[PATCH 1/2] sandbox: Initialize sysreset before relocation
Without this the early sysreset code cannot be tested.
Signed-off-by: Michal Suchanek msuchanek@suse.de ---
arch/sandbox/dts/sandbox.dtsi | 1 + arch/sandbox/dts/test.dts | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 56e6b38bfa..9e96ff12a1 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -239,6 +239,7 @@
reset@1 { compatible = "sandbox,reset"; + u-boot,dm-pre-reloc; };
rng { diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 2761588f0d..c59b118e96 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1119,10 +1119,12 @@
reset@0 { compatible = "sandbox,warm-reset"; + u-boot,dm-pre-reloc; };
resetc: reset-ctl {
Boards can have multiple sysresets, iterate all when printing sysreset info.
Also print the symbolic error when reporting sysreset failure.
Fixes: 23471aed5c ("board_f: Add reset status printing") Signed-off-by: Michal Suchanek msuchanek@suse.de ---
common/board_f.c | 31 +++++++++++++++++++------------ 1 file changed, 19 insertions(+), 12 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 18e2246733..0835b376bc 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -55,7 +55,7 @@ #include <asm/io.h> #include <asm/sections.h> #include <dm/root.h> -#include <linux/errno.h> +#include <errno.h>
/* * Pointer to initial global data area @@ -163,20 +163,27 @@ static int print_resetinfo(void) { struct udevice *dev; char status[256]; + bool first = true; int ret;
- ret = uclass_first_device_err(UCLASS_SYSRESET, &dev); - if (ret) { - debug("%s: No sysreset device found (error: %d)\n", - __func__, ret); - /* Not all boards have sysreset drivers available during early - * boot, so don't fail if one can't be found. - */ - return 0; - } + /* Not all boards have sysreset drivers available during early + * boot, so don't fail if one can't be found. + */ + for (ret = uclass_first_device_check(UCLASS_SYSRESET, &dev); dev; + ret = uclass_next_device_check(&dev)) { + if (ret) { + debug("%s: %s sysreset device (error: %d %s)\n", + __func__, dev->name, ret, errno_str(ret)); + continue; + }
- if (!sysreset_get_status(dev, status, sizeof(status))) - printf("%s", status); + if (!sysreset_get_status(dev, status, sizeof(status))) { + printf("%s%s", first ? "" : " ", status); + first = false; + } + } + if (!first) + printf("\n");
return 0; }
Please no
Michal Suchanek
