[U-Boot] [PATCH 0/8] net/net.c: clenups for checkpatch compliance
net/net.c currently raises a lot of checkpatch issues: 76 errors, 197 warnings. This patchset fixes most of them, leaving 0 errors and 25 warnings.
Since the changes are quite massive I split them in separate patches, one per each category of errors/warning.
The 25 warnings still present are of the following types: - WARNING: consider using kstrto* in preference to simple_strtoul which is Linux-specific; - WARNING: externs should be avoided in .c files these are due to loop-dependencies between net/net.c and other files; - WARNING: line over 80 characters described in the commit message for patch 1; - WARNING: Use of volatile is usually wrong [...] I've had a quick look at these, but I don't know in detail how the networking code and Ethernet drivers (and maybe DMA?) interact, so I cannot remove them being sure that things will continue working.
Luca Ceresoli (8): net/net.c: cosmetic: fix lines over 80 characters net/net.c: cosmetic: variable initializations net/net.c: cosmetic: fix whitespace issues net/net.c: cosmetic: fix brace issues net/net.c: cosmetic: fix pointer syntax issues net/net.c: cosmetic: parentheses not required for return net/net.c: cosmetic: fix indentation net/net.c: cosmetic: do not use assignment in if condition
net/net.c | 600 ++++++++++++++++++++++++++++++++++--------------------------- 1 files changed, 333 insertions(+), 267 deletions(-)
This removes the following checkpatch warning: - WARNING: line over 80 characters
There is still one such warning that is hard to fix with cosmetic-only changes without compromising code readability, so I', leaving it as it is for now: WARNING: line over 80 characters #1537: FILE: net.c:1537: + [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ...
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 238 +++++++++++++++++++++++++++++++++++++++++-------------------- 1 files changed, 159 insertions(+), 79 deletions(-)
diff --git a/net/net.c b/net/net.c index e50bdf1..90312eb 100644 --- a/net/net.c +++ b/net/net.c @@ -101,7 +101,8 @@ DECLARE_GLOBAL_DATA_PTR;
#ifndef CONFIG_ARP_TIMEOUT -# define ARP_TIMEOUT 5000UL /* Milliseconds before trying ARP again */ +/* Milliseconds before trying ARP again */ +# define ARP_TIMEOUT 5000UL #else # define ARP_TIMEOUT CONFIG_ARP_TIMEOUT #endif @@ -115,16 +116,24 @@ DECLARE_GLOBAL_DATA_PTR;
/** BOOTP EXTENTIONS **/
-IPaddr_t NetOurSubnetMask=0; /* Our subnet mask (0=unknown) */ -IPaddr_t NetOurGatewayIP=0; /* Our gateways IP address */ -IPaddr_t NetOurDNSIP=0; /* Our DNS IP address */ +/* Our subnet mask (0=unknown) */ +IPaddr_t NetOurSubnetMask=0; +/* Our gateways IP address */ +IPaddr_t NetOurGatewayIP=0; +/* Our DNS IP address */ +IPaddr_t NetOurDNSIP=0; #if defined(CONFIG_BOOTP_DNS2) -IPaddr_t NetOurDNS2IP=0; /* Our 2nd DNS IP address */ -#endif -char NetOurNISDomain[32]={0,}; /* Our NIS domain */ -char NetOurHostName[32]={0,}; /* Our hostname */ -char NetOurRootPath[64]={0,}; /* Our bootpath */ -ushort NetBootFileSize=0; /* Our bootfile size in blocks */ +/* Our 2nd DNS IP address */ +IPaddr_t NetOurDNS2IP=0; +#endif +/* Our NIS domain */ +char NetOurNISDomain[32]={0,}; +/* Our hostname */ +char NetOurHostName[32]={0,}; +/* Our bootpath */ +char NetOurRootPath[64]={0,}; +/* Our bootfile size in blocks */ +ushort NetBootFileSize=0;
#ifdef CONFIG_MCAST_TFTP /* Multicast TFTP */ IPaddr_t Mcast_addr; @@ -132,16 +141,25 @@ IPaddr_t Mcast_addr;
/** END OF BOOTP EXTENTIONS **/
-ulong NetBootFileXferSize; /* The actual transferred size of the bootfile (in bytes) */ -uchar NetOurEther[6]; /* Our ethernet address */ -uchar NetServerEther[6] = /* Boot server enet address */ +/* The actual transferred size of the bootfile (in bytes) */ +ulong NetBootFileXferSize; +/* Our ethernet address */ +uchar NetOurEther[6]; +/* Boot server enet address */ +uchar NetServerEther[6] = { 0, 0, 0, 0, 0, 0 }; -IPaddr_t NetOurIP; /* Our IP addr (0 = unknown) */ -IPaddr_t NetServerIP; /* Server IP addr (0 = unknown) */ -volatile uchar *NetRxPacket; /* Current receive packet */ -int NetRxPacketLen; /* Current rx packet length */ -unsigned NetIPID; /* IP packet ID */ -uchar NetBcastAddr[6] = /* Ethernet bcast address */ +/* Our IP addr (0 = unknown) */ +IPaddr_t NetOurIP; +/* Server IP addr (0 = unknown) */ +IPaddr_t NetServerIP; +/* Current receive packet */ +volatile uchar *NetRxPacket; +/* Current rx packet length */ +int NetRxPacketLen; +/* IP packet ID */ +unsigned NetIPID; +/* Ethernet bcast address */ +uchar NetBcastAddr[6] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; uchar NetEtherNullAddr[6] = { 0, 0, 0, 0, 0, 0 }; @@ -149,24 +167,33 @@ uchar NetEtherNullAddr[6] = void (*push_packet)(volatile void *, int len) = 0; #endif #if defined(CONFIG_CMD_CDP) -uchar NetCDPAddr[6] = /* Ethernet bcast address */ +/* Ethernet bcast address */ +uchar NetCDPAddr[6] = { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; #endif -int NetState; /* Network loop state */ +/* Network loop state */ +int NetState; #ifdef CONFIG_NET_MULTI -int NetRestartWrap = 0; /* Tried all network devices */ -static int NetRestarted = 0; /* Network loop restarted */ -static int NetDevExists = 0; /* At least one device configured */ +/* Tried all network devices */ +int NetRestartWrap = 0; +/* Network loop restarted */ +static int NetRestarted = 0; +/* At least one device configured */ +static int NetDevExists = 0; #endif
/* XXX in both little & big endian machines 0xFFFF == ntohs(-1) */ -ushort NetOurVLAN = 0xFFFF; /* default is without VLAN */ -ushort NetOurNativeVLAN = 0xFFFF; /* ditto */ +/* default is without VLAN */ +ushort NetOurVLAN = 0xFFFF; +/* ditto */ +ushort NetOurNativeVLAN = 0xFFFF;
-char BootFile[128]; /* Boot File name */ +/* Boot File name */ +char BootFile[128];
#if defined(CONFIG_CMD_PING) -IPaddr_t NetPingIP; /* the ip address to ping */ +/* the ip address to ping */ +IPaddr_t NetPingIP;
static void PingStart(void); #endif @@ -176,8 +203,10 @@ static void CDPStart(void); #endif
#if defined(CONFIG_CMD_SNTP) -IPaddr_t NetNtpServerIP; /* NTP server IP address */ -int NetTimeOffset=0; /* offset time from UTC */ +/* NTP server IP address */ +IPaddr_t NetNtpServerIP; +/* offset time from UTC */ +int NetTimeOffset=0; #endif
#ifdef CONFIG_NETCONSOLE @@ -187,13 +216,19 @@ int nc_input_packet(uchar *pkt, unsigned dest, unsigned src, unsigned len);
volatile uchar PktBuf[(PKTBUFSRX+1) * PKTSIZE_ALIGN + PKTALIGN];
-volatile uchar *NetRxPackets[PKTBUFSRX]; /* Receive packets */ +/* Receive packet */ +volatile uchar *NetRxPackets[PKTBUFSRX];
-static rxhand_f *packetHandler; /* Current RX packet handler */ -static thand_f *timeHandler; /* Current timeout handler */ -static ulong timeStart; /* Time base value */ -static ulong timeDelta; /* Current timeout value */ -volatile uchar *NetTxPacket = 0; /* THE transmit packet */ +/* Current RX packet handler */ +static rxhand_f *packetHandler; +/* Current timeout handler */ +static thand_f *timeHandler; +/* Time base value */ +static ulong timeStart; +/* Current timeout value */ +static ulong timeDelta; +/* THE transmit packet */ +volatile uchar *NetTxPacket = 0;
static int net_check_prereq (proto_t protocol);
@@ -203,8 +238,10 @@ static int NetTryCount;
IPaddr_t NetArpWaitPacketIP; IPaddr_t NetArpWaitReplyIP; -uchar *NetArpWaitPacketMAC; /* MAC address of waiting packet's destination */ -uchar *NetArpWaitTxPacket; /* THE transmit packet */ +/* MAC address of waiting packet's destination */ +uchar *NetArpWaitPacketMAC; +/* THE transmit packet */ +uchar *NetArpWaitTxPacket; int NetArpWaitTxPacketSize; uchar NetArpWaitPacketBuf[PKTSIZE_ALIGN + PKTALIGN]; ulong NetArpWaitTimerStart; @@ -230,10 +267,13 @@ void ArpRequest (void) arp->ar_pln = 4; arp->ar_op = htons (ARPOP_REQUEST);
- memcpy (&arp->ar_data[0], NetOurEther, 6); /* source ET addr */ - NetWriteIP ((uchar *) & arp->ar_data[6], NetOurIP); /* source IP addr */ + /* source ET addr */ + memcpy (&arp->ar_data[0], NetOurEther, 6); + /* source IP addr */ + NetWriteIP ((uchar *) & arp->ar_data[6], NetOurIP); for (i = 10; i < 16; ++i) { - arp->ar_data[i] = 0; /* dest ET addr = 0 */ + /* dest ET addr = 0 */ + arp->ar_data[i] = 0; }
if ((NetArpWaitPacketIP & NetOurSubnetMask) != @@ -449,7 +489,9 @@ restart: }
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && defined(CONFIG_STATUS_LED) && defined(STATUS_LED_RED) +#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ + defined(CONFIG_STATUS_LED) && \ + defined(STATUS_LED_RED) /* * Echo the inverted link state to the fault LED. */ @@ -504,7 +546,8 @@ restart: /* * Echo the inverted link state to the fault LED. */ - if(miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { + if(miiphy_link(eth_get_dev()->name, + CONFIG_SYS_FAULT_MII_ADDR)) { status_led_set (STATUS_LED_RED, STATUS_LED_OFF); } else { status_led_set (STATUS_LED_RED, STATUS_LED_ON); @@ -654,7 +697,10 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) if (dest == 0xFFFFFFFF) ether = NetBcastAddr;
- /* if MAC address was not discovered yet, save the packet and do an ARP request */ + /* + * if MAC address was not discovered yet, save the packet and do + * an ARP request + */ if (memcmp(ether, NetEtherNullAddr, 6) == 0) {
debug("sending ARP for %08lx\n", dest); @@ -666,10 +712,12 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) pkt += NetSetEther (pkt, NetArpWaitPacketMAC, PROT_IP);
