[U-Boot] [PATCH 1/2] tqma6_mba6: Fix the error handling in board_eth_init()
We should not return 0 on failure, so return a negative error code instead.
Also centralize the error path so that is easier to follow.
Cc: Markus Niebel Markus.Niebel@tq-group.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/tqc/tqma6/tqma6_mba6.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/board/tqc/tqma6/tqma6_mba6.c b/board/tqc/tqma6/tqma6_mba6.c index 6f4cffd..e58b714 100644 --- a/board/tqc/tqma6/tqma6_mba6.c +++ b/board/tqc/tqma6/tqma6_mba6.c @@ -309,24 +309,26 @@ int board_eth_init(bd_t *bis)
bus = fec_get_miibus(base, -1); if (!bus) - return 0; + return -EINVAL; /* scan phy */ phydev = phy_find_by_mask(bus, (0xf << CONFIG_FEC_MXC_PHYADDR), PHY_INTERFACE_MODE_RGMII);
if (!phydev) { - free(bus); - puts("No phy found\n"); - return 0; + ret = -EINVAL; + goto free_bus; } ret = fec_probe(bis, -1, base, bus, phydev); - if (ret) { - puts("FEC MXC: probe failed\n"); - free(phydev); - free(bus); - } + if (ret) + goto free_phydev;
return 0; + +free_phydev: + free(phydev); +free_bus: + free(bus); + return ret; }
int tqma6_bb_board_early_init_f(void)
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/udoo/udoo.c | 19 +++++++++++-------- 1 file changed, 11 insertions(+), 8 deletions(-)
diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index a8bd90a..a574a2f 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -191,23 +191,26 @@ int board_eth_init(bd_t *bis) #ifdef CONFIG_FEC_MXC bus = fec_get_miibus(base, -1); if (!bus) - return 0; + return -EINVAL; /* scan phy 4,5,6,7 */ phydev = phy_find_by_mask(bus, (0xf << 4), PHY_INTERFACE_MODE_RGMII);
if (!phydev) { - free(bus); - return 0; + ret = -EINVAL; + goto free_bus; } printf("using phy at %d\n", phydev->addr); ret = fec_probe(bis, -1, base, bus, phydev); - if (ret) { - printf("FEC MXC: %s:failed\n", __func__); - free(phydev); - free(bus); - } + if (ret) + goto free_phydev; #endif return 0; + +free_phydev: + free(phydev); +free_bus: + free(bus); + return ret; }
int board_mmc_init(bd_t *bis)
Fabio Estevam
