[U-Boot] [PATCH 11/22] ppc4xx: remove OCRTC board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 - board/esd/ocrtc/Kconfig | 12 -- board/esd/ocrtc/MAINTAINERS | 6 - board/esd/ocrtc/Makefile | 8 -- board/esd/ocrtc/cmd_ocrtc.c | 68 ---------- board/esd/ocrtc/flash.c | 140 ------------------- board/esd/ocrtc/ocrtc.c | 78 ----------- board/esd/ocrtc/ocrtc.h | 28 ---- configs/OCRTC_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/OCRTC.h | 285 --------------------------------------- 11 files changed, 1 insertion(+), 632 deletions(-) delete mode 100644 board/esd/ocrtc/Kconfig delete mode 100644 board/esd/ocrtc/MAINTAINERS delete mode 100644 board/esd/ocrtc/Makefile delete mode 100644 board/esd/ocrtc/cmd_ocrtc.c delete mode 100644 board/esd/ocrtc/flash.c delete mode 100644 board/esd/ocrtc/ocrtc.c delete mode 100644 board/esd/ocrtc/ocrtc.h delete mode 100644 configs/OCRTC_defconfig delete mode 100644 include/configs/OCRTC.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index cab8f25..ea4227e 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -125,9 +125,6 @@ config TARGET_CPCI405AB config TARGET_CPCI405DT bool "Support CPCI405DT"
-config TARGET_OCRTC - bool "Support OCRTC" - config TARGET_PCI405 bool "Support PCI405"
@@ -229,7 +226,6 @@ source "board/csb472/Kconfig" source "board/dave/PPChameleonEVB/Kconfig" source "board/esd/cpci2dp/Kconfig" source "board/esd/cpci405/Kconfig" -source "board/esd/ocrtc/Kconfig" source "board/esd/pci405/Kconfig" source "board/esd/plu405/Kconfig" source "board/esd/pmc405/Kconfig" diff --git a/board/esd/ocrtc/Kconfig b/board/esd/ocrtc/Kconfig deleted file mode 100644 index 44b402d..0000000 --- a/board/esd/ocrtc/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_OCRTC - -config SYS_BOARD - default "ocrtc" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "OCRTC" - -endif diff --git a/board/esd/ocrtc/MAINTAINERS b/board/esd/ocrtc/MAINTAINERS deleted file mode 100644 index 85c1a12..0000000 --- a/board/esd/ocrtc/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -OCRTC BOARD -M: Matthias Fuchs matthias.fuchs@esd-electronics.com -S: Maintained -F: board/esd/ocrtc/ -F: include/configs/OCRTC.h -F: configs/OCRTC_defconfig diff --git a/board/esd/ocrtc/Makefile b/board/esd/ocrtc/Makefile deleted file mode 100644 index 44b7d5d..0000000 --- a/board/esd/ocrtc/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = ocrtc.o flash.o ../common/misc.o cmd_ocrtc.o diff --git a/board/esd/ocrtc/cmd_ocrtc.c b/board/esd/ocrtc/cmd_ocrtc.c deleted file mode 100644 index 6dcbd8b..0000000 --- a/board/esd/ocrtc/cmd_ocrtc.c +++ /dev/null @@ -1,68 +0,0 @@ -/* - * (C) Copyright 2003 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <pci.h> -#include <pci_ids.h> -#include <asm/4xx_pci.h> - - -#if defined(CONFIG_CMD_BSP) - -/* - * Set device number on pci board - */ -int do_setdevice(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - int idx = 1; /* start at 1 (skip device 0) */ - pci_dev_t bdf = 0; - u32 addr; - - while (bdf >= 0) { - if ((bdf = pci_find_device(PCI_VENDOR_ID_IBM, PCI_DEVICE_ID_IBM_405GP, idx++)) < 0) { - break; - } - printf("Found device nr %d at %x!\n", idx-1, bdf); - pci_read_config_dword(bdf, PCI_BASE_ADDRESS_1, &addr); - addr &= ~0xf; - *(u32 *)addr = (bdf & 0x0000f800) >> 11; - printf("Wrote %x at %x!\n", (bdf & 0x0000f800) >> 11, addr); - } - - return 0; -} -U_BOOT_CMD( - setdevice, 1, 1, do_setdevice, - "Set device number on pci adapter boards", - "" -); - - -/* - * Get device number on pci board - */ -int do_getdevice(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - u32 device; - char str[32]; - - device = *(u32 *)0x0; - device = 0x16 - device; /* calculate vxworks bp slot id */ - sprintf(str, "%d", device); - setenv("slot", str); - printf("Variabel slot set to %x\n", device); - - return 0; -} -U_BOOT_CMD( - getdevice, 1, 1, do_getdevice, - "Get device number and set slot env variable", - "" -); - -#endif diff --git a/board/esd/ocrtc/flash.c b/board/esd/ocrtc/flash.c deleted file mode 100644 index 279746e..0000000 --- a/board/esd/ocrtc/flash.c +++ /dev/null @@ -1,140 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/ppc4xx.h> -#include <asm/processor.h> - -/* - * include common flash code (for esd boards) - */ -#include "../common/flash.c" - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long * addr, flash_info_t * info); -static void flash_get_offsets (ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0, size_b1; - int i; - uint pbcr; - unsigned long base_b0, base_b1; - int size_val = 0; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - base_b0 = FLASH_BASE0_PRELIM; - size_b0 = flash_get_size ((vu_long *) base_b0, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0 << 20); - } - - base_b1 = FLASH_BASE1_PRELIM; - size_b1 = flash_get_size ((vu_long *) base_b1, &flash_info[1]); - - /* Re-do