[PATCH 0/6] IPQ40xx: Improve support
This is a third patch series working towards providing a usable U-boot support for Qualcomm IPQ40xx SoC-s.
This patch series adds SPI driver so booting is finally possible, RNG driver for the built in pseudo RNG and MDIO driver to prepare for future ethernet support.
Booting Linux is now possible.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr
Robert Marko (6): spi: Add Qualcomm QUP SPI controller driver IPQ40xx: Add SPI support net: Add IPQ40xx MDIO driver IPQ40xx: Add support for MDIO rng: Add Qualcomm MSM PRNG driver IPQ40xx: Add PRNG support
MAINTAINERS | 3 + arch/arm/dts/qcom-ipq4019.dtsi | 47 ++ arch/arm/mach-ipq40xx/clock-ipq4019.c | 21 +- arch/arm/mach-ipq40xx/pinctrl-ipq4019.c | 7 + doc/device-tree-bindings/spi/spi-qup.txt | 33 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/mdio-ipq4019.c | 146 +++++ drivers/rng/Kconfig | 7 + drivers/rng/Makefile | 1 + drivers/rng/msm_rng.c | 143 ++++ drivers/spi/Kconfig | 10 + drivers/spi/Makefile | 1 + drivers/spi/spi-qup.c | 803 +++++++++++++++++++++++ 14 files changed, 1228 insertions(+), 2 deletions(-) create mode 100644 doc/device-tree-bindings/spi/spi-qup.txt create mode 100644 drivers/net/mdio-ipq4019.c create mode 100644 drivers/rng/msm_rng.c create mode 100644 drivers/spi/spi-qup.c
This patch adds support for the Qualcomm QUP SPI controller that is commonly found in most of Qualcomm SoC-s.
Driver currently supports v1.1.1, v2.1.1 and v2.2.1 HW. FIFO and Block modes are supported, no support for DMA mode is planned.
Signed-off-by: Robert Marko robert.marko@sartura.hr Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- MAINTAINERS | 1 + doc/device-tree-bindings/spi/spi-qup.txt | 33 + drivers/spi/Kconfig | 10 + drivers/spi/Makefile | 1 + drivers/spi/spi-qup.c | 803 +++++++++++++++++++++++ 5 files changed, 848 insertions(+) create mode 100644 doc/device-tree-bindings/spi/spi-qup.txt create mode 100644 drivers/spi/spi-qup.c
diff --git a/MAINTAINERS b/MAINTAINERS index ed5e354873..aa6cbb965d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -241,6 +241,7 @@ F: include/dt-bindings/clock/qcom,ipq4019-gcc.h F: include/dt-bindings/reset/qcom,ipq4019-reset.h F: drivers/reset/reset-ipq4019.c F: drivers/phy/phy-qcom-ipq4019-usb.c +F: drivers/spi/spi-qup.c
ARM MARVELL KIRKWOOD ARMADA-XP ARMADA-38X ARMADA-37XX ARMADA-7K/8K M: Stefan Roese sr@denx.de diff --git a/doc/device-tree-bindings/spi/spi-qup.txt b/doc/device-tree-bindings/spi/spi-qup.txt new file mode 100644 index 0000000000..3697df2631 --- /dev/null +++ b/doc/device-tree-bindings/spi/spi-qup.txt @@ -0,0 +1,33 @@ +Qualcomm QUP SPI controller Device Tree Bindings +------------------------------------------- + +Required properties: +- compatible : Should be "qcom,spi-qup-v1.1.1", "qcom,spi-qup-v2.1.1" + or "qcom,spi-qup-v2.2.1" +- reg : Physical base address and size of SPI registers map. +- clock : Clock phandle (see clock bindings for details). +- #address-cells : Number of cells required to define a chip select + address on the SPI bus. Should be set to 1. +- #size-cells : Should be zero. +- pinctrl-names : Must be "default" +- pinctrl-n : At least one pinctrl phandle +- cs-gpios : Should specify GPIOs used for chipselects. + The gpios will be referred to as reg = <index> in the + SPI child nodes. + +Optional properties: +- num-cs : total number of chipselects + +Example: + + blsp1_spi1: spi@78b5000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x78b5000 0x600>; + clock = <&gcc 23>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "spi"; + pinctrl-0 = <&blsp_spi0>; + num-cs = <2>; + cs-gpios = <&soc_gpios 54 GPIO_ACTIVE_HIGH>, <&soc_gpios 4 GPIO_ACTIVE_HIGH>; + }; diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 5df97c80fa..f7a9852565 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -271,6 +271,16 @@ config PL022_SPI controller. If you have an embedded system with an AMBA(R) bus and a PL022 controller, say Y or M here.
+config SPI_QUP + bool "Qualcomm SPI controller with QUP interface" + depends on ARCH_IPQ40XX + help + Qualcomm Universal Peripheral (QUP) core is an AHB slave that + provides a common data path (an output FIFO and an input FIFO) + for serial peripheral interface (SPI) mini-core. SPI in master + mode supports up to 50MHz, up to four chip selects, programmable + data path from 4 bits to 32 bits and numerous protocol variants. + config RENESAS_RPC_SPI bool "Renesas RPC SPI driver" depends on RCAR_GEN3 || RZA1 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index b5c9ff1af8..d9b5bd9b79 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_OCTEON_SPI) += octeon_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_PIC32_SPI) += pic32_spi.o obj-$(CONFIG_PL022_SPI) += pl022_spi.o +obj-$(CONFIG_SPI_QUP) += spi-qup.o obj-$(CONFIG_RENESAS_RPC_SPI) += renesas_rpc_spi.o obj-$(CONFIG_ROCKCHIP_SPI) += rk_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o diff --git a/drivers/spi/spi-qup.c b/drivers/spi/spi-qup.c new file mode 100644 index 0000000000..6f8df55fa5 --- /dev/null +++ b/drivers/spi/spi-qup.c @@ -0,0 +1,803 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Driver for Qualcomm QUP SPI controller + * FIFO and Block modes supported, no DMA + * mode support + * + * Copyright (c) 2020 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + * Author: Luka Kovacic luka.kovacic@sartura.hr + * + * Based on stock U-boot and Linux drivers + */ + +#include <asm/gpio.h> +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <linux/delay.h> +#include <spi.h> + +#define QUP_CONFIG 0x0000 +#define QUP_STATE 0x0004 +#define QUP_IO_M_MODES 0x0008 +#define QUP_SW_RESET 0x000c +#define QUP_OPERATIONAL 0x0018 +#define QUP_ERROR_FLAGS 0x001c +#define QUP_ERROR_FLAGS_EN 0x0020 +#define QUP_OPERATIONAL_MASK 0x0028 +#define QUP_HW_VERSION 0x0030 +#define QUP_MX_OUTPUT_CNT 0x0100 +#define QUP_OUTPUT_FIFO 0x0110 +#define QUP_MX_WRITE_CNT 0x0150 +#define QUP_MX_INPUT_CNT 0x0200 +#define QUP_MX_READ_CNT 0x0208 +#define QUP_INPUT_FIFO 0x0218 + +#define SPI_CONFIG 0x0300 +#define SPI_IO_CONTROL 0x0304 +#define SPI_ERROR_FLAGS 0x0308 +#define SPI_ERROR_FLAGS_EN 0x030c + +/* QUP_CONFIG fields */ +#define QUP_CONFIG_SPI_MODE BIT(8) +#define QUP_CONFIG_CLOCK_AUTO_GATE BIT(13) +#define QUP_CONFIG_NO_INPUT BIT(7) +#define QUP_CONFIG_NO_OUTPUT BIT(6) +#define QUP_CONFIG_N 0x001f + +/* QUP_STATE fields */ +#define QUP_STATE_VALID BIT(2) +#define QUP_STATE_RESET 0 +#define QUP_STATE_RUN 1 +#define QUP_STATE_PAUSE 3 +#define QUP_STATE_MASK 3 +#define QUP_STATE_CLEAR 2 + +/* QUP_IO_M_MODES fields */ +#define QUP_IO_M_PACK_EN BIT(15) +#define QUP_IO_M_UNPACK_EN BIT(14) +#define QUP_IO_M_INPUT_MODE_MASK_SHIFT 12 +#define QUP_IO_M_OUTPUT_MODE_MASK_SHIFT 10 +#define QUP_IO_M_INPUT_MODE_MASK (3 << QUP_IO_M_INPUT_MODE_MASK_SHIFT) +#define QUP_IO_M_OUTPUT_MODE_MASK (3 << QUP_IO_M_OUTPUT_MODE_MASK_SHIFT) + +#define QUP_IO_M_OUTPUT_BLOCK_SIZE(x) (((x) & (0x03 << 0)) >> 0) +#define QUP_IO_M_OUTPUT_FIFO_SIZE(x) (((x) & (0x07 << 2)) >> 2) +#define QUP_IO_M_INPUT_BLOCK_SIZE(x) (((x) & (0x03 << 5)) >> 5) +#define QUP_IO_M_INPUT_FIFO_SIZE(x) (((x) & (0x07 << 7)) >> 7) + +#define QUP_IO_M_MODE_FIFO 0 +#define QUP_IO_M_MODE_BLOCK 1 +#define QUP_IO_M_MODE_DMOV 2 +#define QUP_IO_M_MODE_BAM 3 + +/* QUP_OPERATIONAL fields */ +#define QUP_OP_IN_BLOCK_READ_REQ BIT(13) +#define QUP_OP_OUT_BLOCK_WRITE_REQ BIT(12) +#define QUP_OP_MAX_INPUT_DONE_FLAG BIT(11) +#define QUP_OP_MAX_OUTPUT_DONE_FLAG BIT(10) +#define QUP_OP_IN_SERVICE_FLAG BIT(9) +#define QUP_OP_OUT_SERVICE_FLAG BIT(8) +#define QUP_OP_IN_FIFO_FULL BIT(7) +#define QUP_OP_OUT_FIFO_FULL BIT(6) +#define QUP_OP_IN_FIFO_NOT_EMPTY BIT(5) +#define QUP_OP_OUT_FIFO_NOT_EMPTY BIT(4) + +/* QUP_ERROR_FLAGS and QUP_ERROR_FLAGS_EN fields */ +#define QUP_ERROR_OUTPUT_OVER_RUN BIT(5) +#define QUP_ERROR_INPUT_UNDER_RUN BIT(4) +#define QUP_ERROR_OUTPUT_UNDER_RUN BIT(3) +#define QUP_ERROR_INPUT_OVER_RUN BIT(2) + +/* SPI_CONFIG fields */ +#define SPI_CONFIG_HS_MODE BIT(10) +#define SPI_CONFIG_INPUT_FIRST BIT(9) +#define SPI_CONFIG_LOOPBACK BIT(8) + +/* SPI_IO_CONTROL fields */ +#define SPI_IO_C_FORCE_CS BIT(11) +#define SPI_IO_C_CLK_IDLE_HIGH BIT(10) +#define SPI_IO_C_MX_CS_MODE BIT(8) +#define SPI_IO_C_CS_N_POLARITY_0 BIT(4) +#define SPI_IO_C_CS_SELECT(x) (((x) & 3) << 2) +#define SPI_IO_C_CS_SELECT_MASK 0x000c +#define SPI_IO_C_TRISTATE_CS BIT(1) +#define SPI_IO_C_NO_TRI_STATE BIT(0) + +/* SPI_ERROR_FLAGS and SPI_ERROR_FLAGS_EN fields */ +#define SPI_ERROR_CLK_OVER_RUN BIT(1) +#define SPI_ERROR_CLK_UNDER_RUN BIT(0) + +#define SPI_NUM_CHIPSELECTS 4 + +#define SPI_DELAY_THRESHOLD 1 +#define SPI_DELAY_RETRY 10 + +#define SPI_RESET_STATE 0 +#define SPI_RUN_STATE 1 +#define SPI_CORE_RESET 0 +#define SPI_CORE_RUNNING 1 + +#define DUMMY_DATA_VAL 0 +#define TIMEOUT_CNT 100 + +#define QUP_STATE_VALID_BIT 2 +#define QUP_CONFIG_MINI_CORE_MSK (0x0F << 8) +#define QUP_CONFIG_MINI_CORE_SPI BIT(8) +#define QUP_CONF_INPUT_MSK BIT(7) +#define QUP_CONF_INPUT_ENA (0 << 7) +#define QUP_CONF_NO_INPUT BIT(7) +#define QUP_CONF_OUTPUT_MSK BIT(6) +#define QUP_CONF_OUTPUT_ENA (0 << 6) +#define QUP_CONF_NO_OUTPUT BIT(6) +#define QUP_STATE_RUN_STATE 0x1 +#define QUP_STATE_RESET_STATE 0x0 +#define QUP_STATE_PAUSE_STATE 0x3 +#define SPI_BIT_WORD_MSK 0x1F +#define SPI_8_BIT_WORD 0x07 +#define LOOP_BACK_MSK BIT(8) +#define NO_LOOP_BACK (0 << 8) +#define SLAVE_OPERATION_MSK BIT(5) +#define SLAVE_OPERATION (0 << 5) +#define CLK_ALWAYS_ON (0 << 9) +#define MX_CS_MODE BIT(8) +#define CS_POLARITY_MASK BIT(4) +#define NO_TRI_STATE BIT(0) +#define FORCE_CS_MSK BIT(11) +#define FORCE_CS_EN BIT(11) +#define FORCE_CS_DIS (0 << 11) +#define OUTPUT_BIT_SHIFT_MSK BIT(16) +#define OUTPUT_BIT_SHIFT_EN BIT(16) +#define INPUT_BLOCK_MODE_MSK (0x03 << 12) +#define INPUT_BLOCK_MODE (0x01 << 12) +#define OUTPUT_BLOCK_MODE_MSK (0x03 << 10) +#define OUTPUT_BLOCK_MODE (0x01 << 10) +#define INPUT_BAM_MODE (0x3 << 12) +#define OUTPUT_BAM_MODE (0x3 << 10) +#define PACK_EN (0x1 << 15) +#define UNPACK_EN (0x1 << 14) +#define PACK_EN_MSK (0x1 << 15) +#define UNPACK_EN_MSK (0x1 << 14) +#define OUTPUT_SERVICE_MSK (0x1 << 8) +#define INPUT_SERVICE_MSK (0x1 << 9) +#define OUTPUT_SERVICE_DIS (0x1 << 8) +#define INPUT_SERVICE_DIS (0x1 << 9) +#define BLSP0_SPI_DEASSERT_WAIT_REG 0x0310 +#define QUP_DATA_AVAILABLE_FOR_READ BIT(5) +#define SPI_INPUT_BLOCK_SIZE 4 +#define SPI_OUTPUT_BLOCK_SIZE 4 +#define SPI_BITLEN_MSK 0x07 +#define MAX_COUNT_SIZE 0xffff + +struct qup_spi_priv { + phys_addr_t base; + struct clk clk; + u32 num_cs; + struct gpio_desc cs_gpios[SPI_NUM_CHIPSELECTS]; + bool cs_high; + u32 core_state; +}; + +static int qup_spi_set_cs(struct udevice *dev, unsigned int cs, bool enable) +{ + struct qup_spi_priv *priv = dev_get_priv(dev); + + debug("%s: cs=%d enable=%d\n", __func__, cs, enable); + + if (cs >= SPI_NUM_CHIPSELECTS) + return -ENODEV; + + if (!dm_gpio_is_valid(&priv->cs_gpios[cs])) + return -EINVAL; + + if (priv->cs_high) + enable = !enable; + + return dm_gpio_set_value(&priv->cs_gpios[cs], enable ? 1 : 0); +} + +/* + * Function to write data to OUTPUT FIFO + */ +static void qup_spi_write_byte(struct udevice *dev, unsigned char data) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + /* Wait for space in the FIFO */ + while ((readl(priv->base + QUP_OPERATIONAL) & QUP_OP_OUT_FIFO_FULL)) + udelay(1); + + /* Write the byte of data */ + writel(data, priv->base + QUP_OUTPUT_FIFO); +} + +/* + * Function to read data from Input FIFO + */ +static unsigned char qup_spi_read_byte(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + /* Wait for Data in FIFO */ + while (!(readl(priv->base + QUP_OPERATIONAL) & QUP_DATA_AVAILABLE_FOR_READ)) { + printf("Stuck at FIFO data wait\n"); + udelay(1); + } + + /* Read a byte of data */ + return readl(priv->base + QUP_INPUT_FIFO) & 0xff; +} + +/* + * Function to check wheather Input or Output FIFO + * has data to be serviced + */ +static int qup_spi_check_fifo_status(struct udevice *dev, u32 reg_addr) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + unsigned int count = TIMEOUT_CNT; + unsigned int status_flag; + unsigned int val; + + do { + val = readl(priv->base + reg_addr); + count--; + if (count == 0) + return -ETIMEDOUT; + + status_flag = ((val & QUP_OP_OUT_SERVICE_FLAG) | (val & QUP_OP_IN_SERVICE_FLAG)); + } while (!status_flag); + + return 0; +} + +/* + * Function to configure Input and Output enable/disable + */ +static void qup_spi_enable_io_config(struct udevice *dev, u32 write_cnt, u32 read_cnt) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + + if (write_cnt) { + clrsetbits_le32(priv->base + QUP_CONFIG, + QUP_CONF_OUTPUT_MSK, QUP_CONF_OUTPUT_ENA); + } else { + clrsetbits_le32(priv->base + QUP_CONFIG, + QUP_CONF_OUTPUT_MSK, QUP_CONF_NO_OUTPUT); + } + + if (read_cnt) { + clrsetbits_le32(priv->base + QUP_CONFIG, + QUP_CONF_INPUT_MSK, QUP_CONF_INPUT_ENA); + } else { + clrsetbits_le32(priv->base + QUP_CONFIG, + QUP_CONF_INPUT_MSK, QUP_CONF_NO_INPUT); + } +} + +static int check_bit_state(struct udevice *dev, u32 reg_addr, int bit_num, int val, + int us_delay) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + unsigned int count = TIMEOUT_CNT; + unsigned int bit_val = ((readl(priv->base + reg_addr) >> bit_num) & 0x01); + + while (bit_val != val) { + count--; + if (count == 0) + return -ETIMEDOUT; + udelay(us_delay); + bit_val = ((readl(priv->base + reg_addr) >> bit_num) & 0x01); + } + + return 0; +} + +/* + * Check whether QUPn State is valid + */ +static int check_qup_state_valid(struct udevice *dev) +{ + return check_bit_state(dev, QUP_STATE, QUP_STATE_VALID, 1, 1); +} + +/* + * Configure QUPn Core state + */ +static int qup_spi_config_spi_state(struct udevice *dev, unsigned int state) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + u32 val; + int ret; + + ret = check_qup_state_valid(dev); + if (ret != 0) + return ret; + + switch (state) { + case SPI_RUN_STATE: + /* Set the state to RUN */ + val = ((readl(priv->base + QUP_STATE) & ~QUP_STATE_MASK) + | QUP_STATE_RUN); + writel(val, priv->base + QUP_STATE); + ret = check_qup_state_valid(dev); + if (ret != 0) + return ret; + priv->core_state = SPI_CORE_RUNNING; + break; + case SPI_RESET_STATE: + /* Set the state to RESET */ + val = ((readl(priv->base + QUP_STATE) & ~QUP_STATE_MASK) + | QUP_STATE_RESET); + writel(val, priv->base + QUP_STATE); + ret = check_qup_state_valid(dev); + if (ret != 0) + return ret; + priv->core_state = SPI_CORE_RESET; + break; + default: + printf("Unsupported QUP SPI state: %d\n", state); + ret = -EINVAL; + break; + } + return ret; +} + +/* + * Function to read bytes number of data from the Input FIFO + */ +static int __qup_spi_blsp_spi_read(struct udevice *dev, u8 *data_buffer, unsigned int bytes) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + u32 val; + unsigned int i; + unsigned int read_bytes = bytes; + unsigned int fifo_count; + int ret = 0; + int state_config; + + /* Configure no of bytes to read */ + state_config = qup_spi_config_spi_state(dev, SPI_RESET_STATE); + if (state_config) + return state_config; + + /* Configure input and output enable */ + qup_spi_enable_io_config(dev, 0, read_bytes); + + writel(bytes, priv->base + QUP_MX_INPUT_CNT); + + state_config = qup_spi_config_spi_state(dev, SPI_RUN_STATE); + if (state_config) + return state_config; + + while (read_bytes) { + ret = qup_spi_check_fifo_status(dev, QUP_OPERATIONAL); + if (ret != 0) + goto out; + + val = readl(priv->base + QUP_OPERATIONAL); + if (val & QUP_OP_IN_SERVICE_FLAG) { + /* + * acknowledge to hw that software will + * read input data + */ + val &= QUP_OP_IN_SERVICE_FLAG; + writel(val, priv->base + QUP_OPERATIONAL); + + fifo_count = ((read_bytes > SPI_INPUT_BLOCK_SIZE) ? + SPI_INPUT_BLOCK_SIZE : read_bytes); + + for (i = 0; i < fifo_count; i++) { + *data_buffer = qup_spi_read_byte(dev); + data_buffer++; + read_bytes--; + } + } + } + +out: + /* + * Put the SPI Core back in the Reset State + * to end the transfer + */ + (void)qup_spi_config_spi_state(dev, SPI_RESET_STATE); + + return ret; +} + +static int qup_spi_blsp_spi_read(struct udevice *dev, u8 *data_buffer, unsigned int bytes) +{ + int length, ret; + + while (bytes) { + length = (bytes < MAX_COUNT_SIZE) ? bytes : MAX_COUNT_SIZE; + + ret = __qup_spi_blsp_spi_read(dev, data_buffer, length); + if (ret != 0) + return ret; + + data_buffer += length; + bytes -= length; + } + + return 0; +} + +/* + * Function to write data to the Output FIFO + */ +static int __qup_blsp_spi_write(struct udevice *dev, const u8 *cmd_buffer, unsigned int bytes) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + u32 val; + unsigned int i; + unsigned int write_len = bytes; + unsigned int read_len = bytes; + unsigned int fifo_count; + int ret = 0; + int state_config; + + state_config = qup_spi_config_spi_state(dev, SPI_RESET_STATE); + if (state_config) + return state_config; + + writel(bytes, priv->base + QUP_MX_OUTPUT_CNT); + writel(bytes, priv->base + QUP_MX_INPUT_CNT); + state_config = qup_spi_config_spi_state(dev, SPI_RUN_STATE); + if (state_config) + return state_config; + + /* Configure input and output enable */ + qup_spi_enable_io_config(dev, write_len, read_len); + + /* + * read_len considered to ensure that we read the dummy data for the + * write we performed. This is needed to ensure with WR-RD transaction + * to get the actual data on the subsequent read cycle that happens + */ + while (write_len || read_len) { + ret = qup_spi_check_fifo_status(dev, QUP_OPERATIONAL); + if (ret != 0) + goto out; + + val = readl(priv->base + QUP_OPERATIONAL); + if (val & QUP_OP_OUT_SERVICE_FLAG) { + /* + * acknowledge to hw that software will write + * expected output data + */ + val &= QUP_OP_OUT_SERVICE_FLAG; + writel(val, priv->base + QUP_OPERATIONAL); + + if (write_len > SPI_OUTPUT_BLOCK_SIZE) + fifo_count = SPI_OUTPUT_BLOCK_SIZE; + else + fifo_count = write_len; + + for (i = 0; i < fifo_count; i++) { + /* Write actual data to output FIFO */ + qup_spi_write_byte(dev, *cmd_buffer); + cmd_buffer++; + write_len--; + } + } + if (val & QUP_OP_IN_SERVICE_FLAG) { + /* + * acknowledge to hw that software + * will read input data + */ + val &= QUP_OP_IN_SERVICE_FLAG; + writel(val, priv->base + QUP_OPERATIONAL); + + if (read_len > SPI_INPUT_BLOCK_SIZE) + fifo_count = SPI_INPUT_BLOCK_SIZE; + else + fifo_count = read_len; + + for (i = 0; i < fifo_count; i++) { + /* Read dummy data for the data written */ + (void)qup_spi_read_byte(dev); + + /* Decrement the write count after reading the + * dummy data from the device. This is to make + * sure we read dummy data before we write the + * data to fifo + */ + read_len--; + } + } + } +out: + /* + * Put the SPI Core back in the Reset State + * to end the transfer + */ + (void)qup_spi_config_spi_state(dev, SPI_RESET_STATE); + + return ret; +} + +static int qup_spi_blsp_spi_write(struct udevice *dev, const u8 *cmd_buffer, unsigned int bytes) +{ + int length, ret; + + while (bytes) { + length = (bytes < MAX_COUNT_SIZE) ? bytes : MAX_COUNT_SIZE; + + ret = __qup_blsp_spi_write(dev, cmd_buffer, length); + if (ret != 0) + return ret; + + cmd_buffer += length; + bytes -= length; + } + + return 0; +} + +static int qup_spi_set_speed(struct udevice *dev, uint speed) +{ + return 0; +} + +static int qup_spi_set_mode(struct udevice *dev, uint mode) +{ + struct qup_spi_priv *priv = dev_get_priv(dev); + unsigned int clk_idle_state; + unsigned int input_first_mode; + u32 val; + + switch (mode) { + case SPI_MODE_0: + clk_idle_state = 0; + input_first_mode = SPI_CONFIG_INPUT_FIRST; + break; + case SPI_MODE_1: + clk_idle_state = 0; + input_first_mode = 0; + break; + case SPI_MODE_2: + clk_idle_state = 1; + input_first_mode = SPI_CONFIG_INPUT_FIRST; + break; + case SPI_MODE_3: + clk_idle_state = 1; + input_first_mode = 0; + break; + default: + printf("Unsupported spi mode: %d\n", mode); + return -EINVAL; + } + + if (mode & SPI_CS_HIGH) + priv->cs_high = true; + else + priv->cs_high = false; + + val = readl(priv->base + SPI_CONFIG); + val |= input_first_mode; + writel(val, priv->base + SPI_CONFIG); + + val = readl(priv->base + SPI_IO_CONTROL); + if (clk_idle_state) + val |= SPI_IO_C_CLK_IDLE_HIGH; + else + val &= ~SPI_IO_C_CLK_IDLE_HIGH; + + writel(val, priv->base + SPI_IO_CONTROL); + + return 0; +} + +static void qup_spi_reset(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + + /* Driver may not be probed yet */ + if (!priv) + return; + + writel(0x1, priv->base + QUP_SW_RESET); + udelay(5); +} + +static int qup_spi_hw_init(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct qup_spi_priv *priv = dev_get_priv(bus); + int ret; + + /* QUPn module configuration */ + qup_spi_reset(dev); + + /* Set the QUPn state */ + ret = qup_spi_config_spi_state(dev, SPI_RESET_STATE); + if (ret) + return ret; + + /* + * Configure Mini core to SPI core with Input Output enabled, + * SPI master, N = 8 bits + */ + clrsetbits_le32(priv->base + QUP_CONFIG, (QUP_CONFIG_MINI_CORE_MSK | + QUP_CONF_INPUT_MSK | + QUP_CONF_OUTPUT_MSK | + SPI_BIT_WORD_MSK), + (QUP_CONFIG_MINI_CORE_SPI | + QUP_CONF_INPUT_ENA | + QUP_CONF_OUTPUT_ENA | + SPI_8_BIT_WORD)); + + /* + * Configure Input first SPI protocol, + * SPI master mode and no loopback + */ + clrsetbits_le32(priv->base + SPI_CONFIG, (LOOP_BACK_MSK | + SLAVE_OPERATION_MSK), + (NO_LOOP_BACK | + SLAVE_OPERATION)); + + /* + * Configure SPI IO Control Register + * CLK_ALWAYS_ON = 0 + * MX_CS_MODE = 0 + * NO_TRI_STATE = 1 + */ + writel((CLK_ALWAYS_ON | NO_TRI_STATE), priv->base + SPI_IO_CONTROL); + + /* + * Configure SPI IO Modes. + * OUTPUT_BIT_SHIFT_EN = 1 + * INPUT_MODE = Block Mode + * OUTPUT MODE = Block Mode + */ + + clrsetbits_le32(priv->base + QUP_IO_M_MODES, (OUTPUT_BIT_SHIFT_MSK | + INPUT_BLOCK_MODE_MSK | + OUTPUT_BLOCK_MODE_MSK), + (OUTPUT_BIT_SHIFT_EN | + INPUT_BLOCK_MODE | + OUTPUT_BLOCK_MODE)); + + /* Disable Error mask */ + writel(0, priv->base + SPI_ERROR_FLAGS_EN); + writel(0, priv->base + QUP_ERROR_FLAGS_EN); + writel(0, priv->base + BLSP0_SPI_DEASSERT_WAIT_REG); + + return ret; +} + +static int qup_spi_claim_bus(struct udevice *dev) +{ + int ret; + + ret = qup_spi_hw_init(dev); + if (ret) + return -EIO; + + return 0; +} + +static int qup_spi_release_bus(struct udevice *dev) +{ + /* Reset the SPI hardware */ + qup_spi_reset(dev); + + return 0; +} + +static int qup_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev_get_parent(dev); + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + unsigned int len; + const u8 *txp = dout; + u8 *rxp = din; + int ret = 0; + + if (bitlen & SPI_BITLEN_MSK) { + printf("Invalid bit length\n"); + return -EINVAL; + } + + len = bitlen >> 3; + + if (flags & SPI_XFER_BEGIN) { + ret = qup_spi_hw_init(dev); + if (ret != 0) + return ret; + + ret = qup_spi_set_cs(bus, slave_plat->cs, false); + if (ret != 0) + return ret; + } + + if (dout != NULL) { + ret = qup_spi_blsp_spi_write(dev, txp, len); + if (ret != 0) + return ret; + } + + if (din != NULL) { + ret = qup_spi_blsp_spi_read(dev, rxp, len); + if (ret != 0) + return ret; + } + + if (flags & SPI_XFER_END) { + ret = qup_spi_set_cs(bus, slave_plat->cs, true); + if (ret != 0) + return ret; + } + + return ret; +} + +static int qup_spi_probe(struct udevice *dev) +{ + struct qup_spi_priv *priv = dev_get_priv(dev); + int ret; + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) + return ret; + + ret = clk_enable(&priv->clk); + if (ret < 0) + return ret; + + priv->num_cs = dev_read_u32_default(dev, "num-cs", 1); + + ret = gpio_request_list_by_name(dev, "cs-gpios", priv->cs_gpios, + priv->num_cs, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + if (ret < 0) { + printf("Can't get %s cs gpios: %d\n", dev->name, ret); + return -EINVAL; + } + + return 0; +} + +static const struct dm_spi_ops qup_spi_ops = { + .claim_bus = qup_spi_claim_bus, + .release_bus = qup_spi_release_bus, + .xfer = qup_spi_xfer, + .set_speed = qup_spi_set_speed, + .set_mode = qup_spi_set_mode, + /* + * cs_info is not needed, since we require all chip selects to be + * in the device tree explicitly + */ +}; + +static const struct udevice_id qup_spi_ids[] = { + { .compatible = "qcom,spi-qup-v1.1.1", }, + { .compatible = "qcom,spi-qup-v2.1.1", }, + { .compatible = "qcom,spi-qup-v2.2.1", }, + { } +}; + +U_BOOT_DRIVER(spi_qup) = { + .name = "spi_qup", + .id = UCLASS_SPI, + .of_match = qup_spi_ids, + .ops = &qup_spi_ops, + .priv_auto_alloc_size = sizeof(struct qup_spi_priv), + .probe = qup_spi_probe, +};
Since we have SPI driver for IPQ40xx QUP SPI controller, lets add the necessary nodes, pinctrl and clocks.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/dts/qcom-ipq4019.dtsi | 12 ++++++++++++ arch/arm/mach-ipq40xx/clock-ipq4019.c | 17 +++++++++++++++-- arch/arm/mach-ipq40xx/pinctrl-ipq4019.c | 3 +++ 3 files changed, 30 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/qcom-ipq4019.dtsi b/arch/arm/dts/qcom-ipq4019.dtsi index e0e4188e5d..936ef74f94 100644 --- a/arch/arm/dts/qcom-ipq4019.dtsi +++ b/arch/arm/dts/qcom-ipq4019.dtsi @@ -22,6 +22,7 @@
aliases { serial0 = &blsp1_uart1; + spi0 = &blsp1_spi1; };
