[U-Boot] [PATCH v4] OMAP3: add CM-T35 board
Add CM-T35 board support
Signed-off-by: Mike Rapoport mike@compulab.co.il
-- v2 changes: - rename board config file from omap3_cm-t35.h to cm-t35.h - remove SZ_xx references - add MAKEALL/MAINTEINERS entries
v3 changes: - fix whitespace and indentation - remove eth_init from board_eth_init - add CM-T35 entry to doc/README.omap3 - fixed board name in MAINTAINERS
v4 changes: - rebased agains u-boot-ti/next branch
--- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 2 + board/cm-t35/Makefile | 47 +++++++ board/cm-t35/cm-t35.c | 190 +++++++++++++++++++++++++++++ board/cm-t35/cm-t35.h | 173 ++++++++++++++++++++++++++ board/cm-t35/config.mk | 30 +++++ doc/README.omap3 | 16 ++- include/configs/cm-t35.h | 299 ++++++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 760 insertions(+), 2 deletions(-) create mode 100644 board/cm-t35/Makefile create mode 100644 board/cm-t35/cm-t35.c create mode 100644 board/cm-t35/cm-t35.h create mode 100644 board/cm-t35/config.mk create mode 100644 include/configs/cm-t35.h
diff --git a/MAINTAINERS b/MAINTAINERS index d70a9d2..49b2164 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -677,6 +677,10 @@ Stelian Pop stelian.pop@leadtechdesign.com at91sam9263ek ARM926EJS (AT91SAM9263 SoC) at91sam9rlek ARM926EJS (AT91SAM9RL SoC)
+Mike Rapoport mike@compulab.co.il + + cm-t35 ARM CORTEX-A8 (OMAP3xx SoC) + Tom Rix Tom.Rix@windriver.com
omap3_zoom2 ARM CORTEX-A8 (OMAP3xx SoC) diff --git a/MAKEALL b/MAKEALL index d63c5c2..6f90ad5 100755 --- a/MAKEALL +++ b/MAKEALL @@ -612,6 +612,7 @@ LIST_ARM11=" \ ## ARM Cortex-A8 Systems ######################################################################### LIST_ARM_CORTEX_A8=" \ + cm-t35 \ devkit8000 \ omap3_beagle \ omap3_overo \ diff --git a/Makefile b/Makefile index bcb3fe9..24c9418 100644 --- a/Makefile +++ b/Makefile @@ -3143,6 +3143,8 @@ SMN42_config : unconfig ######################################################################### ## ARM CORTEX Systems ######################################################################### +cm-t35_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 cm-t35 NULL omap3
devkit8000_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 devkit8000 timll omap3 diff --git a/board/cm-t35/Makefile b/board/cm-t35/Makefile new file mode 100644 index 0000000..7b80aaa --- /dev/null +++ b/board/cm-t35/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := cm-t35.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/cm-t35/cm-t35.c b/board/cm-t35/cm-t35.c new file mode 100644 index 0000000..40488a2 --- /dev/null +++ b/board/cm-t35/cm-t35.c @@ -0,0 +1,190 @@ +/* + * (C) Copyright 2009 + * CompuLab, Ltd. <www.compulab.co.il> + * + * Authors : + * Igor Vaisbein igor@compulab.co.il + * Mike Rapoport mike@compulab.co.il + * + * Derived from omap3evm and Beagle Board by + * Manikandan Pillai mani.pillai@ti.com + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <net.h> +#include <i2c.h> +#include <twl4030.h> + +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-types.h> + +#include "cm-t35.h" + +static u32 gpmc_net_config[GPMC_MAX_REG] = { + NET_GPMC_CONFIG1, + NET_GPMC_CONFIG2, + NET_GPMC_CONFIG3, + NET_GPMC_CONFIG4, + NET_GPMC_CONFIG5, + NET_GPMC_CONFIG6, + 0 +}; + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: setup_net_chip + * Description: Setting up the configuration GPMC registers specific to the + * Ethernet hardware. + */ +static void setup_net_chip(void) +{ + struct ctrl *ctrl_base = (struct ctrl *)OMAP34XX_CTRL_BASE; + + enable_gpmc_cs_config(gpmc_net_config, &gpmc_cfg->cs[5], + CM_T35_SMC911X_BASE, GPMC_SIZE_16M); + enable_gpmc_cs_config(gpmc_net_config, &gpmc_cfg->cs[4], + SB_T35_SMC911X_BASE, GPMC_SIZE_16M); + + /* Enable off mode for NWE in PADCONF_GPMC_NWE register */ + writew(readw(&ctrl_base->gpmc_nwe) | 0x0E00, &ctrl_base->gpmc_nwe); + + /* Enable off mode for NOE in PADCONF_GPMC_NADV_ALE register */ + writew(readw(&ctrl_base->gpmc_noe) | 0x0E00, &ctrl_base->gpmc_noe); + + /* Enable off mode for ALE in PADCONF_GPMC_NADV_ALE register */ + writew(readw(&ctrl_base->gpmc_nadv_ale) | 0x0E00, + &ctrl_base->gpmc_nadv_ale); + + /* Reset the ethernet controller via TPS65930 GPIO */ + /* Set GPIO1 of TPS65930 as output */ + twl4030_i2c_write_u8(TWL4030_CHIP_GPIO, 0x02, + TWL4030_BASEADD_GPIO+0x03); + /* Send a pulse on the GPIO pin */ + twl4030_i2c_write_u8(TWL4030_CHIP_GPIO, 