[U-Boot] [PATCH resend v2 00/13] sunxi: Add support for R40 SoC
Hi everyone,
This is a resend of my Allwinner R40 SoC support series v2. This is rebased on v2017.05-rc2. Maxime's ack for the first two patches have been added, and the defconfig has been regenerated which moved the CONFIG_SPL_I2C_SUPPORT=y line around.
The patches can also be found here:
https://github.com/wens/u-boot-sunxi/tree/r40
Original v2 cover letter:
This is v2 of my Allwinner R40 SoC support series.
Changes since v1:
- Add Maxime's ack for all but the first patch.
- Add a patch to split up very long Kconfig lines.
This series adds support for the new R40 SoC. The R40 is marketed as the successor to the A20. It is mostly pin compatible (in software) with the A20. It has a somewhat similar memory layout, a hybrid of A20 and newer sun6i gen.. Like the A20, it does not have a PRCM block.
Checkpatch throws out a lot of errors, mostly "no spaces at the start of a line" or "space prohibited after that open parenthesis '('", but fixing them does not improve the readability of the code.
Patch 1 splits up some very long Kconfig lines. (new in v2)
Patch 2 introduces the R40 to U-boot, by adding a Kconfig symbol, fixing up any SoC depends on in Kconfig to disable unsupported features, and reworking board level pinmuxes.
Patch 3 enables using the AXP221s PMIC in I2C mode. The R40 is paired with this PMIC, but it does not have a P2WI controller.
Patch 4 fixes the watchdog reset function for R40. The R40's watchdog register layout is like the A10/A20.
Patch 5 adds mmc pinmux settings for R40.
Patch 6 fixes the PLL lock settings for the R40. The R40's CCU has a new mode for PLL lock, which can be configured and also switched back to the old mode. Here we just use the old mode, which is the same as the other sun6i gen. SoCs.
Patch 7 provides some default DRAM settings for the R40. These were taken from the Bananapi M2 Ultra, the only R40 board available.
Patch 8 adds the compatible string for the R40 PIO. It is mostly compatible with the A20, with a few functions gone, and a few new ones.
Patch 9 adds DRAM initialization support for the R40. The DRAM controller is very similar to the A64 and H5, however the A15 line and CSC1 line are muxed on the same pin. Also the PIR_QSGATE bit must not be set, or DRAM init fails.
Patch 10 enables SPL for R40.
Patch 11 fixes the address of the CPUCFG block on the R40. It is the same as on the A20.
Patch 12 adds a PSCI implementation for the R40. As the register layout is slightly erratic, we just use a macro for the ones that can't fit into the cpucfg register definition structure.
Patch 13 adds a board dts and defconfig for the Bananapi M2 Ultra.
Please have a look.
Regards ChenYu
Chen-Yu Tsai (13): sunxi: Split up long Kconfig lines sunxi: Add initial support for R40 sunxi: Enable AXP221s in I2C mode with the R40 SoC sunxi: Fix watchdog reset function for R40 sunxi: Add mmc[1-3] pinmux settings for R40 sunxi: Set PLL lock enable bits for R40 sunxi: Provide defaults for R40 DRAM settings gpio: sunxi: Add compatible string for R40 PIO sunxi: Use H3/A64 DRAM initialization code for R40 sunxi: Enable SPL for R40 sunxi: Fix CPUCFG address for R40 sunxi: Add PSCI support for R40 sunxi: Add support for Bananapi M2 Ultra
arch/arm/cpu/armv7/sunxi/psci.c | 35 ++++- arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 69 +++++++++ arch/arm/dts/sun8i-r40.dtsi | 183 ++++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 2 + arch/arm/include/asm/arch-sunxi/cpu.h | 1 + arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 6 +- arch/arm/include/asm/arch-sunxi/dram.h | 4 +- arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h | 20 ++- arch/arm/include/asm/arch-sunxi/timer.h | 5 +- arch/arm/include/asm/arch-sunxi/watchdog.h | 5 +- arch/arm/mach-sunxi/Makefile | 1 + arch/arm/mach-sunxi/board.c | 15 +- arch/arm/mach-sunxi/clock_sun6i.c | 9 +- arch/arm/mach-sunxi/cpu_info.c | 2 + arch/arm/mach-sunxi/dram_sun8i_h3.c | 121 ++++++++++++++-- arch/arm/mach-sunxi/pmic_bus.c | 7 + board/sunxi/Kconfig | 41 +++++- board/sunxi/MAINTAINERS | 6 + board/sunxi/board.c | 36 ++++- configs/Bananapi_M2_Ultra_defconfig | 15 ++ drivers/gpio/sunxi_gpio.c | 1 + drivers/power/Kconfig | 16 ++- 23 files changed, 550 insertions(+), 52 deletions(-) create mode 100644 arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts create mode 100644 arch/arm/dts/sun8i-r40.dtsi create mode 100644 configs/Bananapi_M2_Ultra_defconfig
Currently we have some lines in board/sunxi/Kconfig that are very long. These line either provide default values for a set of SoCs, or limit some option to a subset of sunxi SoCs.
Fortunately Kconfig makes it easy to split them. The Kconfig language document states
If multiple dependencies are defined, they are connected with '&&'.
This means we can split existing dependencies at "&&" symbols. This applies to both the "depends on" lines and "if" expressions.
This patch splits them up to one symbol per line. This will make it easier to add, remove, or modify one item at a time.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 25 ++++++++++++++++++++----- 1 file changed, 20 insertions(+), 5 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index a667c9e5c5c1..bd0019713984 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -159,7 +159,10 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool - default y if MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUNXI_H3_H5 || MACH_SUN8I_A83T + default y if MACH_SUN8I_A23 + default y if MACH_SUN8I_A33 + default y if MACH_SUN8I_A83T + default y if MACH_SUNXI_H3_H5
config RESERVE_ALLWINNER_BOOT0_HEADER bool "reserve space for Allwinner boot0 header" @@ -308,9 +311,13 @@ config DRAM_ODT_CORRECTION endif
config SYS_CLK_FREQ - default 816000000 if MACH_SUN50I + default 1008000000 if MACH_SUN4I + default 1008000000 if MACH_SUN5I + default 1008000000 if MACH_SUN6I default 912000000 if MACH_SUN7I - default 1008000000 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN8I || MACH_SUN9I + default 1008000000 if MACH_SUN8I + default 1008000000 if MACH_SUN9I + default 816000000 if MACH_SUN50I
config SYS_CONFIG_NAME default "sun4i" if MACH_SUN4I @@ -512,7 +519,10 @@ config AXP_GPIO
config VIDEO bool "Enable graphical uboot console on HDMI, LCD or VGA" - depends on !MACH_SUN8I_A83T && !MACH_SUNXI_H3_H5 && !MACH_SUN9I && !MACH_SUN50I + depends on !MACH_SUN8I_A83T + depends on !MACH_SUNXI_H3_H5 + depends on !MACH_SUN9I + depends on !MACH_SUN50I default y ---help--- Say Y here to add support for using a cfb console on the HDMI, LCD @@ -714,7 +724,12 @@ config GMAC_TX_DELAY Set the GMAC Transmit Clock Delay Chain value.