reserved-memory { @@ -89,6 +90,17 @@ gpio-count = <100>; gpio-bank-name="soc"; #gpio-cells = <2>; + u-boot,dm-pre-reloc; + }; + + blsp1_spi1: spi@78b5000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x78b5000 0x600>; + clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + u-boot,dm-pre-reloc; };
usb3_ss_phy: ssphy@9a000 { diff --git a/arch/arm/mach-ipq40xx/clock-ipq4019.c b/arch/arm/mach-ipq40xx/clock-ipq4019.c index 83a688e625..d5b5f4cb79 100644 --- a/arch/arm/mach-ipq40xx/clock-ipq4019.c +++ b/arch/arm/mach-ipq40xx/clock-ipq4019.c @@ -2,7 +2,7 @@ /* * Clock drivers for Qualcomm IPQ40xx * - * Copyright (c) 2019 Sartura Ltd. + * Copyright (c) 2020 Sartura Ltd. * * Author: Robert Marko robert.marko@sartura.hr * @@ -24,7 +24,7 @@ ulong msm_set_rate(struct clk *clk, ulong rate) switch (clk->id) { case GCC_BLSP1_UART1_APPS_CLK: /*UART1*/ /* This clock is already initialized by SBL1 */ - return 0; + return 0; break; default: return 0; @@ -47,8 +47,21 @@ static ulong msm_clk_set_rate(struct clk *clk, ulong rate) return msm_set_rate(clk, rate); }
+static int msm_enable(struct clk *clk) +{ + switch (clk->id) { + case GCC_BLSP1_QUP1_SPI_APPS_CLK: /*SPI1*/ + /* This clock is already initialized by SBL1 */ + return 0; + break; + default: + return 0; + } +} + static struct clk_ops msm_clk_ops = { .set_rate = msm_clk_set_rate, + .enable = msm_enable, };
static const struct udevice_id msm_clk_ids[] = { diff --git a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c b/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c index 06a57f2e5e..1f283516cb 100644 --- a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c +++ b/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c @@ -18,6 +18,9 @@ static const struct pinctrl_function msm_pinctrl_functions[] = { {"blsp_uart0_0", 1}, /* Only for GPIO:16,17 */ {"blsp_uart0_1", 2}, /* Only for GPIO:60,61 */ {"blsp_uart1", 1}, + {"blsp_spi0_0", 1}, /* Only for GPIO:12,13,14,15 */ + {"blsp_spi0_1", 2}, /* Only for GPIO:54,55,56,57 */ + {"blsp_spi1", 2}, };
static const char *ipq4019_get_function_name(struct udevice *dev,
This adds the driver for the IPQ40xx built-in MDIO. This will be needed to support future PHY driver.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- MAINTAINERS | 1 + drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/mdio-ipq4019.c | 146 +++++++++++++++++++++++++++++++++++++ 4 files changed, 155 insertions(+) create mode 100644 drivers/net/mdio-ipq4019.c
diff --git a/MAINTAINERS b/MAINTAINERS index aa6cbb965d..5f1a815c88 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -242,6 +242,7 @@ F: include/dt-bindings/reset/qcom,ipq4019-reset.h F: drivers/reset/reset-ipq4019.c F: drivers/phy/phy-qcom-ipq4019-usb.c F: drivers/spi/spi-qup.c +F: drivers/net/mdio-ipq4019.c
ARM MARVELL KIRKWOOD ARMADA-XP ARMADA-38X ARMADA-37XX ARMADA-7K/8K M: Stefan Roese sr@denx.de diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index a0d2d21a55..09a4688d69 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -701,6 +701,13 @@ config MDIO_MUX_I2CREG an I2C chip. The board it was developed for uses a mux controlled by on-board FPGA which in turn is accessed as a chip over I2C.
+config MDIO_IPQ4019 + bool "Qualcomm IPQ4019 MDIO interface support" + depends on DM_MDIO + help + This driver supports the MDIO interface found in Qualcomm + IPQ40xx series Soc-s. + config MVMDIO bool "Marvell MDIO interface support" depends on DM_MDIO diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 03f01921ea..9cd4b36f57 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -40,6 +40,7 @@ obj-$(CONFIG_LAN91C96) += lan91c96.o obj-$(CONFIG_LPC32XX_ETH) += lpc32xx_eth.o obj-$(CONFIG_MACB) += macb.o obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o +obj-$(CONFIG_MDIO_IPQ4019) += mdio-ipq4019.o obj-$(CONFIG_MDIO_MUX_I2CREG) += mdio_mux_i2creg.o obj-$(CONFIG_MDIO_MUX_SANDBOX) += mdio_mux_sandbox.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o diff --git a/drivers/net/mdio-ipq4019.c b/drivers/net/mdio-ipq4019.c new file mode 100644 index 0000000000..bc68e1d506 --- /dev/null +++ b/drivers/net/mdio-ipq4019.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Qualcomm IPQ4019 MDIO driver + * + * Copyright (c) 2020 Sartura Ltd. + * + * Author: Luka Kovacic luka.kovacic@sartura.hr + * Author: Robert Marko robert.marko@sartura.hr + * + * Based on Linux driver + */ + +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <linux/bitops.h> +#include <linux/iopoll.h> +#include <miiphy.h> +#include <phy.h> + +#define MDIO_MODE_REG 0x40 +#define MDIO_ADDR_REG 0x44 +#define MDIO_DATA_WRITE_REG 0x48 +#define MDIO_DATA_READ_REG 0x4c +#define MDIO_CMD_REG 0x50 +#define MDIO_CMD_ACCESS_BUSY BIT(16) +#define MDIO_CMD_ACCESS_START BIT(8) +#define MDIO_CMD_ACCESS_CODE_READ 0 +#define MDIO_CMD_ACCESS_CODE_WRITE 1 + +/* 0 = Clause 22, 1 = Clause 45 */ +#define MDIO_MODE_BIT BIT(8) + +#define IPQ4019_MDIO_TIMEOUT 10000 +#define IPQ4019_MDIO_SLEEP 10 + +struct ipq4019_mdio_priv { + phys_addr_t mdio_base; +}; + +static int ipq4019_mdio_wait_busy(struct ipq4019_mdio_priv *priv) +{ + unsigned int busy; + + return readl_poll_sleep_timeout(priv->mdio_base + MDIO_CMD_REG, busy, + (busy & MDIO_CMD_ACCESS_BUSY) == 0, IPQ4019_MDIO_SLEEP, + IPQ4019_MDIO_TIMEOUT); +} + +int ipq4019_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + struct ipq4019_mdio_priv *priv = dev_get_priv(dev); + unsigned int cmd; + + if (ipq4019_mdio_wait_busy(priv)) + return -ETIMEDOUT; + + /* Issue the phy address and reg */ + writel((addr << 8) | reg, priv->mdio_base + MDIO_ADDR_REG); + + cmd = MDIO_CMD_ACCESS_START | MDIO_CMD_ACCESS_CODE_READ; + + /* Issue read command */ + writel(cmd, priv->mdio_base + MDIO_CMD_REG); + + /* Wait read complete */ + if (ipq4019_mdio_wait_busy(priv)) + return -ETIMEDOUT; + + /* Read and return data */ + return readl(priv->mdio_base + MDIO_DATA_READ_REG); +} + +int ipq4019_mdio_write(struct udevice *dev, int addr, int devad, + int reg, u16 val) +{ + struct ipq4019_mdio_priv *priv = dev_get_priv(dev); + unsigned int cmd; + + if (ipq4019_mdio_wait_busy(priv)) + return -ETIMEDOUT; + + /* Issue the phy addreass and reg */ + writel((addr << 8) | reg, priv->mdio_base + MDIO_ADDR_REG); + + /* Issue write data */ + writel(val, priv->mdio_base + MDIO_DATA_WRITE_REG); + + cmd = MDIO_CMD_ACCESS_START | MDIO_CMD_ACCESS_CODE_WRITE; + + /* Issue write command */ + writel(cmd, priv->mdio_base + MDIO_CMD_REG); + + /* Wait for write complete */ + + if (ipq4019_mdio_wait_busy(priv)) + return -ETIMEDOUT; + + return 0; +} + +static const struct mdio_ops ipq4019_mdio_ops = { + .read = ipq4019_mdio_read, + .write = ipq4019_mdio_write, +}; + +static int ipq4019_mdio_bind(struct udevice *dev) +{ + if (ofnode_valid(dev->node)) + device_set_name(dev, ofnode_get_name(dev->node)); + + return 0; +} + +static int ipq4019_mdio_probe(struct udevice *dev) +{ + struct ipq4019_mdio_priv *priv = dev_get_priv(dev); + unsigned int data; + + priv->mdio_base = dev_read_addr(dev); + if (priv->mdio_base == FDT_ADDR_T_NONE) + return -EINVAL; + + /* Enter Clause 22 mode */ + data = readl(priv->mdio_base + MDIO_MODE_REG); + data &= ~MDIO_MODE_BIT; + writel(data, priv->mdio_base + MDIO_MODE_REG); + + return 0; +} + +static const struct udevice_id ipq4019_mdio_ids[] = { + { .compatible = "qcom,ipq4019-mdio", }, + { } +}; + +U_BOOT_DRIVER(ipq4019_mdio) = { + .name = "ipq4019_mdio", + .id = UCLASS_MDIO, + .of_match = ipq4019_mdio_ids, + .bind = ipq4019_mdio_bind, + .probe = ipq4019_mdio_probe, + .ops = &ipq4019_mdio_ops, + .priv_auto_alloc_size = sizeof(struct ipq4019_mdio_priv), +};
Lets add the necessary DTS node and pinctrl properties for newly added MDIO driver.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/dts/qcom-ipq4019.dtsi | 28 +++++++++++++++++++++++++ arch/arm/mach-ipq40xx/pinctrl-ipq4019.c | 4 ++++ 2 files changed, 32 insertions(+)
diff --git a/arch/arm/dts/qcom-ipq4019.dtsi b/arch/arm/dts/qcom-ipq4019.dtsi index 936ef74f94..031691e5d2 100644 --- a/arch/arm/dts/qcom-ipq4019.dtsi +++ b/arch/arm/dts/qcom-ipq4019.dtsi @@ -103,6 +103,34 @@ u-boot,dm-pre-reloc; };
+ mdio: mdio@90000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "qcom,ipq4019-mdio"; + reg = <0x90000 0x64>; + status = "disabled"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; + + ethphy1: ethernet-phy@1 { + reg = <1>; + }; + + ethphy2: ethernet-phy@2 { + reg = <2>; + }; + + ethphy3: ethernet-phy@3 { + reg = <3>; + }; + + ethphy4: ethernet-phy@4 { + reg = <4>; + }; + }; + usb3_ss_phy: ssphy@9a000 { compatible = "qcom,usb-ss-ipq4019-phy"; #phy-cells = <0>; diff --git a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c b/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c index 1f283516cb..3e365f8cc8 100644 --- a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c +++ b/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c @@ -21,6 +21,10 @@ static const struct pinctrl_function msm_pinctrl_functions[] = { {"blsp_spi0_0", 1}, /* Only for GPIO:12,13,14,15 */ {"blsp_spi0_1", 2}, /* Only for GPIO:54,55,56,57 */ {"blsp_spi1", 2}, + {"mdio_0", 1}, /* Only for GPIO6 */ + {"mdio_1", 2}, /* Only for GPIO53 */ + {"mdc_0", 1}, /* Only for GPIO7 */ + {"mdc_1", 2}, /* Only for GPIO52 */ };
Add support for the hardware pseudo random number generator found in Qualcomm SoC-s.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- MAINTAINERS | 1 + drivers/rng/Kconfig | 7 +++ drivers/rng/Makefile | 1 + drivers/rng/msm_rng.c | 143 ++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 152 insertions(+) create mode 100644 drivers/rng/msm_rng.c
diff --git a/MAINTAINERS b/MAINTAINERS index 5f1a815c88..8a1bc97443 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -243,6 +243,7 @@ F: drivers/reset/reset-ipq4019.c F: drivers/phy/phy-qcom-ipq4019-usb.c F: drivers/spi/spi-qup.c F: drivers/net/mdio-ipq4019.c +F: drivers/rng/msm_rng.c
ARM MARVELL KIRKWOOD ARMADA-XP ARMADA-38X ARMADA-37XX ARMADA-7K/8K M: Stefan Roese sr@denx.de diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index e4b22d79eb..11001c8ae7 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -24,6 +24,13 @@ config RNG_SANDBOX Enable random number generator for sandbox. This is an emulation of a rng device.
