[U-Boot-Users] Pull request u-boot-blackfin.git
This should get the Blackfin port building/running fine with mainline u-boot and a bunch of cleanups in the process. More/bigger things to come ...
The following changes since commit 2c5260f711168d5ee91c70ddbb7d897013eefc46: Ladislav Michl (1): ARM: AT91RM9200 based boards config cleanup
git://www.denx.de/git/u-boot-blackfin.git master
Mike Frysinger (21): add gitignores for Blackfin pieces fix building on Blackfin as the assembler supports the .set syntax, not the = syntax, for assigning symbols make smc91111_eeprom managment simpler by depending on the board configuration file rather than a hardcoded list of boards add some more Blackfin docs add the default Blackfin logo used by Blackfin boards with splash screens add missing __raw versions of Blackfin read/write io functions always pull in asm/blackfin.h for Blackfin ports punt Blackfin VDSP headers and import sanitized/auto-generated ones unify the Blackfin board targets move -ffixed-P5 to blackfin_config.mk and drop unused -D__BLACKFIN__ add Blackfin-specific bdinfo command add support for Blackfin symbol prefixes to examples add Blackfin-specific reginfo command use C code rather than inline assembly add support for memory commands with Blackfin L1 instruction memory interface to Blackfin on-chip One-Time-Programmable memory move Blackfin cpu object list to respective cpu directories scrub unused symbols generate u-boot.ldr for Blackfin targets rewrite/cleanup Blackfin RTC driver new command for displaying strings at specified memory locations
.gitignore | 4 + Makefile | 47 +- README | 5 + blackfin_config.mk | 10 +- board/bf533-ezkit/.gitignore | 1 + board/bf533-ezkit/flash.c | 8 +- board/bf533-stamp/.gitignore | 1 + board/bf533-stamp/bf533-stamp.c | 32 +- board/bf533-stamp/spi.c | 39 +- board/bf537-stamp/.gitignore | 1 + board/bf537-stamp/bf537-stamp.c | 9 +- board/bf537-stamp/ether_bf537.c | 6 +- board/bf537-stamp/flash.c | 2 +- board/bf537-stamp/nand.c | 4 +- board/bf537-stamp/post-memory.c | 18 +- board/bf537-stamp/stm_m25p64.c | 43 +- board/bf561-ezkit/.gitignore | 1 + board/bf561-ezkit/bf561-ezkit.c | 4 +- common/Makefile | 2 + common/cmd_bdinfo.c | 31 + common/cmd_mem.c | 51 +- common/cmd_otp.c | 163 + common/cmd_reginfo.c | 45 +- common/cmd_strings.c | 49 + common/environment.c | 7 +- config.mk | 1 + cpu/bf533/Makefile | 4 +- cpu/bf533/bf533_serial.h | 4 +- cpu/bf533/cache.S | 3 +- cpu/bf533/config.mk | 2 +- cpu/bf533/cpu.c | 26 +- cpu/bf533/init_sdram.S | 4 + cpu/bf533/init_sdram_bootrom_initblock.S | 4 + cpu/bf533/interrupt.S | 12 +- cpu/bf533/interrupts.c | 4 - cpu/bf533/ints.c | 37 +- cpu/bf533/serial.c | 47 +- cpu/bf533/start.S | 27 +- cpu/bf533/traps.c | 25 +- cpu/bf537/Makefile | 4 +- cpu/bf537/cache.S | 1 + cpu/bf537/config.mk | 2 +- cpu/bf537/cpu.c | 26 +- cpu/bf537/i2c.c | 45 +- cpu/bf537/init_sdram.S | 4 + cpu/bf537/init_sdram_bootrom_initblock.S | 4 + cpu/bf537/interrupt.S | 12 +- cpu/bf537/interrupts.c | 4 - cpu/bf537/ints.c | 37 +- cpu/bf537/serial.c | 57 +- cpu/bf537/serial.h | 4 +- cpu/bf537/start.S | 31 +- cpu/bf537/traps.c | 25 +- cpu/bf561/Makefile | 4 +- cpu/bf561/cache.S | 1 + cpu/bf561/config.mk | 2 +- cpu/bf561/cpu.c | 26 +- cpu/bf561/init_sdram.S | 4 + cpu/bf561/init_sdram_bootrom_initblock.S | 4 + cpu/bf561/interrupt.S | 12 +- cpu/bf561/interrupts.c | 4 - cpu/bf561/ints.c | 37 +- cpu/bf561/serial.c | 47 +- cpu/bf561/serial.h | 4 +- cpu/bf561/start.S | 58 +- cpu/bf561/traps.c | 25 +- doc/README.blackfin | 46 + doc/README.standalone | 21 +- drivers/rtc/Makefile | 2 +- drivers/rtc/bf5xx_rtc.c | 143 - drivers/rtc/bfin_rtc.c | 117 + examples/.gitignore | 1 + examples/Makefile | 8 +- examples/smc91111_eeprom | Bin 0 -> 13643 bytes examples/smc91111_eeprom.c | 31 +- include/.gitignore | 1 + include/asm-blackfin/arch-bf533/anomaly.h | 172 - include/asm-blackfin/arch-bf533/bf533_serial.h | 78 - include/asm-blackfin/arch-bf533/bf5xx_rtc.h | 46 - include/asm-blackfin/arch-bf533/cdefBF531.h | 24 - include/asm-blackfin/arch-bf533/cdefBF532.h | 398 -- include/asm-blackfin/arch-bf533/cdefBF533.h | 24 - include/asm-blackfin/arch-bf533/defBF531.h | 24 - include/asm-blackfin/arch-bf533/defBF532.h | 1159 ---- include/asm-blackfin/arch-bf533/defBF533.h | 24 - include/asm-blackfin/arch-bf533/defBF533_extn.h | 77 - include/asm-blackfin/arch-bf533/irq.h | 137 - include/asm-blackfin/arch-bf537/anomaly.h | 116 - include/asm-blackfin/arch-bf537/bf537_serial.h | 78 - include/asm-blackfin/arch-bf537/bf5xx_rtc.h | 46 - include/asm-blackfin/arch-bf537/cdefBF534.h | 1009 ---- include/asm-blackfin/arch-bf537/cdefBF537.h | 186 - include/asm-blackfin/arch-bf537/defBF534.h | 2627 --------- include/asm-blackfin/arch-bf537/defBF537.h | 488 -- include/asm-blackfin/arch-bf537/defBF537_extn.h | 76 - include/asm-blackfin/arch-bf537/irq.h | 94 - include/asm-blackfin/arch-bf561/anomaly.h | 181 - include/asm-blackfin/arch-bf561/bf561_serial.h | 78 - include/asm-blackfin/arch-bf561/cdefBF561.h | 998 ---- include/asm-blackfin/arch-bf561/defBF561.h | 1941 ------- include/asm-blackfin/arch-bf561/defBF561_extn.h | 76 - include/asm-blackfin/arch-bf561/irq.h | 137 - include/asm-blackfin/arch-common/bf53x_rtc.h | 46 - include/asm-blackfin/arch-common/cdefBF5xx.h | 40 - include/asm-blackfin/arch-common/cdef_LPBlackfin.h | 160 - include/asm-blackfin/arch-common/def_LPBlackfin.h | 445 -- include/asm-blackfin/bfin_logo_230x230.h | 2377 ++++++++ include/asm-blackfin/bitops.h | 32 +- include/asm-blackfin/blackfin-config-post.h | 72 + include/asm-blackfin/blackfin-config-pre.h | 40 + include/asm-blackfin/blackfin.h | 45 +- include/asm-blackfin/blackfin_cdef.h | 67 + include/asm-blackfin/blackfin_def.h | 105 + include/asm-blackfin/blackfin_defs.h | 83 - include/asm-blackfin/blackfin_local.h | 215 + include/asm-blackfin/cplb.h | 47 +- include/asm-blackfin/current.h | 40 - include/asm-blackfin/entry.h | 133 +- include/asm-blackfin/global_data.h | 2 - include/asm-blackfin/hw_irq.h | 43 - include/asm-blackfin/io-kernel.h | 138 - include/asm-blackfin/io.h | 99 +- include/asm-blackfin/irq.h | 142 - include/asm-blackfin/linkage.h | 18 +- .../mach-bf527/ADSP-EDN-BF52x-extended_cdef.h | 1507 +++++ .../mach-bf527/ADSP-EDN-BF52x-extended_def.h | 509 ++ include/asm-blackfin/mach-bf527/BF522_cdef.h | 344 ++ include/asm-blackfin/mach-bf527/BF522_def.h | 139 + include/asm-blackfin/mach-bf527/BF523_cdef.h | 344 ++ include/asm-blackfin/mach-bf527/BF523_def.h | 139 + include/asm-blackfin/mach-bf527/BF524_cdef.h | 851 +++ include/asm-blackfin/mach-bf527/BF524_def.h | 308 + include/asm-blackfin/mach-bf527/BF525_cdef.h | 851 +++ include/asm-blackfin/mach-bf527/BF525_def.h | 308 + include/asm-blackfin/mach-bf527/BF526_cdef.h | 1088 ++++ include/asm-blackfin/mach-bf527/BF526_def.h | 387 ++ include/asm-blackfin/mach-bf527/BF527_cdef.h | 1088 ++++ include/asm-blackfin/mach-bf527/BF527_def.h | 387 ++ include/asm-blackfin/mach-bf527/anomaly.h | 55 + include/asm-blackfin/mach-bf527/def_local.h | 1 + include/asm-blackfin/mach-bf527/ports.h | 127 + include/asm-blackfin/mach-bf533/BF531_cdef.h | 14 + include/asm-blackfin/mach-bf533/BF531_def.h | 23 + include/asm-blackfin/mach-bf533/BF532_cdef.h | 14 + include/asm-blackfin/mach-bf533/BF532_def.h | 23 + include/asm-blackfin/mach-bf533/BF533_cdef.h | 14 + include/asm-blackfin/mach-bf533/BF533_def.h | 29 + include/asm-blackfin/mach-bf533/anomaly.h | 263 + include/asm-blackfin/mach-bf533/def_local.h | 1 + include/asm-blackfin/mach-bf533/ports.h | 26 + .../mach-bf537/ADSP-EDN-BF534-extended_cdef.h | 2755 +++++++++ .../mach-bf537/ADSP-EDN-BF534-extended_def.h | 925 +++ include/asm-blackfin/mach-bf537/BF534_cdef.h | 14 + include/asm-blackfin/mach-bf537/BF534_def.h | 29 + include/asm-blackfin/mach-bf537/BF536_cdef.h | 251 + include/asm-blackfin/mach-bf537/BF536_def.h | 102 + include/asm-blackfin/mach-bf537/BF537_cdef.h | 251 + include/asm-blackfin/mach-bf537/BF537_def.h | 108 + include/asm-blackfin/mach-bf537/anomaly.h | 152 + include/asm-blackfin/mach-bf537/def_local.h | 1 + include/asm-blackfin/mach-bf537/ports.h | 78 + .../mach-bf548/ADSP-EDN-BF542-extended_cdef.h | 4381 ++++++++++++++ .../mach-bf548/ADSP-EDN-BF542-extended_def.h | 1467 +++++ .../mach-bf548/ADSP-EDN-BF544-extended_cdef.h | 4975 ++++++++++++++++ .../mach-bf548/ADSP-EDN-BF544-extended_def.h | 1665 ++++++ .../mach-bf548/ADSP-EDN-BF547-extended_cdef.h | 3619 ++++++++++++ .../mach-bf548/ADSP-EDN-BF547-extended_def.h | 1213 ++++ .../mach-bf548/ADSP-EDN-BF548-extended_cdef.h | 5791 ++++++++++++++++++ .../mach-bf548/ADSP-EDN-BF548-extended_def.h | 1937 ++++++ .../mach-bf548/ADSP-EDN-BF549-extended_cdef.h | 6139 ++++++++++++++++++++ .../mach-bf548/ADSP-EDN-BF549-extended_def.h | 2053 +++++++ include/asm-blackfin/mach-bf548/BF541_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF541_def.h | 118 + include/asm-blackfin/mach-bf548/BF542_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF542_def.h | 133 + include/asm-blackfin/mach-bf548/BF544_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF544_def.h | 133 + include/asm-blackfin/mach-bf548/BF547_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF547_def.h | 127 + include/asm-blackfin/mach-bf548/BF548_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF548_def.h | 133 + include/asm-blackfin/mach-bf548/BF549_cdef.h | 326 ++ include/asm-blackfin/mach-bf548/BF549_def.h | 133 + include/asm-blackfin/mach-bf548/anomaly.h | 99 + include/asm-blackfin/mach-bf548/def_local.h | 1 + include/asm-blackfin/mach-bf548/ports.h | 257 + include/asm-blackfin/mach-bf561/BF561_cdef.h | 470 ++ include/asm-blackfin/mach-bf561/BF561_def.h | 175 + include/asm-blackfin/mach-bf561/anomaly.h | 270 + include/asm-blackfin/mach-bf561/def_local.h | 10 + .../mach-common/ADSP-EDN-DUAL-CORE-extended_cdef.h | 1990 +++++++ .../mach-common/ADSP-EDN-DUAL-CORE-extended_def.h | 670 +++ .../asm-blackfin/mach-common/ADSP-EDN-core_cdef.h | 67 + .../asm-blackfin/mach-common/ADSP-EDN-core_def.h | 29 + .../mach-common/ADSP-EDN-extended_cdef.h | 1612 +++++ .../mach-common/ADSP-EDN-extended_def.h | 544 ++ include/asm-blackfin/mach-common/bits/bootrom.h | 218 + include/asm-blackfin/mach-common/bits/core.h | 109 + include/asm-blackfin/mach-common/bits/dma.h | 58 + include/asm-blackfin/mach-common/bits/ebiu.h | 421 ++ include/asm-blackfin/mach-common/bits/emac.h | 220 + include/asm-blackfin/mach-common/bits/eppi.h | 70 + include/asm-blackfin/mach-common/bits/lockbox.h | 62 + include/asm-blackfin/mach-common/bits/mpu.h | 116 + include/asm-blackfin/mach-common/bits/otp.h | 72 + include/asm-blackfin/mach-common/bits/pll.h | 96 + include/asm-blackfin/mach-common/bits/ppi.h | 38 + include/asm-blackfin/mach-common/bits/rtc.h | 42 + include/asm-blackfin/mach-common/bits/spi.h | 67 + include/asm-blackfin/mach-common/bits/sport.h | 89 + include/asm-blackfin/mach-common/bits/timer.h | 78 + include/asm-blackfin/mach-common/bits/trace.h | 19 + include/asm-blackfin/mach-common/bits/twi.h | 77 + include/asm-blackfin/mach-common/bits/uart.h | 98 + include/asm-blackfin/mach-common/bits/watchdog.h | 19 + include/asm-blackfin/machdep.h | 90 - include/asm-blackfin/page_offset.h | 35 - include/asm-blackfin/posix_types.h | 3 + include/asm-blackfin/processor.h | 140 +- include/asm-blackfin/segment.h | 46 - include/asm-blackfin/setup.h | 87 - include/asm-blackfin/string.h | 1 - include/asm-blackfin/system.h | 167 +- include/asm-blackfin/u-boot.h | 10 +- include/asm-blackfin/uaccess.h | 205 - include/asm-blackfin/virtconvert.h | 46 - include/common.h | 3 + lib_blackfin/bf533_string.c | 23 +- lib_blackfin/cache.c | 6 +- tools/easylogo/linux_blackfin.tga | Bin 0 -> 158718 bytes 230 files changed, 61691 insertions(+), 13133 deletions(-) create mode 100644 board/bf533-ezkit/.gitignore create mode 100644 board/bf533-stamp/.gitignore create mode 100644 board/bf537-stamp/.gitignore create mode 100644 board/bf561-ezkit/.gitignore create mode 100644 common/cmd_otp.c create mode 100644 common/cmd_strings.c create mode 100644 doc/README.blackfin delete mode 100644 drivers/rtc/bf5xx_rtc.c create mode 100644 drivers/rtc/bfin_rtc.c create mode 100755 examples/smc91111_eeprom delete mode 100644 include/asm-blackfin/arch-bf533/anomaly.h delete mode 100644 include/asm-blackfin/arch-bf533/bf533_serial.h delete mode 100644 include/asm-blackfin/arch-bf533/bf5xx_rtc.h delete mode 100644 include/asm-blackfin/arch-bf533/cdefBF531.h delete mode 100644 include/asm-blackfin/arch-bf533/cdefBF532.h delete mode 100644 include/asm-blackfin/arch-bf533/cdefBF533.h delete mode 100644 include/asm-blackfin/arch-bf533/defBF531.h delete mode 100644 include/asm-blackfin/arch-bf533/defBF532.h delete mode 100644 include/asm-blackfin/arch-bf533/defBF533.h delete mode 100644 include/asm-blackfin/arch-bf533/defBF533_extn.h delete mode 100644 include/asm-blackfin/arch-bf533/irq.h delete mode 100644 include/asm-blackfin/arch-bf537/anomaly.h delete mode 100644 include/asm-blackfin/arch-bf537/bf537_serial.h delete mode 100644 include/asm-blackfin/arch-bf537/bf5xx_rtc.h delete mode 100644 include/asm-blackfin/arch-bf537/cdefBF534.h delete mode 100644 include/asm-blackfin/arch-bf537/cdefBF537.h delete mode 100644 include/asm-blackfin/arch-bf537/defBF534.h delete mode 100644 include/asm-blackfin/arch-bf537/defBF537.h delete mode 100644 include/asm-blackfin/arch-bf537/defBF537_extn.h delete mode 100644 include/asm-blackfin/arch-bf537/irq.h delete mode 100644 include/asm-blackfin/arch-bf561/anomaly.h delete mode 100644 include/asm-blackfin/arch-bf561/bf561_serial.h delete mode 100644 include/asm-blackfin/arch-bf561/cdefBF561.h delete mode 100644 include/asm-blackfin/arch-bf561/defBF561.h delete mode 100644 include/asm-blackfin/arch-bf561/defBF561_extn.h delete mode 100644 include/asm-blackfin/arch-bf561/irq.h delete mode 100644 include/asm-blackfin/arch-common/bf53x_rtc.h delete mode 100644 