[PATCH 0/3] Add support for the GST ESPRESSOBin-Ultra board
This patchset adds initial support for the ESPRESSOBin-Ultra board from Globalscale Technologies, Inc.
The board is based on the 64-bit dual-core Marvell Armada 3720 SoC. Peripherals: - 5 Gigabit Ethernet ports (WAN has PoE, up to 30W, Topaz 6341 switch) - RTC clock (PCF8563) - USB 3.0 port - USB 2.0 port - 4x LED - UART over Micro-USB - M.2 slot (2280) - Mini PCI-E slot
Additionally support for importing Marvell hw_info formatted environments is added to fully support the board.
Luka Kovacic (3): cmd: env: Add 'env import -h' for Marvell hw_info formatted environments arm: mvebu: mvebu_armada-37xx: Define the loadaddr environment variable arm: mvebu: Initial ESPRESSOBin-Ultra board support
arch/arm/dts/Makefile | 1 + .../arm/dts/armada-3720-espressobin-ultra.dts | 202 ++++++++++++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 8 + board/Marvell/mvebu_armada-37xx/board.c | 76 ++++++- cmd/nvedit.c | 22 +- .../mvebu_espressobin-ultra-88f3720_defconfig | 90 ++++++++ include/configs/mvebu_armada-37xx.h | 1 + lib/hashtable.c | 2 +- 8 files changed, 391 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts create mode 100644 configs/mvebu_espressobin-ultra-88f3720_defconfig
The '-h' flag is added to the 'env import' command to enable parsing Marvell hw_info formatted environments. This format is often used on Marvell Armada A37XX based devices to store parameters like the board serial number, factory MAC addresses and some other information.
Currently this environment format can only be imported, not exported. These parameters are usually written to the flash in the factory.
This functionality has been tested on the GST ESPRESSOBin-Ultra board successfully.
Usage example: => sf probe => sf read ${loadaddr} 0x003E000A 0x1F0 # Read the environment from SPI flash => env import -h ${loadaddr}
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr --- cmd/nvedit.c | 22 ++++++++++++++++++---- lib/hashtable.c | 2 +- 2 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index d0d2eca904..eab490ac48 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -1060,7 +1060,7 @@ sep_err:
#ifdef CONFIG_CMD_IMPORTENV /* - * env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] + * env import [-d] [-t [-r] | -b | -h | -c] addr [size] [var ...] * -d: delete existing environment before importing if no var is * passed; if vars are passed, if one var is in the current * environment but not in the environment at addr, delete var from @@ -1073,6 +1073,7 @@ sep_err: * to import text files created with editors which are using CRLF * for line endings. Only effective in addition to -t. * -b: assume binary format ('\0' separated, "\0\0" terminated) + * -h: assume Marvell hw_info format (0x20 separated, "0x20\0" terminated) * -c: assume checksum protected environment format * addr: memory address to read from * size: length of input data; if missing, proper '\0' @@ -1082,6 +1083,14 @@ sep_err: * var... List of the names of the only variables that get imported from * the environment at address 'addr'. Without arguments, the whole * environment gets imported. + * + * Using the "-h" flag you can import a Marvell hw_info formatted environment. + * This is commonly used on Marvell Armada A37XX devices to store the board serial + * number, MAC addresses and some other information. + * Currently you can only import these by loading the data into memory and parse it + * using this command. Exporting is currently not supported, due to tight memory + * restrictions and a strict formatting scheme. + * These parameters are usually populated in the factory. */ static int do_env_import(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -1107,6 +1116,11 @@ static int do_env_import(struct cmd_tbl *cmdtp, int flag, goto sep_err; sep = '\0'; break; + case 'h': /* Marvell hw_info format */ + if (fmt++) + goto sep_err; + sep = 0x20; + break; case 'c': /* external checksum format */ if (fmt++) goto sep_err; @@ -1199,8 +1213,8 @@ static int do_env_import(struct cmd_tbl *cmdtp, int flag, return 0;
sep_err: - printf("## %s: only one of "-b", "-c" or "-t" allowed\n", - cmd); + printf("## %s: only one of "-b", "-h", "-c" or "-t" allowed\n", + cmd); return 1; } #endif @@ -1450,7 +1464,7 @@ static char env_help_text[] = #endif #endif #if defined(CONFIG_CMD_IMPORTENV) - "env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment\n" + "env import [-d] [-t [-r] | -b | -h | -c] addr [size] [var ...] - import environment\n" #endif #if defined(CONFIG_CMD_NVEDIT_INFO) "env info - display environment information\n" diff --git a/lib/hashtable.c b/lib/hashtable.c index ff5ff72639..06322e3304 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -794,7 +794,7 @@ static int drop_var_from_set(const char *name, int nvars, char * vars[]) * multi-line values. * * In theory, arbitrary separator characters can be used, but only - * '\0' and '\n' have really been tested. + * '\0', '\n' and 0x20 have been tested. */
int himport_r(struct hsearch_data *htab,
So, the implementation itself is fine:
And I take it as a given that we can't get the boards populated with an existing separator, so we need to solve this somehow or another. I am however loathe to increase every platform by a handful of bytes (help text, code text) to cover this case, and adding #ifdef around the help text in particular would be very ugly. Is there any clean way to write this as a board-specific command? I assume the overall intention is to import the factory env for the required information, store it in regular U-Boot environment and then never touch the factory area again. Thanks!