NetSetIP (pkt, dest, dport, sport, len); - memcpy(pkt + IP_HDR_SIZE, (uchar *)NetTxPacket + (pkt - (uchar *)NetArpWaitTxPacket) + IP_HDR_SIZE, len); + memcpy(pkt + IP_HDR_SIZE, (uchar *)NetTxPacket + + (pkt - (uchar *)NetArpWaitTxPacket) + IP_HDR_SIZE, len);
/* size of the waiting packet */ - NetArpWaitTxPacketSize = (pkt - NetArpWaitTxPacket) + IP_HDR_SIZE + len; + NetArpWaitTxPacketSize = (pkt - NetArpWaitTxPacket) + + IP_HDR_SIZE + len;
/* and do the ARP request */ NetArpWaitTry = 1; @@ -713,9 +761,11 @@ int PingSend(void) ip = (volatile IP_t *)pkt;
/* - * Construct an IP and ICMP header. (need to set no fragment bit - XXX) + * Construct an IP and ICMP header. + * (need to set no fragment bit - XXX) */ - ip->ip_hl_v = 0x45; /* IP_HDR_SIZE / 4 (not including UDP) */ + /* IP_HDR_SIZE / 4 (not including UDP) */ + ip->ip_hl_v = 0x45; ip->ip_tos = 0; ip->ip_len = htons(IP_HDR_SIZE_NO_UDP + 8); ip->ip_id = htons(NetIPID++); @@ -723,8 +773,10 @@ int PingSend(void) ip->ip_ttl = 255; ip->ip_p = 0x01; /* ICMP */ ip->ip_sum = 0; - NetCopyIP((void*)&ip->ip_src, &NetOurIP); /* already in network byte order */ - NetCopyIP((void*)&ip->ip_dst, &NetPingIP); /* - "" - */ + /* already in network byte order */ + NetCopyIP((void*)&ip->ip_src, &NetOurIP); + /* - "" - */ + NetCopyIP((void*)&ip->ip_dst, &NetPingIP); ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2);
s = &ip->udp_src; /* XXX ICMP starts here */ @@ -735,7 +787,8 @@ int PingSend(void) s[1] = ~NetCksum((uchar *)s, 8/2);
/* size of the waiting packet */ - NetArpWaitTxPacketSize = (pkt - NetArpWaitTxPacket) + IP_HDR_SIZE_NO_UDP + 8; + NetArpWaitTxPacketSize = + (pkt - NetArpWaitTxPacket) + IP_HDR_SIZE_NO_UDP + 8;
/* and do the ARP request */ NetArpWaitTry = 1; @@ -800,7 +853,8 @@ static int CDPOK; ushort CDPNativeVLAN; ushort CDPApplianceVLAN;
-static const uchar CDP_SNAP_hdr[8] = { 0xAA, 0xAA, 0x03, 0x00, 0x00, 0x0C, 0x20, 0x00 }; +static const uchar CDP_SNAP_hdr[8] = { 0xAA, 0xAA, 0x03, 0x00, 0x00, 0x0C, 0x20, + 0x00 };
static ushort CDP_compute_csum(const uchar *buff, ushort len) { @@ -831,13 +885,15 @@ static ushort CDP_compute_csum(const uchar *buff, ushort len) * CDP uses the IP checksum algorithm with a twist; * for the last byte it *sign* extends and sums. */ - result = (result & 0xffff0000) | ((result + leftover) & 0x0000ffff); + result = (result & 0xffff0000) | + ((result + leftover) & 0x0000ffff); } while (result >> 16) result = (result & 0xFFFF) + (result >> 16);
if (odd) - result = ((result >> 8) & 0xff) | ((result & 0xff) << 8); + result = ((result >> 8) & 0xff) | + ((result & 0xff) << 8); }
/* add up 16-bit and 17-bit words for 17+c bits */ @@ -890,7 +946,8 @@ int CDPSendTrigger(void) *pkt++ = 180; /* TTL */ s = (volatile ushort *)pkt; cp = s; - *s++ = htons(0); /* checksum (0 for later calculation) */ + /* checksum (0 for later calculation) */ + *s++ = htons(0);
/* CDP fields */ #ifdef CONFIG_CDP_DEVICE_ID @@ -962,7 +1019,8 @@ int CDPSendTrigger(void) et->et_protlen = htons(len);
len = ETHER_HDR_SIZE + sizeof(CDP_SNAP_hdr); - chksum = CDP_compute_csum((uchar *)NetTxPacket + len, (uchar *)s - (NetTxPacket + len)); + chksum = CDP_compute_csum((uchar *)NetTxPacket + len, + (uchar *)s - (NetTxPacket + len)); if (chksum == 0) chksum = 0xFFFF; *cp = htons(chksum); @@ -1019,10 +1077,13 @@ CDPHandler(const uchar * pkt, unsigned len) if (pkt[0] < 0x02 || pkt[1] == 0) return;
- /* if version is greater than 0x02 maybe we'll have a problem; output a warning */ + /* + * if version is greater than 0x02 maybe we'll have a problem; + * output a warning + */ if (pkt[0] != 0x02) - printf("** WARNING: CDP packet received with a protocol version %d > 2\n", - pkt[0] & 0xff); + printf("** WARNING: CDP packet received with a protocol version" + "%d > 2\n", pkt[0] & 0xff);
if (CDP_compute_csum(pkt, len) != 0) return; @@ -1075,10 +1136,12 @@ CDPHandler(const uchar * pkt, unsigned len) ss = (const ushort *)(t + 1);
#ifdef CONFIG_CDP_APPLIANCE_VLAN_TYPE - if (applid == CONFIG_CDP_APPLIANCE_VLAN_TYPE) + if (applid == + CONFIG_CDP_APPLIANCE_VLAN_TYPE) vlan = *ss; #else - vlan = ntohs(*ss); /* XXX will this work; dunno */ + /* XXX will this work; dunno */ + vlan = ntohs(*ss); #endif t += 3; tlen -= 3; } @@ -1440,7 +1503,8 @@ NetReceive(volatile uchar * inpkt, int len) }
switch (ntohs(arp->ar_op)) { - case ARPOP_REQUEST: /* reply with our IP address */ + case ARPOP_REQUEST: + /* reply with our IP address */ debug("Got ARP REQUEST, return our IP\n"); pkt = (uchar *)et; pkt += NetSetEther(pkt, et->et_src, PROT_ARP); @@ -1449,7 +1513,8 @@ NetReceive(volatile uchar * inpkt, int len) NetCopyIP(&arp->ar_data[16], &arp->ar_data[6]); memcpy (&arp->ar_data[ 0], NetOurEther, 6); NetCopyIP(&arp->ar_data[ 6], &NetOurIP); - (void) eth_send((uchar *)et, (pkt - (uchar *)et) + ARP_HDR_SIZE); + (void) eth_send((uchar *)et, + (pkt - (uchar *)et) + ARP_HDR_SIZE); return;
case ARPOP_REPLY: /* arp reply */ @@ -1474,14 +1539,16 @@ NetReceive(volatile uchar * inpkt, int len) if (tmp == NetArpWaitReplyIP) { debug("Got it\n"); /* save address for later use */ - memcpy(NetArpWaitPacketMAC, &arp->ar_data[0], 6); + memcpy(NetArpWaitPacketMAC, + &arp->ar_data[0], 6);
#ifdef CONFIG_NETCONSOLE (*packetHandler)(0,0,0,0); #endif /* modify header, and transmit it */ memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, NetArpWaitPacketMAC, 6); - (void) eth_send(NetArpWaitTxPacket, NetArpWaitTxPacketSize); + (void) eth_send(NetArpWaitTxPacket, + NetArpWaitTxPacketSize);
/* no arp request pending now */ NetArpWaitPacketIP = 0; @@ -1491,7 +1558,8 @@ NetReceive(volatile uchar * inpkt, int len) } return; default: - debug("Unexpected ARP opcode 0x%x\n", ntohs(arp->ar_op)); + debug("Unexpected ARP opcode 0x%x\n", + ntohs(arp->ar_op)); return; } break; @@ -1588,19 +1656,22 @@ NetReceive(volatile uchar * inpkt, int len) case ICMP_REDIRECT: if (icmph->code != ICMP_REDIR_HOST) return; - printf (" ICMP Host Redirect to %pI4 ", &icmph->un.gateway); + printf (" ICMP Host Redirect to %pI4 ", + &icmph->un.gateway); return; #if defined(CONFIG_CMD_PING) case ICMP_ECHO_REPLY: /* - * IP header OK. Pass the packet to the current handler. + * IP header OK. Pass the packet to the + * current handler. */ /* XXX point to ip packet */ (*packetHandler)((uchar *)ip, 0, 0, 0); return; case ICMP_ECHO_REQUEST: - debug("Got ICMP ECHO REQUEST, return %d bytes \n", - ETHER_HDR_SIZE + len); + debug("Got ICMP ECHO REQUEST, " + "return %d bytes \n", + ETHER_HDR_SIZE + len);
memcpy (&et->et_dest[0], &et->et_src[0], 6); memcpy (&et->et_src[ 0], NetOurEther, 6); @@ -1609,13 +1680,15 @@ NetReceive(volatile uchar * inpkt, int len) ip->ip_off = 0; NetCopyIP((void*)&ip->ip_dst, &ip->ip_src); NetCopyIP((void*)&ip->ip_src, &NetOurIP); - ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP >> 1); + ip->ip_sum = ~NetCksum((uchar *)ip, + IP_HDR_SIZE_NO_UDP >> 1);
icmph->type = ICMP_ECHO_REPLY; icmph->checksum = 0; icmph->checksum = ~NetCksum((uchar *)icmph, - (len - IP_HDR_SIZE_NO_UDP) >> 1); - (void) eth_send((uchar *)et, ETHER_HDR_SIZE + len); + (len - IP_HDR_SIZE_NO_UDP) >> 1); + (void) eth_send((uchar *)et, + ETHER_HDR_SIZE + len); return; #endif default: @@ -1656,7 +1729,8 @@ NetReceive(volatile uchar * inpkt, int len) xsum += sumdata; } while ((xsum >> 16) != 0) { - xsum = (xsum & 0x0000ffff) + ((xsum >> 16) & 0x0000ffff); + xsum = (xsum & 0x0000ffff) + + ((xsum >> 16) & 0x0000ffff); } if ((xsum != 0x00000000) && (xsum != 0x0000ffff)) { printf(" UDP wrong checksum %08lx %08x\n", @@ -1804,7 +1878,8 @@ NetEthHdrSize(void) if (myvlanid == (ushort)-1) myvlanid = VLAN_NONE;
- return ((myvlanid & VLAN_IDMASK) == VLAN_NONE) ? ETHER_HDR_SIZE : VLAN_ETHER_HDR_SIZE; + return ((myvlanid & VLAN_IDMASK) == VLAN_NONE) ? ETHER_HDR_SIZE : + VLAN_ETHER_HDR_SIZE; }
int @@ -1849,7 +1924,8 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) * Construct an IP and UDP header. * (need to set no fragment bit - XXX) */ - ip->ip_hl_v = 0x45; /* IP_HDR_SIZE / 4 (not including UDP) */ + /* IP_HDR_SIZE / 4 (not including UDP) */ + ip->ip_hl_v = 0x45; ip->ip_tos = 0; ip->ip_len = htons(IP_HDR_SIZE + len); ip->ip_id = htons(NetIPID++); @@ -1857,8 +1933,10 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_ttl = 255; ip->ip_p = 17; /* UDP */ ip->ip_sum = 0; - NetCopyIP((void*)&ip->ip_src, &NetOurIP); /* already in network byte order */ - NetCopyIP((void*)&ip->ip_dst, &dest); /* - "" - */ + /* already in network byte order */ + NetCopyIP((void*)&ip->ip_src, &NetOurIP); + /* - "" - */ + NetCopyIP((void*)&ip->ip_dst, &dest); ip->udp_src = htons(sport); ip->udp_dst = htons(dport); ip->udp_len = htons(8 + len); @@ -1879,7 +1957,9 @@ void copy_filename (char *dst, const char *src, int size) *dst = '\0'; }
-#if defined(CONFIG_CMD_NFS) || defined(CONFIG_CMD_SNTP) || defined(CONFIG_CMD_DNS) +#if defined(CONFIG_CMD_NFS) || \ + defined(CONFIG_CMD_SNTP) || \ + defined(CONFIG_CMD_DNS) /* * make port a little random (1024-17407) * This keeps the math somewhat trivial to compute, and seems to work with
please do not split string literals -mike
Hi Mike,
What do you suggest as an alternative? Leave the line more than 80 characters long?
I think the best thing would be to split the NetReceive() function that contains that line, which is currently ~400 lines long. This would reduce the amount of tabs in front of the deeply nested lines (such as this).
So I would agree to leave the line as is, waiting for NetReceive() to be split in a future cleanup work.
