[PATCH v8 1/2] led: led_cortina: Add CAxxx LED support
Add Cortina Access LED controller support for CAxxxx SOCs
Signed-off-by: Jway Lin jway.lin@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com CC: Simon Glass sjg@chromium.org
Changes in v8: - No code change - Split out individual driver from Cortina Package 2 patch series to help streamline acceptence into master
Changes in v7: - rename OFFSET to SHIFT from macros - add additinal struct comments - Reading the DT should really happen in the ofdata_to_platdata method
Changes in v4: - remove unused macros - remove cortina prefix from macros - remove use BSS variable - further cleanup to meet code style guidelines - add additinal struct comments - rename DT blink rate symbol
MAINTAINERS | 8 +- drivers/led/Kconfig | 8 ++ drivers/led/Makefile | 1 + drivers/led/led_cortina.c | 305 ++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 321 insertions(+), 1 deletion(-) create mode 100644 drivers/led/led_cortina.c
diff --git a/MAINTAINERS b/MAINTAINERS index 8add9d4..7a624bd 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -181,6 +181,9 @@ F: drivers/gpio/cortina_gpio.c F: drivers/watchdog/cortina_wdt.c F: drivers/serial/serial_cortina.c F: drivers/mmc/ca_dw_mmc.c +F: drivers/i2c/i2c-cortina.c +F: drivers/i2c/i2c-cortina.h +F: drivers/led/led_cortina.c
ARM/CZ.NIC TURRIS MOX SUPPORT M: Marek Behun marek.behun@nic.cz @@ -732,6 +735,9 @@ F: drivers/gpio/cortina_gpio.c F: drivers/watchdog/cortina_wdt.c F: drivers/serial/serial_cortina.c F: drivers/mmc/ca_dw_mmc.c +F: drivers/i2c/i2c-cortina.c +F: drivers/i2c/i2c-cortina.h +F: drivers/led/led_cortina.c
MIPS MSCC M: Gregory CLEMENT gregory.clement@bootlin.com @@ -824,7 +830,7 @@ S: Maintained F: arch/powerpc/
POWERPC MPC8XX -M: Christophe Leroy christophe.leroy@csgroup.eu +M: Christophe Leroy christophe.leroy@c-s.fr S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-mpc8xx.git F: arch/powerpc/cpu/mpc8xx/ diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index 6675934..cc87fbf 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -35,6 +35,14 @@ config LED_BCM6858 This option enables support for LEDs connected to the BCM6858 HW has blinking capabilities and up to 32 LEDs can be controlled.
+config LED_CORTINA + bool "LED Support for Cortina Access CAxxxx SoCs" + depends on LED && (CORTINA_PLATFORM) + help + This option enables support for LEDs connected to the Cortina + Access CAxxxx SOCs. + + config LED_BLINK bool "Support LED blinking" depends on LED diff --git a/drivers/led/Makefile b/drivers/led/Makefile index 3654dd3..8e3ae7f 100644 --- a/drivers/led/Makefile +++ b/drivers/led/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_LED_BCM6328) += led_bcm6328.o obj-$(CONFIG_LED_BCM6358) += led_bcm6358.o obj-$(CONFIG_LED_BCM6858) += led_bcm6858.o obj-$(CONFIG_$(SPL_)LED_GPIO) += led_gpio.o +obj-$(CONFIG_LED_CORTINA) += led_cortina.o diff --git a/drivers/led/led_cortina.c b/drivers/led/led_cortina.c new file mode 100644 index 0000000..a6d9159 --- /dev/null +++ b/drivers/led/led_cortina.c @@ -0,0 +1,305 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/* + * Copyright (C) 2020 Cortina-Access + * Author: Jway Lin jway.lin@cortina-access.com + * + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <led.h> +#include <asm/io.h> +#include <dm/lists.h> + +#define LED_MAX_HW_BLINK 127 +#define LED_MAX_COUNT 16 + +/* LED_CONTROL fields */ +#define LED_BLINK_RATE1_SHIFT 0 +#define LED_BLINK_RATE1_MASK 0xff +#define LED_BLINK_RATE2_SHIFT 8 +#define LED_BLINK_RATE2_MASK 0xff +#define LED_CLK_TEST BIT(16) +#define LED_CLK_POLARITY BIT(17) +#define LED_CLK_TEST_MODE BIT(16) +#define LED_CLK_TEST_RX_TEST BIT(30) +#define LED_CLK_TEST_TX_TEST BIT(31) + +/* LED_CONFIG fields */ +#define LED_EVENT_ON_SHIFT 0 +#define LED_EVENT_ON_MASK 0x7 +#define LED_EVENT_BLINK_SHIFT 3 +#define LED_EVENT_BLINK_MASK 0x7 +#define LED_EVENT_OFF_SHIFT 6 +#define LED_EVENT_OFF_MASK 0x7 +#define LED_OFF_ON_SHIFT 9 +#define LED_OFF_ON_MASK 0x3 +#define LED_PORT_SHIFT 11 +#define LED_PORT_MASK 0x7 +#define LED_OFF_VAL BIT(14) +#define LED_SW_EVENT BIT(15) +#define LED_BLINK_SEL BIT(16) + +/* LED_CONFIG structures */ +struct cortina_led_cfg { + void __iomem *regs; + u32 pin; /* LED pin nubmer */ + bool active_low; /*Active-High or Active-Low*/ + u32 off_event; /* set led off event (RX,TX,SW)*/ + u32 blink_event; /* set led blink event (RX,TX,SW)*/ + u32 on_event; /* set led on event (RX,TX,SW)*/ + u32 port; /* corresponding ethernet port */ + int blink_sel; /* select blink-rate1 or blink-rate2 */ +}; + +/* LED_control structures */ +struct cortina_led_platdata { + void __iomem *ctrl_regs; + u16 rate1; /* blink rate setting 0 */ + u16 rate2; /* blink rate setting 1 */ +}; + +enum ca_led_state_t { + CA_EVENT_MODE = 0, + CA_LED_ON = 1, + CA_LED_OFF, +}; + +static void cortina_led_write(void __iomem *reg, unsigned long data) +{ + writel(data, reg); +} + +static unsigned long cortina_led_read(void __iomem *reg) +{ + return readl(reg); +} + +static enum led_state_t cortina_led_get_state(struct udevice *dev) +{ + struct cortina_led_cfg *priv = dev_get_priv(dev); + enum led_state_t state = LEDST_OFF; + u32 val; + + val = readl(priv->regs); + + if (val & LED_SW_EVENT) + state = LEDST_ON; + + return state; +} + +static int cortina_led_set_state(struct udevice *dev, enum led_state_t state) +{ + u32 val; + struct cortina_led_cfg *priv = dev_get_priv(dev); + + val = readl(priv->regs); + val &= ~(LED_OFF_ON_MASK << LED_OFF_ON_SHIFT); + + switch (state) { + case LEDST_OFF: + val &= ~LED_SW_EVENT; + val |= CA_LED_OFF << LED_OFF_ON_SHIFT; + cortina_led_write(priv->regs, val); + break; + case LEDST_ON: + val |= LED_SW_EVENT; + val |= CA_LED_ON << LED_OFF_ON_SHIFT; + cortina_led_write(priv->regs, val); + break; + case LEDST_TOGGLE: + if (cortina_led_get_state(dev) == LEDST_OFF) + return cortina_led_set_state(dev, LEDST_ON); + else + return cortina_led_set_state(dev, LEDST_OFF); + break; +#ifdef CONFIG_LED_BLINK + case LEDST_BLINK: + val &= ~LED_SW_EVENT; + val |= CA_LED_OFF << LED_OFF_ON_SHIFT; + val |= LED_EVENT_BLINK_MASK << LED_EVENT_BLINK_SHIFT; + cortina_led_write(priv->regs, val); + break; +#endif + + default: + return -EINVAL; + } + + return 0; +} + +static