[U-Boot] [PATCH 1/3] block: pass block dev not num to read/write/erase()
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist.
Signed-off-by: Stephen Warren swarren@nvidia.com --- api/api_storage.c | 15 +-------------- board/freescale/common/sdhc_boot.c | 2 +- board/gdsys/p1022/controlcenterd-id.c | 6 +++--- board/gdsys/p1022/sdhc_boot.c | 2 +- common/cmd_disk.c | 6 +++--- common/cmd_ide.c | 26 +++++++++++++++++--------- common/cmd_mmc.c | 6 +++--- common/cmd_read.c | 2 +- common/cmd_sata.c | 16 ++++++++++++++-- common/cmd_scsi.c | 21 ++++++++++++--------- common/cmd_usb.c | 4 ++-- common/cmd_usb_mass_storage.c | 6 ++---- common/env_mmc.c | 10 +++------- common/fb_mmc.c | 7 +++---- common/spl/spl_mmc.c | 7 ++++--- common/usb_storage.c | 18 ++++++++++-------- disk/part_amiga.c | 10 ++++------ disk/part_dos.c | 8 +++++--- disk/part_efi.c | 34 ++++++++++++++++------------------ disk/part_iso.c | 10 +++++----- disk/part_mac.c | 9 +++++---- drivers/block/sandbox.c | 12 ++++++++---- drivers/block/systemace.c | 10 ++++++---- drivers/dfu/dfu_mmc.c | 4 ++-- drivers/mmc/fsl_esdhc_spl.c | 8 +++++--- drivers/mmc/mmc.c | 4 +++- drivers/mmc/mmc_private.h | 15 ++++++++------- drivers/mmc/mmc_write.c | 8 ++++++-- drivers/mmc/sunxi_mmc.c | 2 +- drivers/net/fm/fm.c | 3 ++- drivers/net/phy/cortina.c | 3 ++- fs/ext4/dev.c | 30 +++++++++++++++--------------- fs/ext4/ext4_common.c | 10 +++++----- fs/fat/fat.c | 4 ++-- fs/fat/fat_write.c | 3 +-- fs/reiserfs/dev.c | 24 +++++++++++++++--------- fs/zfs/dev.c | 28 +++++++++++++++------------- include/ide.h | 6 ++++-- include/part.h | 12 +++++++----- lib/gunzip.c | 3 +-- test/dm/usb.c | 2 +- 41 files changed, 224 insertions(+), 192 deletions(-)
diff --git a/api/api_storage.c b/api/api_storage.c index ec92ae48d1c2..bc2b4d6b8cc7 100644 --- a/api/api_storage.c +++ b/api/api_storage.c @@ -345,19 +345,6 @@ int dev_close_stor(void *cookie) }
-static int dev_stor_index(block_dev_desc_t *dd) -{ - int i, type; - - type = dev_stor_type(dd); - for (i = 0; i < specs[type].max_dev; i++) - if (dd == get_dev(specs[type].name, i)) - return i; - - return (specs[type].max_dev); -} - - lbasize_t dev_read_stor(void *cookie, void *buf, lbasize_t len, lbastart_t start) { int type; @@ -374,5 +361,5 @@ lbasize_t dev_read_stor(void *cookie, void *buf, lbasize_t len, lbastart_t start return 0; }
- return (dd->block_read(dev_stor_index(dd), start, len, buf)); + return dd->block_read(dd, start, len, buf); } diff --git a/board/freescale/common/sdhc_boot.c b/board/freescale/common/sdhc_boot.c index 022f38b117f2..e55a03090ab8 100644 --- a/board/freescale/common/sdhc_boot.c +++ b/board/freescale/common/sdhc_boot.c @@ -29,7 +29,7 @@ int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) return 1;
/* read out the first block, get the config data information */ - n = mmc->block_dev.block_read(mmc->block_dev.dev, 0, 1, tmp_buf); + n = mmc->block_dev.block_read(&mmc->block_dev, 0, 1, tmp_buf); if (!n) { free(tmp_buf); return 1; diff --git a/board/gdsys/p1022/controlcenterd-id.c b/board/gdsys/p1022/controlcenterd-id.c index 11d075c38593..46a46c0d8683 100644 --- a/board/gdsys/p1022/controlcenterd-id.c +++ b/board/gdsys/p1022/controlcenterd-id.c @@ -232,7 +232,7 @@ static int ccdm_mmc_read(struct mmc *mmc, u64 src, u8 *dst, int size) ofs = src % blk_len;
if (ofs) { - n = mmc->block_dev.block_read(mmc->block_dev.dev, block_no++, 1, + n = mmc->block_dev.block_read(&mmc->block_dev, block_no++, 1, tmp_buf); if (!n) goto failure; @@ -243,7 +243,7 @@ static int ccdm_mmc_read(struct mmc *mmc, u64 src, u8 *dst, int size) } cnt = size / blk_len; if (cnt) { - n = mmc->block_dev.block_read(mmc->block_dev.dev, block_no, cnt, + n = mmc->block_dev.block_read(&mmc->block_dev, block_no, cnt, dst); if (n != cnt) goto failure; @@ -253,7 +253,7 @@ static int ccdm_mmc_read(struct mmc *mmc, u64 src, u8 *dst, int size) block_no += cnt; } if (size) { - n = mmc->block_dev.block_read(mmc->block_dev.dev, block_no++, 1, + n = mmc->block_dev.block_read(&mmc->block_dev, block_no++, 1, tmp_buf); if (!n) goto failure; diff --git a/board/gdsys/p1022/sdhc_boot.c b/board/gdsys/p1022/sdhc_boot.c index fd0e910d7ba7..6a4a6ef6af24 100644 --- a/board/gdsys/p1022/sdhc_boot.c +++ b/board/gdsys/p1022/sdhc_boot.c @@ -43,7 +43,7 @@ int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) return 1;
/* read out the first block, get the config data information */ - n = mmc->block_dev.block_read(mmc->block_dev.dev, 0, 1, tmp_buf); + n = mmc->block_dev.block_read(&mmc->block_dev, 0, 1, tmp_buf); if (!n) { free(tmp_buf); return 1; diff --git a/common/cmd_disk.c b/common/cmd_disk.c index 8a1fda9f68a4..3025225c7642 100644 --- a/common/cmd_disk.c +++ b/common/cmd_disk.c @@ -56,7 +56,7 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, ", Block Size: %ld\n", info.start, info.size, info.blksz);
- if (dev_desc->block_read(dev, info.start, 1, (ulong *) addr) != 1) { + if (dev_desc->block_read(dev_desc, info.start, 1, (ulong *)addr) != 1) { printf("** Read error on %d:%d\n", dev, part); bootstage_error(BOOTSTAGE_ID_IDE_PART_READ); return 1; @@ -100,8 +100,8 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, cnt /= info.blksz; cnt -= 1;
- if (dev_desc->block_read(dev, info.start + 1, cnt, - (ulong *)(addr + info.blksz)) != cnt) { + if (dev_desc->block_read(dev_desc, info.start + 1, cnt, + (ulong *)(addr + info.blksz)) != cnt) { printf("** Read error on %d:%d\n", dev, part); bootstage_error(BOOTSTAGE_ID_IDE_READ); return 1; diff --git a/common/cmd_ide.c b/common/cmd_ide.c index ecd3e9d64f08..f19a7ce42a72 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -79,8 +79,8 @@ static void ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len
#ifdef CONFIG_ATAPI static void atapi_inquiry(block_dev_desc_t *dev_desc); -static ulong atapi_read(int device, lbaint_t blknr, lbaint_t blkcnt, - void *buffer); +static ulong atapi_read(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, void *buffer); #endif
@@ -187,6 +187,7 @@ int do_ide(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (strcmp(argv[1], "read") == 0) { ulong addr = simple_strtoul(argv[2], NULL, 16); ulong cnt = simple_strtoul(argv[4], NULL, 16); + block_dev_desc_t *dev_desc; ulong n;
#ifdef CONFIG_SYS_64BIT_LBA @@ -201,9 +202,9 @@ int do_ide(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) curr_device, blk, cnt); #endif
- n = ide_dev_desc[curr_device].block_read(curr_device, - blk, cnt, - (ulong *)addr); + dev_desc = &ide_dev_desc[curr_device]; + n = dev_desc->block_read(dev_desc, blk, cnt, + (ulong *)addr); /* flush cache after read */ flush_cache(addr, cnt * ide_dev_desc[curr_device].blksz); @@ -230,7 +231,8 @@ int do_ide(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) printf("\nIDE write: device %d block # %ld, count %ld ... ", curr_device, blk, cnt); #endif - n = ide_write(curr_device, blk, cnt, (ulong *) addr); + n = ide_write(&ide_dev_desc[curr_device], blk, cnt, + (ulong *)addr);
printf("%ld blocks written: %s\n", n, (n == cnt) ? "OK" : "ERROR"); @@ -711,8 +713,10 @@ static void ide_ident(block_dev_desc_t *dev_desc)
-ulong ide_read(int device, lbaint_t blknr, lbaint_t blkcnt, void *buffer) +ulong ide_read(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, + void *buffer) { + int device = block_dev->dev; ulong n = 0; unsigned char c; unsigned char pwrsave = 0; /* power save */ @@ -835,8 +839,10 @@ IDE_READ_E: /* ------------------------------------------------------------------------- */
-ulong ide_write(int device, lbaint_t blknr, lbaint_t blkcnt, const void *buffer) +ulong ide_write(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, + const void *buffer) { + int device = block_dev->dev; ulong n = 0; unsigned char c;
@@ -1388,8 +1394,10 @@ static void atapi_inquiry(block_dev_desc_t *dev_desc) #define ATAPI_READ_BLOCK_SIZE 2048 /* assuming CD part */ #define ATAPI_READ_MAX_BLOCK (ATAPI_READ_MAX_BYTES/ATAPI_READ_BLOCK_SIZE)
-ulong atapi_read(int device, lbaint_t blknr, lbaint_t blkcnt, void *buffer) +ulong atapi_read(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, + void *buffer) { + int device = block_dev->dev; ulong n = 0; unsigned char ccb[12]; /* Command descriptor block */ ulong cnt; diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index a6b7313e4a44..6b5c1ac1109e 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -351,7 +351,7 @@ static int do_mmc_read(cmd_tbl_t *cmdtp, int flag, printf("\nMMC read: dev # %d, block # %d, count %d ... ", curr_device, blk, cnt);