Luca
if there is no alternative, then yes -mike
This removes the following checkpatch errors: - ERROR: do not initialise globals to 0 or NULL - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: that open brace { should be on the previous line
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 42 ++++++++++++++++++++---------------------- 1 files changed, 20 insertions(+), 22 deletions(-)
diff --git a/net/net.c b/net/net.c index 90312eb..e89e118 100644 --- a/net/net.c +++ b/net/net.c @@ -117,23 +117,23 @@ DECLARE_GLOBAL_DATA_PTR; /** BOOTP EXTENTIONS **/
/* Our subnet mask (0=unknown) */ -IPaddr_t NetOurSubnetMask=0; +IPaddr_t NetOurSubnetMask; /* Our gateways IP address */ -IPaddr_t NetOurGatewayIP=0; +IPaddr_t NetOurGatewayIP; /* Our DNS IP address */ -IPaddr_t NetOurDNSIP=0; +IPaddr_t NetOurDNSIP; #if defined(CONFIG_BOOTP_DNS2) /* Our 2nd DNS IP address */ -IPaddr_t NetOurDNS2IP=0; +IPaddr_t NetOurDNS2IP; #endif /* Our NIS domain */ -char NetOurNISDomain[32]={0,}; +char NetOurNISDomain[32] = {0,}; /* Our hostname */ -char NetOurHostName[32]={0,}; +char NetOurHostName[32] = {0,}; /* Our bootpath */ -char NetOurRootPath[64]={0,}; +char NetOurRootPath[64] = {0,}; /* Our bootfile size in blocks */ -ushort NetBootFileSize=0; +ushort NetBootFileSize;
#ifdef CONFIG_MCAST_TFTP /* Multicast TFTP */ IPaddr_t Mcast_addr; @@ -146,8 +146,7 @@ ulong NetBootFileXferSize; /* Our ethernet address */ uchar NetOurEther[6]; /* Boot server enet address */ -uchar NetServerEther[6] = - { 0, 0, 0, 0, 0, 0 }; +uchar NetServerEther[6]; /* Our IP addr (0 = unknown) */ IPaddr_t NetOurIP; /* Server IP addr (0 = unknown) */ @@ -159,27 +158,26 @@ int NetRxPacketLen; /* IP packet ID */ unsigned NetIPID; /* Ethernet bcast address */ -uchar NetBcastAddr[6] = - { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; -uchar NetEtherNullAddr[6] = - { 0, 0, 0, 0, 0, 0 }; +uchar NetBcastAddr[6] = { + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; +uchar NetEtherNullAddr[6]; #ifdef CONFIG_API void (*push_packet)(volatile void *, int len) = 0; #endif #if defined(CONFIG_CMD_CDP) /* Ethernet bcast address */ -uchar NetCDPAddr[6] = - { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; +uchar NetCDPAddr[6] = { + 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; #endif /* Network loop state */ int NetState; #ifdef CONFIG_NET_MULTI /* Tried all network devices */ -int NetRestartWrap = 0; +int NetRestartWrap; /* Network loop restarted */ -static int NetRestarted = 0; +static int NetRestarted; /* At least one device configured */ -static int NetDevExists = 0; +static int NetDevExists; #endif
/* XXX in both little & big endian machines 0xFFFF == ntohs(-1) */ @@ -206,7 +204,7 @@ static void CDPStart(void); /* NTP server IP address */ IPaddr_t NetNtpServerIP; /* offset time from UTC */ -int NetTimeOffset=0; +int NetTimeOffset; #endif
#ifdef CONFIG_NETCONSOLE @@ -228,7 +226,7 @@ static ulong timeStart; /* Current timeout value */ static ulong timeDelta; /* THE transmit packet */ -volatile uchar *NetTxPacket = 0; +volatile uchar *NetTxPacket;
@@ -319,7 +317,7 @@ void ArpTimeoutCheck(void) static void NetInitLoop(proto_t protocol) { - static int env_changed_id = 0; + static int env_changed_id; bd_t *bd = gd->bd; int env_id = get_env_id ();
On Wed, May 4, 2011 at 08:40, Luca Ceresoli wrote:
- ERROR: that open brace { should be on the previous line ... -uchar NetCDPAddr[6] =
your fix here is worse than the original. just leave them be. -mike
Damn, you're right!
I think a one-line solution would be even better (and much simpler):
uchar NetCDPAddr[6] = {0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc};
BTW, this is the original checkpatch message: ERROR: that open brace { should be on the previous line #172: FILE: net.c:172: +uchar NetCDPAddr[6] = + { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc };
So either we choose the one-line solution above, or we have the first checkpatch message that should be disabled in the U-Boot version, when it will exist.
Your opinion?
Luca
- 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc };
Damn, you're right!
i agree
sometimes it does warn when people do things wrongly, but this is once again why i advocate people reviewing the output and not acting like a robot.
i cant check checkpatch atm to see how it reacts, but these are acceptable in my mind: uchar foo[] = { 0, 1, 2, 3, }; uchar foo[] = { 0, 1, 2, 3, }; uchar foo[] = { 0, 1, 2, 3, };
the form you used though is certainly wrong (even if checkpatch didnt say so): uchar foo[] = { 0, 1, 2, 3, }; -mike
This removes the following checkpatch issues: - ERROR: space prohibited after that open parenthesis '(' - ERROR: space prohibited before that close parenthesis ')' - ERROR: space prohibited after that open square bracket '[' - ERROR: space prohibited after that '&' (ctx:WxW) - ERROR: spaces required around that '=' (ctx:VxW) - ERROR: space required before the open parenthesis '(' - ERROR: space required after that ',' (ctx:VxV) - ERROR: need consistent spacing around '+' (ctx:WxV) - WARNING: unnecessary whitespace before a quoted newline - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '('
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 192 ++++++++++++++++++++++++++++++------------------------------ 1 files changed, 96 insertions(+), 96 deletions(-)
diff --git a/net/net.c b/net/net.c index e89e118..630aeee 100644 --- a/net/net.c +++ b/net/net.c @@ -228,7 +228,7 @@ static ulong timeDelta; /* THE transmit packet */ volatile uchar *NetTxPacket;
-static int net_check_prereq (proto_t protocol); +static int net_check_prereq(proto_t protocol);
@@ -245,7 +245,7 @@ uchar NetArpWaitPacketBuf[PKTSIZE_ALIGN + PKTALIGN]; ulong NetArpWaitTimerStart; int NetArpWaitTry;
-void ArpRequest (void) +void ArpRequest(void) { int i; volatile uchar *pkt; @@ -255,20 +255,20 @@ void ArpRequest (void)
pkt = NetTxPacket;
- pkt += NetSetEther (pkt, NetBcastAddr, PROT_ARP); + pkt += NetSetEther(pkt, NetBcastAddr, PROT_ARP);
arp = (ARP_t *) pkt;
- arp->ar_hrd = htons (ARP_ETHER); - arp->ar_pro = htons (PROT_IP); + arp->ar_hrd = htons(ARP_ETHER); + arp->ar_pro = htons(PROT_IP); arp->ar_hln = 6; arp->ar_pln = 4; - arp->ar_op = htons (ARPOP_REQUEST); + arp->ar_op = htons(ARPOP_REQUEST);
/* source ET addr */ - memcpy (&arp->ar_data[0], NetOurEther, 6); + memcpy(&arp->ar_data[0], NetOurEther, 6); /* source IP addr */ - NetWriteIP ((uchar *) & arp->ar_data[6], NetOurIP); + NetWriteIP((uchar *) &arp->ar_data[6], NetOurIP); for (i = 10; i < 16; ++i) { /* dest ET addr = 0 */ arp->ar_data[i] = 0; @@ -277,7 +277,7 @@ void ArpRequest (void) if ((NetArpWaitPacketIP & NetOurSubnetMask) != (NetOurIP & NetOurSubnetMask)) { if (NetOurGatewayIP == 0) { - puts ("## Warning: gatewayip needed but not set\n"); + puts("## Warning: gatewayip needed but not set\n"); NetArpWaitReplyIP = NetArpWaitPacketIP; } else { NetArpWaitReplyIP = NetOurGatewayIP; @@ -286,8 +286,8 @@ void ArpRequest (void) NetArpWaitReplyIP = NetArpWaitPacketIP; }
- NetWriteIP ((uchar *) & arp->ar_data[16], NetArpWaitReplyIP); - (void) eth_send (NetTxPacket, (pkt - NetTxPacket) + ARP_HDR_SIZE); + NetWriteIP((uchar *) &arp->ar_data[16], NetArpWaitReplyIP); + (void) eth_send(NetTxPacket, (pkt - NetTxPacket) + ARP_HDR_SIZE); }
void ArpTimeoutCheck(void) @@ -304,7 +304,7 @@ void ArpTimeoutCheck(void) NetArpWaitTry++;
if (NetArpWaitTry >= ARP_TIMEOUT_COUNT) { - puts ("\nARP Retry count exceeded; starting again\n"); + puts("\nARP Retry count exceeded; starting again\n"); NetArpWaitTry = 0; NetStartAgain(); } else { @@ -319,14 +319,14 @@ NetInitLoop(proto_t protocol) { static int env_changed_id; bd_t *bd = gd->bd; - int env_id = get_env_id (); + int env_id = get_env_id();
/* update only when the environment has changed */ if (env_changed_id != env_id) { NetCopyIP(&NetOurIP, &bd->bi_ip_addr); - NetOurGatewayIP = getenv_IPaddr ("gatewayip"); - NetOurSubnetMask= getenv_IPaddr ("netmask"); - NetServerIP = getenv_IPaddr ("serverip"); + NetOurGatewayIP = getenv_IPaddr("gatewayip"); + NetOurSubnetMask = getenv_IPaddr("netmask"); + NetServerIP = getenv_IPaddr("serverip"); NetOurNativeVLAN = getenv_VLAN("nvlan"); NetOurVLAN = getenv_VLAN("vlan"); #if defined(CONFIG_CMD_DNS) @@ -391,7 +391,7 @@ NetLoop(proto_t protocol)
restart: #ifdef CONFIG_NET_MULTI - memcpy (NetOurEther, eth_get_dev()->enetaddr, 6); + memcpy(NetOurEther, eth_get_dev()->enetaddr, 6); #else eth_getenv_enetaddr("ethaddr", NetOurEther); #endif @@ -405,7 +405,7 @@ restart: */ NetInitLoop(protocol);
- switch (net_check_prereq (protocol)) { + switch (net_check_prereq(protocol)) { case 1: /* network not configured */ eth_halt(); @@ -438,14 +438,14 @@ restart: case BOOTP: BootpTry = 0; NetOurIP = 0; - BootpRequest (); + BootpRequest(); break;
#if defined(CONFIG_CMD_RARP) case RARP: RarpTry = 0; NetOurIP = 0; - RarpRequest (); + RarpRequest(); break; #endif #if defined(CONFIG_CMD_PING) @@ -493,10 +493,10 @@ restart: /* * Echo the inverted link state to the fault LED. */ - if(miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { - status_led_set (STATUS_LED_RED, STATUS_LED_OFF); + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { + status_led_set(STATUS_LED_RED, STATUS_LED_OFF); } else { - status_led_set (STATUS_LED_RED, STATUS_LED_ON); + status_led_set(STATUS_LED_RED, STATUS_LED_ON); } #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ @@ -524,7 +524,7 @@ restart: */ if (ctrlc()) { eth_halt(); - puts ("\nAbort\n"); + puts("\nAbort\n"); return (-1); }
@@ -538,19 +538,19 @@ restart: thand_f *x;
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -# if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ - defined(CONFIG_STATUS_LED) && \ - defined(STATUS_LED_RED) +#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ + defined(CONFIG_STATUS_LED) && \ + defined(STATUS_LED_RED) /* * Echo the inverted link state to the fault LED. */ - if(miiphy_link(eth_get_dev()->name, + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { - status_led_set (STATUS_LED_RED, STATUS_LED_OFF); + status_led_set(STATUS_LED_RED, STATUS_LED_OFF); } else { - status_led_set (STATUS_LED_RED, STATUS_LED_ON); + status_led_set(STATUS_LED_RED, STATUS_LED_ON); } -# endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ +#endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ x = timeHandler; timeHandler = (thand_f *)0; @@ -601,7 +601,7 @@ startAgainHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) /* Totally ignore the packet */ }
-void NetStartAgain (void) +void NetStartAgain(void) { char *nretry; int retry_forever = 0; @@ -629,19 +629,19 @@ void NetStartAgain (void) NetTryCount++;
#ifndef CONFIG_NET_MULTI - NetSetTimeout (10000UL, startAgainTimeout); - NetSetHandler (startAgainHandler); + NetSetTimeout(10000UL, startAgainTimeout); + NetSetHandler(startAgainHandler); #else /* !CONFIG_NET_MULTI*/ - eth_halt (); + eth_halt(); #if !defined(CONFIG_NET_DO_NOT_TRY_ANOTHER) - eth_try_another (!NetRestarted); + eth_try_another(!NetRestarted); #endif - eth_init (gd->bd); + eth_init(gd->bd); if (NetRestartWrap) { NetRestartWrap = 0; if (NetDevExists) { - NetSetTimeout (10000UL, startAgainTimeout); - NetSetHandler (startAgainHandler); + NetSetTimeout(10000UL, startAgainTimeout); + NetSetHandler(startAgainHandler); } else { NetState = NETLOOP_FAIL; } @@ -707,9 +707,9 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) NetArpWaitPacketMAC = ether;