config SPL_STACK_R_ADDR - default 0x4fe00000 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN7I || MACH_SUN8I || MACH_SUN50I + default 0x4fe00000 if MACH_SUN4I + default 0x4fe00000 if MACH_SUN5I + default 0x4fe00000 if MACH_SUN6I + default 0x4fe00000 if MACH_SUN7I + default 0x4fe00000 if MACH_SUN8I default 0x2fe00000 if MACH_SUN9I + default 0x4fe00000 if MACH_SUN50I
endif
The R40 is the successor to the A20. It is a hybrid of the A20, A33 and the H3.
The R40's PIO controller is compatible with the A20, Reuse the A20 UART and I2C muxing code by adding the R40's macro.
The display pipeline is the newer DE 2.0 variant. Block enabling video on R40 for now.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/mach-sunxi/board.c | 10 +++++++--- arch/arm/mach-sunxi/cpu_info.c | 2 ++ board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 19 ++++++++++++++----- 4 files changed, 30 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 5e03d039433a..5a74c9717d84 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -69,12 +69,14 @@ struct mm_region *mem_map = sunxi_mem_map; static int gpio_init(void) { #if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif -#if defined(CONFIG_MACH_SUN8I) +#if defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); #else @@ -82,7 +84,9 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); #endif sunxi_gpio_set_pull(SUNXI_GPF(4), 1); -#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I)) +#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40)) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index 85633ccec216..7851de299ab5 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -87,6 +87,8 @@ int print_cpuinfo(void) printf("CPU: Allwinner A83T (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_H3 printf("CPU: Allwinner H3 (SUN8I %04x)\n", sunxi_get_sram_id()); +#elif defined CONFIG_MACH_SUN8I_R40 + printf("CPU: Allwinner R40 (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN9I puts("CPU: Allwinner A80 (SUN9I)\n"); #elif defined CONFIG_MACH_SUN50I diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index bd0019713984..67ceae35bf9b 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -134,6 +134,11 @@ config MACH_SUN8I_H3 select MACH_SUNXI_H3_H5 select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
+config MACH_SUN8I_R40 + bool "sun8i (Allwinner R40)" + select CPU_V7 + select SUNXI_GEN_SUN6I + config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 @@ -163,6 +168,7 @@ config MACH_SUN8I default y if MACH_SUN8I_A33 default y if MACH_SUN8I_A83T default y if MACH_SUNXI_H3_H5 + default y if MACH_SUN8I_R40
config RESERVE_ALLWINNER_BOOT0_HEADER bool "reserve space for Allwinner boot0 header" @@ -521,6 +527,7 @@ config VIDEO bool "Enable graphical uboot console on HDMI, LCD or VGA" depends on !MACH_SUN8I_A83T depends on !MACH_SUNXI_H3_H5 + depends on !MACH_SUN8I_R40 depends on !MACH_SUN9I depends on !MACH_SUN50I default y diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b9660128e5e7..495cb591a9fb 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -394,7 +394,10 @@ int board_mmc_init(bd_t *bis) void i2c_init_board(void) { #ifdef CONFIG_I2C0_ENABLE -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); clock_twi_onoff(0, 1); @@ -410,7 +413,9 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_I2C1_ENABLE -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); clock_twi_onoff(1, 1); @@ -430,7 +435,9 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_I2C2_ENABLE -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN4I_GPB_TWI2); sunxi_gpio_set_cfgpin(SUNXI_GPB(21), SUN4I_GPB_TWI2); clock_twi_onoff(2, 1); @@ -454,7 +461,8 @@ void i2c_init_board(void) sunxi_gpio_set_cfgpin(SUNXI_GPG(10), SUN6I_GPG_TWI3); sunxi_gpio_set_cfgpin(SUNXI_GPG(11), SUN6I_GPG_TWI3); clock_twi_onoff(3, 1); -#elif defined(CONFIG_MACH_SUN7I) +#elif defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPI(0), SUN7I_GPI_TWI3); sunxi_gpio_set_cfgpin(SUNXI_GPI(1), SUN7I_GPI_TWI3); clock_twi_onoff(3, 1); @@ -462,7 +470,8 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_I2C4_ENABLE -#if defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) sunxi_gpio_set_cfgpin(SUNXI_GPI(2), SUN7I_GPI_TWI4); sunxi_gpio_set_cfgpin(SUNXI_GPI(3), SUN7I_GPI_TWI4); clock_twi_onoff(4, 1);
The R40 SoC uses the AXP221s in I2C mode to supply power.