- n = mmc->block_dev.block_read(curr_device, blk, cnt, addr); + n = mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, addr); /* flush cache after read */ flush_cache((ulong)addr, cnt * 512); /* FIXME */ printf("%d blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR"); @@ -383,7 +383,7 @@ static int do_mmc_write(cmd_tbl_t *cmdtp, int flag, printf("Error: card is write protected!\n"); return CMD_RET_FAILURE; } - n = mmc->block_dev.block_write(curr_device, blk, cnt, addr); + n = mmc->block_dev.block_write(&mmc->block_dev, blk, cnt, addr); printf("%d blocks written: %s\n", n, (n == cnt) ? "OK" : "ERROR");
return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; @@ -411,7 +411,7 @@ static int do_mmc_erase(cmd_tbl_t *cmdtp, int flag, printf("Error: card is write protected!\n"); return CMD_RET_FAILURE; } - n = mmc->block_dev.block_erase(curr_device, blk, cnt); + n = mmc->block_dev.block_erase(&mmc->block_dev, blk, cnt); printf("%d blocks erased: %s\n", n, (n == cnt) ? "OK" : "ERROR");
return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; diff --git a/common/cmd_read.c b/common/cmd_read.c index f0fc9bfe17ad..871028878174 100644 --- a/common/cmd_read.c +++ b/common/cmd_read.c @@ -66,7 +66,7 @@ int do_read(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (dev_desc->block_read(dev, offset + blk, cnt, addr) < 0) { + if (dev_desc->block_read(dev_desc, offset + blk, cnt, addr) < 0) { printf("Error reading blocks\n"); return 1; } diff --git a/common/cmd_sata.c b/common/cmd_sata.c index 51f67033ae32..76baceae8c93 100644 --- a/common/cmd_sata.c +++ b/common/cmd_sata.c @@ -18,6 +18,18 @@ static int sata_curr_device = -1; block_dev_desc_t sata_dev_desc[CONFIG_SYS_SATA_MAX_DEVICE];
+static unsigned long sata_bread(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt, void *dst) +{ + return sata_read(block_dev->dev, start, blkcnt, dst); +} + +static unsigned long sata_bwrite(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt, const void *buffer) +{ + return sata_write(block_dev->dev, start, blkcnt, buffer); +} + int __sata_initialize(void) { int rc; @@ -32,8 +44,8 @@ int __sata_initialize(void) sata_dev_desc[i].lba = 0; sata_dev_desc[i].blksz = 512; sata_dev_desc[i].log2blksz = LOG2(sata_dev_desc[i].blksz); - sata_dev_desc[i].block_read = sata_read; - sata_dev_desc[i].block_write = sata_write; + sata_dev_desc[i].block_read = sata_bread; + sata_dev_desc[i].block_write = sata_bwrite;
rc = init_sata(i); if (!rc) { diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 31c43195e451..a5a3e9472f7e 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -66,9 +66,9 @@ void scsi_ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len);
static int scsi_read_capacity(ccb *pccb, lbaint_t *capacity, unsigned long *blksz); -static ulong scsi_read(int device, lbaint_t blknr, lbaint_t blkcnt, - void *buffer); -static ulong scsi_write(int device, lbaint_t blknr, +static ulong scsi_read(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, void *buffer); +static ulong scsi_write(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, const void *buffer);
@@ -334,7 +334,8 @@ int do_scsi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ulong n; printf ("\nSCSI read: device %d block # %ld, count %ld ... ", scsi_curr_dev, blk, cnt); - n = scsi_read(scsi_curr_dev, blk, cnt, (ulong *)addr); + n = scsi_read(&scsi_dev_desc[scsi_curr_dev], + blk, cnt, (ulong *)addr); printf ("%ld blocks read: %s\n",n,(n==cnt) ? "OK" : "ERROR"); return 0; } else if (strcmp(argv[1], "write") == 0) { @@ -345,8 +346,8 @@ int do_scsi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("\nSCSI write: device %d block # %ld, " "count %ld ... ", scsi_curr_dev, blk, cnt); - n = scsi_write(scsi_curr_dev, blk, cnt, - (ulong *)addr); + n = scsi_write(&scsi_dev_desc[scsi_curr_dev], + blk, cnt, (ulong *)addr); printf("%ld blocks written: %s\n", n, (n == cnt) ? "OK" : "ERROR"); return 0; @@ -363,9 +364,10 @@ int do_scsi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #define SCSI_MAX_READ_BLK 0xFFFF #define SCSI_LBA48_READ 0xFFFFFFF
-static ulong scsi_read(int device, lbaint_t blknr, lbaint_t blkcnt, - void *buffer) +static ulong scsi_read(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, void *buffer) { + int device = block_dev->dev; lbaint_t start, blks; uintptr_t buf_addr; unsigned short smallblks = 0; @@ -429,9 +431,10 @@ static ulong scsi_read(int device, lbaint_t blknr, lbaint_t blkcnt, /* Almost the maximum amount of the scsi_ext command.. */ #define SCSI_MAX_WRITE_BLK 0xFFFF
-static ulong scsi_write(int device, lbaint_t blknr, +static ulong scsi_write(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, const void *buffer) { + int device = block_dev->dev; lbaint_t start, blks; uintptr_t buf_addr; unsigned short smallblks; diff --git a/common/cmd_usb.c b/common/cmd_usb.c index a540b422db3a..c7b642c40af9 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -759,7 +759,7 @@ static int do_usb(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("\nUSB read: device %d block # %ld, count %ld" " ... ", usb_stor_curr_dev, blk, cnt); stor_dev = usb_stor_get_dev(usb_stor_curr_dev); - n = stor_dev->block_read(usb_stor_curr_dev, blk, cnt, + n = stor_dev->block_read(stor_dev, blk, cnt, (ulong *)addr); printf("%ld blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR"); @@ -781,7 +781,7 @@ static int do_usb(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("\nUSB write: device %d block # %ld, count %ld" " ... ", usb_stor_curr_dev, blk, cnt); stor_dev = usb_stor_get_dev(usb_stor_curr_dev); - n = stor_dev->block_write(usb_stor_curr_dev, blk, cnt, + n = stor_dev->block_write(stor_dev, blk, cnt, (ulong *)addr); printf("%ld blocks write: %s\n", n, (n == cnt) ? "OK" : "ERROR"); diff --git a/common/cmd_usb_mass_storage.c b/common/cmd_usb_mass_storage.c index 040738911290..f4bafecd0d45 100644 --- a/common/cmd_usb_mass_storage.c +++ b/common/cmd_usb_mass_storage.c @@ -19,9 +19,8 @@ static int ums_read_sector(struct ums *ums_dev, { block_dev_desc_t *block_dev = ums_dev->block_dev; lbaint_t blkstart = start + ums_dev->start_sector; - int dev_num = block_dev->dev;
- return block_dev->block_read(dev_num, blkstart, blkcnt, buf); + return block_dev->block_read(block_dev, blkstart, blkcnt, buf); }
static int ums_write_sector(struct ums *ums_dev, @@ -29,9 +28,8 @@ static int ums_write_sector(struct ums *ums_dev, { block_dev_desc_t *block_dev = ums_dev->block_dev; lbaint_t blkstart = start + ums_dev->start_sector; - int dev_num = block_dev->dev;
- return block_dev->block_write(dev_num, blkstart, blkcnt, buf); + return block_dev->block_write(block_dev, blkstart, blkcnt, buf); }
static struct ums ums_dev = { diff --git a/common/env_mmc.c b/common/env_mmc.c index 96398224cc84..f182749e8b88 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -127,7 +127,7 @@ static inline int write_env(struct mmc *mmc, unsigned long size, blk_start = ALIGN(offset, mmc->write_bl_len) / mmc->write_bl_len; blk_cnt = ALIGN(size, mmc->write_bl_len) / mmc->write_bl_len;
- n = mmc->block_dev.block_write(CONFIG_SYS_MMC_ENV_DEV, blk_start, + n = mmc->block_dev.block_write(&mmc->block_dev, blk_start, blk_cnt, (u_char *)buffer);
return (n == blk_cnt) ? 0 : -1; @@ -192,16 +192,12 @@ static inline int read_env(struct mmc *mmc, unsigned long size, unsigned long offset, const void *buffer) { uint blk_start, blk_cnt, n; - int dev = CONFIG_SYS_MMC_ENV_DEV; - -#ifdef CONFIG_SPL_BUILD - dev = 0; -#endif
blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(size, mmc->read_bl_len) / mmc->read_bl_len;
- n = mmc->block_dev.block_read(dev, blk_start, blk_cnt, (uchar *)buffer); + n = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_cnt, + (uchar *)buffer);
return (n == blk_cnt) ? 0 : -1; } diff --git a/common/fb_mmc.c b/common/fb_mmc.c index b480e76554bc..6e742dac56f7 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -58,7 +58,7 @@ static int fb_mmc_sparse_write(struct sparse_storage *storage, block_dev_desc_t *dev_desc = sparse->dev_desc; int ret;
- ret = dev_desc->block_write(dev_desc->dev, offset, size, data); + ret = dev_desc->block_write(dev_desc, offset, size, data); if (!ret) return -EIO;
