[PATCH V5 1/2] mmc: add OpenPiton mmc support
From: Tianrui Wei tianrui-wei@outlook.com Date: Fri, 4 June 2021 12:45:29 +0800 Subject: [PATCH v5 1/2] mmc: add OpenPiton mmc support
This patch adds mmc support for OpenPiton board.
Changelog:
v5: move definitions around, changed some incompatible type information
Signed-off-by: Tianrui Wei tianrui-wei@outlook.com Signed-off-by: Jonathan Balkind jbalkind@ucsb.edu ---
drivers/mmc/Kconfig | 7 + drivers/mmc/Makefile | 1 + drivers/mmc/piton_mmc.c | 174 +++++ 3 files changed, 182 insertions(+) create mode 100644 drivers/mmc/piton_mmc.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 14d79139..1038800f 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -707,6 +707,13 @@ config MMC_SUNXI_HAS_MODE_SWITCH bool depends on MMC_SUNXI
+config MMC_PITON + bool "MMC support for openpiton SoC" + depends on DM_MMC && BLK + help + This driver enables SD card support in U-Boot port for + OpenPiton SoC + config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 1c849cba..698dfe05 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -71,6 +71,7 @@ obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o obj-$(CONFIG_MMC_SDHCI_ZYNQ) += zynq_sdhci.o
obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o +obj-$(CONFIG_MMC_PITON) += piton_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += tmio-common.o uniphier-sd.o obj-$(CONFIG_RENESAS_SDHI) += tmio-common.o renesas-sdhi.o obj-$(CONFIG_MMC_BCM2835) += bcm2835_sdhost.o diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c new file mode 100644 index 00000000..2b2d5756 --- /dev/null +++ b/drivers/mmc/piton_mmc.c @@ -0,0 +1,174 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2009 SAMSUNG Electronics + * Minkyu Kang mk7.kang@samsung.com + * Jaehoon Chung jh80.chung@samsung.com + * Portions Copyright 2011-2019 NVIDIA Corporation + * Portions Copyright 2021 Tianrui Wei + * This file is adapted from tegra_mmc.c + * Tianrui Wei tianrui-wei@outlook.com + */ + +#include <asm/gpio.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <linux/bitops.h> +#include <linux/types.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <log.h> +#include <div64.h> +#include <mmc.h> + +struct piton_mmc_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +struct piton_mmc_priv { + u64 piton_mmc_base_addr; /* peripheral id */ +}; + +/* + * see mmc_read_blocks to see how it is used. + * start block is hidden at cmd->arg + * also, initialize the block size at init + */ +static int piton_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + /* check first if this is a pure command */ + if (!data) + return 0; + + u64 byte_cnt, start_block, start_addr; + + struct piton_mmc_priv *priv = dev_get_priv(dev); + unsigned long *buff = (unsigned long *)data->dest; + + start_addr = priv->piton_mmc_base_addr + (start_block); + byte_cnt = data->blocks * data->blocksize; + start_block = cmd->cmdarg; + + /* if there is a read */ + if (data->flags & MMC_DATA_READ) { + for (u64 i = 0; i < byte_cnt; i += 4) { + *(buff) = readl((void *)(start_addr + i)); + buff++; + } + } else { + /* else there is a write + * we don't handle write, so error right away + */ + return -ENODEV; + } + + return 0; +} + +static int piton_mmc_ofdata_to_platdata(struct udevice *dev) +{ + struct piton_mmc_priv *priv = dev_get_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg; + struct mmc *mmc; + /* fill in device description */ + struct blk_desc *bdesc; + + priv->piton_mmc_base_addr = dev_read_addr(dev); + cfg = &plat->cfg; + cfg->name = "PITON MMC"; + cfg->host_caps = MMC_MODE_8BIT; + cfg->f_max = 100000; + cfg->f_min = 400000; + cfg->voltages = MMC_VDD_21_22; + + mmc = &plat->mmc; + mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + mmc->capacity_user = 0x100000000; + mmc->capacity_user *= mmc->read_bl_len; + mmc->capacity_boot = 0; + mmc->capacity_rpmb = 0; + for (int i = 0; i < 4; i++) + mmc->capacity_gp[i] = 0; + mmc->capacity = 0x2000000000ULL; + mmc->has_init = 1; + + bdesc = mmc_get_blk_desc(mmc); + bdesc->lun = 0; + bdesc->hwpart = 0; + bdesc->type = 0; + bdesc->blksz = mmc->read_bl_len; + bdesc->log2blksz = LOG2(bdesc->blksz); + bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len); + + return 0; +} + +/* test if piton has the micro mmc card present + * always return 1, which means present + */ +static int piton_mmc_getcd(struct udevice *dev) +{ + /* + * always return 1 + */ + return 1; +} + +/* dummy function, piton_mmc don't need initialization + * in hw + */ +static const struct dm_mmc_ops piton_mmc_ops = { + .send_cmd = piton_mmc_send_cmd, + .get_cd = piton_mmc_getcd, +}; + +static int piton_mmc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + upriv->mmc = &plat->mmc; + upriv->mmc->has_init = 1; + upriv->mmc->capacity = 0x2000000000ULL; + upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + + return 0; +} + +static int piton_mmc_bind(struct udevice *dev) +{ + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT; + cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; + cfg->f_min = 1000000; + cfg->f_max = 52000000; + cfg->b_max = U32_MAX; + + return mmc_bind(dev, &plat->mmc, cfg); +} + +static const struct udevice_id piton_mmc_ids[] = { + {.compatible = "openpiton,piton-mmc"}, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(piton_mmc_drv) = { + .name = "piton_mmc", + .id = UCLASS_MMC, + .of_match = piton_mmc_ids, + .ofdata_to_platdata = piton_mmc_ofdata_to_platdata, + .bind = piton_mmc_bind, + .probe = piton_mmc_probe, + .ops = &piton_mmc_ops, + .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat), + .priv_auto_alloc_size = sizeof(struct piton_mmc_priv), +};
Changelog:
+config MMC_PITON
- bool "MMC support for openpiton SoC"
- depends on DM_MMC && BLK
- help
- This driver enables SD card support in U-Boot port for
We already know it's for U-Boot ;)
- OpenPiton SoC
Please add a bit more than this. In particular, it would be useful to note that this is an "emulated" device where the host does all of the work.
- config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91
- (C) Copyright 2009 SAMSUNG Electronics
- Minkyu Kang mk7.kang@samsung.com
- Jaehoon Chung jh80.chung@samsung.com
- Portions Copyright 2011-2019 NVIDIA Corporation
- Portions Copyright 2021 Tianrui Wei
- This file is adapted from tegra_mmc.c
- Tianrui Wei tianrui-wei@outlook.com
- struct mmc_config cfg;
- struct mmc mmc;
- u64 piton_mmc_base_addr; /* peripheral id */
Again, please use void __iomem *.
- see mmc_read_blocks to see how it is used.
- start block is hidden at cmd->arg
Hidden?
- also, initialize the block size at init
Nit: alignment
- /* check first if this is a pure command */
- if (!data)
Variable declarations come before code.
- u64 byte_cnt, start_block, start_addr;
I think these should be size_t, since you use it for pointer arithmetic.
- struct piton_mmc_priv *priv = dev_get_priv(dev);
- unsigned long *buff = (unsigned long *)data->dest;
- start_addr = priv->piton_mmc_base_addr + (start_block);
- byte_cnt = data->blocks * data->blocksize;
What should happen if (byte_cnt & 3)?
- start_block = cmd->cmdarg;
- /* if there is a read */
- if (data->flags & MMC_DATA_READ) {
Declare i with the rest of the variables.
I think this could be rewritten as
size_t byte_cnt; u32 *buff, *start_addr;
for (byte_cnt = /* ... */; byte_cnt; byte_cnt -= sizeof(u32)); *buff++ = readl(start_addr++);
Which more closely follows the model of memcpy. Speaking of which, I thought you were going to use it:
Scratch the previous email, I stand corrected. You're right about memcpy could work, thanks for the great suggestion :P
What happened to that?
buff++;
- } else {
return -ENODEV;
Please use -ENOSYS. See [1] for details.
In general, several of my comments on your previous patch are still unaddressed. I would like if you could either respond to them with your reasoning for not addressing them, or implement them.
--Sean
[1] https://u-boot.readthedocs.io/en/latest/develop/driver-model/design.html#err...