Some regulator's common usages have changed, and also the recommended voltage for existing usages have changed. Update the defaults to match.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/mach-sunxi/pmic_bus.c | 7 +++++++ board/sunxi/Kconfig | 2 +- drivers/power/Kconfig | 16 ++++++++++------ 3 files changed, 18 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 7c57f02792b9..f917c3e070a5 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -41,6 +41,9 @@ int pmic_bus_init(void) p2wi_init(); ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP221_CTRL_ADDR, AXP221_INIT_DATA); +# elif defined CONFIG_MACH_SUN8I_R40 + /* Nothing. R40 uses the AXP221s in I2C mode */ + ret = 0; # else ret = rsb_init(); if (ret) @@ -65,6 +68,8 @@ int pmic_bus_read(u8 reg, u8 *data) #elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_read(reg, data); +# elif defined CONFIG_MACH_SUN8I_R40 + return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); # else return rsb_read(AXP223_RUNTIME_ADDR, reg, data); # endif @@ -80,6 +85,8 @@ int pmic_bus_write(u8 reg, u8 data) #elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_write(reg, data); +# elif defined CONFIG_MACH_SUN8I_R40 + return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); # else return rsb_write(AXP223_RUNTIME_ADDR, reg, data); # endif diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 67ceae35bf9b..9e69c59784af 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -466,7 +466,7 @@ config USB3_VBUS_PIN
config I2C0_ENABLE bool "Enable I2C/TWI controller 0" - default y if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I + default y if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || MACH_SUN8I_R40 default n if MACH_SUN6I || MACH_SUN8I select CMD_I2C ---help--- diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index 64e5bc2f74b4..911ecb1144a6 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -10,7 +10,7 @@ choice prompt "Select Sunxi PMIC Variant" depends on ARCH_SUNXI default AXP209_POWER if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I - default AXP221_POWER if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 + default AXP221_POWER if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40 default AXP818_POWER if MACH_SUN8I_A83T default SUNXI_NO_PMIC if MACH_SUNXI_H3_H5 || MACH_SUN50I
@@ -37,7 +37,7 @@ config AXP209_POWER
config AXP221_POWER bool "axp221 / axp223 pmic support" - depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 + depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40 select CMD_POWEROFF ---help--- Select this to enable support for the axp221/axp223 pmic found on most @@ -70,7 +70,7 @@ endchoice config AXP_DCDC1_VOLT int "axp pmic dcdc1 voltage" depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 3300 if AXP818_POWER + default 3300 if AXP818_POWER || MACH_SUN8I_R40 default 3000 if MACH_SUN6I || MACH_SUN8I || MACH_SUN9I ---help--- Set the voltage (mV) to program the axp pmic dcdc1 at, set to 0 to @@ -97,6 +97,7 @@ config AXP_DCDC2_VOLT On A23/A33 boards dcdc2 is used for VDD-SYS and should be 1.1V. On A80 boards dcdc2 powers the GPU and can be left off. On A83T boards dcdc2 is used for VDD-CPUA(cluster 0) and should be 0.9V. + On R40 boards dcdc2 is VDD-CPU and should be 1.1V
config AXP_DCDC3_VOLT int "axp pmic dcdc3 voltage" @@ -104,6 +105,7 @@ config AXP_DCDC3_VOLT default 900 if AXP809_POWER || AXP818_POWER default 1500 if AXP152_POWER default 1250 if AXP209_POWER + default 1100 if MACH_SUN8I_R40 default 1200 if MACH_SUN6I || MACH_SUN8I ---help--- Set the voltage (mV) to program the axp pmic dcdc3 at, set to 0 to @@ -114,6 +116,7 @@ config AXP_DCDC3_VOLT On A23 / A31 / A33 boards dcdc3 is VDD-CPU and should be 1.2V. On A80 boards dcdc3 is used for VDD-CPUA(cluster 0) and should be 0.9V. On A83T boards dcdc3 is used for VDD-CPUB(cluster 1) and should be 0.9V. + On R40 boards dcdc3 is VDD-SYS and VDD-GPU and should be 1.1V.
config AXP_DCDC4_VOLT int "axp pmic dcdc4 voltage" @@ -138,13 +141,13 @@ config AXP_DCDC5_VOLT ---help--- Set the voltage (mV) to program the axp pmic dcdc5 at, set to 0 to disable dcdc5. - On A23 / A31 / A33 / A80 / A83T boards dcdc5 is VCC-DRAM and + On A23 / A31 / A33 / A80 / A83T / R40 boards dcdc5 is VCC-DRAM and should be 1.5V, 1.35V if DDR3L is used.
config AXP_ALDO1_VOLT int "axp pmic (a)ldo1 voltage" depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 0 if MACH_SUN6I + default 0 if MACH_SUN6I || MACH_SUN8I_R40 default 1800 if MACH_SUN8I_A83T default 3000 if MACH_SUN8I || MACH_SUN9I ---help--- @@ -183,7 +186,8 @@ config AXP_ALDO3_VOLT Set the voltage (mV) to program the axp pmic aldo3 at, set to 0 to disable aldo3. On A10(s) / A13 / A20 boards aldo3 should be 2.8V. - On A23 / A31 / A33 boards aldo3 is VCC-PLL and AVCC and should be 3.0V. + On A23 / A31 / A33 / R40 boards aldo3 is VCC-PLL and AVCC and should + be 3.0V. On A80 boards aldo3 is normally not used. On A83T / H8 boards aldo3 is AVCC, VCC-PL, and VCC-LED, and should be 3.0V.
The watchdog found on the R40 SoC is the older variant found on the A20. Add the proper "#if defines" to make it work.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/include/asm/arch-sunxi/timer.h | 5 ++--- arch/arm/include/asm/arch-sunxi/watchdog.h | 5 ++++- arch/arm/mach-sunxi/board.c | 5 ++--- 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/timer.h b/arch/arm/include/asm/arch-sunxi/timer.h index a665309803cb..ccdf942534a4 100644 --- a/arch/arm/include/asm/arch-sunxi/timer.h +++ b/arch/arm/include/asm/arch-sunxi/timer.h @@ -67,7 +67,7 @@ struct sunxi_timer_reg { struct sunxi_timer timer[6]; /* We have 6 timers */ u8 res2[16]; struct sunxi_avs avs; -#ifdef CONFIG_SUNXI_GEN_SUN4I +#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40) struct sunxi_wdog wdog; /* 0x90 */ /* XXX the following is not accurate for sun5i/sun7i */ struct sunxi_64cnt cnt64; /* 0xa0 */ @@ -77,8 +77,7 @@ struct sunxi_timer_reg { struct sunxi_tgp tgp[4]; u8 res5[8]; u32 cpu_cfg; -#endif -#ifdef CONFIG_SUNXI_GEN_SUN6I +#elif defined(CONFIG_SUNXI_GEN_SUN6I) u8 res3[16]; struct sunxi_wdog wdog[5]; /* We have 5 watchdogs */ #endif diff --git a/arch/arm/include/asm/arch-sunxi/watchdog.h b/arch/arm/include/asm/arch-sunxi/watchdog.h index 8108be97bab0..ce6d66485609 100644 --- a/arch/arm/include/asm/arch-sunxi/watchdog.h +++ b/arch/arm/include/asm/arch-sunxi/watchdog.h @@ -13,7 +13,10 @@ #define WDT_CTRL_RESTART (0x1 << 0) #define WDT_CTRL_KEY (0x0a57 << 1)
#define WDT_MODE_EN (0x1 << 0) #define WDT_MODE_RESET_EN (0x1 << 1) diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 5a74c9717d84..6ce07dfe0fd7 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -270,7 +270,7 @@ void board_init_f(ulong dummy)
void reset_cpu(ulong addr) { -#ifdef CONFIG_SUNXI_GEN_SUN4I +#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40) static const struct sunxi_wdog *wdog = &((struct sunxi_timer_reg *)SUNXI_TIMER_BASE)->wdog;
@@ -282,8 +282,7 @@ void reset_cpu(ulong addr) /* sun5i sometimes gets stuck without this */ writel(WDT_MODE_RESET_EN | WDT_MODE_EN, &wdog->mode); } -#endif -#ifdef CONFIG_SUNXI_GEN_SUN6I +#elif defined(CONFIG_SUNXI_GEN_SUN6I) static const struct sunxi_wdog *wdog = ((struct sunxi_timer_reg *)SUNXI_TIMER_BASE)->wdog;
The PIO is generally compatible with the A20, except that it routes the full 8 bits and eMMC reset pins for mmc2.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/board.c | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 495cb591a9fb..21ce8348922c 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -199,7 +199,8 @@ static void mmc_pinmux_setup(int sdc) case 1: pins = sunxi_name_to_gpio_bank(CONFIG_MMC1_PINS);
-#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) if (pins == SUNXI_GPIO_H) { /* SDC1: PH22-PH-27 */ for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { @@ -294,6 +295,17 @@ static void mmc_pinmux_setup(int sdc) sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(SUNXI_GPC(24), 2); } +#elif defined(CONFIG_MACH_SUN8I_R40) + /* SDC2: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); #elif defined(CONFIG_MACH_SUN8I) || defined(CONFIG_MACH_SUN50I) /* SDC2: PC5-PC6, PC8-PC16 */ for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { @@ -320,7 +332,8 @@ static void mmc_pinmux_setup(int sdc) case 3: pins = sunxi_name_to_gpio_bank(CONFIG_MMC3_PINS);
-#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) /* SDC3: PI4-PI9 */ for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3);
According to the BSP released by Banana Pi, the R40 (sun8iw11p1) has an extra "PLL lock control" register in the CCU, which controls whether the individual PLL lock status bits in each PLL's control register work or not.
