[PATCH v3 1/1] Makefile: pass -undef option to cmd_gen_envp
Without the '-undef' option, the 'linux' string in .env files is replaced with the string '1 '. For example, in the board/armadeus/opos6uldev/opos6uldev.env file,
kernelimg=opos6ul-linux.bin
becomes
kernelimg=opos6ul-1 .bin
in the include/generated/env.in file.
That's because 'linux' is a System-specific Predefined Macros. [1]
Pass the '-undef' option to fix this issue.
[1] https://gcc.gnu.org/onlinedocs/gcc-13.2.0/cpp/System-specific-Predefined-Mac...
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com ---
Changes for v3: - use -undef instead of ansi. With -undef, there is no need to modify iot2050.env and smegw01.env files anymore.
Changes for v2: - explain the change of iot2050.env and smegw01.env in the commit log
Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 3b5db90df6f9..63b006e0e0f1 100644 --- a/Makefile +++ b/Makefile @@ -1804,7 +1804,8 @@ ENV_FILE := $(if $(ENV_SOURCE_FILE),$(ENV_FILE_CFG),$(wildcard $(ENV_FILE_BOARD) quiet_cmd_gen_envp = ENVP $@ cmd_gen_envp = \ if [ -s "$(ENV_FILE)" ]; then \ - $(CPP) -P $(CFLAGS) -x assembler-with-cpp -D__ASSEMBLY__ \ + $(CPP) -P $(CFLAGS) -x assembler-with-cpp -undef \ + -D__ASSEMBLY__ \ -D__UBOOT_CONFIG__ \ -I . -I include -I $(srctree)/include \ -include linux/kconfig.h -include include/config.h \
becomes
becomes
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com Reviewed-by: Tom Rini trini@konsulko.com
Sébastien Szymanski