Hello Tom,
I have already considered the possibility of implementing this in a board-specific way, but I tried implementing it here to avoid unnecessary code duplication. You are correct, the intention is to use this functionality as a migration path. It's good to keep the factory area intact, in case it's still needed in the future. The Marvell hw_info area is limited to MACs and serial numbers by the stock utility.
I've also compared the resulting u-boot.bin binary size with and without the patch and the difference is about 40 bytes.
-- Tom
Kind regards, Luka
On Fri, Feb 05, 2021 at 11:02:23PM +0100, Luka Kovacic wrote:
Hello Tom,
OK. And can we put this in the board-specific path somehow, relatively cleanly?
Yes, but it's 40 bytes on nearly every single platform.
Hello Tom,
I've been thinking about the following options: - Implementing a separate command under cmd/mvebu (hw_info), like done in the stock U-Boot. I'm not inclined to this one, as I don't see real utility in updating this factory area. A positive with this one is that it abstracts reading of the SPI flash.
- No command, automatic migration, directly from the SPI flash (implemented in the board.c file. I don't see this as a clean way of doing it, the Armada A37XX board.c is already quite full of board-specific init.
- Implemented as is, but with #ifdef This would break CONFIG_CMD_IMPORTENV into smaller pieces. #ifdef wouldn't look too bad around the code, only the inline string changes would be ugly.
What would you recommend?
-- Tom
Kind regards, Luka
Hello Tom,
I hate to say it but I prefer the first, especially if it ends up being like 50 lines of code or whatever to write the function and all that. Or the second option, if the first option really ends up being messy once you write it and the second one less messy. Thanks!
Hello Tom,
Okay, I agree.
I think the first option should end up cleaner than both other options. I'll do it this way.
-- Tom
Kind regards, Luka
Hello Tom,
> The '-h' flag is added to the 'env import' command to enable parsing > Marvell hw_info formatted environments. > This format is often used on Marvell Armada A37XX based devices to store > parameters like the board serial number, factory MAC addresses and some > other information. > > Currently this environment format can only be imported, not exported. > These parameters are usually written to the flash in the factory. > > This functionality has been tested on the GST ESPRESSOBin-Ultra board > successfully. > > Usage example: > => sf probe > => sf read ${loadaddr} 0x003E000A 0x1F0 # Read the environment from > SPI flash > => env import -h ${loadaddr} > > Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr > Cc: Luka Perkov luka.perkov@sartura.hr > Cc: Robert Marko robert.marko@sartura.hr
Okay, I agree.
Ok. Please rebase on latest mainline and send v2 once it's ready.
Thanks, Stefan
Add the loadaddr U-Boot environment variable, as this is available in the stock Marvell U-Boot by default on Marvell Armada A37XX platforms.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr --- include/configs/mvebu_armada-37xx.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 0d585606a7..6da82078a4 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -89,6 +89,7 @@
/* fdt_addr and kernel_addr are needed for existing distribution boot scripts */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x6000000\0" \ "scriptaddr=0x6d00000\0" \ "pxefile_addr_r=0x6e00000\0" \ "fdt_addr=0x6f00000\0" \
Add initial support for the ESPRESSOBin-Ultra board from Globalscale Technologies, Inc.