This patch enables it for all the PLLs.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 2 ++ arch/arm/mach-sunxi/clock_sun6i.c | 5 +++++ 2 files changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index 1bfb48bd52df..1aefd5a64c1f 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -142,6 +142,8 @@ struct sunxi_ccm_reg { u32 apb2_reset_cfg; /* 0x2d8 APB2 Reset config */ u32 reserved25[5]; u32 ccu_sec_switch; /* 0x2f0 CCU Security Switch, H3 only */ + u32 reserved26[11]; + u32 pll_lock_ctrl; /* 0x320 PLL lock control, R40 only */ };
/* apb2 bit field */ diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 4762fbf0c3f0..3c8c53fcf76b 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -35,6 +35,11 @@ void clock_init_safe(void) clrbits_le32(&prcm->pll_ctrl1, PRCM_PLL_CTRL_LDO_KEY_MASK); #endif
+#ifdef CONFIG_MACH_SUN8I_R40 + /* Set PLL lock enable bits and switch to old lock mode */ + writel(GENMASK(12, 0), &ccm->pll_lock_ctrl); +#endif + clock_set_pll1(408000000);
writel(PLL6_CFG_DEFAULT, &ccm->pll6_cfg);
These values were taken from the Banana Pi M2 Ultra fex file found in the released vendor BSP. This is the only publicly available R40 device at the time of this writing.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 9e69c59784af..94d01cb5c1ec 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -203,6 +203,7 @@ config DRAM_TYPE config DRAM_CLK int "sunxi dram clock speed" default 792 if MACH_SUN9I + default 648 if MACH_SUN8I_R40 default 312 if MACH_SUN6I || MACH_SUN8I default 360 if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I default 672 if MACH_SUN50I @@ -224,6 +225,7 @@ config DRAM_ZQ int "sunxi dram zq value" default 123 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN8I default 127 if MACH_SUN7I + default 3881979 if MACH_SUN8I_R40 default 4145117 if MACH_SUN9I default 3881915 if MACH_SUN50I ---help--- @@ -233,6 +235,7 @@ config DRAM_ODT_EN bool "sunxi dram odt enable" default n if !MACH_SUN8I_A23 default y if MACH_SUN8I_A23 + default y if MACH_SUN8I_R40 default y if MACH_SUN50I ---help--- Select this to enable dram odt (on die termination).
The PIO on the R40 SoC is mostly compatible with the A20. Only a few pin functions for mmc2 were added to the PC pingroup, to support 8 bit eMMCs.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- drivers/gpio/sunxi_gpio.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index 8d2bb18504ae..3f40e8383001 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -352,6 +352,7 @@ static const struct udevice_id sunxi_gpio_ids[] = { ID("allwinner,sun8i-a33-pinctrl", a_all), ID("allwinner,sun8i-a83t-pinctrl", a_all), ID("allwinner,sun8i-h3-pinctrl", a_all), + ID("allwinner,sun8i-r40-pinctrl", a_all), ID("allwinner,sun9i-a80-pinctrl", a_all), ID("allwinner,sun6i-a31-r-pinctrl", l_2), ID("allwinner,sun8i-a23-r-pinctrl", l_1),
The R40 seems to have a variant of the memory controller found in the H3 and A64 SoCs. Adapt the code for use on the R40. The changes are based on released DRAM code and comparing register dumps from boot0.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/include/asm/arch-sunxi/cpu.h | 1 + arch/arm/include/asm/arch-sunxi/dram.h | 4 +- arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h | 20 +++- arch/arm/mach-sunxi/Makefile | 1 + arch/arm/mach-sunxi/clock_sun6i.c | 4 +- arch/arm/mach-sunxi/dram_sun8i_h3.c | 121 +++++++++++++++++++++--- 6 files changed, 133 insertions(+), 18 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu.h b/arch/arm/include/asm/arch-sunxi/cpu.h index e8e670e7e903..caec86526417 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu.h +++ b/arch/arm/include/asm/arch-sunxi/cpu.h @@ -16,5 +16,6 @@ #define SOCID_A64 0x1689 #define SOCID_H3 0x1680 #define SOCID_H5 0x1718 +#define SOCID_R40 0x1701
#endif /* _SUNXI_CPU_H */ diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index 1dc82205b7df..f452f889f928 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -24,7 +24,9 @@ #include <asm/arch/dram_sun8i_a33.h> #elif defined(CONFIG_MACH_SUN8I_A83T) #include <asm/arch/dram_sun8i_a83t.h> -#elif defined(CONFIG_MACH_SUNXI_H3_H5) || defined(CONFIG_MACH_SUN50I) +#elif defined(CONFIG_MACH_SUNXI_H3_H5) || \ + defined(CONFIG_MACH_SUN8I_R40) || \ + defined(CONFIG_MACH_SUN50I) #include <asm/arch/dram_sun8i_h3.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/dram_sun9i.h> diff --git a/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h b/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h index 25d07d9863c9..2770986b613f 100644 --- a/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h +++ b/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h @@ -15,7 +15,8 @@