pkt = NetArpWaitTxPacket; - pkt += NetSetEther (pkt, NetArpWaitPacketMAC, PROT_IP); + pkt += NetSetEther(pkt, NetArpWaitPacketMAC, PROT_IP);
- NetSetIP (pkt, dest, dport, sport, len); + NetSetIP(pkt, dest, dport, sport, len); memcpy(pkt + IP_HDR_SIZE, (uchar *)NetTxPacket + (pkt - (uchar *)NetArpWaitTxPacket) + IP_HDR_SIZE, len);
@@ -727,8 +727,8 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) debug("sending UDP to %08lx/%pM\n", dest, ether);
pkt = (uchar *)NetTxPacket; - pkt += NetSetEther (pkt, ether, PROT_IP); - NetSetIP (pkt, dest, dport, sport, len); + pkt += NetSetEther(pkt, ether, PROT_IP); + NetSetIP(pkt, dest, dport, sport, len); (void) eth_send(NetTxPacket, (pkt - NetTxPacket) + IP_HDR_SIZE + len);
return 0; /* transmitted */ @@ -796,14 +796,14 @@ int PingSend(void) }
static void -PingTimeout (void) +PingTimeout(void) { eth_halt(); NetState = NETLOOP_FAIL; /* we did not get the reply */ }
static void -PingHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) +PingHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) { IPaddr_t tmp; volatile IP_t *ip = (volatile IP_t *)pkt; @@ -818,10 +818,10 @@ PingHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) static void PingStart(void) { #if defined(CONFIG_NET_MULTI) - printf ("Using %s device\n", eth_get_name()); + printf("Using %s device\n", eth_get_name()); #endif /* CONFIG_NET_MULTI */ - NetSetTimeout (10000UL, PingTimeout); - NetSetHandler (PingHandler); + NetSetTimeout(10000UL, PingTimeout); + NetSetHandler(PingHandler);
PingSend(); } @@ -919,8 +919,8 @@ int CDPSendTrigger(void) Ethernet_t *et; int len; ushort chksum; -#if defined(CONFIG_CDP_DEVICE_ID) || defined(CONFIG_CDP_PORT_ID) || \ - defined(CONFIG_CDP_VERSION) || defined(CONFIG_CDP_PLATFORM) +#if defined(CONFIG_CDP_DEVICE_ID) || defined(CONFIG_CDP_PORT_ID) || \ + defined(CONFIG_CDP_VERSION) || defined(CONFIG_CDP_PLATFORM) char buf[32]; #endif
@@ -1028,12 +1028,12 @@ int CDPSendTrigger(void) }
static void -CDPTimeout (void) +CDPTimeout(void) { CDPSeq++;
if (CDPSeq < 3) { - NetSetTimeout (CDP_TIMEOUT, CDPTimeout); + NetSetTimeout(CDP_TIMEOUT, CDPTimeout); CDPSendTrigger(); return; } @@ -1046,7 +1046,7 @@ CDPTimeout (void) }
static void -CDPDummyHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) +CDPDummyHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) { /* nothing */ } @@ -1171,7 +1171,7 @@ CDPHandler(const uchar * pkt, unsigned len) static void CDPStart(void) { #if defined(CONFIG_NET_MULTI) - printf ("Using %s device\n", eth_get_name()); + printf("Using %s device\n", eth_get_name()); #endif CDPSeq = 0; CDPOK = 0; @@ -1179,8 +1179,8 @@ static void CDPStart(void) CDPNativeVLAN = htons(-1); CDPApplianceVLAN = htons(-1);
- NetSetTimeout (CDP_TIMEOUT, CDPTimeout); - NetSetHandler (CDPDummyHandler); + NetSetTimeout(CDP_TIMEOUT, CDPTimeout); + NetSetHandler(CDPDummyHandler);
CDPSendTrigger(); } @@ -1284,7 +1284,7 @@ static IP_t *__NetDefragment(IP_t *ip, int *lenp) * (thus being a superset of a previously-received fragment). */
- if ( (h >= thisfrag) && (h->last_byte <= start + len) ) { + if ((h >= thisfrag) && (h->last_byte <= start + len)) { /* complete overlap with hole: remove hole */ if (!h->prev_hole && !h->next_hole) { /* last remaining hole */ @@ -1507,10 +1507,10 @@ NetReceive(volatile uchar * inpkt, int len) pkt = (uchar *)et; pkt += NetSetEther(pkt, et->et_src, PROT_ARP); arp->ar_op = htons(ARPOP_REPLY); - memcpy (&arp->ar_data[10], &arp->ar_data[0], 6); + memcpy(&arp->ar_data[10], &arp->ar_data[0], 6); NetCopyIP(&arp->ar_data[16], &arp->ar_data[6]); - memcpy (&arp->ar_data[ 0], NetOurEther, 6); - NetCopyIP(&arp->ar_data[ 6], &NetOurIP); + memcpy(&arp->ar_data[0], NetOurEther, 6); + NetCopyIP(&arp->ar_data[6], &NetOurIP); (void) eth_send((uchar *)et, (pkt - (uchar *)et) + ARP_HDR_SIZE); return; @@ -1541,7 +1541,7 @@ NetReceive(volatile uchar * inpkt, int len) &arp->ar_data[0], 6);
#ifdef CONFIG_NETCONSOLE - (*packetHandler)(0,0,0,0); + (*packetHandler)(0, 0, 0, 0); #endif /* modify header, and transmit it */ memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, NetArpWaitPacketMAC, 6); @@ -1576,14 +1576,14 @@ NetReceive(volatile uchar * inpkt, int len) (ntohs(arp->ar_pro) != PROT_IP) || (arp->ar_hln != 6) || (arp->ar_pln != 4)) {
- puts ("invalid RARP header\n"); + puts("invalid RARP header\n"); } else { NetCopyIP(&NetOurIP, &arp->ar_data[16]); if (NetServerIP == 0) - NetCopyIP(&NetServerIP, &arp->ar_data[ 6]); - memcpy (NetServerEther, &arp->ar_data[ 0], 6); + NetCopyIP(&NetServerIP, &arp->ar_data[6]); + memcpy(NetServerEther, &arp->ar_data[0], 6);
- (*packetHandler)(0,0,0,0); + (*packetHandler)(0, 0, 0, 0); } break; #endif @@ -1612,7 +1612,7 @@ NetReceive(volatile uchar * inpkt, int len) } /* Check the Checksum of the header */ if (!NetCksumOk((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2)) { - puts ("checksum bad\n"); + puts("checksum bad\n"); return; } /* If it is not for us, ignore it */ @@ -1654,7 +1654,7 @@ NetReceive(volatile uchar * inpkt, int len) case ICMP_REDIRECT: if (icmph->code != ICMP_REDIR_HOST) return; - printf (" ICMP Host Redirect to %pI4 ", + printf(" ICMP Host Redirect to %pI4 ", &icmph->un.gateway); return; #if defined(CONFIG_CMD_PING) @@ -1668,11 +1668,11 @@ NetReceive(volatile uchar * inpkt, int len) return; case ICMP_ECHO_REQUEST: debug("Got ICMP ECHO REQUEST, " - "return %d bytes \n", + "return %d bytes\n", ETHER_HDR_SIZE + len);
- memcpy (&et->et_dest[0], &et->et_src[0], 6); - memcpy (&et->et_src[ 0], NetOurEther, 6); + memcpy(&et->et_dest[0], &et->et_src[0], 6); + memcpy(&et->et_src[0], NetOurEther, 6);
ip->ip_sum = 0; ip->ip_off = 0; @@ -1740,7 +1740,7 @@ NetReceive(volatile uchar * inpkt, int len)
#ifdef CONFIG_NETCONSOLE - nc_input_packet((uchar *)ip +IP_HDR_SIZE, + nc_input_packet((uchar *)ip + IP_HDR_SIZE, ntohs(ip->udp_dst), ntohs(ip->udp_src), ntohs(ip->udp_len) - 8); @@ -1748,7 +1748,7 @@ NetReceive(volatile uchar * inpkt, int len) /* * IP header OK. Pass the packet to the current handler. */ - (*packetHandler)((uchar *)ip +IP_HDR_SIZE, + (*packetHandler)((uchar *)ip + IP_HDR_SIZE, ntohs(ip->udp_dst), ntohs(ip->udp_src), ntohs(ip->udp_len) - 8); @@ -1759,14 +1759,14 @@ NetReceive(volatile uchar * inpkt, int len)
-static int net_check_prereq (proto_t protocol) +static int net_check_prereq(proto_t protocol) { switch (protocol) { /* Fall through */ #if defined(CONFIG_CMD_PING) case PING: if (NetPingIP == 0) { - puts ("*** ERROR: ping address not given\n"); + puts("*** ERROR: ping address not given\n"); return (1); } goto common; @@ -1774,7 +1774,7 @@ static int net_check_prereq (proto_t protocol) #if defined(CONFIG_CMD_SNTP) case SNTP: if (NetNtpServerIP == 0) { - puts ("*** ERROR: NTP server address not given\n"); + puts("*** ERROR: NTP server address not given\n"); return (1); } goto common; @@ -1793,16 +1793,16 @@ static int net_check_prereq (proto_t protocol) case NETCONS: case TFTP: if (NetServerIP == 0) { - puts ("*** ERROR: `serverip' not set\n"); + puts("*** ERROR: `serverip' not set\n"); return (1); } -#if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ - defined(CONFIG_CMD_DNS) +#if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ + defined(CONFIG_CMD_DNS) common: #endif
if (NetOurIP == 0) { - puts ("*** ERROR: `ipaddr' not set\n"); + puts("*** ERROR: `ipaddr' not set\n"); return (1); } /* Fall through */ @@ -1813,28 +1813,28 @@ static int net_check_prereq (proto_t protocol) case BOOTP: case CDP: case DHCP: - if (memcmp (NetOurEther, "\0\0\0\0\0\0", 6) == 0) { + if (memcmp(NetOurEther, "\0\0\0\0\0\0", 6) == 0) { #ifdef CONFIG_NET_MULTI - extern int eth_get_dev_index (void); - int num = eth_get_dev_index (); + extern int eth_get_dev_index(void); + int num = eth_get_dev_index();
switch (num) { case -1: - puts ("*** ERROR: No ethernet found.\n"); + puts("*** ERROR: No ethernet found.\n"); return (1); case 0: - puts ("*** ERROR: `ethaddr' not set\n"); + puts("*** ERROR: `ethaddr' not set\n"); break; default: - printf ("*** ERROR: `eth%daddr' not set\n", + printf("*** ERROR: `eth%daddr' not set\n", num); break; }
- NetStartAgain (); + NetStartAgain(); return (2); #else - puts ("*** ERROR: `ethaddr' not set\n"); + puts("*** ERROR: `ethaddr' not set\n"); return (1); #endif } @@ -1890,8 +1890,8 @@ NetSetEther(volatile uchar * xet, uchar * addr, uint prot) if (myvlanid == (ushort)-1) myvlanid = VLAN_NONE;
- memcpy (et->et_dest, addr, 6); - memcpy (et->et_src, NetOurEther, 6); + memcpy(et->et_dest, addr, 6); + memcpy(et->et_src, NetOurEther, 6); if ((myvlanid & VLAN_IDMASK) == VLAN_NONE) { et->et_protlen = htons(prot); return ETHER_HDR_SIZE; @@ -1942,7 +1942,7 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2); }
-void copy_filename (char *dst, const char *src, int size) +void copy_filename(char *dst, const char *src, int size) { if (*src && (*src == '"')) { ++src; @@ -1969,13 +1969,13 @@ unsigned int random_port(void) } #endif
-void ip_to_string (IPaddr_t x, char *s) +void ip_to_string(IPaddr_t x, char *s) { - x = ntohl (x); - sprintf (s, "%d.%d.%d.%d", - (int) ((x >> 24) & 0xff), - (int) ((x >> 16) & 0xff), - (int) ((x >> 8) & 0xff), (int) ((x >> 0) & 0xff) + x = ntohl(x); + sprintf(s, "%d.%d.%d.%d", + (int) ((x >> 24) & 0xff), + (int) ((x >> 16) & 0xff), + (int) ((x >> 8) & 0xff), (int) ((x >> 0) & 0xff) ); }
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 38 +++++++++++++------------------------- 1 files changed, 13 insertions(+), 25 deletions(-)
diff --git a/net/net.c b/net/net.c index 630aeee..14dc65a 100644 --- a/net/net.c +++ b/net/net.c @@ -369,9 +369,8 @@ NetLoop(proto_t protocol) */ NetTxPacket = &PktBuf[0] + (PKTALIGN - 1); NetTxPacket -= (ulong)NetTxPacket % PKTALIGN; - for (i = 0; i < PKTBUFSRX; i++) { + for (i = 0; i < PKTBUFSRX; i++) NetRxPackets[i] = NetTxPacket + (i+1)*PKTSIZE_ALIGN; - } }
if (!NetArpWaitTxPacket) { @@ -493,11 +492,10 @@ restart: /* * Echo the inverted link state to the fault LED. */ - if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) status_led_set(STATUS_LED_RED, STATUS_LED_OFF); - } else { + else status_led_set(STATUS_LED_RED, STATUS_LED_ON); - } #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */
@@ -1098,9 +1096,8 @@ CDPHandler(const uchar * pkt, unsigned len) ss = (const ushort *)pkt; type = ntohs(ss[0]); tlen = ntohs(ss[1]); - if (tlen > len) { + if (tlen > len) goto pkt_short; - }
pkt += tlen; len -= tlen; @@ -1479,26 +1476,20 @@ NetReceive(volatile uchar * inpkt, int len) printf("bad length %d < %d\n", len, ARP_HDR_SIZE); return; } - if (ntohs(arp->ar_hrd) != ARP_ETHER) { + if (ntohs(arp->ar_hrd) != ARP_ETHER) return; - } - if (ntohs(arp->ar_pro) != PROT_IP) { + if (ntohs(arp->ar_pro) != PROT_IP) return; - } - if (arp->ar_hln != 6) { + if (arp->ar_hln != 6) return; - } - if (arp->ar_pln != 4) { + if (arp->ar_pln != 4) return; - }
