[U-Boot] [PATCH] travis-ci: Try harder to build all ARM targets
The way that we have things broken down currently allows for some combinations of vendor or CPU to not be built. To fix this, create a new catch-all job that excludes everything we've built elsewhere. For the sake of simplicity we are allowing for the possibility of some overlap between the vendor-based jobs and the CPU-based jobs. While we're in here, make a failed build provide the summary of failure.
Signed-off-by: Tom Rini trini@konsulko.com --- .travis.yml | 47 +++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 39 insertions(+), 8 deletions(-)
diff --git a/.travis.yml b/.travis.yml index bb9325bacc33..3d7fffe0bd3e 100644 --- a/.travis.yml +++ b/.travis.yml @@ -78,6 +78,7 @@ script: tools/buildman/buildman -P ${BUILDMAN}; ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then + tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret; fi; fi @@ -96,31 +97,54 @@ matrix: # we need to build by vendor due to 50min time limit for builds # each env setting here is a dedicated build - env: - - BUILDMAN="arm1136" + - BUILDMAN="arm11" - env: - - BUILDMAN="arm1176" - - env: - - BUILDMAN="arm720t" + - BUILDMAN="arm7" - env: - BUILDMAN="arm920t" - env: + - JOB="arm926ejs" + BUILDMAN="arm926ejs -x mx,siemens,atmel" + - env: + - BUILDMAN="arm946es" + - env: - BUILDMAN="atmel -x avr32" - env: - BUILDMAN="avr32" TOOLCHAIN="avr32" - env: - - BUILDMAN="davinci" - - env: - BUILDMAN="denx" - env: - JOB="Freescale ARM" BUILDMAN="freescale -x powerpc,m68k" - env: + - JOB="i.MX (non-Freescale)" + BUILDMAN="mx -x freescale" + - env: + - BUILDMAN="sun4i" + - env: + - BUILDMAN="sun5i" + - env: + - BUILDMAN="sun6i" + - env: + - BUILDMAN="sun7i" + - env: + - BUILDMAN="sun8i" + - env: + - BUILDMAN="sun9i" + - env: + - BUILDMAN="sun50i" + - env: + - JOB="Catch-all ARM" + BUILDMAN="arm -x arm11,arm7,arm9,aarch64,atmel,denx,freescale,kirkwood,siemens,tegra,uniphier,mx,sunxi,am33xx,omap3,omap4,omap5,pxa" + - env: - BUILDMAN="sandbox x86" TOOLCHAIN="x86_64" - env: - BUILDMAN="kirkwood" - env: + - BUILDMAN="pxa" + - env: - BUILDMAN="m68k" TOOLCHAIN="m68k" - env: @@ -158,11 +182,18 @@ matrix: - env: - BUILDMAN="tegra" - env: - - BUILDMAN="ti" + - JOB="am33xx" + BUILDMAN="am33xx -x siemens" + - env: + - BUILDMAN="omap3" + - env: + - BUILDMAN="omap4" + - env: + - BUILDMAN="omap5" - env: - BUILDMAN="uniphier" - env: - - BUILDMAN="aarch64 -x tegra,freescale,uniphier" + - BUILDMAN="aarch64 -x tegra,freescale,uniphier,sunxi" TOOLCHAIN="aarch64" - env: - BUILDMAN="sh4"