struct sunxi_mctl_com_reg { u32 cr; /* 0x00 control register */ - u8 res0[0x8]; /* 0x04 */ + u32 cr_r1; /* 0x04 rank 1 control register (R40 only) */ + u8 res0[0x4]; /* 0x08 */ u32 tmr; /* 0x0c (unused on H3) */ u32 mcr[16][2]; /* 0x10 */ u32 bwcr; /* 0x90 bandwidth control register */ @@ -63,6 +64,17 @@ struct sunxi_mctl_com_reg { #define MCTL_CR_DUAL_RANK (0x1 << 0) #define MCTL_CR_SINGLE_RANK (0x0 << 0)
+/* + * CR_R1 is a register found in the R40's DRAM controller. It sets various + * parameters for rank 1. Bits [11:0] have the same meaning as the bits in + * MCTL_CR, but they apply to rank 1 only. This implies we can have + * different chips for rank 1 than rank 0. + * + * As address line A15 and CS1 chip select for rank 1 are muxed on the same + * pin, if single rank is used, A15 must be muxed in. + */ +#define MCTL_CR_R1_MUX_A15 (0x1 << 21) + #define PROTECT_MAGIC (0x94be6fa3)
struct sunxi_mctl_ctl_reg { @@ -72,7 +84,8 @@ struct sunxi_mctl_ctl_reg { u32 clken; /* 0x0c */ u32 pgsr[2]; /* 0x10 PHY general status registers */ u32 statr; /* 0x18 */ - u8 res1[0x14]; /* 0x1c */ + u8 res1[0x10]; /* 0x1c */ + u32 lp3mr11; /* 0x2c */ u32 mr[4]; /* 0x30 mode registers */ u32 pllgcr; /* 0x40 */ u32 ptr[5]; /* 0x44 PHY timing registers */ @@ -120,7 +133,8 @@ struct sunxi_mctl_ctl_reg { struct { /* 0x300 DATX8 modules*/ u32 mdlr; /* 0x00 master delay line register */ u32 lcdlr[3]; /* 0x04 local calibrated delay line registers */ - u32 bdlr[12]; /* 0x10 bit delay line registers */ + u32 bdlr[11]; /* 0x10 bit delay line registers */ + u32 sdlr; /* 0x3c output enable bit delay registers */ u32 gtr; /* 0x40 general timing register */ u32 gcr; /* 0x44 general configuration register */ u32 gsr[3]; /* 0x48 general status registers */ diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index efab4811ee54..5510aa54353f 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -49,6 +49,7 @@ obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_MACH_SUNXI_H3_H5) += dram_sun8i_h3.o +obj-$(CONFIG_MACH_SUN8I_R40) += dram_sun8i_h3.o obj-$(CONFIG_MACH_SUN9I) += dram_sun9i.o obj-$(CONFIG_MACH_SUN50I) += dram_sun8i_h3.o endif diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 3c8c53fcf76b..9068c88ab2f8 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -222,7 +222,9 @@ done: } #endif
-#if defined(CONFIG_MACH_SUN8I_A33) || defined(CONFIG_MACH_SUN50I) +#if defined(CONFIG_MACH_SUN8I_A33) || \ + defined(CONFIG_MACH_SUN8I_R40) || \ + defined(CONFIG_MACH_SUN50I) void clock_set_pll11(unsigned int clk, bool sigma_delta_enable) { struct sunxi_ccm_reg * const ccm = diff --git a/arch/arm/mach-sunxi/dram_sun8i_h3.c b/arch/arm/mach-sunxi/dram_sun8i_h3.c index d681a9df8be2..2d12661a14d3 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_h3.c +++ b/arch/arm/mach-sunxi/dram_sun8i_h3.c @@ -70,6 +70,12 @@ static void mctl_set_bit_delays(struct dram_para *para) writel(ACBDLR_WRITE_DELAY(para->ac_delays[i]), &mctl_ctl->acbdlr[i]);
+#ifdef CONFIG_MACH_SUN8I_R40 + /* DQSn, DMn, DQn output enable bit delay */ + for (i = 0; i < 4; i++) + writel(0x6 << 24, &mctl_ctl->dx[i].sdlr); +#endif + setbits_le32(&mctl_ctl->pgcr[0], 1 << 26); }
@@ -86,6 +92,9 @@ enum { MBUS_PORT_DI = 9, MBUS_PORT_DE = 10, MBUS_PORT_DE_CFD = 11, + MBUS_PORT_UNKNOWN1 = 12, + MBUS_PORT_UNKNOWN2 = 13, + MBUS_PORT_UNKNOWN3 = 14, };
enum { @@ -205,6 +214,42 @@ static void mctl_set_master_priority_h5(void) MBUS_CONF(DE_CFD, true, HIGHEST, 0, 600, 400, 200); }
+static void mctl_set_master_priority_r40(void) +{ + struct sunxi_mctl_com_reg * const mctl_com = + (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; + + /* enable bandwidth limit windows and set windows size 1us */ + writel(399, &mctl_com->tmr); + writel((1 << 16), &mctl_com->bwcr); + + /* set cpu high priority */ + writel(0x00000001, &mctl_com->mapr); + + /* Port 2 is reserved per Allwinner's linux-3.10 source, yet + * they initialise it */ + MBUS_CONF( CPU, true, HIGHEST, 0, 300, 260, 150); + MBUS_CONF( GPU, true, HIGHEST, 0, 600, 400, 200); + MBUS_CONF( UNUSED, true, HIGHEST, 0, 512, 256, 96); + MBUS_CONF( DMA, true, HIGHEST, 0, 256, 128, 32); + MBUS_CONF( VE, true, HIGHEST, 0, 1900, 1500, 1000); + MBUS_CONF( CSI, true, HIGHEST, 0, 150, 120, 100); + MBUS_CONF( NAND, true, HIGH, 0, 256, 128, 64); + MBUS_CONF( SS, true, HIGHEST, 0, 