- if (NetOurIP == 0) { + if (NetOurIP == 0) return; - }
- if (NetReadIP(&arp->ar_data[16]) != NetOurIP) { + if (NetReadIP(&arp->ar_data[16]) != NetOurIP) return; - }
switch (ntohs(arp->ar_op)) { case ARPOP_REQUEST: @@ -1603,13 +1594,11 @@ NetReceive(volatile uchar * inpkt, int len) debug("len=%d, v=%02x\n", len, ip->ip_hl_v & 0xff);
/* Can't deal with anything except IPv4 */ - if ((ip->ip_hl_v & 0xf0) != 0x40) { + if ((ip->ip_hl_v & 0xf0) != 0x40) return; - } /* Can't deal with IP options (headers != 20 bytes) */ - if ((ip->ip_hl_v & 0x0f) > 0x05) { + if ((ip->ip_hl_v & 0x0f) > 0x05) return; - } /* Check the Checksum of the header */ if (!NetCksumOk((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2)) { puts("checksum bad\n"); @@ -1949,9 +1938,8 @@ void copy_filename(char *dst, const char *src, int size) --size; }
- while ((--size > 0) && *src && (*src != '"')) { + while ((--size > 0) && *src && (*src != '"')) *dst++ = *src++; - } *dst = '\0'; }
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)"
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 36 ++++++++++++++++++------------------ 1 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/net/net.c b/net/net.c index 14dc65a..0e13fb2 100644 --- a/net/net.c +++ b/net/net.c @@ -594,7 +594,7 @@ startAgainTimeout(void) }
static void -startAgainHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) +startAgainHandler(uchar *pkt, unsigned dest, unsigned src, unsigned len) { /* Totally ignore the packet */ } @@ -655,14 +655,14 @@ void NetStartAgain(void) */
void -NetSetHandler(rxhand_f * f) +NetSetHandler(rxhand_f *f) { packetHandler = f; }
void -NetSetTimeout(ulong iv, thand_f * f) +NetSetTimeout(ulong iv, thand_f *f) { if (iv == 0) { timeHandler = (thand_f *)0; @@ -675,7 +675,7 @@ NetSetTimeout(ulong iv, thand_f * f)
void -NetSendPacket(volatile uchar * pkt, int len) +NetSendPacket(volatile uchar *pkt, int len) { (void) eth_send(pkt, len); } @@ -770,9 +770,9 @@ int PingSend(void) ip->ip_p = 0x01; /* ICMP */ ip->ip_sum = 0; /* already in network byte order */ - NetCopyIP((void*)&ip->ip_src, &NetOurIP); + NetCopyIP((void *)&ip->ip_src, &NetOurIP); /* - "" - */ - NetCopyIP((void*)&ip->ip_dst, &NetPingIP); + NetCopyIP((void *)&ip->ip_dst, &NetPingIP); ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2);
s = &ip->udp_src; /* XXX ICMP starts here */ @@ -801,7 +801,7 @@ PingTimeout(void) }
static void -PingHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) +PingHandler(uchar *pkt, unsigned dest, unsigned src, unsigned len) { IPaddr_t tmp; volatile IP_t *ip = (volatile IP_t *)pkt; @@ -1044,13 +1044,13 @@ CDPTimeout(void) }
static void -CDPDummyHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) +CDPDummyHandler(uchar *pkt, unsigned dest, unsigned src, unsigned len) { /* nothing */ }
static void -CDPHandler(const uchar * pkt, unsigned len) +CDPHandler(const uchar *pkt, unsigned len) { const uchar *t; const ushort *ss; @@ -1356,7 +1356,7 @@ static inline IP_t *NetDefragment(IP_t *ip, int *lenp) #endif
void -NetReceive(volatile uchar * inpkt, int len) +NetReceive(volatile uchar *inpkt, int len) { Ethernet_t *et; IP_t *ip; @@ -1665,8 +1665,8 @@ NetReceive(volatile uchar * inpkt, int len)
ip->ip_sum = 0; ip->ip_off = 0; - NetCopyIP((void*)&ip->ip_dst, &ip->ip_src); - NetCopyIP((void*)&ip->ip_src, &NetOurIP); + NetCopyIP((void *)&ip->ip_dst, &ip->ip_src); + NetCopyIP((void *)&ip->ip_src, &NetOurIP); ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP >> 1);
@@ -1836,14 +1836,14 @@ static int net_check_prereq(proto_t protocol) /**********************************************************************/
int -NetCksumOk(uchar * ptr, int len) +NetCksumOk(uchar *ptr, int len) { return !((NetCksum(ptr, len) + 1) & 0xfffe); }
unsigned -NetCksum(uchar * ptr, int len) +NetCksum(uchar *ptr, int len) { ulong xsum; ushort *p = (ushort *)ptr; @@ -1870,7 +1870,7 @@ NetEthHdrSize(void) }
int -NetSetEther(volatile uchar * xet, uchar * addr, uint prot) +NetSetEther(volatile uchar *xet, uchar * addr, uint prot) { Ethernet_t *et = (Ethernet_t *)xet; ushort myvlanid; @@ -1895,7 +1895,7 @@ NetSetEther(volatile uchar * xet, uchar * addr, uint prot) }
void -NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) +NetSetIP(volatile uchar *xip, IPaddr_t dest, int dport, int sport, int len) { IP_t *ip = (IP_t *)xip;
@@ -1921,9 +1921,9 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_p = 17; /* UDP */ ip->ip_sum = 0; /* already in network byte order */ - NetCopyIP((void*)&ip->ip_src, &NetOurIP); + NetCopyIP((void *)&ip->ip_src, &NetOurIP); /* - "" - */ - NetCopyIP((void*)&ip->ip_dst, &dest); + NetCopyIP((void *)&ip->ip_dst, &dest); ip->udp_src = htons(sport); ip->udp_dst = htons(dport); ip->udp_len = htons(8 + len);
This removes the following checkpatch issue: - ERROR: return is not a function, parentheses are not required
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 30 +++++++++++++++--------------- 1 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/net/net.c b/net/net.c index 0e13fb2..2bffc5b 100644 --- a/net/net.c +++ b/net/net.c @@ -385,7 +385,7 @@ NetLoop(proto_t protocol) #endif if (eth_init(bd) < 0) { eth_halt(); - return(-1); + return -1; }
restart: @@ -408,7 +408,7 @@ restart: case 1: /* network not configured */ eth_halt(); - return (-1); + return -1;
#ifdef CONFIG_NET_MULTI case 2: @@ -523,7 +523,7 @@ restart: if (ctrlc()) { eth_halt(); puts("\nAbort\n"); - return (-1); + return -1; }
ArpTimeoutCheck(); @@ -580,7 +580,7 @@ restart: return NetBootFileXferSize;
case NETLOOP_FAIL: - return (-1); + return -1; } } } @@ -1756,7 +1756,7 @@ static int net_check_prereq(proto_t protocol) case PING: if (NetPingIP == 0) { puts("*** ERROR: ping address not given\n"); - return (1); + return 1; } goto common; #endif @@ -1764,7 +1764,7 @@ static int net_check_prereq(proto_t protocol) case SNTP: if (NetNtpServerIP == 0) { puts("*** ERROR: NTP server address not given\n"); - return (1); + return 1; } goto common; #endif @@ -1783,7 +1783,7 @@ static int net_check_prereq(proto_t protocol) case TFTP: if (NetServerIP == 0) { puts("*** ERROR: `serverip' not set\n"); - return (1); + return 1; } #if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ defined(CONFIG_CMD_DNS) @@ -1792,7 +1792,7 @@ static int net_check_prereq(proto_t protocol)
if (NetOurIP == 0) { puts("*** ERROR: `ipaddr' not set\n"); - return (1); + return 1; } /* Fall through */
@@ -1810,7 +1810,7 @@ static int net_check_prereq(proto_t protocol) switch (num) { case -1: puts("*** ERROR: No ethernet found.\n"); - return (1); + return 1; case 0: puts("*** ERROR: `ethaddr' not set\n"); break; @@ -1821,17 +1821,17 @@ static int net_check_prereq(proto_t protocol) }
NetStartAgain(); - return (2); + return 2; #else puts("*** ERROR: `ethaddr' not set\n"); - return (1); + return 1; #endif } /* Fall through */ default: - return (0); + return 0; } - return (0); /* OK */ + return 0; /* OK */ } /**********************************************************************/
@@ -1853,7 +1853,7 @@ NetCksum(uchar *ptr, int len) xsum += *p++; xsum = (xsum & 0xffff) + (xsum >> 16); xsum = (xsum & 0xffff) + (xsum >> 16); - return (xsum & 0xffff); + return xsum & 0xffff; }
int @@ -1997,5 +1997,5 @@ ushort string_to_VLAN(const char *s)
ushort getenv_VLAN(char *var) { - return (string_to_VLAN(getenv(var))); + return string_to_VLAN(getenv(var)); }
This removes the following checkpatch issues: - ERROR: switch and case should be at the same indent - WARNING: suspect code indent for conditional statements - WARNING: labels should not be indented
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 85 ++++++++++++++++++++++++++++++------------------------------- 1 files changed, 42 insertions(+), 43 deletions(-)
diff --git a/net/net.c b/net/net.c index 2bffc5b..13efa67 100644 --- a/net/net.c +++ b/net/net.c @@ -1106,51 +1106,50 @@ CDPHandler(const uchar *pkt, unsigned len) tlen -= 4;
switch (type) { - case CDP_DEVICE_ID_TLV: - break; - case CDP_ADDRESS_TLV: - break; - case CDP_PORT_ID_TLV: - break; - case CDP_CAPABILITIES_TLV: - break; - case CDP_VERSION_TLV: - break; - case CDP_PLATFORM_TLV: - break; - case CDP_NATIVE_VLAN_TLV: - nvlan = *ss; - break; - case CDP_APPLIANCE_VLAN_TLV: - t = (const uchar *)ss; - while (tlen > 0) { - if (tlen < 3) - goto pkt_short; + case CDP_DEVICE_ID_TLV: + break; + case CDP_ADDRESS_TLV: + break; + case CDP_PORT_ID_TLV: + break; + case CDP_CAPABILITIES_TLV: + break; + case CDP_VERSION_TLV: + break; + case CDP_PLATFORM_TLV: + break; + case CDP_NATIVE_VLAN_TLV: + nvlan = *ss; + break; + case CDP_APPLIANCE_VLAN_TLV: + t = (const uchar *)ss; + while (tlen > 0) { + if (tlen < 3) + goto pkt_short;
- applid = t[0]; - ss = (const ushort *)(t + 1); + applid = t[0]; + ss = (const ushort *)(t + 1);
#ifdef CONFIG_CDP_APPLIANCE_VLAN_TYPE - if (applid == - CONFIG_CDP_APPLIANCE_VLAN_TYPE) - vlan = *ss; + if (applid == CONFIG_CDP_APPLIANCE_VLAN_TYPE) + vlan = *ss; #else - /* XXX will this work; dunno */ - vlan = ntohs(*ss); + /* XXX will this work; dunno */ + vlan = ntohs(*ss); #endif - t += 3; tlen -= 3; - } - break; - case CDP_TRIGGER_TLV: - break; - case CDP_POWER_CONSUMPTION_TLV: - break; - case CDP_SYSNAME_TLV: - break; - case CDP_SYSOBJECT_TLV: - break; - case CDP_MANAGEMENT_ADDRESS_TLV: - break; + t += 3; tlen -= 3; + } + break; + case CDP_TRIGGER_TLV: + break; + case CDP_POWER_CONSUMPTION_TLV: + break; + case CDP_SYSNAME_TLV: + break; + case CDP_SYSOBJECT_TLV: + break; + case CDP_MANAGEMENT_ADDRESS_TLV: + break; } }
@@ -1610,7 +1609,7 @@ NetReceive(volatile uchar *inpkt, int len) #ifdef CONFIG_MCAST_TFTP if (Mcast_addr != tmp) #endif - return; + return; } /* * The function returns the unchanged packet if it's not @@ -1787,7 +1786,7 @@ static int net_check_prereq(proto_t protocol) } #if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ defined(CONFIG_CMD_DNS) - common: +common: #endif
if (NetOurIP == 0) { @@ -1882,7 +1881,7 @@ NetSetEther(volatile uchar *xet, uchar * addr, uint prot) memcpy(et->et_dest, addr, 6); memcpy(et->et_src, NetOurEther, 6); if ((myvlanid & VLAN_IDMASK) == VLAN_NONE) { - et->et_protlen = htons(prot); + et->et_protlen = htons(prot); return ETHER_HDR_SIZE; } else { VLAN_Ethernet_t *vet = (VLAN_Ethernet_t *)xet;
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com --- net/net.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/net/net.c b/net/net.c index 13efa67..c17d071 100644 --- a/net/net.c +++ b/net/net.c @@ -1616,7 +1616,8 @@ NetReceive(volatile uchar *inpkt, int len) * a fragment, and either the complete packet or NULL if * it is a fragment (if !CONFIG_IP_DEFRAG, it returns NULL) */ - if (!(ip = NetDefragment(ip, &len))) + ip = NetDefragment(ip, &len); + if (!ip) return; /* * watch for ICMP host redirects
this is an update to the net/net.c cleanup, incorporating Mike's suggestions to patches 1 and 2. Thanks Mike.
net/net.c currently raises a lot of checkpatch issues: 76 errors, 197 warnings. This patchset fixes most of them, leaving 0 errors and 27 warnings.