@@ -84,8 +84,7 @@ static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info,
puts("Flashing Raw Image\n");
- blks = dev_desc->block_write(dev_desc->dev, info->start, blkcnt, - buffer); + blks = dev_desc->block_write(dev_desc, info->start, blkcnt, buffer); if (blks != blkcnt) { error("failed writing to device %d\n", dev_desc->dev); fastboot_fail(response_str, "failed writing to device"); @@ -206,7 +205,7 @@ void fb_mmc_erase(const char *cmd, char *response) printf("Erasing blocks " LBAFU " to " LBAFU " due to alignment\n", blks_start, blks_start + blks_size);
- blks = dev_desc->block_erase(dev_desc->dev, blks_start, blks_size); + blks = dev_desc->block_erase(dev_desc, blks_start, blks_size); if (blks != blks_size) { error("failed erasing from device %d", dev_desc->dev); fastboot_fail(response_str, "failed erasing from device"); diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index f2c1af5d35e8..c3931c6c4d77 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -28,7 +28,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) sizeof(struct image_header));
/* read image header to find the image size & load address */ - count = mmc->block_dev.block_read(0, sector, 1, header); + count = mmc->block_dev.block_read(&mmc->block_dev, sector, 1, header); debug("read sector %lx, count=%lu\n", sector, count); if (count == 0) goto end; @@ -45,7 +45,8 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) mmc->read_bl_len;
/* Read the header too to avoid extra memcpy */ - count = mmc->block_dev.block_read(0, sector, image_size_sectors, + count = mmc->block_dev.block_read(&mmc->block_dev, sector, + image_size_sectors, (void *)(ulong)spl_image.load_addr); debug("read %x sectors to %x\n", image_size_sectors, spl_image.load_addr); @@ -149,7 +150,7 @@ static int mmc_load_image_raw_os(struct mmc *mmc) { unsigned long count;
- count = mmc->block_dev.block_read(0, + count = mmc->block_dev.block_read(&mmc->block_dev, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, (void *) CONFIG_SYS_SPL_ARGS_ADDR); diff --git a/common/usb_storage.c b/common/usb_storage.c index 4fa6538db58a..68efde678af4 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -119,10 +119,10 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *us, block_dev_desc_t *dev_desc); int usb_storage_probe(struct usb_device *dev, unsigned int ifnum, struct us_data *ss); -unsigned long usb_stor_read(int device, lbaint_t blknr, - lbaint_t blkcnt, void *buffer); -unsigned long usb_stor_write(int device, lbaint_t blknr, - lbaint_t blkcnt, const void *buffer); +static unsigned long usb_stor_read(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, void *buffer); +static unsigned long usb_stor_write(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, const void *buffer); void uhci_show_temp_int_td(void);
#ifdef CONFIG_PARTITIONS @@ -1027,9 +1027,10 @@ static void usb_bin_fixup(struct usb_device_descriptor descriptor, } #endif /* CONFIG_USB_BIN_FIXUP */
-unsigned long usb_stor_read(int device, lbaint_t blknr, - lbaint_t blkcnt, void *buffer) +static unsigned long usb_stor_read(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, void *buffer) { + int device = block_dev->dev; lbaint_t start, blks; uintptr_t buf_addr; unsigned short smallblks; @@ -1097,9 +1098,10 @@ retry_it: return blkcnt; }
-unsigned long usb_stor_write(int device, lbaint_t blknr, - lbaint_t blkcnt, const void *buffer) +static unsigned long usb_stor_write(block_dev_desc_t *block_dev, lbaint_t blknr, + lbaint_t blkcnt, const void *buffer) { + int device = block_dev->dev; lbaint_t start, blks; uintptr_t buf_addr; unsigned short smallblks; diff --git a/disk/part_amiga.c b/disk/part_amiga.c index 260a3d5e87c8..57c1b9d055f0 100644 --- a/disk/part_amiga.c +++ b/disk/part_amiga.c @@ -140,8 +140,7 @@ struct rigid_disk_block *get_rdisk(block_dev_desc_t *dev_desc)
for (i=0; i<limit; i++) { - ulong res = dev_desc->block_read(dev_desc->dev, i, 1, - (ulong *)block_buffer); + ulong res = dev_desc->block_read(dev_desc, i, 1, (ulong *)block_buffer); if (res == 1) { struct rigid_disk_block *trdb = (struct rigid_disk_block *)block_buffer; @@ -183,7 +182,7 @@ struct bootcode_block *get_bootcode(block_dev_desc_t *dev_desc)
for (i = 0; i < limit; i++) { - ulong res = dev_desc->block_read(dev_desc->dev, i, 1, (ulong *)block_buffer); + ulong res = dev_desc->block_read(dev_desc, i, 1, (ulong *)block_buffer); if (res == 1) { struct bootcode_block *boot = (struct bootcode_block *)block_buffer; @@ -258,7 +257,7 @@ static struct partition_block *find_partition(block_dev_desc_t *dev_desc, int pa
while (block != 0xFFFFFFFF) { - ulong res = dev_desc->block_read(dev_desc->dev, block, 1, + ulong res = dev_desc->block_read(dev_desc, block, 1, (ulong *)block_buffer); if (res == 1) { @@ -354,8 +353,7 @@ void print_part_amiga (block_dev_desc_t *dev_desc)
PRINTF("Trying to load block #0x%X\n", block);
- res = dev_desc->block_read(dev_desc->dev, block, 1, - (ulong *)block_buffer); + res = dev_desc->block_read(dev_desc, block, 1, (ulong *)block_buffer); if (res == 1) { p = (struct partition_block *)block_buffer; diff --git a/disk/part_dos.c b/disk/part_dos.c index 89263d38aaa0..cc9fdc5c10bb 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -90,7 +90,7 @@ int test_part_dos (block_dev_desc_t *dev_desc) { ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz);
- if (dev_desc->block_read(dev_desc->dev, 0, 1, (ulong *) buffer) != 1) + if (dev_desc->block_read(dev_desc, 0, 1, (ulong *)buffer) != 1) return -1;
if (test_block_type(buffer) != DOS_MBR) @@ -109,7 +109,8 @@ static void print_partition_extended(block_dev_desc_t *dev_desc, dos_partition_t *pt; int i;
- if (dev_desc->block_read(dev_desc->dev, ext_part_sector, 1, (ulong *) buffer) != 1) { + if (dev_desc->block_read(dev_desc, ext_part_sector, 1, + (ulong *)buffer) != 1) { printf ("** Can't read partition table on %d:%d **\n", dev_desc->dev, ext_part_sector); return; @@ -173,7 +174,8 @@ static int get_partition_info_extended (block_dev_desc_t *dev_desc, int ext_part int i; int dos_type;
- if (dev_desc->block_read (dev_desc->dev, ext_part_sector, 1, (ulong *) buffer) != 1) { + if (dev_desc->block_read(dev_desc, ext_part_sector, 1, + (ulong *)buffer) != 1) { printf ("** Can't read partition table on %d:%d **\n", dev_desc->dev, ext_part_sector); return -1; diff --git a/disk/part_efi.c b/disk/part_efi.c index b1e01558a69f..22dfbb16b56c 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -324,7 +324,7 @@ int test_part_efi(block_dev_desc_t * dev_desc) ALLOC_CACHE_ALIGN_BUFFER_PAD(legacy_mbr, legacymbr, 1, dev_desc->blksz);
/* Read legacy MBR from block 0 and validate it */ - if ((dev_desc->block_read(dev_desc->dev, 0, 1, (ulong *)legacymbr) != 1) + if ((dev_desc->block_read(dev_desc, 0, 1, (ulong *)legacymbr) != 1) || (is_pmbr_valid(legacymbr) != 1)) { return -1; } @@ -354,7 +354,7 @@ static int set_protective_mbr(block_dev_desc_t *dev_desc) p_mbr->partition_record[0].nr_sects = (u32) dev_desc->lba - 1;
/* Write MBR sector to the MMC device */ - if (dev_desc->block_write(dev_desc->dev, 0, 1, p_mbr) != 1) { + if (dev_desc->block_write(dev_desc, 0, 1, p_mbr) != 1) { printf("** Can't write to device %d **\n", dev_desc->dev); return -1; @@ -386,22 +386,22 @@ int write_gpt_table(block_dev_desc_t *dev_desc, gpt_h->header_crc32 = cpu_to_le32(calc_crc32);
/* Write the First GPT to the block right after the Legacy MBR */ - if (dev_desc->block_write(dev_desc->dev, 1, 1, gpt_h) != 1) + if (dev_desc->block_write(dev_desc, 1, 1, gpt_h) != 1) goto err;
- if (dev_desc->block_write(dev_desc->dev, 2, pte_blk_cnt, gpt_e) + if (dev_desc->block_write(dev_desc, 2, pte_blk_cnt, gpt_e) != pte_blk_cnt) goto err;
prepare_backup_gpt_header(gpt_h);
- if (dev_desc->block_write(dev_desc->dev, + if (dev_desc->block_write(dev_desc, (lbaint_t)le64_to_cpu(gpt_h->last_usable_lba) + 1, pte_blk_cnt, gpt_e) != pte_blk_cnt) goto err;