256, 128, 64); + MBUS_CONF( TS, true, HIGHEST, 0, 256, 128, 64); + MBUS_CONF( DI, true, HIGH, 0, 1024, 256, 64); + + /* + * The port names are probably wrong, but no correct sources + * are available. + */ + MBUS_CONF( DE, true, HIGH, 0, 128, 48, 0); + MBUS_CONF( DE_CFD, true, HIGH, 0, 384, 256, 0); + MBUS_CONF(UNKNOWN1, true, HIGHEST, 0, 512, 384, 256); + MBUS_CONF(UNKNOWN2, true, HIGHEST, 2, 8192, 6144, 1024); + MBUS_CONF(UNKNOWN3, true, HIGH, 0, 1280, 144, 64); +} + static void mctl_set_master_priority(uint16_t socid) { switch (socid) { @@ -217,6 +262,9 @@ static void mctl_set_master_priority(uint16_t socid) case SOCID_H5: mctl_set_master_priority_h5(); return; + case SOCID_R40: + mctl_set_master_priority_r40(); + return; } }
@@ -268,6 +316,9 @@ static void mctl_set_timing_params(uint16_t socid, struct dram_para *para) writel(0x18, &mctl_ctl->mr[2]); /* CWL=8 */ writel(0x0, &mctl_ctl->mr[3]);
+ if (socid == SOCID_R40) + writel(0x3, &mctl_ctl->lp3mr11); /* odt_en[7:4] */ + /* set DRAM timing */ writel(DRAMTMG0_TWTP(twtp) | DRAMTMG0_TFAW(tfaw) | DRAMTMG0_TRAS_MAX(trasmax) | DRAMTMG0_TRAS(tras), @@ -383,7 +434,7 @@ static void mctl_h3_zq_calibration_quirk(struct dram_para *para) } }
-static void mctl_set_cr(struct dram_para *para) +static void mctl_set_cr(uint16_t socid, struct dram_para *para) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; @@ -393,6 +444,14 @@ static void mctl_set_cr(struct dram_para *para) (para->dual_rank ? MCTL_CR_DUAL_RANK : MCTL_CR_SINGLE_RANK) | MCTL_CR_PAGE_SIZE(para->page_size) | MCTL_CR_ROW_BITS(para->row_bits), &mctl_com->cr); + + if (socid == SOCID_R40) { + if (para->dual_rank) + panic("Dual rank memory not supported\n"); + + /* Mux pin to A15 address line for single rank memory. */ + setbits_le32(&mctl_com->cr_r1, MCTL_CR_R1_MUX_A15); + } }
static void mctl_sys_init(uint16_t socid, struct dram_para *para) @@ -407,14 +466,14 @@ static void mctl_sys_init(uint16_t socid, struct dram_para *para) clrbits_le32(&ccm->ahb_gate0, 1 << AHB_GATE_OFFSET_MCTL); clrbits_le32(&ccm->ahb_reset0_cfg, 1 << AHB_RESET_OFFSET_MCTL); clrbits_le32(&ccm->pll5_cfg, CCM_PLL5_CTRL_EN); - if (socid == SOCID_A64) + if (socid == SOCID_A64 || socid == SOCID_R40) clrbits_le32(&ccm->pll11_cfg, CCM_PLL11_CTRL_EN); udelay(10);
clrbits_le32(&ccm->dram_clk_cfg, CCM_DRAMCLK_CFG_RST); udelay(1000);
- if (socid == SOCID_A64) { + if (socid == SOCID_A64 || socid == SOCID_R40) { clock_set_pll11(CONFIG_DRAM_CLK * 2 * 1000000, false); clrsetbits_le32(&ccm->dram_clk_cfg, CCM_DRAMCLK_CFG_DIV_MASK | @@ -459,7 +518,7 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para)
unsigned int i;
- mctl_set_cr(para); + mctl_set_cr(socid, para); mctl_set_timing_params(socid, para); mctl_set_master_priority(socid);
@@ -509,6 +568,13 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para) /* dphy & aphy phase select ? */ clrsetbits_le32(&mctl_ctl->pgcr[2], (0x3 << 10) | (0x3 << 8), (0x0 << 10) | (0x3 << 8)); + } else if (socid == SOCID_R40) { + /* dx ddr_clk & hdr_clk dynamic mode (tpr13[9] == 0) */ + clrbits_le32(&mctl_ctl->pgcr[0], (0x3 << 14) | (0x3 << 12)); + + /* dphy & aphy phase select ? */ + clrsetbits_le32(&mctl_ctl->pgcr[2], (0x3 << 10) | (0x3 << 8), + (0x0 << 10) | (0x3 << 8)); }
/* set half DQ */ @@ -535,6 +601,11 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para) mctl_phy_init(PIR_ZCAL | PIR_PLLINIT | PIR_DCAL | PIR_PHYRST | PIR_DRAMRST | PIR_DRAMINIT | PIR_QSGATE); /* no PIR_QSGATE for H5 ???? */ + } else if (socid == SOCID_R40) { + clrsetbits_le32(&mctl_ctl->zqcr, 0xffffff, CONFIG_DRAM_ZQ); + + mctl_phy_init(PIR_ZCAL | PIR_PLLINIT | PIR_DCAL | PIR_PHYRST | + PIR_DRAMRST | PIR_DRAMINIT); }
/* detect ranks and bus width */ @@ -554,7 +625,7 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para) para->bus_width = 16; }
- mctl_set_cr(para); + mctl_set_cr(socid, para); udelay(20);
/* re-train */ @@ -575,7 +646,7 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para) /* set PGCR3, CKE polarity */ if (socid == SOCID_H3) writel(0x00aa0060, &mctl_ctl->pgcr[3]); - else if (socid == SOCID_A64 || socid == SOCID_H5) + else if (socid == SOCID_A64 || socid == SOCID_H5 || socid == SOCID_R40) writel(0xc0aa0060, &mctl_ctl->pgcr[3]);
/* power down zq calibration module for power save */ @@ -587,12 +658,12 @@ static int mctl_channel_init(uint16_t socid, struct dram_para *para) return 0; }