+config RNG_MSM + bool "Qualcomm SoCs Random Number Generator support" + depends on DM_RNG + help + This driver provides support for the Random Number + Generator hardware found on Qualcomm SoCs. + config RNG_STM32MP1 bool "Enable random number generator for STM32MP1" depends on ARCH_STM32MP diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 44a0003917..8953406882 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -6,5 +6,6 @@ obj-$(CONFIG_DM_RNG) += rng-uclass.o obj-$(CONFIG_RNG_MESON) += meson-rng.o obj-$(CONFIG_RNG_SANDBOX) += sandbox_rng.o +obj-$(CONFIG_RNG_MSM) += msm_rng.o obj-$(CONFIG_RNG_STM32MP1) += stm32mp1_rng.o obj-$(CONFIG_RNG_ROCKCHIP) += rockchip_rng.o diff --git a/drivers/rng/msm_rng.c b/drivers/rng/msm_rng.c new file mode 100644 index 0000000000..d51119303a --- /dev/null +++ b/drivers/rng/msm_rng.c @@ -0,0 +1,143 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * PRNG driver for Qualcomm IPQ40xx + * + * Copyright (c) 2020 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + * + * Based on Linux driver + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <linux/bitops.h> +#include <rng.h> + +/* Device specific register offsets */ +#define PRNG_DATA_OUT 0x0000 +#define PRNG_STATUS 0x0004 +#define PRNG_LFSR_CFG 0x0100 +#define PRNG_CONFIG 0x0104 + +/* Device specific register masks and config values */ +#define PRNG_LFSR_CFG_MASK 0x0000ffff +#define PRNG_LFSR_CFG_CLOCKS 0x0000dddd +#define PRNG_CONFIG_HW_ENABLE BIT(1) +#define PRNG_STATUS_DATA_AVAIL BIT(0) + +#define MAX_HW_FIFO_DEPTH 16 +#define MAX_HW_FIFO_SIZE (MAX_HW_FIFO_DEPTH * 4) +#define WORD_SZ 4 + +struct msm_rng_priv { + phys_addr_t base; + struct clk clk; +}; + +static int msm_rng_read(struct udevice *dev, void *data, size_t len) +{ + struct msm_rng_priv *priv = dev_get_priv(dev); + size_t currsize = 0; + u32 *retdata = data; + size_t maxsize; + u32 val; + + /* calculate max size bytes to transfer back to caller */ + maxsize = min_t(size_t, MAX_HW_FIFO_SIZE, len); + + /* read random data from hardware */ + do { + val = readl_relaxed(priv->base + PRNG_STATUS); + if (!(val & PRNG_STATUS_DATA_AVAIL)) + break; + + val = readl_relaxed(priv->base + PRNG_DATA_OUT); + if (!val) + break; + + *retdata++ = val; + currsize += WORD_SZ; + + /* make sure we stay on 32bit boundary */ + if ((maxsize - currsize) < WORD_SZ) + break; + } while (currsize < maxsize); + + return 0; +} + +static int msm_rng_enable(struct msm_rng_priv *priv, int enable) +{ + u32 val; + + if (enable) { + /* Enable PRNG only if it is not already enabled */ + val = readl_relaxed(priv->base + PRNG_CONFIG); + if (val & PRNG_CONFIG_HW_ENABLE) { + val = readl_relaxed(priv->base + PRNG_LFSR_CFG); + val &= ~PRNG_LFSR_CFG_MASK; + val |= PRNG_LFSR_CFG_CLOCKS; + writel(val, priv->base + PRNG_LFSR_CFG); + + val = readl_relaxed(priv->base + PRNG_CONFIG); + val |= PRNG_CONFIG_HW_ENABLE; + writel(val, priv->base + PRNG_CONFIG); + } + } else { + val = readl_relaxed(priv->base + PRNG_CONFIG); + val &= ~PRNG_CONFIG_HW_ENABLE; + writel(val, priv->base + PRNG_CONFIG); + } + + return 0; +} + +static int msm_rng_probe(struct udevice *dev) +{ + struct msm_rng_priv *priv = dev_get_priv(dev); + + int ret; + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) + return ret; + + ret = clk_enable(&priv->clk); + if (ret < 0) + return ret; + + return msm_rng_enable(priv, 1); +} + +static int msm_rng_remove(struct udevice *dev) +{ + struct msm_rng_priv *priv = dev_get_priv(dev); + + return msm_rng_enable(priv, 0); +} + +static const struct dm_rng_ops msm_rng_ops = { + .read = msm_rng_read, +}; + +static const struct udevice_id msm_rng_match[] = { + { .compatible = "qcom,prng", }, + {}, +}; + +U_BOOT_DRIVER(msm_rng) = { + .name = "msm-rng", + .id = UCLASS_RNG, + .of_match = msm_rng_match, + .ops = &msm_rng_ops, + .probe = msm_rng_probe, + .remove = msm_rng_remove, + .priv_auto_alloc_size = sizeof(struct msm_rng_priv), +};
Hello Robert,
Can we make CONFIG_RNG_MSM depend on CONFIG_ARCH_IPQ40XX so it is not shown as choice for other architectures?
Should CONFIG_RNG_MSM default to yes on ARCH_IPQ40XX?
Best regards
Heinrich
On Mon, Dec 14, 2020 at 6:22 PM Heinrich Schuchardt xypron.debian@gmx.de wrote:
Qualcomm SoC-s.
Hello Robert,
Sure, as it's currently the only architecture using it.
It's currently enabled per board defconfig, I don't think it's vital enough to default to yes.
Regards, Robert
Best regards
Heinrich
Since we now have the driver for Qualcomm PRNG HW, lets use it and add the necessary clocks and nodes.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/dts/qcom-ipq4019.dtsi | 7 +++++++ arch/arm/mach-ipq40xx/clock-ipq4019.c | 4 ++++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/dts/qcom-ipq4019.dtsi b/arch/arm/dts/qcom-ipq4019.dtsi index 031691e5d2..7a52ea2c4e 100644 --- a/arch/arm/dts/qcom-ipq4019.dtsi +++ b/arch/arm/dts/qcom-ipq4019.dtsi @@ -60,6 +60,13 @@ u-boot,dm-pre-reloc; };
+ rng: rng@22000 { + compatible = "qcom,prng"; + reg = <0x22000 0x140>; + clocks = <&gcc GCC_PRNG_AHB_CLK>; + status = "disabled"; + }; + reset: gcc-reset@1800000 { compatible = "qcom,gcc-reset-ipq4019"; reg = <0x1800000 0x60000>; diff --git a/arch/arm/mach-ipq40xx/clock-ipq4019.c b/arch/arm/mach-ipq40xx/clock-ipq4019.c index d5b5f4cb79..31ae9719e8 100644 --- a/arch/arm/mach-ipq40xx/clock-ipq4019.c +++ b/arch/arm/mach-ipq40xx/clock-ipq4019.c @@ -54,6 +54,10 @@ static int msm_enable(struct clk *clk) /* This clock is already initialized by SBL1 */ return 0; break; + case GCC_PRNG_AHB_CLK: /*PRNG*/ + /* This clock is already initialized by SBL1 */ + return 0; + break; default: return 0; }
Robert Marko