include/asm-blackfin/arch-common/cdefBF5xx.h delete mode 100644 include/asm-blackfin/arch-common/cdef_LPBlackfin.h delete mode 100644 include/asm-blackfin/arch-common/def_LPBlackfin.h create mode 100644 include/asm-blackfin/bfin_logo_230x230.h create mode 100644 include/asm-blackfin/blackfin-config-post.h create mode 100644 include/asm-blackfin/blackfin-config-pre.h create mode 100644 include/asm-blackfin/blackfin_cdef.h create mode 100644 include/asm-blackfin/blackfin_def.h delete mode 100644 include/asm-blackfin/blackfin_defs.h create mode 100644 include/asm-blackfin/blackfin_local.h delete mode 100644 include/asm-blackfin/current.h delete mode 100644 include/asm-blackfin/hw_irq.h delete mode 100644 include/asm-blackfin/io-kernel.h delete mode 100644 include/asm-blackfin/irq.h create mode 100644 include/asm-blackfin/mach-bf527/ADSP-EDN-BF52x-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/ADSP-EDN-BF52x-extended_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF522_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF522_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF523_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF523_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF524_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF524_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF525_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF525_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF526_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF526_def.h create mode 100644 include/asm-blackfin/mach-bf527/BF527_cdef.h create mode 100644 include/asm-blackfin/mach-bf527/BF527_def.h create mode 100644 include/asm-blackfin/mach-bf527/anomaly.h create mode 100644 include/asm-blackfin/mach-bf527/def_local.h create mode 100644 include/asm-blackfin/mach-bf527/ports.h create mode 100644 include/asm-blackfin/mach-bf533/BF531_cdef.h create mode 100644 include/asm-blackfin/mach-bf533/BF531_def.h create mode 100644 include/asm-blackfin/mach-bf533/BF532_cdef.h create mode 100644 include/asm-blackfin/mach-bf533/BF532_def.h create mode 100644 include/asm-blackfin/mach-bf533/BF533_cdef.h create mode 100644 include/asm-blackfin/mach-bf533/BF533_def.h create mode 100644 include/asm-blackfin/mach-bf533/anomaly.h create mode 100644 include/asm-blackfin/mach-bf533/def_local.h create mode 100644 include/asm-blackfin/mach-bf533/ports.h create mode 100644 include/asm-blackfin/mach-bf537/ADSP-EDN-BF534-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf537/ADSP-EDN-BF534-extended_def.h create mode 100644 include/asm-blackfin/mach-bf537/BF534_cdef.h create mode 100644 include/asm-blackfin/mach-bf537/BF534_def.h create mode 100644 include/asm-blackfin/mach-bf537/BF536_cdef.h create mode 100644 include/asm-blackfin/mach-bf537/BF536_def.h create mode 100644 include/asm-blackfin/mach-bf537/BF537_cdef.h create mode 100644 include/asm-blackfin/mach-bf537/BF537_def.h create mode 100644 include/asm-blackfin/mach-bf537/anomaly.h create mode 100644 include/asm-blackfin/mach-bf537/def_local.h create mode 100644 include/asm-blackfin/mach-bf537/ports.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF542-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF542-extended_def.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF544-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF544-extended_def.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF547-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF547-extended_def.