-static void mctl_auto_detect_dram_size(struct dram_para *para) +static void mctl_auto_detect_dram_size(uint16_t socid, struct dram_para *para) { /* detect row address bits */ para->page_size = 512; para->row_bits = 16; - mctl_set_cr(para); + mctl_set_cr(socid, para);
for (para->row_bits = 11; para->row_bits < 16; para->row_bits++) if (mctl_mem_matches((1 << (para->row_bits + 3)) * para->page_size)) @@ -600,7 +671,7 @@ static void mctl_auto_detect_dram_size(struct dram_para *para)
/* detect page size */ para->page_size = 8192; - mctl_set_cr(para); + mctl_set_cr(socid, para);
for (para->page_size = 512; para->page_size < 8192; para->page_size *= 2) if (mctl_mem_matches(para->page_size)) @@ -630,6 +701,22 @@ static void mctl_auto_detect_dram_size(struct dram_para *para) 0, 0, 0, 0, 0, 0, 0, 0, \ 0, 0, 0, 0, 0, 0, 0 }
+#define SUN8I_R40_DX_READ_DELAYS \ + {{ 14, 14, 14, 14, 14, 14, 14, 14, 14, 0, 0 }, \ + { 14, 14, 14, 14, 14, 14, 14, 14, 14, 0, 0 }, \ + { 14, 14, 14, 14, 14, 14, 14, 14, 14, 0, 0 }, \ + { 14, 14, 14, 14, 14, 14, 14, 14, 14, 0, 0 } } +#define SUN8I_R40_DX_WRITE_DELAYS \ + {{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 6, 0 }, \ + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 6, 0 }, \ + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 6, 0 }, \ + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 6, 0 } } +#define SUN8I_R40_AC_DELAYS \ + { 0, 0, 3, 0, 0, 0, 0, 0, \ + 0, 0, 0, 0, 0, 0, 0, 0, \ + 0, 0, 0, 0, 0, 0, 0, 0, \ + 0, 0, 0, 0, 0, 0, 0 } + #define SUN50I_A64_DX_READ_DELAYS \ {{ 16, 16, 16, 16, 17, 16, 16, 17, 16, 1, 0 }, \ { 17, 17, 17, 17, 17, 17, 17, 17, 17, 1, 0 }, \ @@ -679,6 +766,10 @@ unsigned long sunxi_dram_init(void) .dx_read_delays = SUN8I_H3_DX_READ_DELAYS, .dx_write_delays = SUN8I_H3_DX_WRITE_DELAYS, .ac_delays = SUN8I_H3_AC_DELAYS, +#elif defined(CONFIG_MACH_SUN8I_R40) + .dx_read_delays = SUN8I_R40_DX_READ_DELAYS, + .dx_write_delays = SUN8I_R40_DX_WRITE_DELAYS, + .ac_delays = SUN8I_R40_AC_DELAYS, #elif defined(CONFIG_MACH_SUN50I) .dx_read_delays = SUN50I_A64_DX_READ_DELAYS, .dx_write_delays = SUN50I_A64_DX_WRITE_DELAYS, @@ -696,6 +787,8 @@ unsigned long sunxi_dram_init(void) */ #if defined(CONFIG_MACH_SUN8I_H3) uint16_t socid = SOCID_H3; +#elif defined(CONFIG_MACH_SUN8I_R40) + uint16_t socid = SOCID_R40; #elif defined(CONFIG_MACH_SUN50I) uint16_t socid = SOCID_A64; #elif defined(CONFIG_MACH_SUN50I_H5) @@ -716,9 +809,11 @@ unsigned long sunxi_dram_init(void) if (socid == SOCID_H3) writel(0x0c000400, &mctl_ctl->odtcfg);
- if (socid == SOCID_A64 || socid == SOCID_H5) { + if (socid == SOCID_A64 || socid == SOCID_H5 || socid == SOCID_R40) { + /* VTF enable (tpr13[8] == 1) */ setbits_le32(&mctl_ctl->vtfcr, - (socid == SOCID_H5 ? 3 : 2) << 8); + (socid != SOCID_A64 ? 3 : 2) << 8); + /* DQ hold disable (tpr13[26] == 1) */ clrbits_le32(&mctl_ctl->pgcr[2], (1 << 13)); }
@@ -726,8 +821,8 @@ unsigned long sunxi_dram_init(void) setbits_le32(&mctl_com->cccr, 1 << 31); udelay(10);
- mctl_auto_detect_dram_size(¶); - mctl_set_cr(¶); + mctl_auto_detect_dram_size(socid, ¶); + mctl_set_cr(socid, ¶);
return (1UL << (para.row_bits + 3)) * para.page_size * (para.dual_rank ? 2 : 1);
Now that we can do DRAM initialization for the R40, we can enable SPL support for it.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 94d01cb5c1ec..5bc4ce037f54 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -138,6 +138,7 @@ config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" select CPU_V7 select SUNXI_GEN_SUN6I + select SUPPORT_SPL
The R40 has the CPUCFG block at the same address as the A20. Fix it.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index ea672fe8449a..88c3f138173f 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -108,7 +108,7 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_TP_BASE 0x01c25000 #define SUNXI_PMU_BASE 0x01c25400
-#ifdef CONFIG_MACH_SUN7I +#if defined CONFIG_MACH_SUN7I || defined CONFIG_MACH_SUN8I_R40 #define SUNXI_CPUCFG_BASE 0x01c25c00 #endif
@@ -167,7 +167,9 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_RTC_BASE 0x01f00000 #define SUNXI_PRCM_BASE 0x01f01400
-#if defined CONFIG_SUNXI_GEN_SUN6I && !defined CONFIG_MACH_SUN8I_A83T +#if defined CONFIG_SUNXI_GEN_SUN6I && \ + !defined CONFIG_MACH_SUN8I_A83T && \ + !defined CONFIG_MACH_SUN8I_R40 #define SUNXI_CPUCFG_BASE 0x01f01c00 #endif
The R40's CPU controls are a combination of sun6i and sun7i.
All controls are in the CPUCFG block, and it seems the R40 does not have a PRCM block. The core reset, power gating and clamp controls are grouped like sun6i.
Last, the R40 does not have a secure SRAM block.