- if (dev_desc->block_write(dev_desc->dev, + if (dev_desc->block_write(dev_desc, (lbaint_t)le64_to_cpu(gpt_h->my_lba), 1, gpt_h) != 1) goto err; @@ -737,7 +737,7 @@ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf) /* write MBR */ lba = 0; /* MBR is always at 0 */ cnt = 1; /* MBR (1 block) */ - if (dev_desc->block_write(dev_desc->dev, lba, cnt, buf) != cnt) { + if (dev_desc->block_write(dev_desc, lba, cnt, buf) != cnt) { printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", __func__, "MBR", cnt, lba); return 1; @@ -746,7 +746,7 @@ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf) /* write Primary GPT */ lba = GPT_PRIMARY_PARTITION_TABLE_LBA; cnt = 1; /* GPT Header (1 block) */ - if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_h) != cnt) { + if (dev_desc->block_write(dev_desc, lba, cnt, gpt_h) != cnt) { printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", __func__, "Primary GPT Header", cnt, lba); return 1; @@ -754,7 +754,7 @@ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf)
lba = le64_to_cpu(gpt_h->partition_entry_lba); cnt = gpt_e_blk_cnt; - if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_e) != cnt) { + if (dev_desc->block_write(dev_desc, lba, cnt, gpt_e) != cnt) { printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", __func__, "Primary GPT Entries", cnt, lba); return 1; @@ -765,7 +765,7 @@ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf) /* write Backup GPT */ lba = le64_to_cpu(gpt_h->partition_entry_lba); cnt = gpt_e_blk_cnt; - if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_e) != cnt) { + if (dev_desc->block_write(dev_desc, lba, cnt, gpt_e) != cnt) { printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", __func__, "Backup GPT Entries", cnt, lba); return 1; @@ -773,7 +773,7 @@ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf)
lba = le64_to_cpu(gpt_h->my_lba); cnt = 1; /* GPT Header (1 block) */ - if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_h) != cnt) { + if (dev_desc->block_write(dev_desc, lba, cnt, gpt_h) != cnt) { printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", __func__, "Backup GPT Header", cnt, lba); return 1; @@ -843,8 +843,7 @@ static int is_gpt_valid(block_dev_desc_t *dev_desc, u64 lba, }
/* Read GPT Header from device */ - if (dev_desc->block_read(dev_desc->dev, (lbaint_t)lba, 1, pgpt_head) - != 1) { + if (dev_desc->block_read(dev_desc, (lbaint_t)lba, 1, pgpt_head) != 1) { printf("*** ERROR: Can't read GPT header ***\n"); return 0; } @@ -881,6 +880,7 @@ static gpt_entry *alloc_read_gpt_entries(block_dev_desc_t * dev_desc, gpt_header * pgpt_head) { size_t count = 0, blk_cnt; + lbaint_t blk; gpt_entry *pte = NULL;
if (!dev_desc || !pgpt_head) { @@ -909,12 +909,10 @@ static gpt_entry *alloc_read_gpt_entries(block_dev_desc_t * dev_desc, }
/* Read GPT Entries from device */ + blk = le64_to_cpu(pgpt_head->partition_entry_lba); blk_cnt = BLOCK_CNT(count, dev_desc); - if (dev_desc->block_read (dev_desc->dev, - (lbaint_t)le64_to_cpu(pgpt_head->partition_entry_lba), - (lbaint_t) (blk_cnt), pte) - != blk_cnt) { - + if (dev_desc->block_read(dev_desc, blk, (lbaint_t)blk_cnt, pte) + != blk_cnt) { printf("*** ERROR: Can't read GPT Entries ***\n"); free(pte); return NULL; diff --git a/disk/part_iso.c b/disk/part_iso.c index 2547c703db54..0b1ac606374b 100644 --- a/disk/part_iso.c +++ b/disk/part_iso.c @@ -62,8 +62,8 @@ int get_partition_info_iso_verb(block_dev_desc_t * dev_desc, int part_num, disk_
/* the first sector (sector 0x10) must be a primary volume desc */ blkaddr=PVD_OFFSET; - if (dev_desc->block_read (dev_desc->dev, PVD_OFFSET, 1, (ulong *) tmpbuf) != 1) - return (-1); + if (dev_desc->block_read(dev_desc, PVD_OFFSET, 1, (ulong *)tmpbuf) != 1) + return -1; if(ppr->desctype!=0x01) { if(verb) printf ("** First descriptor is NOT a primary desc on %d:%d **\n", @@ -84,8 +84,8 @@ int get_partition_info_iso_verb(block_dev_desc_t * dev_desc, int part_num, disk_ PRINTF(" Lastsect:%08lx\n",lastsect); for(i=blkaddr;i<lastsect;i++) { PRINTF("Reading block %d\n", i); - if (dev_desc->block_read (dev_desc->dev, i, 1, (ulong *) tmpbuf) != 1) - return (-1); + if (dev_desc->block_read(dev_desc, i, 1, (ulong *)tmpbuf) != 1) + return -1; if(ppr->desctype==0x00) break; /* boot entry found */ if(ppr->desctype==0xff) { @@ -104,7 +104,7 @@ int get_partition_info_iso_verb(block_dev_desc_t * dev_desc, int part_num, disk_ } bootaddr=le32_to_int(pbr->pointer); PRINTF(" Boot Entry at: %08lX\n",bootaddr); - if (dev_desc->block_read (dev_desc->dev, bootaddr, 1, (ulong *) tmpbuf) != 1) { + if (dev_desc->block_read(dev_desc, bootaddr, 1, (ulong *)tmpbuf) != 1) { if(verb) printf ("** Can't read Boot Entry at %lX on %d:%d **\n", bootaddr,dev_desc->dev, part_num); diff --git a/disk/part_mac.c b/disk/part_mac.c index 099e0a0035be..f3bc8dd55535 100644 --- a/disk/part_mac.c +++ b/disk/part_mac.c @@ -51,7 +51,8 @@ int test_part_mac (block_dev_desc_t *dev_desc)
n = 1; /* assuming at least one partition */ for (i=1; i<=n; ++i) { - if ((dev_desc->block_read(dev_desc->dev, i, 1, (ulong *)mpart) != 1) || + if ((dev_desc->block_read(dev_desc, i, 1, + (ulong *)mpart) != 1) || (mpart->signature != MAC_PARTITION_MAGIC) ) { return (-1); } @@ -104,7 +105,7 @@ void print_part_mac (block_dev_desc_t *dev_desc) char c;
printf ("%4ld: ", i); - if (dev_desc->block_read (dev_desc->dev, i, 1, (ulong *)mpart) != 1) { + if (dev_desc->block_read(dev_desc, i, 1, (ulong *)mpart) != 1) { printf ("** Can't read Partition Map on %d:%ld **\n", dev_desc->dev, i); return; @@ -150,7 +151,7 @@ void print_part_mac (block_dev_desc_t *dev_desc) */ static int part_mac_read_ddb (block_dev_desc_t *dev_desc, mac_driver_desc_t *ddb_p) { - if (dev_desc->block_read(dev_desc->dev, 0, 1, (ulong *)ddb_p) != 1) { + if (dev_desc->block_read(dev_desc, 0, 1, (ulong *)ddb_p) != 1) { printf ("** Can't read Driver Desriptor Block **\n"); return (-1); } @@ -178,7 +179,7 @@ static int part_mac_read_pdb (block_dev_desc_t *dev_desc, int part, mac_partitio * partition 1 first since this is the only way to * know how many partitions we have. */ - if (dev_desc->block_read (dev_desc->dev, n, 1, (ulong *)pdb_p) != 1) { + if (dev_desc->block_read(dev_desc, n, 1, (ulong *)pdb_p) != 1) { printf ("** Can't read Partition Map on %d:%d **\n", dev_desc->dev, n); return (-1); diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index 73f4c4a9e98c..170f0fa5bf20 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -22,9 +22,11 @@ static struct host_block_dev *find_host_device(int dev) return NULL; }
-static unsigned long host_block_read(int dev, unsigned long start, - lbaint_t blkcnt, void *buffer) +static unsigned long host_block_read(block_dev_desc_t *block_dev, + unsigned long start, lbaint_t blkcnt, + void *buffer) { + int dev = block_dev->dev; struct host_block_dev *host_dev = find_host_device(dev);
if (!host_dev) @@ -42,9 +44,11 @@ static unsigned long host_block_read(int dev, unsigned long start, return -1; }
-static unsigned long host_block_write(int dev, unsigned long start, - lbaint_t blkcnt, const void *buffer) +static unsigned long host_block_write(block_dev_desc_t *block_dev, + unsigned long start, lbaint_t blkcnt, + const void *buffer) { + int dev = block_dev->dev; struct host_block_dev *host_dev = find_host_device(dev); if (os_lseek(host_dev->fd, start * host_dev->blk_dev.blksz, diff --git a/drivers/block/systemace.c b/drivers/block/systemace.c index fdf75b5abfc9..b974e80167e9 100644 --- a/drivers/block/systemace.c +++ b/drivers/block/systemace.c @@ -69,8 +69,9 @@ static u16 ace_readw(unsigned off) return in16(base + off); }
-static unsigned long systemace_read(int dev, unsigned long start, - lbaint_t blkcnt, void *buffer); +static unsigned long systemace_read(block_dev_desc_t *block_dev, + unsigned long start, lbaint_t blkcnt, + void *buffer);
static block_dev_desc_t systemace_dev = { 0 };
@@ -136,8 +137,9 @@ block_dev_desc_t *systemace_get_dev(int dev) * the dev_desc) to read blocks of data. The return value is the * number of blocks read. A zero return indicates an error. */ -static unsigned long systemace_read(int dev, unsigned long start, - lbaint_t blkcnt, void *buffer) +static unsigned long systemace_read(block_dev_desc_t *block_dev, + unsigned long start, lbaint_t blkcnt, + void *buffer) { int retry; unsigned blk_countdown; diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 5a9fb4a6e247..7ff2a810f303 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -77,11 +77,11 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, dfu->data.mmc.dev_num, blk_start, blk_count, buf); switch (op) { case DFU_OP_READ: - n = mmc->block_dev.block_read(dfu->data.mmc.dev_num, blk_start, + n = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_count, buf); break; case DFU_OP_WRITE: - n = mmc->block_dev.block_write(dfu->data.mmc.dev_num, blk_start, + n = mmc->block_dev.block_write(&mmc->block_dev, blk_start, blk_count, buf); break; default: diff --git a/drivers/mmc/fsl_esdhc_spl.c b/drivers/mmc/fsl_esdhc_spl.c index b1cb4b3534f8..301d9b3ab996 100644 --- a/drivers/mmc/fsl_esdhc_spl.c +++ b/drivers/mmc/fsl_esdhc_spl.c @@ -38,7 +38,8 @@ void mmc_spl_load_image(uint32_t offs, unsigned int size, void *vdst) blk_start = ALIGN(offs, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(size, mmc->read_bl_len) / mmc->read_bl_len;