sizing to get full correct info */ - - if (size_b1) { - mtdcr (EBC0_CFGADDR, PB0CR); - pbcr = mfdcr (EBC0_CFGDATA); - mtdcr (EBC0_CFGADDR, PB0CR); - base_b1 = -size_b1; - switch (size_b1) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - } - pbcr = (pbcr & 0x0001ffff) | base_b1 | (size_val << 17); - mtdcr (EBC0_CFGDATA, pbcr); - /* printf("PB1CR = %x\n", pbcr); */ - } - - if (size_b0) { - mtdcr (EBC0_CFGADDR, PB1CR); - pbcr = mfdcr (EBC0_CFGDATA); - mtdcr (EBC0_CFGADDR, PB1CR); - base_b0 = base_b1 - size_b0; - switch (size_b1) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - } - pbcr = (pbcr & 0x0001ffff) | base_b0 | (size_val << 17); - mtdcr (EBC0_CFGDATA, pbcr); - /* printf("PB0CR = %x\n", pbcr); */ - } - - size_b0 = flash_get_size ((vu_long *) base_b0, &flash_info[0]); - - flash_get_offsets (base_b0, &flash_info[0]); - - /* monitor protection ON by default */ - flash_protect (FLAG_PROTECT_SET, - base_b0 + size_b0 - monitor_flash_len, - base_b0 + size_b0 - 1, &flash_info[0]); - - if (size_b1) { - /* Re-do sizing to get full correct info */ - size_b1 = flash_get_size ((vu_long *) base_b1, &flash_info[1]); - - flash_get_offsets (base_b1, &flash_info[1]); - - /* monitor protection ON by default */ - flash_protect (FLAG_PROTECT_SET, - base_b1 + size_b1 - monitor_flash_len, - base_b1 + size_b1 - 1, &flash_info[1]); - /* monitor protection OFF by default (one is enough) */ - flash_protect (FLAG_PROTECT_CLEAR, - base_b0 + size_b0 - monitor_flash_len, - base_b0 + size_b0 - 1, &flash_info[0]); - } else { - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - } - - flash_info[0].size = size_b0; - flash_info[1].size = size_b1; - - return (size_b0 + size_b1); -} diff --git a/board/esd/ocrtc/ocrtc.c b/board/esd/ocrtc/ocrtc.c deleted file mode 100644 index b815961..0000000 --- a/board/esd/ocrtc/ocrtc.c +++ /dev/null @@ -1,78 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include "ocrtc.h" -#include <asm/processor.h> -#include <i2c.h> -#include <command.h> - - -extern void lxt971_no_sleep(void); - - -int board_early_init_f (void) -{ - /* - * IRQ 0-15 405GP internally generated; active high; level sensitive - * IRQ 16 405GP internally generated; active low; level sensitive - * IRQ 17-24 RESERVED - * IRQ 25 (EXT IRQ 0) CAN0; active low; level sensitive - * IRQ 26 (EXT IRQ 1) CAN1; active low; level sensitive - * IRQ 27 (EXT IRQ 2) PCI SLOT 0; active low; level sensitive - * IRQ 28 (EXT IRQ 3) PCI SLOT 1; active low; level sensitive - * IRQ 29 (EXT IRQ 4) PCI SLOT 2; active low; level sensitive - * IRQ 30 (EXT IRQ 5) PCI SLOT 3; active low; level sensitive - * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive - */ - mtdcr (UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr (UIC0ER, 0x00000000); /* disable all ints */ - mtdcr (UIC0CR, 0x00000000); /* set all to be non-critical */ - mtdcr (UIC0PR, 0xFFFFFF81); /* set int polarities */ - mtdcr (UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr (UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest priority */ - mtdcr (UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - /* - * EBC Configuration Register: clear EBTC -> high-Z ebc signals between - * transfers, set device-paced timeout to 256 cycles - */ - mtebc (EBC0_CFG, 0x20400000); - - return 0; -} - -/* - * Check Board Identity: - */ -int checkboard (void) -{ - char str[64]; - int i = getenv_f("serial#", str, sizeof (str)); - - puts ("Board: "); - - if (i == -1) { -#ifdef CONFIG_OCRTC - puts ("### No HW ID - assuming OCRTC"); -#endif -#ifdef CONFIG_ORSG - puts ("### No HW ID - assuming ORSG"); -#endif - } else { - puts (str); - } - - putc ('\n'); - - /* - * Disable sleep mode in LXT971 - */ - lxt971_no_sleep(); - - return (0); -} diff --git a/board/esd/ocrtc/ocrtc.h b/board/esd/ocrtc/ocrtc.h deleted file mode 100644 index 029e27e..0000000 --- a/board/esd/ocrtc/ocrtc.h +++ /dev/null @@ -1,28 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/**************************************************************************** - * FLASH Memory Map as used by TQ Monitor: - * - * Start Address Length - * +-----------------------+ 0x4000_0000 Start of Flash ----------------- - * | MON8xx code | 0x4000_0100 Reset Vector - * +-----------------------+ 0x400?