const struct led_ops cortina_led_ops = { + .get_state = cortina_led_get_state, + .set_state = cortina_led_set_state, +}; + +static int ca_led_ofdata_to_platdata(struct udevice *dev) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); + + /* Top-level LED node */ + if (!uc_plat->label) { + struct cortina_led_platdata *plt = dev_get_platdata(dev); + + plt->rate1 = + dev_read_u32_default(dev, "Cortina,blink-rate1", 256); + plt->rate2 = + dev_read_u32_default(dev, "Cortina,blink-rate2", 512); + plt->ctrl_regs = dev_remap_addr(dev); + } else { + struct cortina_led_cfg *priv = dev_get_priv(dev); + + priv->regs = dev_remap_addr(dev_get_parent(dev)); + priv->pin = dev_read_u32_default(dev, "pin", LED_MAX_COUNT); + priv->blink_sel = dev_read_u32_default(dev, "blink-sel", 0); + priv->off_event = dev_read_u32_default(dev, "off-event", 0); + priv->blink_event = dev_read_u32_default(dev, "blink-event", 0); + priv->on_event = dev_read_u32_default(dev, "on-event", 0); + priv->port = dev_read_u32_default(dev, "port", 0); + + if (dev_read_bool(dev, "active-low")) + priv->active_low = true; + else + priv->active_low = false; + } + + return 0; +} + +static int cortina_led_probe(struct udevice *dev) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); + + /* Top-level LED node */ + if (!uc_plat->label) { + struct cortina_led_platdata *platdata = dev_get_platdata(dev); + u32 reg_value, val; + u16 rate1, rate2; + + if (!platdata->ctrl_regs) + return -EINVAL; + + reg_value = 0; + reg_value |= LED_CLK_POLARITY; + + rate1 = platdata->rate1; + rate2 = platdata->rate2; + + val = rate1 / 16 - 1; + rate1 = val > LED_MAX_HW_BLINK ? + LED_MAX_HW_BLINK : val; + reg_value |= (rate1 & LED_BLINK_RATE1_MASK) << + LED_BLINK_RATE1_SHIFT; + + val = rate2 / 16 - 1; + rate2 = val > LED_MAX_HW_BLINK ? + LED_MAX_HW_BLINK : val; + reg_value |= (rate2 & LED_BLINK_RATE2_MASK) << + LED_BLINK_RATE2_SHIFT; + + cortina_led_write(platdata->ctrl_regs, reg_value); + + } else { + struct cortina_led_cfg *priv = dev_get_priv(dev); + void __iomem *regs; + u32 val, port, off_event, blink_event, on_event; + + regs = priv->regs; + if (!regs) + return -EINVAL; + + if (priv->pin >= LED_MAX_COUNT) + return -EINVAL; + + priv->regs = regs + 4 + priv->pin * 4; + + val = cortina_led_read(priv->regs); + + if (priv->active_low) + val |= LED_OFF_VAL; + else + val &= ~LED_OFF_VAL; + + if (priv->blink_sel == 0) + val &= ~LED_BLINK_SEL; + else if (priv->blink_sel == 1) + val |= LED_BLINK_SEL; + + off_event = priv->off_event; + val &= ~(LED_EVENT_OFF_MASK << LED_EVENT_OFF_SHIFT); + if (off_event != 0) + val |= BIT(off_event) << LED_EVENT_OFF_SHIFT; + + blink_event = priv->blink_event; + val &= ~(LED_EVENT_BLINK_MASK << LED_EVENT_BLINK_SHIFT); + if (blink_event != 0) + val |= BIT(blink_event) << LED_EVENT_BLINK_SHIFT; + + on_event = priv->on_event; + val &= ~(LED_EVENT_ON_MASK << LED_EVENT_ON_SHIFT); + if (on_event != 0) + val |= BIT(on_event) << LED_EVENT_ON_SHIFT; + + port = priv->port; + val &= ~(LED_PORT_MASK << LED_PORT_SHIFT); + val |= port << LED_PORT_SHIFT; + + /* force off */ + val &= ~(LED_OFF_ON_MASK << LED_OFF_ON_SHIFT); + val |= CA_LED_OFF << LED_OFF_ON_SHIFT; + + cortina_led_write(priv->regs, val); + } + + return 0; +} + +static int cortina_led_bind(struct udevice *parent) +{ + ofnode node; + + dev_for_each_subnode(node, parent) { + struct led_uc_plat *uc_plat; + struct udevice *dev; + const char *label; + int ret; + + label = ofnode_read_string(node, "label"); + if (!label) { + debug("%s: node %s has no label\n", __func__, + ofnode_get_name(node)); + return -EINVAL; + } + + ret = device_bind_driver_to_node(parent, "ca-leds", + ofnode_get_name(node), + node, &dev); + if (ret) + return ret; + uc_plat = dev_get_uclass_platdata(dev); + uc_plat->label = label; + } + + return 0; +} + +static const struct udevice_id ca_led_ids[] = { + { .compatible = "cortina,ca-leds" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(cortina_led) = { + .name = "ca-leds", + .id = UCLASS_LED, + .of_match = ca_led_ids, + .ofdata_to_platdata = ca_led_ofdata_to_platdata, + .bind = cortina_led_bind, + .probe = cortina_led_probe, + .platdata_auto_alloc_size = sizeof(struct cortina_led_platdata), + .priv_auto_alloc_size = sizeof(struct cortina_led_cfg), + .ops = &cortina_led_ops, +};
Add LED support for Cortina Access Presidio Engineering Board
Signed-off-by: Jway Lin jway.lin@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v8: None Changes in v7: None Changes in v4: - rename DT blink rate symbol
arch/arm/dts/ca-presidio-engboard.dts | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/arch/arm/dts/ca-presidio-engboard.dts b/arch/arm/dts/ca-presidio-engboard.dts index c03dacc..2075539 100644 --- a/arch/arm/dts/ca-presidio-engboard.dts +++ b/arch/arm/dts/ca-presidio-engboard.dts @@ -66,4 +66,35 @@ spi-max-frequency = <108000000>; }; }; + + leds: led-controller@f43200f0 { + compatible = "cortina,ca-leds"; + reg = <0x0 0xf43200f0 0x40>; + + cortina,blink-rate1 = <256>; + cortina,blink-rate2 = <512>; + + led@0 { + pin = <0>; + active-low; + blink-sel =<0>; + port = <0>; + off-event = <0>; + label = "led0"; + }; + + led@1 { + pin = <1>; + active-low; + blink-sel =<1>; + label = "led1"; + }; + + led@2 { + pin = <2>; + active-low; + label = "led2"; + }; + + }; };
Hi Alex,
On Thu, 21 May 2020 at 18:43, Alex Nemirovsky alex.nemirovsky@cortina-access.com wrote:
Changes in v8:
- No code change
Changes in v7:
Changes in v4:
One comment below
u32 val;
switch (state) {
case LEDST_OFF:
break;
case LEDST_ON:
break;
case LEDST_TOGGLE:
else
break;
case LEDST_BLINK:
break;
Try to void #ifdef. You should be able to do this:
case CONFIG_LED_BLINK: if (IS_ENABLED(CONFIG_LED_BLINK)) { val code ... break; } /* no break */
default:
return -EINVAL;
plt->rate1 =
plt->rate2 =
} else {
else
u32 reg_value, val;
u16 rate1, rate2;
return -EINVAL;
reg_value = 0;
} else {
void __iomem *regs;
regs = priv->regs;
if (!regs)
return -EINVAL;
return -EINVAL;
val |= LED_OFF_VAL;
else
if (off_event != 0)
if (on_event != 0)
port = priv->port;
/* force off */
ofnode node;
const char *label;
int ret;
if (!label) {
return -EINVAL;
node, &dev);
if (ret)
return ret;
{ /* sentinel */ }
.name = "ca-leds",
.id = UCLASS_LED,
2.7.4
Alex Nemirovsky
