[U-Boot] [PATCH 1/2 V3] EXYNOS5: PINMUX: Added default pinumx settings
This patch performs the pinmux configuration in a common file. As of now only EXYNOS5 pinmux for SDMMC, UART and Ethernet is supported.
Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Chander Kashyap chander.kashyap@linaro.org --- Changes in V2: - Adding pinmux.c to Makefile moved to this patch. - exynos5_pinmux_config made static Changes in V3: - Separate functions made for each peripheral - enum periph_id moved to a separate periph.h arch/arm/cpu/armv7/exynos/Makefile | 2 +- arch/arm/cpu/armv7/exynos/pinmux.c | 224 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/periph.h | 47 ++++++ arch/arm/include/asm/arch-exynos/pinmux.h | 58 ++++++++ 4 files changed, 330 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/exynos/pinmux.c create mode 100644 arch/arm/include/asm/arch-exynos/periph.h create mode 100644 arch/arm/include/asm/arch-exynos/pinmux.h
diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index 90ec2bd..9119961 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -22,7 +22,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-COBJS += clock.o power.o soc.o system.o +COBJS += clock.o power.o soc.o system.o pinmux.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c new file mode 100644 index 0000000..c1321c6 --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -0,0 +1,224 @@ +/* + * Copyright (c) 2012 Samsung Electronics. + * Abhilash Kesavan a.kesavan@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/sromc.h> + +static void exynos5_uart_config(int peripheral) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + struct s5p_gpio_bank *bank; + int i, start, count; + + switch (peripheral) { + case PERIPH_ID_UART0: + bank = &gpio1->a0; + start = 0; + count = 4; + break; + case PERIPH_ID_UART1: + bank = &gpio1->a0; + start = 4; + count = 4; + break; + case PERIPH_ID_UART2: + bank = &gpio1->a1; + start = 0; + count = 4; + break; + case PERIPH_ID_UART3: + bank = &gpio1->a1; + start = 4; + count = 2; + break; + } + for (i = start; i < start + count; i++) { + s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + } +} + +static void exynos5_mmc_config(int peripheral, int flags) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + struct s5p_gpio_bank *bank, *bank_ext; + int i; + switch (peripheral) { + case PERIPH_ID_SDMMC0: + bank = &gpio1->c0; + bank_ext = &gpio1->c1; + break; + case PERIPH_ID_SDMMC1: + bank = &gpio1->c1; + bank_ext = NULL; + break; + case PERIPH_ID_SDMMC2: + bank = &gpio1->c2; + bank_ext = &gpio1->c3; + break; + case PERIPH_ID_SDMMC3: + bank = &gpio1->c3; + bank_ext = NULL; + break; + } + if ((flags & PINMUX_FLAG_8BIT_MODE) && !bank_ext) { + debug("SDMMC device %d does not support 8bit mode", + peripheral); + return -1; + } + if (flags & PINMUX_FLAG_8BIT_MODE) { + for (i = 3; i <= 6; i++) { + s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x3)); + s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); + s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + } + } + for (i = 0; i < 2; i++) { + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); + s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + } + for (i = 3; i <= 6; i++) { + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + s5p_gpio_set_pull(bank, i, GPIO_PULL_UP); + s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + } +} + +static void exynos5_sromc_config(int flags) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + int i; + + /* + * SROM:CS1 and EBI + * + * GPY0[0] SROM_CSn[0] + * GPY0[1] SROM_CSn[1](2) + * GPY0[2] SROM_CSn[2] + * GPY0[3] SROM_CSn[3] + * GPY0[4] EBI_OEn(2) + * GPY0[5] EBI_EEn(2) + * + * GPY1[0] EBI_BEn[0](2) + * GPY1[1] EBI_BEn[1](2) + * GPY1[2] SROM_WAIT(2) + * GPY1[3] EBI_DATA_RDn(2) + */ + s5p_gpio_cfg_pin(&gpio1->y0, (flags & PINMUX_FLAG_BANK), + GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->y0, 4, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->y0, 5, GPIO_FUNC(2)); + + for (i = 0; i < 