Additionally, automatic import of the Marvell hw_info parameters is enabled via the recently added env import -h flag. The parameters stored in Marvell hw_info are usually the board serial number and MAC addresses.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr --- arch/arm/dts/Makefile | 1 + .../arm/dts/armada-3720-espressobin-ultra.dts | 202 ++++++++++++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 8 + board/Marvell/mvebu_armada-37xx/board.c | 76 ++++++- .../mvebu_espressobin-ultra-88f3720_defconfig | 90 ++++++++ 5 files changed, 371 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts create mode 100644 configs/mvebu_espressobin-ultra-88f3720_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 858b79ac97..51455c0271 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -210,6 +210,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ + armada-3720-espressobin-ultra.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ diff --git a/arch/arm/dts/armada-3720-espressobin-ultra.dts b/arch/arm/dts/armada-3720-espressobin-ultra.dts new file mode 100644 index 0000000000..70f97fe239 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-ultra.dts @@ -0,0 +1,202 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for ESPRESSObin-Ultra board + * Copyright (C) 2016 Marvell + * Copyright (C) 2019 Globalscale technologies, Inc. + * Copyright (C) 2020 Sartura Ltd. + * + * Author: Jason Hung jhung@globalscaletechnologies.com + * Author: Luka Kovacic luka.kovacic@sartura.hr + * Author: Vladimir Vid vladimir.vid@sartura.hr + */ + +/dts-v1/; + +#include "armada-372x.dtsi" + +/ { + model = "Globalscale Marvell ESPRESSOBin Ultra Board"; + compatible = "globalscale,espressobin-ultra", "marvell,armada3720", "marvell,armada3710"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + ethernet0 = ð0; + i2c0 = &i2c0; + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x20000000>; + }; + + vcc_sd_reg0: regulator@0 { + compatible = "regulator-gpio"; + regulator-name = "vcc_sd0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-type = "voltage"; + states = <1800000 0x1 + 3300000 0x0>; + gpios = <&gpionb 4 GPIO_ACTIVE_HIGH>; + }; + + gpio-leds { + pinctrl-names = "default"; + pinctrl-0 = <&led1_pins>, <&led2_pins>, <&led3_pins>, <&led4_pins>; + compatible = "gpio-leds"; + + led1 { + label = "led1"; + gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led2 { + label = "led2"; + gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led3 { + label = "led3"; + gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led4 { + label = "led4"; + gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + }; +}; + +&pinctrl_nb { + led1_pins: led1-pins { + groups = "pwm0"; + function = "gpio"; + }; + led2_pins: led2-pins { + groups = "pwm1"; + function = "gpio"; + }; + led3_pins: led3-pins { + groups = "pwm2"; + function = "gpio"; + }; + led4_pins: led4-pins { + groups = "pwm3"; + function = "gpio"; + }; +}; + +&comphy { + max-lanes = <3>; + phy0 { + phy-type = <PHY_TYPE_USB3_HOST0>; + phy-speed = <PHY_SPEED_5G>; + }; + + phy1 { + phy-type = <PHY_TYPE_PEX0>; + phy-speed = <PHY_SPEED_2_5G>; + }; + + phy2 { + phy-type = <PHY_TYPE_SATA0>; + phy-speed = <PHY_SPEED_5G>; + }; +}; + +ð0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>, <&smi_pins>; + phy-mode = "rgmii"; + phy_addr = <0x3>; + fixed-link { + speed = <1000>; + full-duplex; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&sata { + status = "okay"; +}; + +&sdhci0 { + status = "disabled"; +}; + +/* U11 */ +&sdhci1 { + non-removable; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + marvell,xenon-emmc; + marvell,xenon-tun-count = <9>; + marvell,pad-type = "fixed-1-8v"; + + pinctrl-names = "default"; + pinctrl-0 = <&mmc_pins>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + mmccard: mmccard@0 { + compatible = "mmc-card"; + reg = <0>; + }; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi_quad_pins>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p128", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <50000000>; + m25p,fast-read; + }; +}; + +/* Exported on the micro USB connector through an FTDI */ +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "okay"; +}; + +&usb2 { + status = "okay"; +}; + +&usb3 { + status = "okay"; +}; + +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pins>; + reset-gpios = <&gpiosb 3 GPIO_ACTIVE_LOW>; + status = "okay"; +}; diff --git a/board/Marvell/mvebu_armada-37xx/MAINTAINERS b/board/Marvell/mvebu_armada-37xx/MAINTAINERS index f2c0a582d7..d69af832fc 100644 --- a/board/Marvell/mvebu_armada-37xx/MAINTAINERS +++ b/board/Marvell/mvebu_armada-37xx/MAINTAINERS @@ -10,6 +10,14 @@ M: Konstantin Porotchkin kostap@marvell.com S: Maintained F: configs/mvebu_espressobin-88f3720_defconfig