- err = mmc->block_dev.block_read(0, blk_start, blk_cnt, vdst); + err = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_cnt, + vdst); if (err != blk_cnt) { puts("spl: mmc read failed!!\n"); hang(); @@ -85,7 +86,8 @@ void __noreturn mmc_boot(void) /* * Read source addr from sd card */ - err = mmc->block_dev.block_read(0, CONFIG_CFG_DATA_SECTOR, 1, tmp_buf); + err = mmc->block_dev.block_read(&mmc->block_dev, + CONFIG_CFG_DATA_SECTOR, 1, tmp_buf); if (err != 1) { puts("spl: mmc read failed!!\n"); free(tmp_buf); @@ -126,7 +128,7 @@ void __noreturn mmc_boot(void) #endif blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; - err = mmc->block_dev.block_read(0, blk_start, blk_cnt, + err = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_cnt, (uchar *)CONFIG_SYS_MMC_U_BOOT_DST); if (err != blk_cnt) { puts("spl: mmc read failed!!\n"); diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 2a58702848b7..2f8dc1e2dc9e 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -234,8 +234,10 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, return blkcnt; }
-static ulong mmc_bread(int dev_num, lbaint_t start, lbaint_t blkcnt, void *dst) +static ulong mmc_bread(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt, void *dst) { + int dev_num = block_dev->dev; lbaint_t cur, blocks_todo = blkcnt;
if (blkcnt == 0) diff --git a/drivers/mmc/mmc_private.h b/drivers/mmc/mmc_private.h index 447a7001dbd9..6a7063976cea 100644 --- a/drivers/mmc/mmc_private.h +++ b/drivers/mmc/mmc_private.h @@ -22,23 +22,24 @@ void mmc_adapter_card_type_ident(void);
#ifndef CONFIG_SPL_BUILD
-extern unsigned long mmc_berase(int dev_num, lbaint_t start, lbaint_t blkcnt); +unsigned long mmc_berase(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt);
-extern ulong mmc_bwrite(int dev_num, lbaint_t start, lbaint_t blkcnt, - const void *src); +unsigned long mmc_bwrite(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt, const void *src);
#else /* CONFIG_SPL_BUILD */
/* SPL will never write or erase, declare dummies to reduce code size. */
-static inline unsigned long mmc_berase(int dev_num, lbaint_t start, - lbaint_t blkcnt) +static inline unsigned long mmc_berase(block_dev_desc_t *block_dev, + lbaint_t start, lbaint_t blkcnt) { return 0; }
-static inline ulong mmc_bwrite(int dev_num, lbaint_t start, lbaint_t blkcnt, - const void *src) +static inline ulong mmc_bwrite(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt, const void *src) { return 0; } diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index 7aea7e943b9e..bf96b49d6135 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -65,8 +65,10 @@ err_out: return err; }
-unsigned long mmc_berase(int dev_num, lbaint_t start, lbaint_t blkcnt) +unsigned long mmc_berase(block_dev_desc_t *block_dev, lbaint_t start, + lbaint_t blkcnt) { + int dev_num = block_dev->dev; int err = 0; u32 start_rem, blkcnt_rem; struct mmc *mmc = find_mmc_device(dev_num); @@ -165,8 +167,10 @@ static ulong mmc_write_blocks(struct mmc *mmc, lbaint_t start, return blkcnt; }
-ulong mmc_bwrite(int dev_num, lbaint_t start, lbaint_t blkcnt, const void *src) +ulong mmc_bwrite(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt, + const void *src) { + int dev_num = block_dev->dev; lbaint_t cur, blocks_todo = blkcnt;
struct mmc *mmc = find_mmc_device(dev_num); diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index e717c4421629..7b33094d8486 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -454,7 +454,7 @@ int sunxi_mmc_has_egon_boot_signature(struct mmc *mmc) panic("Failed to allocate memory\n");
if (mmc_getcd(mmc) && mmc_init(mmc) == 0 && - mmc->block_dev.block_read(mmc->block_dev.dev, 16, 1, buf) == 1 && + mmc->block_dev.block_read(&mmc->block_dev, 16, 1, buf) == 1 && strncmp(&buf[4], "eGON.BT0", 8) == 0) valid_signature = 1;
diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index df5db723ba23..40fbf19c7572 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -395,7 +395,8 @@ int fm_init_common(int index, struct ccsr_fman *reg) printf("\nMMC read: dev # %u, block # %u, count %u ...\n", dev, blk, cnt); mmc_init(mmc); - (void)mmc->block_dev.block_read(dev, blk, cnt, addr); + (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, + addr); /* flush cache after read */ flush_cache((ulong)addr, cnt * 512); } diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index 3a2b3bba9952..447ecfbeb6df 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -174,7 +174,8 @@ void cs4340_upload_firmware(struct phy_device *phydev) printf("MMC read: dev # %u, block # %u, count %u ...\n", dev, blk, cnt); mmc_init(mmc); - (void)mmc->block_dev.block_read(dev, blk, cnt, addr); + (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, + addr); /* flush cache after read */ flush_cache((ulong)addr, cnt * 512); } diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c index 20f52566f09c..9fd10de0776b 100644 --- a/fs/ext4/dev.c +++ b/fs/ext4/dev.c @@ -76,10 +76,10 @@ int ext4fs_devread(lbaint_t sector, int byte_offset, int byte_len, char *buf) if (byte_offset != 0) { int readlen; /* read first part which isn't aligned with start of sector */ - if (ext4fs_block_dev_desc-> - block_read(ext4fs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *) sec_buf) != 1) { + if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc, + part_info->start + sector, + 1, (void *)sec_buf) + != 1) { printf(" ** ext2fs_devread() read error **\n"); return 0; } @@ -101,18 +101,18 @@ int ext4fs_devread(lbaint_t sector, int byte_offset, int byte_len, char *buf) ALLOC_CACHE_ALIGN_BUFFER(u8, p, ext4fs_block_dev_desc->blksz);
block_len = ext4fs_block_dev_desc->blksz; - ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, + ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc, part_info->start + sector, - 1, (unsigned long *)p); + 1, (void *)p); memcpy(buf, p, byte_len); return 1; }
- if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, - part_info->start + sector, - block_len >> log2blksz, - (unsigned long *) buf) != - block_len >> log2blksz) { + if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc, + part_info->start + sector, + block_len >> log2blksz, + (void *)buf) != + block_len >> log2blksz) { printf(" ** %s read error - block\n", __func__); return 0; } @@ -123,10 +123,10 @@ int ext4fs_devread(lbaint_t sector, int byte_offset, int byte_len, char *buf)
if (byte_len != 0) { /* read rest of data which are not in whole sector */ - if (ext4fs_block_dev_desc-> - block_read(ext4fs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *) sec_buf) != 1) { + if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc, + part_info->start + sector, + 1, (void *)sec_buf) + != 1) { printf("* %s read error - last part\n", __func__); return 0; } diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index e73223ac22c9..55efa4dd7618 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -82,26 +82,26 @@ void put_ext4(uint64_t off, void *buf, uint32_t size)
if (remainder) { if (fs->dev_desc->block_read) { - fs->dev_desc->block_read(fs->dev_desc->dev, + fs->dev_desc->block_read(fs->dev_desc, startblock, 1, sec_buf); temp_ptr = sec_buf; memcpy((temp_ptr + remainder), (unsigned char *)buf, size); - fs->dev_desc->block_write(fs->dev_desc->dev, + fs->dev_desc->block_write(fs->dev_desc, startblock, 1, sec_buf); } } else { if (size >> log2blksz != 0) { - fs->dev_desc->block_write(fs->dev_desc->dev, + fs->dev_desc->block_write(fs->dev_desc, startblock, size >> log2blksz, (unsigned long *)buf); } else { - fs->dev_desc->block_read(fs->dev_desc->dev, + fs->dev_desc->block_read(fs->dev_desc, startblock, 1, sec_buf); temp_ptr = sec_buf; memcpy(temp_ptr, buf, size); - fs->dev_desc->block_write(fs->dev_desc->dev, + fs->dev_desc->block_write(fs->dev_desc, startblock, 1, (unsigned long *)sec_buf); } diff --git a/fs/fat/fat.c b/fs/fat/fat.c index f939bc5deed2..472a63e8bb0a 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -51,8 +51,8 @@ static int disk_read(__u32 block, __u32 nr_blocks, void *buf) if (!cur_dev || !cur_dev->block_read) return -1;
