[PATCH 1/1] efi_selftest: remove superfluous assignments
In test_hii_database_list_package_lists() 'ret' is used for the return code of EFI API calls and 'result' for the return value of the function. Writing EFI_ST_FAILURE to ret is superfluous.
Fixes: 4c4fb10da294 ("efi_selftest: add HII database protocols test") Fixes: ee3c8ba85525 ("efi_selftest: fix memory allocation in HII tests") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_selftest/efi_selftest_hii.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_hii.c b/lib/efi_selftest/efi_selftest_hii.c index f4b55889e2..f219c0120a 100644 --- a/lib/efi_selftest/efi_selftest_hii.c +++ b/lib/efi_selftest/efi_selftest_hii.c @@ -220,14 +220,12 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_BUFFER_TOO_SMALL) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->allocate_pool(EFI_LOADER_DATA, handles_size, (void **)&handles); if (ret != EFI_SUCCESS) { efi_st_error("AllocatePool failed\n"); - ret = EFI_ST_FAILURE; goto out; } ret = hii_database_protocol->list_package_lists(hii_database_protocol, @@ -236,7 +234,6 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_SUCCESS) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->free_pool(handles); @@ -254,14 +251,12 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_BUFFER_TOO_SMALL) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->allocate_pool(EFI_LOADER_DATA, handles_size, (void **)&handles); if (ret != EFI_SUCCESS) { efi_st_error("AllocatePool failed\n"); - ret = EFI_ST_FAILURE; goto out; } ret = hii_database_protocol->list_package_lists(hii_database_protocol, @@ -270,13 +265,11 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_SUCCESS) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->free_pool(handles); if (ret != EFI_SUCCESS) { efi_st_error("FreePool failed\n"); - ret = EFI_ST_FAILURE; goto out; }
@@ -289,14 +282,12 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_BUFFER_TOO_SMALL) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->allocate_pool(EFI_LOADER_DATA, handles_size, (void **)&handles); if (ret != EFI_SUCCESS) { efi_st_error("AllocatePool failed\n"); - ret = EFI_ST_FAILURE; goto out; } ret = hii_database_protocol->list_package_lists(hii_database_protocol, @@ -305,13 +296,11 @@ static int test_hii_database_list_package_lists(void) if (ret != EFI_SUCCESS) { efi_st_error("list_package_lists returned %u\n", (unsigned int)ret); - ret = EFI_ST_FAILURE; goto out; } ret = boottime->free_pool(handles); if (ret != EFI_SUCCESS) { efi_st_error("FreePool failed\n"); - ret = EFI_ST_FAILURE; goto out; }
On Sun, 30 Jul 2023 at 11:35, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
-- 2.40.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
