[U-Boot] [PATCH v3 03/12] x86: video: Add coreboot framebuffer support
Add a basic driver for the coreboot framebuffer.
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Update to avoid using gd which is now a #define
Changes in v2: None
drivers/video/Makefile | 1 + drivers/video/coreboot_fb.c | 101 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+), 0 deletions(-) create mode 100644 drivers/video/coreboot_fb.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index ebb6da8..cc3022a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_S6E8AX0) += s6e8ax0.o COBJS-$(CONFIG_S6E63D6) += s6e63d6.o COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_AMBA) += amba.o +COBJS-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o diff --git a/drivers/video/coreboot_fb.c b/drivers/video/coreboot_fb.c new file mode 100644 index 0000000..d93bd89 --- /dev/null +++ b/drivers/video/coreboot_fb.c @@ -0,0 +1,101 @@ +/* + * coreboot Framebuffer driver. + * + * Copyright (C) 2011 The Chromium OS authors + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/tables.h> +#include <asm/arch/sysinfo.h> +#include <video_fb.h> +#include "videomodes.h" + +/* + * The Graphic Device + */ +GraphicDevice ctfb; + +static int parse_coreboot_table_fb(GraphicDevice *gdev) +{ + struct cb_framebuffer *fb = lib_sysinfo.framebuffer; + + /* If there is no framebuffer structure, bail out and keep + * running on the serial console. + */ + if (!fb) + return 0; + + gdev->winSizeX = fb->x_resolution; + gdev->winSizeY = fb->y_resolution; + + gdev->plnSizeX = fb->x_resolution; + gdev->plnSizeY = fb->y_resolution; + + gdev->gdfBytesPP = fb->bits_per_pixel / 8; + + switch (fb->bits_per_pixel) { + case 24: + gdev->gdfIndex = GDF_32BIT_X888RGB; + break; + case 16: + gdev->gdfIndex = GDF_16BIT_565RGB; + break; + default: + gdev->gdfIndex = GDF__8BIT_INDEX; + break; + } + + gdev->isaBase = CONFIG_SYS_ISA_IO_BASE_ADDRESS; + gdev->pciBase = (unsigned int)fb->physical_address; + + gdev->frameAdrs = (unsigned int)fb->physical_address; + gdev->memSize = fb->bytes_per_line * fb->y_resolution; + + gdev->vprBase = (unsigned int)fb->physical_address; + gdev->cprBase = (unsigned int)fb->physical_address; + + return 1; +} + +void *video_hw_init(void) +{ + GraphicDevice *gdev = &ctfb; + int bits_per_pixel; + + printf("Video: "); + + if (!parse_coreboot_table_fb(gdev)) { + printf("No video mode configured in coreboot!\n"); + return NULL; + } + + bits_per_pixel = gdev->gdfBytesPP * 8; + + /* fill in Graphic device struct */ + sprintf(gdev->modeIdent, "%dx%dx%d", gdev->winSizeX, gdev->winSizeY, + bits_per_pixel); + printf("%s\n", gdev->modeIdent); + + memset((void *)gdev->pciBase, 0, + gdev->winSizeX * gdev->winSizeY * gdev->gdfBytesPP); + + return (void *)gdev; +}