The warnings that are still present are of the following types: - WARNING: consider using kstrto* in preference to simple_strtoul which is Linux-specific; - WARNING: externs should be avoided in .c files these are due to loop-dependencies between net/net.c and other files; - WARNING: line over 80 characters described in the commit message for patch 1; - WARNING: Use of volatile is usually wrong [...] I've had a quick look at these, but I don't know in detail how the networking code and Ethernet drivers (and maybe DMA?) interact, so I cannot remove them being sure that things will continue working.
Luca
net/net.c | 593 ++++++++++++++++++++++++++++++++++--------------------------- 1 files changed, 328 insertions(+), 265 deletions(-)
There are three such warnings left.
The first is hard to fix with cosmetic-only changes without compromising code readability, so I'm leaving it as it is for now: WARNING: line over 80 characters #1537: FILE: net.c:1537: + [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ...
The other two cannot be fixed without splitting string literals, so it is preferred to keep them longer than 80 characters.
Signed-off-by: Luca Ceresoli luca.ceresoli@comelit.it Cc: Wolfgang Denk wd@denx.de Cc: Ben Warren biggerbadderben@gmail.com Cc: Mike Frysinger vapier@gentoo.org
--- Changes since v1: - do not split string literals (even though this means leaving the line longer than 80 characters).
net/net.c | 231 +++++++++++++++++++++++++++++++++++++++++-------------------- 1 files changed, 155 insertions(+), 76 deletions(-)
diff --git a/net/net.c b/net/net.c index e50bdf1..6e3af5b 100644 --- a/net/net.c +++ b/net/net.c @@ -101,7 +101,8 @@ DECLARE_GLOBAL_DATA_PTR;
len = ETHER_HDR_SIZE + sizeof(CDP_SNAP_hdr); - chksum = CDP_compute_csum((uchar *)NetTxPacket + len, (uchar *)s - (NetTxPacket + len)); + chksum = CDP_compute_csum((uchar *)NetTxPacket + len, + (uchar *)s - (NetTxPacket + len)); if (chksum == 0) chksum = 0xFFFF; *cp = htons(chksum); @@ -1019,7 +1077,10 @@ CDPHandler(const uchar * pkt, unsigned len) if (pkt[0] < 0x02 || pkt[1] == 0) return;
- /* if version is greater than 0x02 maybe we'll have a problem; output a warning */ + /* + * if version is greater than 0x02 maybe we'll have a problem; + * output a warning + */ if (pkt[0] != 0x02) printf("** WARNING: CDP packet received with a protocol version %d > 2\n", pkt[0] & 0xff); @@ -1075,10 +1136,12 @@ CDPHandler(const uchar * pkt, unsigned len) ss = (const ushort *)(t + 1);
/* no arp request pending now */ NetArpWaitPacketIP = 0; @@ -1491,7 +1558,8 @@ NetReceive(volatile uchar * inpkt, int len) } return; default: - debug("Unexpected ARP opcode 0x%x\n", ntohs(arp->ar_op)); + debug("Unexpected ARP opcode 0x%x\n", + ntohs(arp->ar_op)); return; } break; @@ -1588,19 +1656,21 @@ NetReceive(volatile uchar * inpkt, int len) case ICMP_REDIRECT: if (icmph->code != ICMP_REDIR_HOST) return; - printf (" ICMP Host Redirect to %pI4 ", &icmph->un.gateway); + printf (" ICMP Host Redirect to %pI4 ", + &icmph->un.gateway); return; #if defined(CONFIG_CMD_PING) case ICMP_ECHO_REPLY: /* - * IP header OK. Pass the packet to the current handler. + * IP header OK. Pass the packet to the + * current handler. */ /* XXX point to ip packet */ (*packetHandler)((uchar *)ip, 0, 0, 0); return; case ICMP_ECHO_REQUEST: debug("Got ICMP ECHO REQUEST, return %d bytes \n", - ETHER_HDR_SIZE + len); + ETHER_HDR_SIZE + len);
memcpy (&et->et_dest[0], &et->et_src[0], 6); memcpy (&et->et_src[ 0], NetOurEther, 6); @@ -1609,13 +1679,15 @@ NetReceive(volatile uchar * inpkt, int len) ip->ip_off = 0; NetCopyIP((void*)&ip->ip_dst, &ip->ip_src); NetCopyIP((void*)&ip->ip_src, &NetOurIP); - ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP >> 1); + ip->ip_sum = ~NetCksum((uchar *)ip, + IP_HDR_SIZE_NO_UDP >> 1);
icmph->type = ICMP_ECHO_REPLY; icmph->checksum = 0; icmph->checksum = ~NetCksum((uchar *)icmph, - (len - IP_HDR_SIZE_NO_UDP) >> 1); - (void) eth_send((uchar *)et, ETHER_HDR_SIZE + len); + (len - IP_HDR_SIZE_NO_UDP) >> 1); + (void) eth_send((uchar *)et, + ETHER_HDR_SIZE + len); return; #endif default: @@ -1656,7 +1728,8 @@ NetReceive(volatile uchar * inpkt, int len) xsum += sumdata; } while ((xsum >> 16) != 0) { - xsum = (xsum & 0x0000ffff) + ((xsum >> 16) & 0x0000ffff); + xsum = (xsum & 0x0000ffff) + + ((xsum >> 16) & 0x0000ffff); } if ((xsum != 0x00000000) && (xsum != 0x0000ffff)) { printf(" UDP wrong checksum %08lx %08x\n", @@ -1804,7 +1877,8 @@ NetEthHdrSize(void) if (myvlanid == (ushort)-1) myvlanid = VLAN_NONE;
int @@ -1849,7 +1923,8 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) * Construct an IP and UDP header. * (need to set no fragment bit - XXX) */ - ip->ip_hl_v = 0x45; /* IP_HDR_SIZE / 4 (not including UDP) */ + /* IP_HDR_SIZE / 4 (not including UDP) */ + ip->ip_hl_v = 0x45; ip->ip_tos = 0; ip->ip_len = htons(IP_HDR_SIZE + len); ip->ip_id = htons(NetIPID++); @@ -1857,8 +1932,10 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_ttl = 255; ip->ip_p = 17; /* UDP */ ip->ip_sum = 0; - NetCopyIP((void*)&ip->ip_src, &NetOurIP); /* already in network byte order */ - NetCopyIP((void*)&ip->ip_dst, &dest); /* - "" - */ + /* already in network byte order */ + NetCopyIP((void*)&ip->ip_src, &NetOurIP); + /* - "" - */ + NetCopyIP((void*)&ip->ip_dst, &dest); ip->udp_src = htons(sport); ip->udp_dst = htons(dport); ip->udp_len = htons(8 + len); @@ -1879,7 +1956,9 @@ void copy_filename (char *dst, const char *src, int size) *dst = '\0'; }
Dear Luca Ceresoli,
In message 1305122401-14967-2-git-send-email-luca.ceresoli@comelit.it you wrote:
- [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ...
Applied, thanks.
--- Changes since v1: - re-fix array initializations (the fix in v1 was worse than the original).
net/net.c | 40 ++++++++++++++++++---------------------- 1 files changed, 18 insertions(+), 22 deletions(-)
diff --git a/net/net.c b/net/net.c index 6e3af5b..4715699 100644 --- a/net/net.c +++ b/net/net.c @@ -117,23 +117,23 @@ DECLARE_GLOBAL_DATA_PTR; /** BOOTP EXTENTIONS **/
#ifdef CONFIG_MCAST_TFTP /* Multicast TFTP */ IPaddr_t Mcast_addr; @@ -146,8 +146,7 @@ ulong NetBootFileXferSize; /* Our ethernet address */ uchar NetOurEther[6]; /* Boot server enet address */ -uchar NetServerEther[6] = - { 0, 0, 0, 0, 0, 0 }; +uchar NetServerEther[6]; /* Our IP addr (0 = unknown) */ IPaddr_t NetOurIP; /* Server IP addr (0 = unknown) */ @@ -159,27 +158,24 @@ int NetRxPacketLen; /* IP packet ID */ unsigned NetIPID; /* Ethernet bcast address */ -uchar NetBcastAddr[6] = - { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; -uchar NetEtherNullAddr[6] = - { 0, 0, 0, 0, 0, 0 }; +uchar NetBcastAddr[6] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; +uchar NetEtherNullAddr[6]; #ifdef CONFIG_API void (*push_packet)(volatile void *, int len) = 0; #endif #if defined(CONFIG_CMD_CDP) /* Ethernet bcast address */ -uchar NetCDPAddr[6] = - { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; +uchar NetCDPAddr[6] = { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; #endif /* Network loop state */ int NetState; #ifdef CONFIG_NET_MULTI /* Tried all network devices */ -int NetRestartWrap = 0; +int NetRestartWrap; /* Network loop restarted */ -static int NetRestarted = 0; +static int NetRestarted; /* At least one device configured */ -static int NetDevExists = 0; +static int NetDevExists; #endif
/* XXX in both little & big endian machines 0xFFFF == ntohs(-1) */ @@ -206,7 +202,7 @@ static void CDPStart(void); /* NTP server IP address */ IPaddr_t NetNtpServerIP; /* offset time from UTC */ -int NetTimeOffset=0; +int NetTimeOffset; #endif
#ifdef CONFIG_NETCONSOLE @@ -228,7 +224,7 @@ static ulong timeStart; /* Current timeout value */ static ulong timeDelta; /* THE transmit packet */ -volatile uchar *NetTxPacket = 0; +volatile uchar *NetTxPacket;
@@ -319,7 +315,7 @@ void ArpTimeoutCheck(void) static void NetInitLoop(proto_t protocol) { - static int env_changed_id = 0; + static int env_changed_id; bd_t *bd = gd->bd; int env_id = get_env_id ();
Dear Luca Ceresoli,
In message 1305122401-14967-3-git-send-email-luca.ceresoli@comelit.it you wrote:
Changes since v1:
Applied, thanks.