- ret = cur_dev->block_read(cur_dev->dev, - cur_part_info.start + block, nr_blocks, buf); + ret = cur_dev->block_read(cur_dev, cur_part_info.start + block, + nr_blocks, buf);
if (nr_blocks && ret == 0) return -1; diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index af828d07bd0a..5ed324ce1a02 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -41,8 +41,7 @@ static int disk_write(__u32 block, __u32 nr_blocks, void *buf) return -1; }
- ret = cur_dev->block_write(cur_dev->dev, - cur_part_info.start + block, + ret = cur_dev->block_write(cur_dev, cur_part_info.start + block, nr_blocks, buf); if (nr_blocks && ret == 0) return -1; diff --git a/fs/reiserfs/dev.c b/fs/reiserfs/dev.c index 68255458d510..7b24d6aa715c 100644 --- a/fs/reiserfs/dev.c +++ b/fs/reiserfs/dev.c @@ -59,9 +59,11 @@ int reiserfs_devread (int sector, int byte_offset, int byte_len, char *buf)
if (byte_offset != 0) { /* read first part which isn't aligned with start of sector */ - if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *)sec_buf) != 1) { + if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc, + part_info->start + + sector, + 1, (void *)sec_buf) + != 1) { printf (" ** reiserfs_devread() read error\n"); return 0; } @@ -73,9 +75,11 @@ int reiserfs_devread (int sector, int byte_offset, int byte_len, char *buf)
/* read sector aligned part */ block_len = byte_len & ~(SECTOR_SIZE-1); - if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc->dev, - part_info->start + sector, block_len/SECTOR_SIZE, - (unsigned long *)buf) != block_len/SECTOR_SIZE) { + if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc, + part_info->start + sector, + block_len / SECTOR_SIZE, + (void *)buf) + != block_len/SECTOR_SIZE) { printf (" ** reiserfs_devread() read error - block\n"); return 0; } @@ -85,9 +89,11 @@ int reiserfs_devread (int sector, int byte_offset, int byte_len, char *buf)
if ( byte_len != 0 ) { /* read rest of data which are not in whole sector */ - if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *)sec_buf) != 1) { + if (reiserfs_block_dev_desc->block_read(reiserfs_block_dev_desc, + part_info->start + + sector, + 1, (void *)sec_buf) + != 1) { printf (" ** reiserfs_devread() read error - last part\n"); return 0; } diff --git a/fs/zfs/dev.c b/fs/zfs/dev.c index 3a1fa5685afe..67d12652b01e 100644 --- a/fs/zfs/dev.c +++ b/fs/zfs/dev.c @@ -55,9 +55,10 @@ int zfs_devread(int sector, int byte_offset, int byte_len, char *buf)
if (byte_offset != 0) { /* read first part which isn't aligned with start of sector */ - if (zfs_block_dev_desc->block_read(zfs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *)sec_buf) != 1) { + if (zfs_block_dev_desc->block_read(zfs_block_dev_desc, + part_info->start + sector, 1, + (void *)sec_buf) + != 1) { printf(" ** zfs_devread() read error **\n"); return 1; } @@ -78,16 +79,18 @@ int zfs_devread(int sector, int byte_offset, int byte_len, char *buf) u8 p[SECTOR_SIZE];
block_len = SECTOR_SIZE; - zfs_block_dev_desc->block_read(zfs_block_dev_desc->dev, - part_info->start + sector, - 1, (unsigned long *)p); + zfs_block_dev_desc->block_read(zfs_block_dev_desc, + part_info->start + sector, + 1, (void *)p); memcpy(buf, p, byte_len); return 0; }
- if (zfs_block_dev_desc->block_read(zfs_block_dev_desc->dev, - part_info->start + sector, block_len / SECTOR_SIZE, - (unsigned long *) buf) != block_len / SECTOR_SIZE) { + if (zfs_block_dev_desc->block_read(zfs_block_dev_desc, + part_info->start + sector, + block_len / SECTOR_SIZE, + (void *)buf) + != block_len / SECTOR_SIZE) { printf(" ** zfs_devread() read error - block\n"); return 1; } @@ -99,10 +102,9 @@ int zfs_devread(int sector, int byte_offset, int byte_len, char *buf)
if (byte_len != 0) { /* read rest of data which are not in whole sector */ - if (zfs_block_dev_desc-> - block_read(zfs_block_dev_desc->dev, - part_info->start + sector, 1, - (unsigned long *) sec_buf) != 1) { + if (zfs_block_dev_desc->block_read(zfs_block_dev_desc, + part_info->start + sector, + 1, (void *)sec_buf) != 1) { printf(" ** zfs_devread() read error - last part\n"); return 1; } diff --git a/include/ide.h b/include/ide.h index d5e05e97cb2f..645e846ac5a8 100644 --- a/include/ide.h +++ b/include/ide.h @@ -41,8 +41,10 @@ typedef ulong lbaint_t; */
void ide_init(void); -ulong ide_read(int device, lbaint_t blknr, lbaint_t blkcnt, void *buffer); -ulong ide_write(int device, lbaint_t blknr, lbaint_t blkcnt, +typedef struct block_dev_desc block_dev_desc_t; +ulong ide_read(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, + void *buffer); +ulong ide_write(block_dev_desc_t *block_dev, lbaint_t blknr, lbaint_t blkcnt, const void *buffer);
#ifdef CONFIG_IDE_PREINIT diff --git a/include/part.h b/include/part.h index 720a867783c4..8396ed178eea 100644 --- a/include/part.h +++ b/include/part.h @@ -10,7 +10,9 @@ #include <ide.h> #include <common.h>
-typedef struct block_dev_desc { +typedef struct block_dev_desc block_dev_desc_t; + +struct block_dev_desc { int if_type; /* type of the interface */ int dev; /* device number */ unsigned char part_type; /* partition type */ @@ -27,19 +29,19 @@ typedef struct block_dev_desc { char vendor [40+1]; /* IDE model, SCSI Vendor */ char product[20+1]; /* IDE Serial no, SCSI product */ char revision[8+1]; /* firmware revision */ - unsigned long (*block_read)(int dev, + unsigned long (*block_read)(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt, void *buffer); - unsigned long (*block_write)(int dev, + unsigned long (*block_write)(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt, const void *buffer); - unsigned long (*block_erase)(int dev, + unsigned long (*block_erase)(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt); void *priv; /* driver private struct pointer */ -}block_dev_desc_t; +};
#define BLOCK_CNT(size, block_dev_desc) (PAD_COUNT(size, block_dev_desc->blksz)) #define PAD_TO_BLOCKSIZE(size, block_dev_desc) \ diff --git a/lib/gunzip.c b/lib/gunzip.c index bdd85c4c1752..d86aa87f6884 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -231,8 +231,7 @@ int gzwrite(unsigned char *src, int len, gzwrite_progress(iteration++, totalfilled, szexpected); - blocks_written = dev->block_write(dev->dev, - outblock, + blocks_written = dev->block_write(dev, outblock, writeblocks, writebuf); outblock += blocks_written; diff --git a/test/dm/usb.c b/test/dm/usb.c index 7d6b644a51b5..d409d21a0781 100644 --- a/test/dm/usb.c +++ b/test/dm/usb.c @@ -50,7 +50,7 @@ static int dm_test_usb_flash(struct unit_test_state *uts) /* Read a few blocks and look for the string we expect */ ut_asserteq(512, dev_desc->blksz); memset(cmp, '\0', sizeof(cmp)); - ut_asserteq(2, dev_desc->block_read(dev_desc->dev, 0, 2, cmp)); + ut_asserteq(2, dev_desc->block_read(dev_desc, 0, 2, cmp)); ut_assertok(strcmp(cmp, "this is a test"));
This will allow us to have multiple block device structs each referring to the same eMMC device, yet different HW partitions.
For now, there is still a single block device per eMMC device. As before, this block device always accesses whichever HW partition was most recently selected. Clients wishing to make use of multiple block devices referring to different HW partitions can simply take a copy of this block device once it points at the correct HW partition, and use each one as they wish. This feature will be used by the next patch.
In the future, perhaps get_device() could be enhanced to return a dynamically allocated block device struct, to avoid the client needing to copy it in order to maintain multiple block devices. However, this would require all users to be updated to free those block device structs at some point, which is rather a large change.
Most callers of mmc_switch_part() wish to permanently switch the default MMC block device's HW partition. Enhance mmc_switch_part() so that it does this. This removes the need for callers to do this. However, common/env_mmc.c needs to save and restore the current HW partition. Make it do this more explicitly.
Replace use of mmc_switch_part() with mmc_select_hwpart() in order to remove duplicate code that skips the call if that HW partition is already selected.