This patch adds a PSCI implementation for CPU bring-up and hotplug for the R40.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/cpu/armv7/sunxi/psci.c | 35 ++++++++++++++++++++++++++++++++--- board/sunxi/Kconfig | 3 +++ 2 files changed, 35 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/psci.c b/arch/arm/cpu/armv7/sunxi/psci.c index 104dc909bc53..b3a34de1aafe 100644 --- a/arch/arm/cpu/armv7/sunxi/psci.c +++ b/arch/arm/cpu/armv7/sunxi/psci.c @@ -27,6 +27,17 @@ #define GICD_BASE (SUNXI_GIC400_BASE + GIC_DIST_OFFSET) #define GICC_BASE (SUNXI_GIC400_BASE + GIC_CPU_OFFSET_A15)
+/* + * R40 is different from other single cluster SoCs. + * + * The power clamps are located in the unused space after the per-core + * reset controls for core 3. The secondary core entry address register + * is in the SRAM controller address range. + */ +#define SUN8I_R40_PWROFF (0x110) +#define SUN8I_R40_PWR_CLAMP(cpu) (0x120 + (cpu) * 0x4) +#define SUN8I_R40_SRAMC_SOFT_ENTRY_REG0 (0xbc) + static void __secure cp15_write_cntp_tval(u32 tval) { asm volatile ("mcr p15, 0, %0, c14, c2, 0" : : "r" (tval)); @@ -68,7 +79,8 @@ static void __secure __mdelay(u32 ms) static void __secure clamp_release(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_H3) + defined(CONFIG_MACH_SUN8I_H3) || \ + defined(CONFIG_MACH_SUN8I_R40) u32 tmp = 0x1ff; do { tmp >>= 1; @@ -82,7 +94,8 @@ static void __secure clamp_release(u32 __maybe_unused *clamp) static void __secure clamp_set(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_H3) + defined(CONFIG_MACH_SUN8I_H3) || \ + defined(CONFIG_MACH_SUN8I_R40) writel(0xff, clamp); #endif } @@ -115,7 +128,17 @@ static void __secure sunxi_cpu_set_power(int __always_unused cpu, bool on) sunxi_power_switch(&cpucfg->cpu1_pwr_clamp, &cpucfg->cpu1_pwroff, on, 0); } -#else /* ! CONFIG_MACH_SUN7I */ +#elif defined CONFIG_MACH_SUN8I_R40 +static void __secure sunxi_cpu_set_power(int cpu, bool on) +{ + struct sunxi_cpucfg_reg *cpucfg = + (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE; + + sunxi_power_switch((void *)cpucfg + SUN8I_R40_PWR_CLAMP(cpu), + (void *)cpucfg + SUN8I_R40_PWROFF, + on, 0); +} +#else /* ! CONFIG_MACH_SUN7I && ! CONFIG_MACH_SUN8I_R40 */ static void __secure sunxi_cpu_set_power(int cpu, bool on) { struct sunxi_prcm_reg *prcm = @@ -213,7 +236,13 @@ int __secure psci_cpu_on(u32 __always_unused unused, u32 mpidr, u32 pc) psci_save_target_pc(cpu, pc);
/* Set secondary core power on PC */ +#ifdef CONFIG_MACH_SUN8I_R40 + /* secondary core entry address is programmed differently */ + writel((u32)&psci_cpu_entry, + SUNXI_SRAMC_BASE + SUN8I_R40_SRAMC_SOFT_ENTRY_REG0); +#else writel((u32)&psci_cpu_entry, &cpucfg->priv0); +#endif
/* Assert reset on target CPU */ writel(0, &cpucfg->cpu[cpu].rst); diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 5bc4ce037f54..811eb47dc17f 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -137,6 +137,9 @@ config MACH_SUN8I_H3 config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select ARCH_SUPPORT_PSCI select SUNXI_GEN_SUN6I select SUPPORT_SPL
The Bananapi M2 Ultra is the first publicly available development board featuring the R40 SoC.
This patch add barebone dtsi/dts files for the R40 and Bananapi M2 Ultra, as well as a defconfig for it.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 69 ++++++++++ arch/arm/dts/sun8i-r40.dtsi | 183 +++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 + configs/Bananapi_M2_Ultra_defconfig | 15 +++ 5 files changed, 275 insertions(+) create mode 100644 arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts create mode 100644 arch/arm/dts/sun8i-r40.dtsi create mode 100644 configs/Bananapi_M2_Ultra_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ce34e3eeff8a..198693c823c6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -304,6 +304,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-plus2e.dtb \ sun8i-h3-nanopi-neo.dtb \ sun8i-h3-nanopi-neo-air.dtb +dtb-$(CONFIG_MACH_SUN8I_R40) += \ + sun8i-r40-bananapi-m2-ultra.dtb dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-pc2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts new file mode 100644 index 000000000000..ab471ab0bffb --- /dev/null +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -0,0 +1,69 @@ +/* + * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-r40.dtsi" + +/ { + model = "Banana Pi BPI-M2-Ultra"; + compatible = "sinovoip,bpi-m2-ultra", "allwinner,sun8i-r40"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi new file mode 100644 index 000000000000..48ec2e855a2c --- /dev/null +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -0,0 +1,183 @@ +/* + * Copyright 2016 Chen-Yu Tsai + * + * Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&gic>; + + aliases { + }; + + chosen { + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + }; + + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + }; + + cpu@1 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <1>; + }; + + cpu@2 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <2>; + }; + + cpu@3 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <3>; + }; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x40000000 0x80000000>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pio: pinctrl@1c20800 { + compatible = "allwinner,sun8i-r40-pinctrl"; + reg = <0x01c20800 0x400>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + /* apb should be replaced once CCU is implemented */ + clocks = <&osc24M>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + interrupt-controller; + #interrupt-cells = <3>; + #gpio-cells = <3>; + + i2c0_pins: i2c0_pins { + pins = "PB0", "PB1"; + function = "i2c0"; + bias-pull-up; + }; + + uart0_pb_pins: uart0_pb_pins { + pins = "PB22", "PB23"; + function = "uart0"; + bias-pull-up; + }; + }; + + uart0: serial@1c28000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28000 0x400>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&osc24M>; + status = "disabled"; + }; + + i2c0: i2c@1c2ac00 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2ac00 0x400>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + gic: interrupt-controller@1c81000 { + compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x1000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + clock-frequency = <24000000>; + arm,cpu-registers-not-fw-configured; + }; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 91ca6eaf7a67..7e05f43341cc 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -109,6 +109,12 @@ M: Paul Kocialkowski contact@paulk.fr S: Maintained F: configs/Ampe_A76_defconfig
+BANANAPI M2 ULTRA BOARD +M: Chen-Yu Tsai wens@csie.org +S: Maintained +F: configs/Bananapi_M2_Ultra_defconfig +F: arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts + COLOMBUS BOARD M: Maxime Ripard maxime.ripard@free-electrons.com S: Maintained diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig new file mode 100644 index 000000000000..c6da7274e176 --- /dev/null +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_R40=y +CONFIG_DRAM_CLK=576 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun8i-r40-bananapi-m2-ultra" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set
On Tue, Apr 18, 2017 at 10:20:16AM +0800, Chen-Yu Tsai wrote:
Hi everyone,
Merged and pushed. Thanks! Maxime
Chen-Yu Tsai
Maxime Ripard