--- Changes since v1: none.
diff --git a/net/net.c b/net/net.c index 4715699..172f4d5 100644 --- a/net/net.c +++ b/net/net.c @@ -226,7 +226,7 @@ static ulong timeDelta; /* THE transmit packet */ volatile uchar *NetTxPacket;
@@ -243,7 +243,7 @@ uchar NetArpWaitPacketBuf[PKTSIZE_ALIGN + PKTALIGN]; ulong NetArpWaitTimerStart; int NetArpWaitTry;
-void ArpRequest (void) +void ArpRequest(void) { int i; volatile uchar *pkt; @@ -253,20 +253,20 @@ void ArpRequest (void)
pkt = NetTxPacket;
/* source ET addr */ - memcpy (&arp->ar_data[0], NetOurEther, 6); + memcpy(&arp->ar_data[0], NetOurEther, 6); /* source IP addr */ - NetWriteIP ((uchar *) & arp->ar_data[6], NetOurIP); + NetWriteIP((uchar *) &arp->ar_data[6], NetOurIP); for (i = 10; i < 16; ++i) { /* dest ET addr = 0 */ arp->ar_data[i] = 0; @@ -275,7 +275,7 @@ void ArpRequest (void) if ((NetArpWaitPacketIP & NetOurSubnetMask) != (NetOurIP & NetOurSubnetMask)) { if (NetOurGatewayIP == 0) { - puts ("## Warning: gatewayip needed but not set\n"); + puts("## Warning: gatewayip needed but not set\n"); NetArpWaitReplyIP = NetArpWaitPacketIP; } else { NetArpWaitReplyIP = NetOurGatewayIP; @@ -284,8 +284,8 @@ void ArpRequest (void) NetArpWaitReplyIP = NetArpWaitPacketIP; }
void ArpTimeoutCheck(void) @@ -302,7 +302,7 @@ void ArpTimeoutCheck(void) NetArpWaitTry++;
if (NetArpWaitTry >= ARP_TIMEOUT_COUNT) { - puts ("\nARP Retry count exceeded; starting again\n"); + puts("\nARP Retry count exceeded; starting again\n"); NetArpWaitTry = 0; NetStartAgain(); } else { @@ -317,14 +317,14 @@ NetInitLoop(proto_t protocol) { static int env_changed_id; bd_t *bd = gd->bd; - int env_id = get_env_id (); + int env_id = get_env_id();
/* update only when the environment has changed */ if (env_changed_id != env_id) { NetCopyIP(&NetOurIP, &bd->bi_ip_addr); - NetOurGatewayIP = getenv_IPaddr ("gatewayip"); - NetOurSubnetMask= getenv_IPaddr ("netmask"); - NetServerIP = getenv_IPaddr ("serverip"); + NetOurGatewayIP = getenv_IPaddr("gatewayip"); + NetOurSubnetMask = getenv_IPaddr("netmask"); + NetServerIP = getenv_IPaddr("serverip"); NetOurNativeVLAN = getenv_VLAN("nvlan"); NetOurVLAN = getenv_VLAN("vlan"); #if defined(CONFIG_CMD_DNS) @@ -389,7 +389,7 @@ NetLoop(proto_t protocol)
restart: #ifdef CONFIG_NET_MULTI - memcpy (NetOurEther, eth_get_dev()->enetaddr, 6); + memcpy(NetOurEther, eth_get_dev()->enetaddr, 6); #else eth_getenv_enetaddr("ethaddr", NetOurEther); #endif @@ -403,7 +403,7 @@ restart: */ NetInitLoop(protocol);
- switch (net_check_prereq (protocol)) { + switch (net_check_prereq(protocol)) { case 1: /* network not configured */ eth_halt(); @@ -436,14 +436,14 @@ restart: case BOOTP: BootpTry = 0; NetOurIP = 0; - BootpRequest (); + BootpRequest(); break;
#if defined(CONFIG_CMD_RARP) case RARP: RarpTry = 0; NetOurIP = 0; - RarpRequest (); + RarpRequest(); break; #endif #if defined(CONFIG_CMD_PING) @@ -491,10 +491,10 @@ restart: /* * Echo the inverted link state to the fault LED. */ - if(miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { - status_led_set (STATUS_LED_RED, STATUS_LED_OFF); + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { + status_led_set(STATUS_LED_RED, STATUS_LED_OFF); } else { - status_led_set (STATUS_LED_RED, STATUS_LED_ON); + status_led_set(STATUS_LED_RED, STATUS_LED_ON); } #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ @@ -522,7 +522,7 @@ restart: */ if (ctrlc()) { eth_halt(); - puts ("\nAbort\n"); + puts("\nAbort\n"); return (-1); }
@@ -536,19 +536,19 @@ restart: thand_f *x;
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -# if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ - defined(CONFIG_STATUS_LED) && \ - defined(STATUS_LED_RED) +#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ + defined(CONFIG_STATUS_LED) && \ + defined(STATUS_LED_RED) /* * Echo the inverted link state to the fault LED. */ - if(miiphy_link(eth_get_dev()->name, + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { - status_led_set (STATUS_LED_RED, STATUS_LED_OFF); + status_led_set(STATUS_LED_RED, STATUS_LED_OFF); } else { - status_led_set (STATUS_LED_RED, STATUS_LED_ON); + status_led_set(STATUS_LED_RED, STATUS_LED_ON); } -# endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ +#endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ x = timeHandler; timeHandler = (thand_f *)0; @@ -599,7 +599,7 @@ startAgainHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) /* Totally ignore the packet */ }
-void NetStartAgain (void) +void NetStartAgain(void) { char *nretry; int retry_forever = 0; @@ -627,19 +627,19 @@ void NetStartAgain (void) NetTryCount++;
#ifndef CONFIG_NET_MULTI - NetSetTimeout (10000UL, startAgainTimeout); - NetSetHandler (startAgainHandler); + NetSetTimeout(10000UL, startAgainTimeout); + NetSetHandler(startAgainHandler); #else /* !CONFIG_NET_MULTI*/ - eth_halt (); + eth_halt(); #if !defined(CONFIG_NET_DO_NOT_TRY_ANOTHER) - eth_try_another (!NetRestarted); + eth_try_another(!NetRestarted); #endif - eth_init (gd->bd); + eth_init(gd->bd); if (NetRestartWrap) { NetRestartWrap = 0; if (NetDevExists) { - NetSetTimeout (10000UL, startAgainTimeout); - NetSetHandler (startAgainHandler); + NetSetTimeout(10000UL, startAgainTimeout); + NetSetHandler(startAgainHandler); } else { NetState = NETLOOP_FAIL; } @@ -705,9 +705,9 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) NetArpWaitPacketMAC = ether;
@@ -725,8 +725,8 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) debug("sending UDP to %08lx/%pM\n", dest, ether);
return 0; /* transmitted */ @@ -794,14 +794,14 @@ int PingSend(void) }
static void -PingHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) +PingHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) { IPaddr_t tmp; volatile IP_t *ip = (volatile IP_t *)pkt; @@ -816,10 +816,10 @@ PingHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) static void PingStart(void) { #if defined(CONFIG_NET_MULTI) - printf ("Using %s device\n", eth_get_name()); + printf("Using %s device\n", eth_get_name()); #endif /* CONFIG_NET_MULTI */ - NetSetTimeout (10000UL, PingTimeout); - NetSetHandler (PingHandler); + NetSetTimeout(10000UL, PingTimeout); + NetSetHandler(PingHandler);
PingSend(); } @@ -917,8 +917,8 @@ int CDPSendTrigger(void) Ethernet_t *et; int len; ushort chksum; -#if defined(CONFIG_CDP_DEVICE_ID) || defined(CONFIG_CDP_PORT_ID) || \ - defined(CONFIG_CDP_VERSION) || defined(CONFIG_CDP_PLATFORM) +#if defined(CONFIG_CDP_DEVICE_ID) || defined(CONFIG_CDP_PORT_ID) || \ + defined(CONFIG_CDP_VERSION) || defined(CONFIG_CDP_PLATFORM) char buf[32]; #endif
@@ -1026,12 +1026,12 @@ int CDPSendTrigger(void) }
if (CDPSeq < 3) { - NetSetTimeout (CDP_TIMEOUT, CDPTimeout); + NetSetTimeout(CDP_TIMEOUT, CDPTimeout); CDPSendTrigger(); return; } @@ -1044,7 +1044,7 @@ CDPTimeout (void) }
static void -CDPDummyHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) +CDPDummyHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) { /* nothing */ } @@ -1169,7 +1169,7 @@ CDPHandler(const uchar * pkt, unsigned len) static void CDPStart(void) { #if defined(CONFIG_NET_MULTI) - printf ("Using %s device\n", eth_get_name()); + printf("Using %s device\n", eth_get_name()); #endif CDPSeq = 0; CDPOK = 0; @@ -1177,8 +1177,8 @@ static void CDPStart(void) CDPNativeVLAN = htons(-1); CDPApplianceVLAN = htons(-1);
CDPSendTrigger(); } @@ -1282,7 +1282,7 @@ static IP_t *__NetDefragment(IP_t *ip, int *lenp) * (thus being a superset of a previously-received fragment). */
- if ( (h >= thisfrag) && (h->last_byte <= start + len) ) { + if ((h >= thisfrag) && (h->last_byte <= start + len)) { /* complete overlap with hole: remove hole */ if (!h->prev_hole && !h->next_hole) { /* last remaining hole */ @@ -1505,10 +1505,10 @@ NetReceive(volatile uchar * inpkt, int len) pkt = (uchar *)et; pkt += NetSetEther(pkt, et->et_src, PROT_ARP); arp->ar_op = htons(ARPOP_REPLY); - memcpy (&arp->ar_data[10], &arp->ar_data[0], 6); + memcpy(&arp->ar_data[10], &arp->ar_data[0], 6); NetCopyIP(&arp->ar_data[16], &arp->ar_data[6]); - memcpy (&arp->ar_data[ 0], NetOurEther, 6); - NetCopyIP(&arp->ar_data[ 6], &NetOurIP); + memcpy(&arp->ar_data[0], NetOurEther, 6); + NetCopyIP(&arp->ar_data[6], &NetOurIP); (void) eth_send((uchar *)et, (pkt - (uchar *)et) + ARP_HDR_SIZE); return; @@ -1539,7 +1539,7 @@ NetReceive(volatile uchar * inpkt, int len) &arp->ar_data[0], 6);
#ifdef CONFIG_NETCONSOLE - (*packetHandler)(0,0,0,0); + (*packetHandler)(0, 0, 0, 0); #endif /* modify header, and transmit it */ memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, NetArpWaitPacketMAC, 6); @@ -1574,14 +1574,14 @@ NetReceive(volatile uchar * inpkt, int len) (ntohs(arp->ar_pro) != PROT_IP) || (arp->ar_hln != 6) || (arp->ar_pln != 4)) {
- (*packetHandler)(0,0,0,0); + (*packetHandler)(0, 0, 0, 0); } break; #endif @@ -1610,7 +1610,7 @@ NetReceive(volatile uchar * inpkt, int len) } /* Check the Checksum of the header */ if (!NetCksumOk((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2)) { - puts ("checksum bad\n"); + puts("checksum bad\n"); return; } /* If it is not for us, ignore it */ @@ -1652,7 +1652,7 @@ NetReceive(volatile uchar * inpkt, int len) case ICMP_REDIRECT: if (icmph->code != ICMP_REDIR_HOST) return; - printf (" ICMP Host Redirect to %pI4 ", + printf(" ICMP Host Redirect to %pI4 ", &icmph->un.gateway); return; #if defined(CONFIG_CMD_PING) @@ -1665,11 +1665,11 @@ NetReceive(volatile uchar * inpkt, int len) (*packetHandler)((uchar *)ip, 0, 0, 0); return; case ICMP_ECHO_REQUEST: - debug("Got ICMP ECHO REQUEST, return %d bytes \n", + debug("Got ICMP ECHO REQUEST, return %d bytes\n", ETHER_HDR_SIZE + len);
ip->ip_sum = 0; ip->ip_off = 0; @@ -1737,7 +1737,7 @@ NetReceive(volatile uchar * inpkt, int len)
#ifdef CONFIG_NETCONSOLE - nc_input_packet((uchar *)ip +IP_HDR_SIZE, + nc_input_packet((uchar *)ip + IP_HDR_SIZE, ntohs(ip->udp_dst), ntohs(ip->udp_src), ntohs(ip->udp_len) - 8); @@ -1745,7 +1745,7 @@ NetReceive(volatile uchar * inpkt, int len) /* * IP header OK. Pass the packet to the current handler. */ - (*packetHandler)((uchar *)ip +IP_HDR_SIZE, + (*packetHandler)((uchar *)ip + IP_HDR_SIZE, ntohs(ip->udp_dst), ntohs(ip->udp_src), ntohs(ip->udp_len) - 8); @@ -1756,14 +1756,14 @@ NetReceive(volatile uchar * inpkt, int len)