4; i++) + s5p_gpio_cfg_pin(&gpio1->y1, i, GPIO_FUNC(2)); + + /* + * EBI: 8 Addrss Lines + * + * GPY3[0] EBI_ADDR[0](2) + * GPY3[1] EBI_ADDR[1](2) + * GPY3[2] EBI_ADDR[2](2) + * GPY3[3] EBI_ADDR[3](2) + * GPY3[4] EBI_ADDR[4](2) + * GPY3[5] EBI_ADDR[5](2) + * GPY3[6] EBI_ADDR[6](2) + * GPY3[7] EBI_ADDR[7](2) + * + * EBI: 16 Data Lines + * + * GPY5[0] EBI_DATA[0](2) + * GPY5[1] EBI_DATA[1](2) + * GPY5[2] EBI_DATA[2](2) + * GPY5[3] EBI_DATA[3](2) + * GPY5[4] EBI_DATA[4](2) + * GPY5[5] EBI_DATA[5](2) + * GPY5[6] EBI_DATA[6](2) + * GPY5[7] EBI_DATA[7](2) + * + * GPY6[0] EBI_DATA[8](2) + * GPY6[1] EBI_DATA[9](2) + * GPY6[2] EBI_DATA[10](2) + * GPY6[3] EBI_DATA[11](2) + * GPY6[4] EBI_DATA[12](2) + * GPY6[5] EBI_DATA[13](2) + * GPY6[6] EBI_DATA[14](2) + * GPY6[7] EBI_DATA[15](2) + */ + for (i = 0; i < 8; i++) { + s5p_gpio_cfg_pin(&gpio1->y3, i, GPIO_FUNC(2)); + s5p_gpio_set_pull(&gpio1->y3, i, GPIO_PULL_UP); + + s5p_gpio_cfg_pin(&gpio1->y5, i, GPIO_FUNC(2)); + s5p_gpio_set_pull(&gpio1->y5, i, GPIO_PULL_UP); + + s5p_gpio_cfg_pin(&gpio1->y6, i, GPIO_FUNC(2)); + s5p_gpio_set_pull(&gpio1->y6, i, GPIO_PULL_UP); + } +} + +static int exynos5_pinmux_config(int peripheral, int flags) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + struct s5p_gpio_bank *bank, *bank_ext; + int i, start, count; + + switch (peripheral) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + exynos5_uart_config(peripheral); + break; + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC1: + case PERIPH_ID_SDMMC2: + case PERIPH_ID_SDMMC3: + exynos5_mmc_config(peripheral, flags); + break; + case PERIPH_ID_SROMC: + exynos5_sromc_config(flags); + break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; + } + + return 0; +} + +int exynos_pinmux_config(int peripheral, int flags) +{ + if (cpu_is_exynos5()) + return exynos5_pinmux_config(peripheral, flags); + else { + debug("pinmux functionality not supported\n"); + return -1; + } +} diff --git a/arch/arm/include/asm/arch-exynos/periph.h b/arch/arm/include/asm/arch-exynos/periph.h new file mode 100644 index 0000000..5db25aa --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/periph.h @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARM_ARCH_PERIPH_H +#define __ASM_ARM_ARCH_PERIPH_H + +/* + * Peripherals requiring clock/pinmux configuration. List will + * grow with support for more devices getting added. + * + */ +enum periph_id { + PERIPH_ID_SDMMC0, + PERIPH_ID_SDMMC1, + PERIPH_ID_SDMMC2, + PERIPH_ID_SDMMC3, + PERIPH_ID_SROMC, + PERIPH_ID_UART0, + PERIPH_ID_UART1, + PERIPH_ID_UART2, + PERIPH_ID_UART3, + + PERIPH_ID_COUNT, + PERIPH_ID_NONE = -1, +}; + +#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/arch/arm/include/asm/arch-exynos/pinmux.h b/arch/arm/include/asm/arch-exynos/pinmux.h new file mode 100644 index 0000000..10ea736 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/pinmux.h @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Abhilash Kesavan a.kesavan@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARM_ARCH_PINMUX_H +#define __ASM_ARM_ARCH_PINMUX_H + +#include "periph.h" + +/* + * Flags for setting specific configarations of peripherals. + * List will grow with support for more devices getting added. + */ +enum { + PINMUX_FLAG_NONE = 0x00000000, + + /* Flags for eMMC */ + PINMUX_FLAG_8BIT_MODE = 1 << 0, /* SDMMC 8-bit mode */ + + /* Flags for SROM controller */ + PINMUX_FLAG_BANK = 3 << 0, /* bank number (0-3) */ + PINMUX_FLAG_16BIT = 1 << 2, /* 16-bit width */ +}; + +/** + * Configures the pinmux for a particular peripheral. + * + * Each gpio can be configured in many different ways (4 bits on exynos) + * such as "input", "output", "special function", "external interrupt" + * etc. This function will configure the peripheral pinmux along with + * pull-up/down and drive strength. + * + * @param peripheral peripheral to be configured + * @param flags configure flags + * @return 0 if ok, -1 on error (e.g. unsupported peripheral) + */ +int exynos_pinmux_config(int peripheral, int flags); + +#endif
Rajeshwari Shinde
