[PATCH 0/3] qcom: serial_msm: calculate UARTDM_CSR automatically
The msm serial UART controller has a bit clock divider register which much be programmed based on the UART clock. This changes per soc and currently is expected to be specified in DT or otherwise selected per board.
This series fixes the apq8016 and ipq4019 clock drivers to return the programmed UART clock rate in clk_set_rate(), it then uses this clock rate and the hardcoded baud rate supported by this driver to calculate the correct value for the UARTDM_CSR register.
--- Caleb Connolly (3): clk/qcom: apq8016: return valid rate when setting UART clock clk/qcom: ipq4019: return valid rate when setting UART clock serial: msm: calculate bit clock divider
doc/device-tree-bindings/serial/msm-serial.txt | 10 --- drivers/clk/qcom/clock-apq8016.c | 4 +- drivers/clk/qcom/clock-ipq4019.c | 2 +- drivers/serial/serial_msm.c | 87 +++++++++++++++++++++----- 4 files changed, 73 insertions(+), 30 deletions(-) --- base-commit: 42f6978987336cff3d98d9cc4643c54a1eb0f36d
// Caleb (they/them)
The clk_init_uart() helper always returns 0, but we're meant to return a real clock rate. Given that we hardcode 115200 baud, just return the clock rate that we set.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/clk/qcom/clock-apq8016.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/qcom/clock-apq8016.c b/drivers/clk/qcom/clock-apq8016.c index 5a5868169c89..6210fba87984 100644 --- a/drivers/clk/qcom/clock-apq8016.c +++ b/drivers/clk/qcom/clock-apq8016.c @@ -99,10 +99,10 @@ static ulong apq8016_clk_set_rate(struct clk *clk, ulong rate) case GCC_SDCC2_APPS_CLK: /* SDC2 */ return clk_init_sdc(priv, 1, rate); break; case GCC_BLSP1_UART2_APPS_CLK: /* UART2 */ - return apq8016_clk_init_uart(priv->base); - break; + apq8016_clk_init_uart(priv->base); + return 7372800; default: return 0; } }
clk_set_rate() should return the clock rate that was set. The IPQ4019 clock driver doesn't set any rates yet but it should still return the expected value so that drivers can work properly.
For a baud rate of 115200 with an expected bit clock divisor of 16, the clock rate should be 1843200 so return that frequency.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/clk/qcom/clock-ipq4019.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/qcom/clock-ipq4019.c b/drivers/clk/qcom/clock-ipq4019.c index d693776d339d..72f235eab212 100644 --- a/drivers/clk/qcom/clock-ipq4019.c +++ b/drivers/clk/qcom/clock-ipq4019.c @@ -20,9 +20,9 @@ static ulong ipq4019_clk_set_rate(struct clk *clk, ulong rate) { switch (clk->id) { case GCC_BLSP1_UART1_APPS_CLK: /*UART1*/ /* This clock is already initialized by SBL1 */ - return 0; + return 1843200; default: return -EINVAL; } }
The driver currently requires the bit clock divider be hardcoded in devicetree (or use the hardcoded default from apq8016).
The bit clock divider is used to derive the baud rate from the core clock:
baudrate = clk_rate / csr_div
clk_rate is the actual programmed core clock rate which is returned by clk_set_rate(), and this UART driver only supports a baudrate of 115200. We can therefore determine the appropriate value for UARTDM_CSR by iterating over the possible values and finding the one where the equation above holds true for a baudrate of 115200.
Implement this logic and drop the non-standard DT bindings for this driver.
