS_FSL_FM1_ADDR; + + for (i = 0; i < size; i++) { + out_be32(&fm->fm_bmi_common.fmbm_ppid[tbl[i].port_id - 1], + tbl[i].icid); + } +} +#endif + void set_icids(void) { /* setup general icid offsets */ set_icid(icid_tbl, icid_tbl_sz); + +#ifdef CONFIG_SYS_FMAN_V3 + set_fman_icids(fman_icid_tbl, fman_icid_tbl_sz); +#endif }
int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) @@ -76,6 +94,66 @@ int fdt_fixup_icid_tbl(void *blob, int smmu_ph, return 0; }
+#ifdef CONFIG_SYS_FMAN_V3 +int get_fman_port_icid(int port_id, struct fman_icid_id_table *tbl, + const int size) +{ + int i; + + for (i = 0; i < size; i++) { + if (tbl[i].port_id == port_id) + return tbl[i].icid; + } + + return -1; +} + +void fdt_fixup_fman_port_icid_by_compat(void *blob, int smmu_ph, + const char *compat) +{ + int noff, len, icid; + const u32 *prop; + + noff = fdt_node_offset_by_compatible(blob, -1, compat); + while (noff > 0) { + prop = fdt_getprop(blob, noff, "cell-index", &len); + if (!prop) { + printf("WARNING missing cell-index for fman port\n"); + continue; + } + if (len != 4) { + printf("WARNING bad cell-index size for fman port\n"); + continue; + } + + icid = get_fman_port_icid(fdt32_to_cpu(*prop), + fman_icid_tbl, fman_icid_tbl_sz); + if (icid < 0) { + printf("WARNING unknown ICID for fman port %d\n", + *prop); + continue; + } + + fdt_set_iommu_prop(blob, noff, smmu_ph, (u32 *)&icid, 1); + + noff = fdt_node_offset_by_compatible(blob, noff, compat); + } +} + +void fdt_fixup_fman_icids(void *blob, int smmu_ph) +{ + static const char * const compats[] = { + "fsl,fman-v3-port-oh", + "fsl,fman-v3-port-rx", + "fsl,fman-v3-port-tx", + }; + int i; + + for (i = 0; i < ARRAY_SIZE(compats); i++) + fdt_fixup_fman_port_icid_by_compat(blob, smmu_ph, compats[i]); +} +#endif + int fdt_get_smmu_phandle(void *blob) { int noff, smmu_ph; @@ -108,4 +186,8 @@ void fdt_fixup_icid(void *blob) return;
fdt_fixup_icid_tbl(blob, smmu_ph, icid_tbl, icid_tbl_sz); + +#ifdef CONFIG_SYS_FMAN_V3 + fdt_fixup_fman_icids(blob, smmu_ph); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index 62bad3ab9c..1592029a60 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -43,3 +43,33 @@ struct icid_id_table icid_tbl[] = { };
int icid_tbl_sz = ARRAY_SIZE(icid_tbl); + +#ifdef CONFIG_SYS_DPAA_FMAN +struct fman_icid_id_table fman_icid_tbl[] = { + /* port id, icid */ + SET_FMAN_ICID_ENTRY(0x02, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x03, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x04, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x05, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x06, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x07, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x08, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x09, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0a, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0b, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0c, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0d, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x28, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x29, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2a, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2b, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2c, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2d, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x10, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x11, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x30, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x31, FSL_DPAA1_STREAM_ID_END), +}; + +int fman_icid_tbl_sz = ARRAY_SIZE(fman_icid_tbl); +#endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index 4f285e3f99..3e7261e1fd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -17,6 +17,11 @@ struct icid_id_table { phys_addr_t reg_addr; };
+struct fman_icid_id_table { + u32 port_id; + u32 icid; +}; + u32 get_ppid_icid(int ppid_tbl_idx, int ppid); int fdt_get_smmu_phandle(void *blob); int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); @@ -74,7 +79,12 @@ void fdt_fixup_icid(void *blob); CONFIG_SYS_FSL_BMAN_ADDR, \ CONFIG_SYS_FSL_BMAN_ADDR)
+#define SET_FMAN_ICID_ENTRY(_port_id, _icid) \ + { .port_id = (_port_id), .icid = (_icid) } + extern struct icid_id_table icid_tbl[]; +extern struct fman_icid_id_table fman_icid_tbl[]; extern int icid_tbl_sz; +extern int fman_icid_tbl_sz;
#endif
Laurentiu Tudor
York Sun