+ESPRESSOBin-Ultra BOARD +M: Luka Kovacic luka.kovacic@sartura.hr +M: Robert Marko robert.marko@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr +S: Maintained +F: arch/arm/dts/armada-3720-espressobin-ultra.dts +F: configs/mvebu_espressobin-ultra-88f3720_defconfig + uDPU BOARD M: Vladimir Vid vladimir.vid@sartura.hr S: Maintained diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 1b9e7520cc..b92b7950e1 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <init.h> #include <mmc.h> +#include <miiphy.h> #include <phy.h> #include <asm/io.h> #include <asm/arch/cpu.h> @@ -53,6 +54,15 @@ DECLARE_GLOBAL_DATA_PTR; #define MVEBU_G2_SMI_PHY_CMD_REG (24) #define MVEBU_G2_SMI_PHY_DATA_REG (25)
+/* Marvell 88E1512 */ +#define MII_MARVELL_PHY_PAGE 22 + +#define MV88E1512_GENERAL_CTRL 20 +#define MV88E1512_MODE_SGMII 1 +#define MV88E1512_RESET_OFFS 15 + +#define ULTRA_MV88E1512_PHYADDR 0x1 + /* * Memory Controller Registers * @@ -258,12 +268,52 @@ static int mii_multi_chip_mode_write(struct mii_dev *bus, int dev_smi_addr, return 0; }
-/* Bring-up board-specific network stuff */ -int board_network_enable(struct mii_dev *bus) +void force_phy_88e1512_sgmii_to_copper(u16 devaddr) { - if (!of_machine_is_compatible("globalscale,espressobin")) - return 0; + const char *name; + u16 reg; + + name = miiphy_get_current_dev(); + if (name) { + /* SGMII-to-Copper mode initialization */ + + /* Select page 18 */ + miiphy_write(name, devaddr, MII_MARVELL_PHY_PAGE, 0x12); + /* In reg 20, write MODE[2:0] = 0x1 (SGMII to Copper) */ + miiphy_read(name, devaddr, MV88E1512_GENERAL_CTRL, ®); + reg &= ~0x7; + reg |= MV88E1512_MODE_SGMII; + miiphy_write(name, devaddr, MV88E1512_GENERAL_CTRL, reg); + /* PHY reset is necessary after changing MODE[2:0] */ + miiphy_read(name, devaddr, MV88E1512_GENERAL_CTRL, ®); + reg |= 1 << MV88E1512_RESET_OFFS; + miiphy_write(name, devaddr, MV88E1512_GENERAL_CTRL, reg); + /* Reset page selection */ + miiphy_write(name, devaddr, MII_MARVELL_PHY_PAGE, 0); + udelay(100); + } +} + +int board_network_enable_espressobin_ultra(struct mii_dev *bus) +{ + /* Setup 88E1512 SGMII-to-Copper mode */ + force_phy_88e1512_sgmii_to_copper(ULTRA_MV88E1512_PHYADDR);
+ /* Restrict output to ports 1,2,3,4 only from port 0 (CPU) */ + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(1), + MVEBU_SW_PORT_BASE_VLAN, BIT(0)); + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(2), + MVEBU_SW_PORT_BASE_VLAN, BIT(0)); + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(3), + MVEBU_SW_PORT_BASE_VLAN, BIT(0)); + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(4), + MVEBU_SW_PORT_BASE_VLAN, BIT(0)); + + return 0; +} + +int board_network_enable_espressobin(struct mii_dev *bus) +{ /* * FIXME: remove this code once Topaz driver gets available * A3720 Community Board Only @@ -304,6 +354,16 @@ int board_network_enable(struct mii_dev *bus) return 0; }
+/* Bring-up the board-specific networking */ +int board_network_enable(struct mii_dev *bus) +{ + if (of_machine_is_compatible("globalscale,espressobin")) + return board_network_enable_espressobin(bus); + if (of_machine_is_compatible("globalscale,espressobin-ultra")) + return board_network_enable_espressobin_ultra(bus); + return 0; +} + #if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) int ft_board_setup(void *blob, struct bd_info *bd) { @@ -312,8 +372,12 @@ int ft_board_setup(void *blob, struct bd_info *bd) int parts_off; int part_off;
- /* Fill SPI MTD partitions for Linux kernel on Espressobin */ - if (!of_machine_is_compatible("globalscale,espressobin")) + /* + * Fill SPI MTD partitions for the Linux kernel on ESPRESSOBin and + * ESPRESSOBin Ultra boards. + */ + if (!of_machine_is_compatible("globalscale,espressobin") && + !of_machine_is_compatible("globalscale,espressobin-ultra")) return 0;
spi_off = fdt_node_offset_by_compatible(blob, -1, "jedec,spi-nor"); diff --git a/configs/mvebu_espressobin-ultra-88f3720_defconfig b/configs/mvebu_espressobin-ultra-88f3720_defconfig new file mode 100644 index 0000000000..e40e280d62 --- /dev/null +++ b/configs/mvebu_espressobin-ultra-88f3720_defconfig @@ -0,0 +1,90 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3F0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_DEFAULT_DEVICE_TREE="armada-3720-espressobin-ultra" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_HUSH_PARSER=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="if printenv read_board_hw_info; then echo "Marvell hw_info already imported..." ; else echo "Importing Marvell hw_info..."; sf probe; sf read ${loadaddr} 0x003E000A 0x1F0; env import -h ${loadaddr}; setenv read_board_hw_info 1; fi" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_AHCI_MVEBU=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PHY_MARVELL=y +CONFIG_MVNETA=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_AARDVARK=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_37XX=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_MVEBU_A3700_UART=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_SHA1=y +CONFIG_SHA256=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y +CONFIG_LED=y +CONFIG_LED_GPIO=y
Luka Kovacic
Stefan Roese