Tested on dragonboard410c.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Cc: Robert Marko robert.marko@sartura.hr --- doc/device-tree-bindings/serial/msm-serial.txt | 10 --- drivers/serial/serial_msm.c | 87 +++++++++++++++++++++----- 2 files changed, 70 insertions(+), 27 deletions(-)
diff --git a/doc/device-tree-bindings/serial/msm-serial.txt b/doc/device-tree-bindings/serial/msm-serial.txt deleted file mode 100644 index dca995798a90..000000000000 --- a/doc/device-tree-bindings/serial/msm-serial.txt +++ /dev/null @@ -1,10 +0,0 @@ -Qualcomm UART (Data Mover mode) - -Required properties: -- compatible: must be "qcom,msm-uartdm-v1.4" -- reg: start address and size of the registers -- clock: interface clock (must accept baudrate as a frequency) - -Optional properties: -- bit-rate: Data Mover bit rate register value - (If not defined then 0xCC is used as default) diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index 8044d38518db..e461929b4338 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -31,8 +31,18 @@ #define UARTDM_RXFS_BUF_SHIFT 0x7 /* Number of bytes in the packing buffer */ #define UARTDM_RXFS_BUF_MASK 0x7 #define UARTDM_MR1 0x00 #define UARTDM_MR2 0x04 +/* + * This is documented on page 1817 of the apq8016e technical reference manual. + * section 6.2.5.3.26 + * + * The upper nybble contains the bit clock divider for the RX pin, the lower + * nybble defines the TX pin. In almost all cases these should be the same value. + * + * The baud rate is the core clock frequency divided by the fixed divider value + * programmed into this register (defined in calc_csr_bitrate()). + */ #define UARTDM_CSR 0xA0
#define UARTDM_SR 0xA4 /* Status register */ #define UARTDM_SR_RX_READY (1 << 0) /* Word is the receiver FIFO */ @@ -52,9 +62,8 @@
#define UARTDM_TF 0x100 /* UART Transmit FIFO register */ #define UARTDM_RF 0x140 /* UART Receive FIFO register */
-#define UART_DM_CLK_RX_TX_BIT_RATE 0xCC #define MSM_BOOT_UART_DM_8_N_1_MODE 0x34 #define MSM_BOOT_UART_DM_CMD_RESET_RX 0x10 #define MSM_BOOT_UART_DM_CMD_RESET_TX 0x20
@@ -63,9 +72,9 @@ DECLARE_GLOBAL_DATA_PTR; struct msm_serial_data { phys_addr_t base; unsigned chars_cnt; /* number of buffered chars */ uint32_t chars_buf; /* buffered chars */ - uint32_t clk_bit_rate; /* data mover mode bit rate register value */ + uint32_t clk_rate; /* core clock rate */ };
static int msm_serial_fetch(struct udevice *dev) { @@ -155,34 +164,63 @@ static const struct dm_serial_ops msm_serial_ops = { .pending = msm_serial_pending, .getc = msm_serial_getc, };
-static int msm_uart_clk_init(struct udevice *dev) +static long msm_uart_clk_init(struct udevice *dev) { - uint clk_rate = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), - "clock-frequency", 115200); + struct msm_serial_data *priv = dev_get_priv(dev); struct clk clk; int ret; + long rate;
ret = clk_get_by_name(dev, "core", &clk); if (ret < 0) { pr_warn("%s: Failed to get clock: %d\n", __func__, ret); - return ret; + return 0; }
- ret = clk_set_rate(&clk, clk_rate); - if (ret < 0) - return ret; + rate = clk_set_rate(&clk, priv->clk_rate);
- return 0; + return rate; +} + +static int calc_csr_bitrate(struct msm_serial_data *priv) +{ + /* This table is from the TRE. See the definition of UARTDM_CSR */ + unsigned int csr_div_table[] = {24576, 12288, 6144, 3072, 1536, 768, 512, 384, + 256, 192, 128, 96, 64, 48, 32, 16}; + int i = ARRAY_SIZE(csr_div_table) - 1; + /* Currently we only support one baudrate */ + int baud = 115200; + + for (; i >= 0; i--) { + int x = priv->clk_rate / csr_div_table[i]; + + if (x == baud) + /* Duplicate the configuration for RX + * as the lower nybble only configures TX + */ + return i + (i << 4); + } + + return -EINVAL; }
static void uart_dm_init(struct msm_serial_data *priv) { /* Delay initialization for a bit to let pins stabilize if necessary */ mdelay(5); + int bitrate = calc_csr_bitrate(priv); + if (bitrate < 0) { + log_warning("Couldn't calculate bit clock divider! Using default\n"); + /* This happens to be the value used on MSM8916 for the hardcoded clockrate + * in clock-apq8016. It's at least a better guess than a value we *know* + * is wrong... + */ + bitrate = 0xCC; + }
