[U-Boot] use "boot select" jumper on NGW100 to select USART
From: Thomas Sprinkmeier thomas.sprinkmeier@gmail.com Date: Mon, 9 Nov 2009 09:28:51 +1030 Subject: [PATCH] use "boot select" jumper on NGW100 to select USART
Without the "boot select" jumper U-Boot will use the USART selected using the CONFIG_USART1, CONFIG_USART2, directive.
If CONFIG_ALT_USART1 (or ..2, ..3, ..0) is defined then, with the jumper in place, that USART is used instead.
Signed-off-by: Thomas Sprinkmeier <thomas.sprinkmeier@gmail.com --- board/atmel/atngw100/atngw100.c | 6 ++- drivers/serial/atmel_usart.c | 15 +------- include/atmel_alt_usart.h | 81 +++++++++++++++++++++++++++++++++++++++ include/configs/atngw100.h | 1 + 4 files changed, 88 insertions(+), 15 deletions(-) create mode 100644 include/atmel_alt_usart.h
diff --git a/board/atmel/atngw100/atngw100.c b/board/atmel/atngw100/atngw100.c index 004d8da..841d9ec 100644 --- a/board/atmel/atngw100/atngw100.c +++ b/board/atmel/atngw100/atngw100.c @@ -29,6 +29,8 @@ #include <asm/arch/portmux.h> #include <netdev.h>
+#include <atmel_alt_usart.h> + DECLARE_GLOBAL_DATA_PTR;
static const struct sdram_config sdram_config = { @@ -53,7 +55,9 @@ int board_early_init_f(void) hmatrix_slave_write(EBI, SFR, HMATRIX_BIT(EBI_SDRAM_ENABLE));
portmux_enable_ebi(16, 23, 0, PORTMUX_DRIVE_HIGH); - portmux_enable_usart1(PORTMUX_DRIVE_MIN); + + USART_JUMPER_CONFIG; + USART_ENABLE;
#if defined(CONFIG_MACB) portmux_enable_macb0(PORTMUX_MACB_MII, PORTMUX_DRIVE_HIGH); diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f50552a..c78755c 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -21,20 +21,7 @@ #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/memory-map.h> - -#if defined(CONFIG_USART0) -# define USART_ID 0 -# define USART_BASE USART0_BASE -#elif defined(CONFIG_USART1) -# define USART_ID 1 -# define USART_BASE USART1_BASE -#elif defined(CONFIG_USART2) -# define USART_ID 2 -# define USART_BASE USART2_BASE -#elif defined(CONFIG_USART3) -# define USART_ID 3 -# define USART_BASE USART3_BASE -#endif +#include <atmel_alt_usart.h>
#include "atmel_usart.h"
diff --git a/include/atmel_alt_usart.h b/include/atmel_alt_usart.h new file mode 100644 index 0000000..1ed2fb8 --- /dev/null +++ b/include/atmel_alt_usart.h @@ -0,0 +1,81 @@ +/* + * Copyright (C) 2009 Thomas Sprinkmeier + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#ifndef __ATMEL_ALT_USART_H__ +#define __ATMEL_ALT_USART_H__ + +/* Define alternate USART ID and BASE */ +#if defined(CONFIG_ALT_USART0) +# define USART_ALT_ID 0 +# define USART_ALT_BASE USART0_BASE +#elif defined(CONFIG_ALT_USART1) +# define USART_ALT_ID 1 +# define USART_ALT_BASE USART1_BASE +#elif defined(CONFIG_ALT_USART2) +# define USART_ALT_ID 2 +# define USART_ALT_BASE USART2_BASE +#elif defined(CONFIG_ALT_USART3) +# define USART_ALT_ID 3 +# define USART_ALT_BASE USART3_BASE +#elif +/* No alternate USART selected */ +#define USART_USE_ALT (0) +#define USART_PIN_CONFIG +#endif + +/* How to read/initialise the boot-select jumper */ +#ifndef USART_USE_ALT +#define USART_USE_ALT (!gpio_get_value(GPIO_PIN_PB(30))) +#define USART_JUMPER_CONFIG portmux_select_gpio(PORTMUX_PORT_B, \ + (1 << 30), \ + PORTMUX_DIR_INPUT) +#endif + +/*Configure default USART ID and BASE*/ +#if defined(CONFIG_USART0) +# define USART_DEF_ID 0 +# define USART_DEF_BASE USART0_BASE +#elif defined(CONFIG_USART1) +# define USART_DEF_ID 1 +# define USART_DEF_BASE USART1_BASE +#elif