-static int net_check_prereq (proto_t protocol) +static int net_check_prereq(proto_t protocol) { switch (protocol) { /* Fall through */ #if defined(CONFIG_CMD_PING) case PING: if (NetPingIP == 0) { - puts ("*** ERROR: ping address not given\n"); + puts("*** ERROR: ping address not given\n"); return (1); } goto common; @@ -1771,7 +1771,7 @@ static int net_check_prereq (proto_t protocol) #if defined(CONFIG_CMD_SNTP) case SNTP: if (NetNtpServerIP == 0) { - puts ("*** ERROR: NTP server address not given\n"); + puts("*** ERROR: NTP server address not given\n"); return (1); } goto common; @@ -1790,16 +1790,16 @@ static int net_check_prereq (proto_t protocol) case NETCONS: case TFTP: if (NetServerIP == 0) { - puts ("*** ERROR: `serverip' not set\n"); + puts("*** ERROR: `serverip' not set\n"); return (1); } -#if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ - defined(CONFIG_CMD_DNS) +#if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ + defined(CONFIG_CMD_DNS) common: #endif
if (NetOurIP == 0) { - puts ("*** ERROR: `ipaddr' not set\n"); + puts("*** ERROR: `ipaddr' not set\n"); return (1); } /* Fall through */ @@ -1810,28 +1810,28 @@ static int net_check_prereq (proto_t protocol) case BOOTP: case CDP: case DHCP: - if (memcmp (NetOurEther, "\0\0\0\0\0\0", 6) == 0) { + if (memcmp(NetOurEther, "\0\0\0\0\0\0", 6) == 0) { #ifdef CONFIG_NET_MULTI - extern int eth_get_dev_index (void); - int num = eth_get_dev_index (); + extern int eth_get_dev_index(void); + int num = eth_get_dev_index();
- NetStartAgain (); + NetStartAgain(); return (2); #else - puts ("*** ERROR: `ethaddr' not set\n"); + puts("*** ERROR: `ethaddr' not set\n"); return (1); #endif } @@ -1887,8 +1887,8 @@ NetSetEther(volatile uchar * xet, uchar * addr, uint prot) if (myvlanid == (ushort)-1) myvlanid = VLAN_NONE;
- memcpy (et->et_dest, addr, 6); - memcpy (et->et_src, NetOurEther, 6); + memcpy(et->et_dest, addr, 6); + memcpy(et->et_src, NetOurEther, 6); if ((myvlanid & VLAN_IDMASK) == VLAN_NONE) { et->et_protlen = htons(prot); return ETHER_HDR_SIZE; @@ -1939,7 +1939,7 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2); }
-void copy_filename (char *dst, const char *src, int size) +void copy_filename(char *dst, const char *src, int size) { if (*src && (*src == '"')) { ++src; @@ -1966,13 +1966,13 @@ unsigned int random_port(void) } #endif
Dear Luca Ceresoli,
In message 1305122401-14967-4-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
diff --git a/net/net.c b/net/net.c index 172f4d5..c22da5f 100644 --- a/net/net.c +++ b/net/net.c @@ -367,9 +367,8 @@ NetLoop(proto_t protocol) */ NetTxPacket = &PktBuf[0] + (PKTALIGN - 1); NetTxPacket -= (ulong)NetTxPacket % PKTALIGN; - for (i = 0; i < PKTBUFSRX; i++) { + for (i = 0; i < PKTBUFSRX; i++) NetRxPackets[i] = NetTxPacket + (i+1)*PKTSIZE_ALIGN; - } }
if (!NetArpWaitTxPacket) { @@ -491,11 +490,10 @@ restart: /* * Echo the inverted link state to the fault LED. */ - if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) { + if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) status_led_set(STATUS_LED_RED, STATUS_LED_OFF); - } else { + else status_led_set(STATUS_LED_RED, STATUS_LED_ON); - } #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */
@@ -1096,9 +1094,8 @@ CDPHandler(const uchar * pkt, unsigned len) ss = (const ushort *)pkt; type = ntohs(ss[0]); tlen = ntohs(ss[1]); - if (tlen > len) { + if (tlen > len) goto pkt_short; - }
pkt += tlen; len -= tlen; @@ -1477,26 +1474,20 @@ NetReceive(volatile uchar * inpkt, int len) printf("bad length %d < %d\n", len, ARP_HDR_SIZE); return; } - if (ntohs(arp->ar_hrd) != ARP_ETHER) { + if (ntohs(arp->ar_hrd) != ARP_ETHER) return; - } - if (ntohs(arp->ar_pro) != PROT_IP) { + if (ntohs(arp->ar_pro) != PROT_IP) return; - } - if (arp->ar_hln != 6) { + if (arp->ar_hln != 6) return; - } - if (arp->ar_pln != 4) { + if (arp->ar_pln != 4) return; - }
switch (ntohs(arp->ar_op)) { case ARPOP_REQUEST: @@ -1601,13 +1592,11 @@ NetReceive(volatile uchar * inpkt, int len) debug("len=%d, v=%02x\n", len, ip->ip_hl_v & 0xff);
/* Can't deal with anything except IPv4 */ - if ((ip->ip_hl_v & 0xf0) != 0x40) { + if ((ip->ip_hl_v & 0xf0) != 0x40) return; - } /* Can't deal with IP options (headers != 20 bytes) */ - if ((ip->ip_hl_v & 0x0f) > 0x05) { + if ((ip->ip_hl_v & 0x0f) > 0x05) return; - } /* Check the Checksum of the header */ if (!NetCksumOk((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2)) { puts("checksum bad\n"); @@ -1946,9 +1935,8 @@ void copy_filename(char *dst, const char *src, int size) --size; }
Dear Luca Ceresoli,
In message 1305122401-14967-5-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
diff --git a/net/net.c b/net/net.c index c22da5f..f8c852d 100644 --- a/net/net.c +++ b/net/net.c @@ -592,7 +592,7 @@ startAgainTimeout(void) }
static void -startAgainHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) +startAgainHandler(uchar *pkt, unsigned dest, unsigned src, unsigned len) { /* Totally ignore the packet */ } @@ -653,14 +653,14 @@ void NetStartAgain(void) */
void -NetSetTimeout(ulong iv, thand_f * f) +NetSetTimeout(ulong iv, thand_f *f) { if (iv == 0) { timeHandler = (thand_f *)0; @@ -673,7 +673,7 @@ NetSetTimeout(ulong iv, thand_f * f)
void -NetSendPacket(volatile uchar * pkt, int len) +NetSendPacket(volatile uchar *pkt, int len) { (void) eth_send(pkt, len); } @@ -768,9 +768,9 @@ int PingSend(void) ip->ip_p = 0x01; /* ICMP */ ip->ip_sum = 0; /* already in network byte order */ - NetCopyIP((void*)&ip->ip_src, &NetOurIP); + NetCopyIP((void *)&ip->ip_src, &NetOurIP); /* - "" - */ - NetCopyIP((void*)&ip->ip_dst, &NetPingIP); + NetCopyIP((void *)&ip->ip_dst, &NetPingIP); ip->ip_sum = ~NetCksum((uchar *)ip, IP_HDR_SIZE_NO_UDP / 2);
s = &ip->udp_src; /* XXX ICMP starts here */ @@ -799,7 +799,7 @@ PingTimeout(void) }
static void -PingHandler(uchar * pkt, unsigned dest, unsigned src, unsigned len) +PingHandler(uchar *pkt, unsigned dest, unsigned src, unsigned len) { IPaddr_t tmp; volatile IP_t *ip = (volatile IP_t *)pkt; @@ -1042,13 +1042,13 @@ CDPTimeout(void) }
static void -CDPHandler(const uchar * pkt, unsigned len) +CDPHandler(const uchar *pkt, unsigned len) { const uchar *t; const ushort *ss; @@ -1354,7 +1354,7 @@ static inline IP_t *NetDefragment(IP_t *ip, int *lenp) #endif
void -NetReceive(volatile uchar * inpkt, int len) +NetReceive(volatile uchar *inpkt, int len) { Ethernet_t *et; IP_t *ip; @@ -1662,8 +1662,8 @@ NetReceive(volatile uchar * inpkt, int len)
@@ -1833,14 +1833,14 @@ static int net_check_prereq(proto_t protocol) /**********************************************************************/
unsigned -NetCksum(uchar * ptr, int len) +NetCksum(uchar *ptr, int len) { ulong xsum; ushort *p = (ushort *)ptr; @@ -1867,7 +1867,7 @@ NetEthHdrSize(void) }
int -NetSetEther(volatile uchar * xet, uchar * addr, uint prot) +NetSetEther(volatile uchar *xet, uchar * addr, uint prot) { Ethernet_t *et = (Ethernet_t *)xet; ushort myvlanid; @@ -1892,7 +1892,7 @@ NetSetEther(volatile uchar * xet, uchar * addr, uint prot) }
@@ -1918,9 +1918,9 @@ NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) ip->ip_p = 17; /* UDP */ ip->ip_sum = 0; /* already in network byte order */ - NetCopyIP((void*)&ip->ip_src, &NetOurIP); + NetCopyIP((void *)&ip->ip_src, &NetOurIP); /* - "" - */ - NetCopyIP((void*)&ip->ip_dst, &dest); + NetCopyIP((void *)&ip->ip_dst, &dest); ip->udp_src = htons(sport); ip->udp_dst = htons(dport); ip->udp_len = htons(8 + len);
Dear Luca Ceresoli,
In message 1305122401-14967-6-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
diff --git a/net/net.c b/net/net.c index f8c852d..63fc60a 100644 --- a/net/net.c +++ b/net/net.c @@ -383,7 +383,7 @@ NetLoop(proto_t protocol) #endif if (eth_init(bd) < 0) { eth_halt(); - return(-1); + return -1; }
restart: @@ -406,7 +406,7 @@ restart: case 1: /* network not configured */ eth_halt(); - return (-1); + return -1;
#ifdef CONFIG_NET_MULTI case 2: @@ -521,7 +521,7 @@ restart: if (ctrlc()) { eth_halt(); puts("\nAbort\n"); - return (-1); + return -1; }
ArpTimeoutCheck(); @@ -578,7 +578,7 @@ restart: return NetBootFileXferSize;
case NETLOOP_FAIL: - return (-1); + return -1; } } } @@ -1753,7 +1753,7 @@ static int net_check_prereq(proto_t protocol) case PING: if (NetPingIP == 0) { puts("*** ERROR: ping address not given\n"); - return (1); + return 1; } goto common; #endif @@ -1761,7 +1761,7 @@ static int net_check_prereq(proto_t protocol) case SNTP: if (NetNtpServerIP == 0) { puts("*** ERROR: NTP server address not given\n"); - return (1); + return 1; } goto common; #endif @@ -1780,7 +1780,7 @@ static int net_check_prereq(proto_t protocol) case TFTP: if (NetServerIP == 0) { puts("*** ERROR: `serverip' not set\n"); - return (1); + return 1; } #if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ defined(CONFIG_CMD_DNS) @@ -1789,7 +1789,7 @@ static int net_check_prereq(proto_t protocol)
@@ -1807,7 +1807,7 @@ static int net_check_prereq(proto_t protocol) switch (num) { case -1: puts("*** ERROR: No ethernet found.\n"); - return (1); + return 1; case 0: puts("*** ERROR: `ethaddr' not set\n"); break; @@ -1818,17 +1818,17 @@ static int net_check_prereq(proto_t protocol) }
@@ -1850,7 +1850,7 @@ NetCksum(uchar *ptr, int len) xsum += *p++; xsum = (xsum & 0xffff) + (xsum >> 16); xsum = (xsum & 0xffff) + (xsum >> 16); - return (xsum & 0xffff); + return xsum & 0xffff; }
int @@ -1994,5 +1994,5 @@ ushort string_to_VLAN(const char *s)
Dear Luca Ceresoli,
In message 1305122401-14967-7-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
diff --git a/net/net.c b/net/net.c index 63fc60a..8b4d28e 100644 --- a/net/net.c +++ b/net/net.c @@ -1104,51 +1104,50 @@ CDPHandler(const uchar *pkt, unsigned len) tlen -= 4;
@@ -1608,7 +1607,7 @@ NetReceive(volatile uchar *inpkt, int len) #ifdef CONFIG_MCAST_TFTP if (Mcast_addr != tmp) #endif - return; + return; } /* * The function returns the unchanged packet if it's not @@ -1784,7 +1783,7 @@ static int net_check_prereq(proto_t protocol) } #if defined(CONFIG_CMD_PING) || defined(CONFIG_CMD_SNTP) || \ defined(CONFIG_CMD_DNS) - common: +common: #endif
if (NetOurIP == 0) { @@ -1879,7 +1878,7 @@ NetSetEther(volatile uchar *xet, uchar * addr, uint prot) memcpy(et->et_dest, addr, 6); memcpy(et->et_src, NetOurEther, 6); if ((myvlanid & VLAN_IDMASK) == VLAN_NONE) { - et->et_protlen = htons(prot); + et->et_protlen = htons(prot); return ETHER_HDR_SIZE; } else { VLAN_Ethernet_t *vet = (VLAN_Ethernet_t *)xet;
Dear Luca Ceresoli,
In message 1305122401-14967-8-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
diff --git a/net/net.c b/net/net.c index 8b4d28e..1c4c982 100644 --- a/net/net.c +++ b/net/net.c @@ -1614,7 +1614,8 @@ NetReceive(volatile uchar *inpkt, int len) * a fragment, and either the complete packet or NULL if * it is a fragment (if !CONFIG_IP_DEFRAG, it returns NULL) */ - if (!(ip = NetDefragment(ip, &len))) + ip = NetDefragment(ip, &len); + if (!ip) return; /* * watch for ICMP host redirects
Dear Luca Ceresoli,
In message 1305122401-14967-9-git-send-email-luca.ceresoli@comelit.it you wrote:
Applied, thanks.
Luca Ceresoli
Mike Frysinger