- struct piton_mmc_plat *plat = dev_get_platdata(dev);
- struct mmc_config *cfg;
- struct mmc *mmc;
- /* fill in device description */
- struct blk_desc *bdesc;
- priv->piton_mmc_base_addr = dev_read_addr(dev);
- cfg = &plat->cfg;
- cfg->name = "PITON MMC";
- cfg->host_caps = MMC_MODE_8BIT;
- cfg->f_max = 100000;
- cfg->f_min = 400000;
- cfg->voltages = MMC_VDD_21_22;
- mmc = &plat->mmc;
- mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
- mmc->capacity_user = 0x100000000;
- mmc->capacity_user *= mmc->read_bl_len;
- mmc->capacity_boot = 0;
- mmc->capacity_rpmb = 0;
- for (int i = 0; i < 4; i++)
- mmc->capacity = 0x2000000000ULL;
- mmc->has_init = 1;
- bdesc = mmc_get_blk_desc(mmc);
- bdesc->lun = 0;
- bdesc->hwpart = 0;
- bdesc->type = 0;
- bdesc->blksz = mmc->read_bl_len;
- bdesc->log2blksz = LOG2(bdesc->blksz);
- bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len);
- always return 1, which means present
* always return 1
- return 1;
- in hw
- .send_cmd = piton_mmc_send_cmd,
- .get_cd = piton_mmc_getcd,
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct mmc_config *cfg = &plat->cfg;
- cfg->name = dev->name;
- upriv->mmc = &plat->mmc;
- upriv->mmc->has_init = 1;
- upriv->mmc->capacity = 0x2000000000ULL;
- upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
- cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT;
- cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34;
- cfg->f_min = 1000000;
- cfg->f_max = 52000000;
- cfg->b_max = U32_MAX;
- return mmc_bind(dev, &plat->mmc, cfg);
{ /* sentinel */ }
- .name = "piton_mmc",
- .id = UCLASS_MMC,
- .of_match = piton_mmc_ids,
- .ofdata_to_platdata = piton_mmc_ofdata_to_platdata,
- .bind = piton_mmc_bind,
- .probe = piton_mmc_probe,
- .ops = &piton_mmc_ops,
- .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat),
- .priv_auto_alloc_size = sizeof(struct piton_mmc_priv),
Dear Sean,
Many thanks for taking the time and energy to review our patches ( again ) And sorry about not responding or not implementing them. I'll go through them one by one and try to doing so in the future :P
Changelog:
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 14d79139..1038800f 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -707,6 +707,13 @@ config MMC_SUNXI_HAS_MODE_SWITCH bool depends on MMC_SUNXI +config MMC_PITON + bool "MMC support for openpiton SoC" + depends on DM_MMC && BLK + help + This driver enables SD card support in U-Boot port for
:P
+ OpenPiton SoC
Will do :P
config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 1c849cba..698dfe05 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -71,6 +71,7 @@ obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o obj-$(CONFIG_MMC_SDHCI_ZYNQ) += zynq_sdhci.o obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o +obj-$(CONFIG_MMC_PITON) += piton_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += tmio-common.o uniphier-sd.o obj-$(CONFIG_RENESAS_SDHI) += tmio-common.o renesas-sdhi.o obj-$(CONFIG_MMC_BCM2835) += bcm2835_sdhost.o diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c new file mode 100644 index 00000000..2b2d5756 --- /dev/null +++ b/drivers/mmc/piton_mmc.c @@ -0,0 +1,174 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
Sorry, forgot this change :(
Hidden?
I wrote this comment a long time ago, I'll comment it out.
Nit: alignment
I'm not sure how to align this? Should I align the struct in the first line and the second line? It appears so in my email client :P
Will do :P
Will do :P
The 1th or 3rd byte will be read into buf,
Thanks for the style suggestion :P I'll use that
I checked with Professor Balkind regarding memcpy, and there were some issues with it because it's accessing an I/O device we need to maintain particular alignment which memcpy might not do, so we're sticking with the old implementation.
Will do :P
Will definitely do that in the future :P
Tianrui
--Sean
[1] https://apac01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fu-boot.re...
+ return 0; +}
+ return 0; +}
- in hw
+ return 0; +}
On 6/6/21 12:57 PM, Tianrui Wei wrote:
Dear Sean,
Changelog:
- help
:P
- OpenPiton SoC
Will do :P
- struct mmc mmc;
Hidden?
Nit: alignment
In your original email, this second line has 7 tabs, whereas the line above it has 29 characters before the `(`. I'm not sure why it's aligned in my reply. You can see the misaligned issue if you view your patch in patchwork.
- if (!data)
Will do :P
Will do :P
Ah, disregard this; presumably blocksize will always be a (large enough) power of two.
Ok.
buff++;
- } else {
return -ENODEV;
Will do :P
Tianrui
--Sean
- struct mmc *mmc;
- cfg = &plat->cfg;
- mmc = &plat->mmc;
- bdesc->lun = 0;
- bdesc->type = 0;
* always return 1
- return 1;
- in hw
{ /* sentinel */ }
- .id = UCLASS_MMC,
Sean Anderson
Tianrui Wei