defined(CONFIG_USART2) +# define USART_DEF_ID 2 +# define USART_DEF_BASE USART2_BASE +#elif defined(CONFIG_USART3) +# define USART_DEF_ID 3 +# define USART_DEF_BASE USART3_BASE +#elif +#error You must define CONFIG_USART[0..1] to select a console port +#endif + + +/* Which USART ID/BASE to use. */ +#define USART_ID (USART_USE_ALT ? USART_ALT_ID : USART_DEF_ID) +#define USART_BASE (USART_USE_ALT ? USART_ALT_BASE : USART_DEF_BASE) + +/* Enable the appropriate USART */ +#define USART_ENABLE { \ + switch (USART_ID) \ + { \ + case 0: portmux_enable_usart0(PORTMUX_DRIVE_MIN); break; \ + case 1: portmux_enable_usart1(PORTMUX_DRIVE_MIN); break; \ + case 2: portmux_enable_usart2(PORTMUX_DRIVE_MIN); break; \ + default: portmux_enable_usart3(PORTMUX_DRIVE_MIN); break; \ + } \ + } while(0) + +#endif /* __ATMEL_ALT_USART_H__ */ diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 4ed5514..60a3b60 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -59,6 +59,7 @@ #define CONFIG_SYS_PLL0_OPT 0x04
#define CONFIG_USART1 1 +#define CONFIG_ALT_USART3 1
/* User serviceable stuff */ #define CONFIG_DOS_PARTITION 1
Dear Thomas Sprinkmeier,
- USART_JUMPER_CONFIG;
- USART_ENABLE;
Function / Macro when used as funxctions should always look as such, i. e. have parens with them.
- switch (USART_ID) \
- case 0: portmux_enable_usart0(PORTMUX_DRIVE_MIN); break; \
- case 1: portmux_enable_usart1(PORTMUX_DRIVE_MIN); break; \
- case 2: portmux_enable_usart2(PORTMUX_DRIVE_MIN); break; \
- default: portmux_enable_usart3(PORTMUX_DRIVE_MIN); break; \
- } while(0)
NAK. When you use a function-style macro it should look like one. But why is this a macro at all? Please make it a (static) inline function instead.
Also please note that the Coding Style requires indentation by TABs.
Dear Wolfgang Denk,
- USART_ENABLE;
So the patch for atmel_usart.c would look like this:
portmux_enable_ebi(16, 23, 0, PORTMUX_DRIVE_HIGH); - portmux_enable_usart1(PORTMUX_DRIVE_MIN); + + USART_JUMPER_CONFIG(); + atmel_usart_enable();
and atmel_alt_usart.h would change to:
+#elif +/* No alternate USART selected */ +#define USART_USE_ALT() (0) +#define USART_PIN_CONFIG() +#endif + +/* How to read/initialise the boot-select jumper */ +#ifndef USART_USE_ALT +#define USART_USE_ALT() (!gpio_get_value(GPIO_PIN_PB(30))) +#define USART_JUMPER_CONFIG() portmux_select_gpio(PORTMUX_PORT_B, \ + (1 << 30), \ + PORTMUX_DIR_INPUT) +#endif
or should USART_USE_ALT and USART_JUMPER_CONFIG become static inline functions (as below)?
I was trying to make as little impact as possible, somehow a macro seemed 'better' than a function.
- } while(0)
+/* Enable the appropriate USART */ +static inline void atmel_usart_enable() +{ + switch (USART_ID) { + case 0: + portmux_enable_usart0(PORTMUX_DRIVE_MIN); + break; + case 1: + portmux_enable_usart1(PORTMUX_DRIVE_MIN); + break; + case 2: + portmux_enable_usart2(PORTMUX_DRIVE_MIN); + break; + default: + portmux_enable_usart3(PORTMUX_DRIVE_MIN); + } +} + +#endif /* __ATMEL_ALT_USART_H__ */
fixed.
Thank you for your patience,
Thomas
Dear Thomas,
In message e355f1140911092249l5c585dedy6970a9f8ce663b8f@mail.gmail.com you wrote:
- USART_JUMPER_CONFIG();
- atmel_usart_enable();
Why not make USART_JUMPER_CONFIG() a function as well?
That would probably be better, indeed.
See "Documentation/CodingStyle", Chapter 12: Macros, Enums and RTL:
Generally, inline functions are preferable to macros resembling functions.
Thomas Sprinkmeier