Signed-off-by: Stephen Warren swarren@nvidia.com --- common/cmd_mmc.c | 18 ++++++------------ common/env_mmc.c | 14 +++++++------- drivers/dfu/dfu_mmc.c | 26 +++++--------------------- drivers/mmc/mmc.c | 18 ++++++++++++------ drivers/mmc/mmc_write.c | 9 +++++++++ include/mmc.h | 1 - include/part.h | 1 + 7 files changed, 40 insertions(+), 47 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 6b5c1ac1109e..1c7156f19c59 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -312,20 +312,14 @@ static int do_mmcrpmb(cmd_tbl_t *cmdtp, int flag, return CMD_RET_FAILURE; } /* Switch to the RPMB partition */ - original_part = mmc->part_num; - if (mmc->part_num != MMC_PART_RPMB) { - if (mmc_switch_part(curr_device, MMC_PART_RPMB) != 0) - return CMD_RET_FAILURE; - mmc->part_num = MMC_PART_RPMB; - } + original_part = mmc->block_dev.part_num; + if (mmc_select_hwpart(curr_device, MMC_PART_RPMB) != 0) + return CMD_RET_FAILURE; ret = cp->cmd(cmdtp, flag, argc, argv);
/* Return to original partition */ - if (mmc->part_num != original_part) { - if (mmc_switch_part(curr_device, original_part) != 0) - return CMD_RET_FAILURE; - mmc->part_num = original_part; - } + if (mmc_select_hwpart(curr_device, original_part) != 0) + return CMD_RET_FAILURE; return ret; } #endif @@ -483,7 +477,7 @@ static int do_mmc_dev(cmd_tbl_t *cmdtp, int flag, printf("mmc%d is current device\n", curr_device); else printf("mmc%d(part %d) is current device\n", - curr_device, mmc->part_num); + curr_device, mmc->block_dev.hwpart);
return CMD_RET_SUCCESS; } diff --git a/common/env_mmc.c b/common/env_mmc.c index f182749e8b88..15aa43d5e162 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -69,6 +69,8 @@ __weak uint mmc_get_env_part(struct mmc *mmc) return CONFIG_SYS_MMC_ENV_PART; }
+static unsigned char env_mmc_orig_hwpart; + static int mmc_set_env_part(struct mmc *mmc) { uint part = mmc_get_env_part(mmc); @@ -79,11 +81,10 @@ static int mmc_set_env_part(struct mmc *mmc) dev = 0; #endif
- if (part != mmc->part_num) { - ret = mmc_switch_part(dev, part); - if (ret) - puts("MMC partition switch failed\n"); - } + env_mmc_orig_hwpart = mmc->block_dev.hwpart; + ret = mmc_select_hwpart(dev, part); + if (ret) + puts("MMC partition switch failed\n");
return ret; } @@ -113,8 +114,7 @@ static void fini_mmc_for_env(struct mmc *mmc) #ifdef CONFIG_SPL_BUILD dev = 0; #endif - if (mmc_get_env_part(mmc) != mmc->part_num) - mmc_switch_part(dev, mmc->part_num); + mmc_select_hwpart(dev, env_mmc_orig_hwpart); #endif }
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 7ff2a810f303..395d472e0bd9 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -20,23 +20,6 @@ static unsigned char *dfu_file_buf; static long dfu_file_buf_len; static long dfu_file_buf_filled;
-static int mmc_access_part(struct dfu_entity *dfu, struct mmc *mmc, int part) -{ - int ret; - - if (part == mmc->part_num) - return 0; - - ret = mmc_switch_part(dfu->data.mmc.dev_num, part); - if (ret) { - error("Cannot switch to partition %d\n", part); - return ret; - } - mmc->part_num = part; - - return 0; -} - static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) { @@ -66,8 +49,9 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, }
if (dfu->data.mmc.hw_partition >= 0) { - part_num_bkp = mmc->part_num; - ret = mmc_access_part(dfu, mmc, dfu->data.mmc.hw_partition); + part_num_bkp = mmc->block_dev.hwpart; + ret = mmc_select_hwpart(dfu->data.mmc.dev_num, + dfu->data.mmc.hw_partition); if (ret) return ret; } @@ -91,12 +75,12 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, if (n != blk_count) { error("MMC operation failed"); if (dfu->data.mmc.hw_partition >= 0) - mmc_access_part(dfu, mmc, part_num_bkp); + mmc_select_hwpart(dfu->data.mmc.dev_num, part_num_bkp); return -EIO; }
if (dfu->data.mmc.hw_partition >= 0) { - ret = mmc_access_part(dfu, mmc, part_num_bkp); + ret = mmc_select_hwpart(dfu->data.mmc.dev_num, part_num_bkp); if (ret) return ret; } diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 2f8dc1e2dc9e..4f94a81ef0dc 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -238,6 +238,7 @@ static ulong mmc_bread(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt, void *dst) { int dev_num = block_dev->dev; + int err; lbaint_t cur, blocks_todo = blkcnt;
if (blkcnt == 0) @@ -247,6 +248,10 @@ static ulong mmc_bread(block_dev_desc_t *block_dev, lbaint_t start, if (!mmc) return 0;
+ err = mmc_select_hwpart(dev_num, block_dev->hwpart); + if (err < 0) + return 0; + if ((start + blkcnt) > mmc->block_dev.lba) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("MMC: block number 0x" LBAF " exceeds max(0x" LBAF ")\n", @@ -581,7 +586,7 @@ int mmc_select_hwpart(int dev_num, int hwpart) if (!mmc) return -ENODEV;
- if (mmc->part_num == hwpart) + if (mmc->block_dev.hwpart == hwpart) return 0;
if (mmc->part_config == MMCPART_NOAVAILABLE) { @@ -593,8 +598,6 @@ int mmc_select_hwpart(int dev_num, int hwpart) if (ret) return ret;
- mmc->part_num = hwpart; - return 0; }
@@ -615,8 +618,10 @@ int mmc_switch_part(int dev_num, unsigned int part_num) * Set the capacity if the switch succeeded or was intended * to return to representing the raw device. */ - if ((ret == 0) || ((ret == -ENODEV) && (part_num == 0))) + if ((ret == 0) || ((ret == -ENODEV) && (part_num == 0))) { ret = mmc_set_capacity(mmc, part_num); + mmc->block_dev.hwpart = part_num; + }
return ret; } @@ -1326,7 +1331,7 @@ static int mmc_startup(struct mmc *mmc) mmc->wr_rel_set = ext_csd[EXT_CSD_WR_REL_SET]; }
- err = mmc_set_capacity(mmc, mmc->part_num); + err = mmc_set_capacity(mmc, mmc->block_dev.hwpart); if (err) return err;
@@ -1467,6 +1472,7 @@ static int mmc_startup(struct mmc *mmc)
/* fill in device description */ mmc->block_dev.lun = 0; + mmc->block_dev.hwpart = 0; mmc->block_dev.type = 0; mmc->block_dev.blksz = mmc->read_bl_len; mmc->block_dev.log2blksz = LOG2(mmc->block_dev.blksz); @@ -1624,7 +1630,7 @@ int mmc_start_init(struct mmc *mmc) return err;
/* The internal partition reset to user partition(0) at every CMD0*/ - mmc->part_num = 0; + mmc->block_dev.hwpart = 0;
/* Test for SD version 2 */ err = mmc_send_if_cond(mmc); diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index bf96b49d6135..5eb437388593 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -78,6 +78,10 @@ unsigned long mmc_berase(block_dev_desc_t *block_dev, lbaint_t start, if (!mmc) return -1;
+ err = mmc_select_hwpart(dev_num, block_dev->hwpart); + if (err < 0) + return -1; + /* * We want to see if the requested start or total block count are * unaligned. We discard the whole numbers and only care about the @@ -172,11 +176,16 @@ ulong mmc_bwrite(block_dev_desc_t *block_dev, lbaint_t start, lbaint_t blkcnt, { int dev_num = block_dev->dev; lbaint_t cur, blocks_todo = blkcnt; + int err;
struct mmc *mmc = find_mmc_device(dev_num); if (!mmc) return 0;
+ err = mmc_select_hwpart(dev_num, block_dev->hwpart); + if (err < 0) + return 0; + if (mmc_set_blocklen(mmc, mmc->write_bl_len)) return 0;
diff --git a/include/mmc.h b/include/mmc.h index cda9a19ce0aa..d647ff0434aa 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -359,7 +359,6 @@ struct mmc { u8 part_attr; u8 wr_rel_set; char part_config; - char part_num; uint tran_speed; uint read_bl_len; uint write_bl_len; diff --git a/include/part.h b/include/part.h index 8396ed178eea..4d00e220e4c8 100644 --- a/include/part.h +++ b/include/part.h @@ -18,6 +18,7 @@ struct block_dev_desc { unsigned char part_type; /* partition type */ unsigned char target; /* target SCSI ID */ unsigned char lun; /* target LUN */ + unsigned char hwpart; /* HW partition, e.g. for eMMC */ unsigned char type; /* device type */ unsigned char removable; /* removable device */ #ifdef CONFIG_LBA48
Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Tom Rini trini@konsulko.com
Extend the ums command to accept a list of block devices. Each of these will be exported as a separate LUN. An example use-case would be:
ums 0 mmc 0,0.1,0.2
... which would export LUNs for eMMC 0's user data, boot0, and boot1 HW partitions. This is useful since it allows the host access to everything on the eMMC without having to somehow stop the ums command from executing and restart it with different parameters.