_???? - * | (unused) | - * +-----------------------+ 0x4001_FF00 - * | Ethernet Addresses | 0x78 - * +-----------------------+ 0x4001_FF78 - * | (Reserved for MON8xx) | 0x44 - * +-----------------------+ 0x4001_FFBC - * | Lock Address | 0x04 - * +-----------------------+ 0x4001_FFC0 ^ - * | Hardware Information | 0x40 | MON8xx - * +=======================+ 0x4002_0000 (sector border) ----------------- - * | Autostart Header | | Applications - * | ... | v - * - *****************************************************************************/ diff --git a/configs/OCRTC_defconfig b/configs/OCRTC_defconfig deleted file mode 100644 index f2fd0c5..0000000 --- a/configs/OCRTC_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_OCRTC=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index d8bb3aa..0b449d1 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +OCRTC ppc4xx 405gpr - - Matthias Fuchs matthias.fuchs@esd.eu HUB405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu HH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu DU440 ppc4xx 440epx - - Matthias Fuchs matthias.fuchs@esd.eu diff --git a/include/configs/OCRTC.h b/include/configs/OCRTC.h deleted file mode 100644 index 4680afe..0000000 --- a/include/configs/OCRTC.h +++ /dev/null @@ -1,285 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405GP 1 /* This is a PPC405 CPU */ -#define CONFIG_OCRTC 1 /* ...on a OCRTC board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFD0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ - -#define CONFIG_SYS_CLK_FREQ 33000000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND "go fff00100" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_ELF -#define CONFIG_CMD_BSP -#define CONFIG_CMD_EEPROM - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_BOOTDELAY 1 /* enable pci bootdelay variable*/ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0x0410 /* PCI Device ID: OCRTC */ -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CONFIG_SYS_PCI_PTM1LA 0x00000000 /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS 0xfc000001 /* 64MB, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFD0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (192 * 1024) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#if 0 /* Use NVRAM for environment variables */ -/*----------------------------------------------------------------------- - * NVRAM organization - */ -#define CONFIG_ENV_IS_IN_NVRAM 1 /* use NVRAM for environment vars */ -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xf0200000 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE (32*1024) /* NVRAM size */ -#define CONFIG_ENV_SIZE 0x1000 /* Size of Environment vars */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_NVRAM_BASE_ADDR+CONFIG_SYS_NVRAM_SIZE-CONFIG_ENV_SIZE) /* Env */ -#define CONFIG_SYS_NVRAM_VXWORKS_OFFS 0x6900 /* Offset for VxWorks eth-addr */ - -#else /* Use EEPROM for environment variables */ - -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x300 /* 768 bytes may be used for env vars */ - /* total size of a CAT24WC08 is 1024 bytes */ -#endif - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC08) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF800000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0xFFC00000 /* FLASH bank #1 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (Flash Bank 1) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR 0xFF85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 2 (PLD - FPGA-boot) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x02015480 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x0,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 3 (PLD - OSL) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x02015480 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x0,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB3CR 0xF0118000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 4 (Spartan2 1) initialization */ -#define CONFIG_SYS_EBC_PB4AP 0x02015580 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x1,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB4CR 0xF209C000 /* BAS=0xF20,BS=16MB,BU=R/W,BW=32bit*/ - -/* Memory Bank 5 (Spartan2 2) initialization */ -#define CONFIG_SYS_EBC_PB5AP 0x02015580 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x1,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB5CR 0xF309C000 /* BAS=0xF30,BS=16MB,BU=R/W,BW=32bit*/ - -/* Memory Bank 6 (Virtex 1) initialization */ -#define CONFIG_SYS_EBC_PB6AP 0x02015580 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x1,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB6CR 0xF409A000 /* BAS=0xF40,BS=16MB,BU=R/W,BW=16bit*/ - -/* Memory Bank 7 (Virtex 2) initialization */ -#define CONFIG_SYS_EBC_PB7AP 0x02015580 /* BME=0x0,TWT=0x04,CSN=0x0,OEN=0x1 */ - /* WBN=0x1,WBF=0x1,TH=0x2,RE=0x1,SOR=0x1,BEM=0x0,PEN=0x0*/ -#define CONFIG_SYS_EBC_PB7CR 0xF509A000 /* BAS=0xF50,BS=16MB,BU=R/W,BW=16bit*/ - - -#define CONFIG_SYS_VXWORKS_MAC_PTR 0x00000000 /* Pass Ethernet MAC to VxWorks */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ - -/* use on chip memory ( OCM ) for temperary stack until sdram is tested */ -#define CONFIG_SYS_TEMP_STACK_OCM 1 - -/* On Chip Memory location */ -#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 -#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 - -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#endif /* __CONFIG_H */
Matthias Fuchs