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF548-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF548-extended_def.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF549-extended_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/ADSP-EDN-BF549-extended_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF541_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF541_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF542_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF542_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF544_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF544_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF547_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF547_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF548_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF548_def.h create mode 100644 include/asm-blackfin/mach-bf548/BF549_cdef.h create mode 100644 include/asm-blackfin/mach-bf548/BF549_def.h create mode 100644 include/asm-blackfin/mach-bf548/anomaly.h create mode 100644 include/asm-blackfin/mach-bf548/def_local.h create mode 100644 include/asm-blackfin/mach-bf548/ports.h create mode 100644 include/asm-blackfin/mach-bf561/BF561_cdef.h create mode 100644 include/asm-blackfin/mach-bf561/BF561_def.h create mode 100644 include/asm-blackfin/mach-bf561/anomaly.h create mode 100644 include/asm-blackfin/mach-bf561/def_local.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-DUAL-CORE-extended_cdef.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-DUAL-CORE-extended_def.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-core_cdef.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-core_def.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-extended_cdef.h create mode 100644 include/asm-blackfin/mach-common/ADSP-EDN-extended_def.h create mode 100644 include/asm-blackfin/mach-common/bits/bootrom.h create mode 100644 include/asm-blackfin/mach-common/bits/core.h create mode 100644 include/asm-blackfin/mach-common/bits/dma.h create mode 100644 include/asm-blackfin/mach-common/bits/ebiu.h create mode 100644 include/asm-blackfin/mach-common/bits/emac.h create mode 100644 include/asm-blackfin/mach-common/bits/eppi.h create mode 100644 include/asm-blackfin/mach-common/bits/lockbox.h create mode 100644 include/asm-blackfin/mach-common/bits/mpu.h create mode 100644 include/asm-blackfin/mach-common/bits/otp.h create mode 100644 include/asm-blackfin/mach-common/bits/pll.h create mode 100644 include/asm-blackfin/mach-common/bits/ppi.h create mode 100644 include/asm-blackfin/mach-common/bits/rtc.h create mode 100644 include/asm-blackfin/mach-common/bits/spi.h create mode 100644 include/asm-blackfin/mach-common/bits/sport.h create mode 100644 include/asm-blackfin/mach-common/bits/timer.h create mode 100644 include/asm-blackfin/mach-common/bits/trace.h create mode 100644 include/asm-blackfin/mach-common/bits/twi.h create mode 100644 include/asm-blackfin/mach-common/bits/uart.h create mode 100644 include/asm-blackfin/mach-common/bits/watchdog.h delete mode 100644 include/asm-blackfin/machdep.h delete mode 100644 include/asm-blackfin/page_offset.h delete mode 100644 include/asm-blackfin/segment.h delete mode 100644 include/asm-blackfin/setup.h delete mode 100644 include/asm-blackfin/uaccess.h delete mode 100644 include/asm-blackfin/virtconvert.h create mode 100644 tools/easylogo/linux_blackfin.tga
Done. Thanks!
Mike Frysinger