Signed-off-by: Stephen Warren swarren@nvidia.com --- common/cmd_usb_mass_storage.c | 135 +++++++++++++++++++++++++++--------- drivers/usb/gadget/f_mass_storage.c | 22 +++--- drivers/usb/gadget/storage_common.c | 7 +- include/usb_mass_storage.h | 6 +- 4 files changed, 121 insertions(+), 49 deletions(-)
diff --git a/common/cmd_usb_mass_storage.c b/common/cmd_usb_mass_storage.c index f4bafecd0d45..041559172d95 100644 --- a/common/cmd_usb_mass_storage.c +++ b/common/cmd_usb_mass_storage.c @@ -2,6 +2,8 @@ * Copyright (C) 2011 Samsung Electronics * Lukasz Majewski l.majewski@samsung.com * + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -17,7 +19,7 @@ static int ums_read_sector(struct ums *ums_dev, ulong start, lbaint_t blkcnt, void *buf) { - block_dev_desc_t *block_dev = ums_dev->block_dev; + block_dev_desc_t *block_dev = &ums_dev->block_dev; lbaint_t blkstart = start + ums_dev->start_sector;
return block_dev->block_read(block_dev, blkstart, blkcnt, buf); @@ -26,39 +28,98 @@ static int ums_read_sector(struct ums *ums_dev, static int ums_write_sector(struct ums *ums_dev, ulong start, lbaint_t blkcnt, const void *buf) { - block_dev_desc_t *block_dev = ums_dev->block_dev; + block_dev_desc_t *block_dev = &ums_dev->block_dev; lbaint_t blkstart = start + ums_dev->start_sector;
-static struct ums ums_dev = { - .read_sector = ums_read_sector, - .write_sector = ums_write_sector, - .name = "UMS disk", -}; +static struct ums *ums; +static int ums_count; + +static void ums_fini(void) +{ + int i; + + for (i = 0; i < ums_count; i++) + free((void *)ums[i].name); + free(ums); + ums = 0; + ums_count = 0; +} + +#define UMS_NAME_LEN 16
-struct ums *ums_init(const char *devtype, const char *devnum) +static int ums_init(const char *devtype, const char *devnums) { + char *s, *t, *devnum, *name; block_dev_desc_t *block_dev; int ret; + struct ums *ums_new;
- ret = get_device(devtype, devnum, &block_dev); - if (ret < 0) - return NULL; + s = strdup(devnums); + if (!s) + return -1; + + t = s; + ums_count = 0; + + for (;;) { + devnum = strsep(&t, ","); + if (!devnum) + break; + + ret = get_device(devtype, devnum, &block_dev); + if (ret < 0) + goto cleanup; + + /* f_mass_storage.c assumes SECTOR_SIZE sectors */ + if (block_dev->blksz != SECTOR_SIZE) { + ret = -1; + goto cleanup; + }
- /* f_mass_storage.c assumes SECTOR_SIZE sectors */ - if (block_dev->blksz != SECTOR_SIZE) - return NULL; + ums_new = realloc(ums, (ums_count + 1) * sizeof(*ums)); + if (!ums_new) { + ret = -1; + goto cleanup; + } + ums = ums_new; + + ums[ums_count].read_sector = ums_read_sector; + ums[ums_count].write_sector = ums_write_sector; + ums[ums_count].start_sector = 0; + ums[ums_count].num_sectors = block_dev->lba; + name = malloc(UMS_NAME_LEN); + if (!name) { + ret = -1; + goto cleanup; + } + snprintf(name, UMS_NAME_LEN, "UMS disk %d", ums_count); + ums[ums_count].name = name; + ums[ums_count].block_dev = *block_dev; + + printf("UMS: LUN %d, dev %d, hwpart %d, sector %#x, count %#x\n", + ums_count, ums[ums_count].block_dev.dev, + ums[ums_count].block_dev.hwpart, + ums[ums_count].start_sector, + ums[ums_count].num_sectors); + + ums_count++; + } + + if (!ums_count) + ret = -1; + else + ret = 0;
- ums_dev.block_dev = block_dev; - ums_dev.start_sector = 0; - ums_dev.num_sectors = block_dev->lba; +cleanup: + free(s);
- printf("UMS: disk start sector: %#x, count: %#x\n", - ums_dev.start_sector, ums_dev.num_sectors); + if (ret < 0) + ums_fini();
- return &ums_dev; + return ret; }
int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, @@ -67,7 +128,6 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, const char *usb_controller; const char *devtype; const char *devnum; - struct ums *ums; unsigned int controller_index; int rc; int cable_ready_timeout __maybe_unused; @@ -84,27 +144,30 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, devnum = argv[2]; }
- ums = ums_init(devtype, devnum); - if (!ums) + rc = ums_init(devtype, devnum); + if (rc < 0) return CMD_RET_FAILURE;
controller_index = (unsigned int)(simple_strtoul( usb_controller, NULL, 0)); if (board_usb_init(controller_index, USB_INIT_DEVICE)) { error("Couldn't init USB controller."); - return CMD_RET_FAILURE; + rc = CMD_RET_FAILURE; + goto cleanup_ums_init; }
- rc = fsg_init(ums); + rc = fsg_init(ums, ums_count); if (rc) { error("fsg_init failed"); - return CMD_RET_FAILURE; + rc = CMD_RET_FAILURE; + goto cleanup_board; }
rc = g_dnl_register("usb_dnl_ums"); if (rc) { error("g_dnl_register failed"); - return CMD_RET_FAILURE; + rc = CMD_RET_FAILURE; + goto cleanup_board; }
/* Timeout unit: seconds */ @@ -120,12 +183,14 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, while (!g_dnl_board_usb_cable_connected()) { if (ctrlc()) { puts("\rCTRL+C - Operation aborted.\n"); - goto exit; + rc = CMD_RET_SUCCESS; + goto cleanup_register; } if (!cable_ready_timeout) { puts("\rUSB cable not detected.\n" \ "Command exit.\n"); - goto exit; + rc = CMD_RET_SUCCESS; + goto cleanup_register; }
printf("\rAuto exit in: %.2d s.", cable_ready_timeout); @@ -148,13 +213,19 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, if (rc == -EPIPE) printf("\rCTRL+C - Operation aborted\n");
- goto exit; + rc = CMD_RET_SUCCESS; + goto cleanup_register; } } -exit: + +cleanup_register: g_dnl_unregister(); +cleanup_board: board_usb_cleanup(controller_index, USB_INIT_DEVICE); - return CMD_RET_SUCCESS; +cleanup_ums_init: + ums_fini(); + + return rc; }
U_BOOT_CMD(ums, 4, 1, do_usb_mass_storage, diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index ec1f23a0cf3f..1ecb92ac6b81 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -444,8 +444,9 @@ static void set_bulk_out_req_length(struct fsg_common *common,
-struct ums *ums; -struct fsg_common *the_fsg_common; +static struct ums *ums; +static int ums_count; +static struct fsg_common *the_fsg_common;
static int fsg_set_halt(struct fsg_dev *fsg, struct usb_ep *ep) { @@ -772,7 +773,7 @@ static int do_read(struct fsg_common *common) }
/* Perform the read */ - rc = ums->read_sector(ums, + rc = ums[common->lun].read_sector(&ums[common->lun], file_offset / SECTOR_SIZE, amount / SECTOR_SIZE, (char __user *)bh->buf); @@ -946,7 +947,7 @@ static int do_write(struct fsg_common *common) amount = bh->outreq->actual;
/* Perform the write */ - rc = ums->write_sector(ums, + rc = ums[common->lun].write_sector(&ums[common->lun], file_offset / SECTOR_SIZE, amount / SECTOR_SIZE, (char __user *)bh->buf); @@ -1062,7 +1063,7 @@ static int do_verify(struct fsg_common *common) }
/* Perform the read */ - rc = ums->read_sector(ums, + rc = ums[common->lun].read_sector(&ums[common->lun], file_offset / SECTOR_SIZE, amount / SECTOR_SIZE, (char __user *)bh->buf); @@ -1117,7 +1118,7 @@ static int do_inquiry(struct fsg_common *common, struct fsg_buffhd *bh) buf[4] = 31; /* Additional length */ /* No special options */ sprintf((char *) (buf + 8), "%-8s%-16s%04x", (char*) vendor_id , - ums->name, (u16) 0xffff); + ums[common->lun].name, (u16) 0xffff);
return 36; } @@ -2456,7 +2457,7 @@ static struct fsg_common *fsg_common_init(struct fsg_common *common, int nluns, i, rc;
/* Find out how many LUNs there should be */ - nluns = 1; + nluns = ums_count; if (nluns < 1 || nluns > FSG_MAX_LUNS) { printf("invalid number of LUNs: %u\n", nluns); return ERR_PTR(-EINVAL); @@ -2501,7 +2502,7 @@ static struct fsg_common *fsg_common_init(struct fsg_common *common, for (i = 0; i < nluns; i++) { common->luns[i].removable = 1;
- rc = fsg_lun_open(&common->luns[i], ""); + rc = fsg_lun_open(&common->luns[i], ums[i].num_sectors, ""); if (rc) goto error_luns; } @@ -2775,9 +2776,10 @@ int fsg_add(struct usb_configuration *c) return fsg_bind_config(c->cdev, c, fsg_common); }
-int fsg_init(struct ums *ums_dev) +int fsg_init(struct ums *ums_devs, int count) { - ums = ums_dev; + ums = ums_devs; + ums_count = count;
return 0; } diff --git a/drivers/usb/gadget/storage_common.c b/drivers/usb/gadget/storage_common.c index b55e40bbda94..b6df130a1405 100644 --- a/drivers/usb/gadget/storage_common.c +++ b/drivers/usb/gadget/storage_common.c @@ -564,7 +564,8 @@ static struct usb_gadget_strings fsg_stringtab = { * the caller must own fsg->filesem for writing. */
-static int fsg_lun_open(struct fsg_lun *curlun, const char *filename) +static int fsg_lun_open(struct fsg_lun *curlun, unsigned int num_sectors, + const char *filename) { int ro;
@@ -572,8 +573,8 @@ static int fsg_lun_open(struct fsg_lun *curlun, const char *filename) ro = curlun->initially_ro;
curlun->ro = ro; - curlun->file_length = ums->num_sectors << 9; - curlun->num_sectors = ums->num_sectors; + curlun->file_length = num_sectors << 9; + curlun->num_sectors = num_sectors; debug("open backing file: %s\n", filename);
return 0; diff --git a/include/usb_mass_storage.h b/include/usb_mass_storage.h index 69b80cd1a367..5804b70c354d 100644 --- a/include/usb_mass_storage.h +++ b/include/usb_mass_storage.h @@ -23,12 +23,10 @@ struct ums { unsigned int start_sector; unsigned int num_sectors; const char *name; - block_dev_desc_t *block_dev; + block_dev_desc_t block_dev; };
-extern struct ums *ums; - -int fsg_init(struct ums *); +int fsg_init(struct ums *ums_devs, int count); void fsg_cleanup(void); int fsg_main_thread(void *); int fsg_add(struct usb_configuration *c);
ums 0 mmc 0,0.1,0.2
ums 0 mmc 0,0.1,0.2
On Mon, Dec 07, 2015 at 11:38:48AM -0700, Stephen Warren wrote:
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist.
Tom,
I assume you were just waiting for the merge window to open before applying this?
Tom,
Yes, thanks.
Stephen Warren