- writel(priv->clk_bit_rate, priv->base + UARTDM_CSR); + writel(bitrate, priv->base + UARTDM_CSR); writel(0x0, priv->base + UARTDM_MR1); writel(MSM_BOOT_UART_DM_8_N_1_MODE, priv->base + UARTDM_MR2); writel(MSM_BOOT_UART_DM_CMD_RESET_RX, priv->base + UARTDM_CR); writel(MSM_BOOT_UART_DM_CMD_RESET_TX, priv->base + UARTDM_CR); @@ -191,18 +229,27 @@ static void uart_dm_init(struct msm_serial_data *priv) writel(0x0, priv->base + UARTDM_DMEN); } static int msm_serial_probe(struct udevice *dev) { - int ret; struct msm_serial_data *priv = dev_get_priv(dev); + long rate;
/* No need to reinitialize the UART after relocation */ if (gd->flags & GD_FLG_RELOC) return 0;
- ret = msm_uart_clk_init(dev); - if (ret) - return ret; + rate = msm_uart_clk_init(dev); + if (rate < 0) + return rate; + if (!rate) { + log_err("Got core clock rate of 0... Please fix your clock driver\n"); + return -EINVAL; + } + + /* Update the clock rate to the actual programmed rate returned by the + * clock driver + */ + priv->clk_rate = rate;
uart_dm_init(priv);
return 0; @@ -210,15 +257,20 @@ static int msm_serial_probe(struct udevice *dev)
static int msm_serial_of_to_plat(struct udevice *dev) { struct msm_serial_data *priv = dev_get_priv(dev); + int ret;
priv->base = dev_read_addr(dev); if (priv->base == FDT_ADDR_T_NONE) return -EINVAL;
- priv->clk_bit_rate = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "bit-rate", UART_DM_CLK_RX_TX_BIT_RATE); + ret = dev_read_u32(dev, "clock-frequency", &priv->clk_rate); + if (ret < 0) { + log_debug("No clock frequency specified, using default rate\n"); + /* Default for APQ8016 */ + priv->clk_rate = 7372800; + }
return 0; }
@@ -241,8 +293,9 @@ U_BOOT_DRIVER(serial_msm) = { #ifdef CONFIG_DEBUG_UART_MSM
static struct msm_serial_data init_serial_data = { .base = CONFIG_VAL(DEBUG_UART_BASE), + .clk_rate = 7372800, };
#include <debug_uart.h>
On Mon, Apr 15, 2024 at 2:44 PM Caleb Connolly caleb.connolly@linaro.org wrote:
Works on Alfa AP120C (IPQ4018) with full DM UART, but debug UART prints junk since .clk_rate = 7372800 is not correct for IPQ40xx. I would suggest using .clk_rate = CONFIG_VAL(DEBUG_UART_CLOCK) instead to populate the value per board, this also avoids per ARCH ifdefs.
Regards, Robert
- This is documented on page 1817 of the apq8016e technical reference manual.
- section 6.2.5.3.26
- The upper nybble contains the bit clock divider for the RX pin, the lower
- nybble defines the TX pin. In almost all cases these should be the same value.
- The baud rate is the core clock frequency divided by the fixed divider value
- programmed into this register (defined in calc_csr_bitrate()).
long rate; ret = clk_get_by_name(dev, "core", &clk); if (ret < 0) { pr_warn("%s: Failed to get clock: %d\n", __func__, ret);
return ret;
return 0; }
if (ret < 0)
return ret;
return rate;
int baud = 115200;
if (x == baud)
return -EINVAL;
if (bitrate < 0) {
* is wrong...
bitrate = 0xCC;
long rate; /* No need to reinitialize the UART after relocation */ if (gd->flags & GD_FLG_RELOC) return 0;
if (ret)
return ret;
if (rate < 0)
return rate;
if (!rate) {
return -EINVAL;
* clock driver
priv->clk_rate = rate; uart_dm_init(priv); return 0;
int ret; priv->base = dev_read_addr(dev); if (priv->base == FDT_ADDR_T_NONE) return -EINVAL;
if (ret < 0) {
} return 0;
-- 2.44.0
Ok awesome, thanks for trying this out. I'll send a v2 with your suggestion.
Can I add your Tested-by?
Regards, Robert
return ret;
return 0; }
if (ret < 0)
return ret;
return rate;
int baud = 115200;
if (x == baud)
return -EINVAL;
if (bitrate < 0) {
* is wrong...
bitrate = 0xCC;
if (ret)
return ret;
if (rate < 0)
return rate;
if (!rate) {
return -EINVAL;
* clock driver
if (ret < 0) {
} return 0;
-- 2.44.0
On Mon, Apr 15, 2024 at 4:18 PM Caleb Connolly caleb.connolly@linaro.org wrote:
Sure, Tested-by: Robert Marko robert.marko@sartura.hr
Regards, Robert
Regards, Robert
return ret;
return 0; }
if (ret < 0)
return ret;
return rate;
int baud = 115200;
if (x == baud)
return -EINVAL;
if (bitrate < 0) {
* is wrong...
bitrate = 0xCC;
if (ret)
return ret;
if (rate < 0)
return rate;
if (!rate) {
return -EINVAL;
* clock driver
if (ret < 0) {
} return 0;
-- 2.44.0
-- // Caleb (they/them)
Caleb Connolly
Robert Marko