0x02, + TWL4030_BASEADD_GPIO+0x0C); + udelay(1); + twl4030_i2c_write_u8(TWL4030_CHIP_GPIO, 0x02, + TWL4030_BASEADD_GPIO+0x09); + udelay(1); + twl4030_i2c_write_u8(TWL4030_CHIP_GPIO, 0x02, + TWL4030_BASEADD_GPIO+0x0C); +} + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_CM_T35; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Init ethernet (done here so udelay works) + */ +int misc_init_r(void) +{ +#ifdef CONFIG_DRIVER_OMAP34XX_I2C + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif + +#if defined(CONFIG_CMD_NET) + setup_net_chip(); +#endif + + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_CM_T35(); +} + +/* + * Routine: handle_mac_address + * Description: prepare MAC address for on-board Ethernet. + */ +static int handle_mac_address(void) +{ + unsigned char enetaddr[6]; + int rc; + + rc = eth_getenv_enetaddr("ethaddr", enetaddr); + if (rc) + return 0; + + rc = i2c_read(0x50, 0, 1, enetaddr, 6); + if (rc) + return rc; + + if (!is_valid_ether_addr(enetaddr)) + return -1; + + return eth_setenv_enetaddr("ethaddr", enetaddr); +} + +/* + * Routine: board_eth_init + * Description: initialize module and base-board Ethernet chips + */ +int board_eth_init(bd_t *bis) +{ + int rc = 0, rc1 = 0; + +#ifdef CONFIG_SMC911X + rc1 = handle_mac_address(); + if (rc1) + printf("CM-T35: No MAC address found\n"); + + rc1 = smc911x_initialize(0, CM_T35_SMC911X_BASE); + if (rc1 > 0) + rc++; + + rc1 = smc911x_initialize(1, SB_T35_SMC911X_BASE); + if (rc1 > 0) + rc++; +#endif + + return rc; +} diff --git a/board/cm-t35/cm-t35.h b/board/cm-t35/cm-t35.h new file mode 100644 index 0000000..188ba42 --- /dev/null +++ b/board/cm-t35/cm-t35.h @@ -0,0 +1,173 @@ +/* + * (C) Copyright 2009 CompuLab, Ltd + * Authors: + * Igor Vaisbein igor@compulab.co.il + * Mike Rapoport mike@compulab.co.il + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CM_T35_H_ +#define _CM_T35_H_ + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "CM-T35 board", + "NAND", +}; + +/* static void setup_net_chip(void); */ + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_CM_T35() \ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) /*GPMC_A1*/\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) /*GPMC_A2*/\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) /*GPMC_A3*/\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) /*GPMC_A4*/\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) /*GPMC_A5*/\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) /*GPMC_A6*/\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) /*GPMC_A7*/\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) /*GPMC_A8*/\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) /*GPMC_A9*/\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) /*GPMC_A10*/\ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) /*GPMC_D0*/\ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) /*GPMC_D1*/\ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) /*GPMC_D2*/\ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) /*GPMC_D3*/\ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) /*GPMC_D4*/\ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) /*GPMC_D5*/\ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) /*GPMC_D6*/\ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) /*GPMC_D7*/\ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) /*GPMC_D8*/\ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) /*GPMC_D9*/\ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) /*GPMC_D10*/\ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) /*GPMC_D11*/\ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) /*GPMC_D12*/\ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) /*GPMC_D13*/\ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) /*GPMC_D14*/\ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) /*GPMC_D15*/\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0*/\ + /* SB-T35 Ethernet */\ + MUX_VAL(CP(GPMC_NCS4), (IEN | PTU | EN | M0)) /*GPMC_nCS4*/\ + /* CM-T35 Ethernet */\ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | DIS | M0)) /*GPMC_nCS5*/\ + MUX_VAL(CP(GPMC_CLK), (IEN | PTD | DIS | M4)) /*GPIO_59*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*nADV_ALE*/\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*nOE*/\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*nWE*/\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) /*nBE0_CLE*/\ + MUX_VAL(CP(GPMC_NBE1), (IDIS | PTD | DIS | M4)) /*GPIO_61*/\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*nWP*/\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*WAIT0*/\ + /*DSS*/\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) /*DSS_PCLK*/\ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) /*DSS_HSYNC*/\ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) /*DSS_VSYNC*/\ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) /*DSS_ACBIAS*/\ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) /*DSS_DATA0*/\ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) /*DSS_DATA1*/\ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) /*DSS_DATA2*/\ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) /*DSS_DATA3*/\ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) /*DSS_DATA4*/\ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) /*DSS_DATA5*/\ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) /*DSS_DATA6*/\ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) /*DSS_DATA7*/\ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) /*DSS_DATA8*/\ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) /*DSS_DATA9*/\ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) /*DSS_DATA10*/\ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) /*DSS_DATA11*/\ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) /*DSS_DATA12*/\ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) /*DSS_DATA13*/\ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) /*DSS_DATA14*/\ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) /*DSS_DATA15*/\ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) /*DSS_DATA16*/\ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) /*DSS_DATA17*/\ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) /*DSS_DATA18*/\ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) /*DSS_DATA19*/\ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) /*DSS_DATA20*/\ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) /*DSS_DATA21*/\ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) /*DSS_DATA22*/\ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) /*DSS_DATA23*/\ + /*Serial Interface*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /*UART3_RX*/\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*OFF_MODE*/\ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) /*CLKOUT1*/\ + MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTD | DIS | M4)) /*green LED*/\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) /*JTAG_TCK*/\ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) /*JTAG_TMS*/\ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) /*JTAG_TDI*/\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*sdrc_cke1*/\ + +#endif diff --git a/board/cm-t35/config.mk b/board/cm-t35/config.mk new file mode 100644 index 0000000..a90c86a --- /dev/null +++ b/board/cm-t35/config.mk @@ -0,0 +1,30 @@ +# +# (C) Copyright 2009 +# CompuLab, Ltd., <www.compulab.co.il> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# Physical Address: +# 8000'0000 (bank0) +# +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80e80000 diff --git a/doc/README.omap3 b/doc/README.omap3 index 6227151..afd0d4e 100644 --- a/doc/README.omap3 +++ b/doc/README.omap3 @@ -21,6 +21,8 @@ Currently the following boards are supported:
* TI/Logic PD Zoom 2 [7]
+* CompuLab Ltd. CM-T35 [8] + Toolchain =========
@@ -61,6 +63,11 @@ make make omap3_zoom2_config make
+* CM-T35: + +make cm-t35_config +make + Custom commands ===============
@@ -119,7 +126,7 @@ To read a bit : Acknowledgements ================
-OMAP3 U-Boot is based on U-Boot tar ball [8] for BeagleBoard and EVM done by +OMAP3 U-Boot is based on U-Boot tar ball [9] for BeagleBoard and EVM done by several TI employees.
Links @@ -153,6 +160,11 @@ http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit [7] TI/Logic PD Zoom 2
http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brie... -[8] TI OMAP3 U-Boot: + +[8] CompuLab Ltd. CM-T35: + +http://www.compulab.co.il/t35/html/t35-cm-datasheet.htm + +[9] TI OMAP3 U-Boot:
http://beagleboard.googlecode.com/files/u-boot_beagle_revb.tar.gz diff --git a/include/configs/cm-t35.h b/include/configs/cm-t35.h new file mode 100644 index 0000000..9c170ae --- /dev/null +++ b/include/configs/cm-t35.h @@ -0,0 +1,299 @@ +/* + * (C) Copyright 2009 CompuLab, Ltd. + * + * Authors : + * Igor Vaisbein igor@compulab.co.il + * Mike Rapoport mike@compulab.co.il + * + * Derived from omap3evm and Beagle Board by + * Manikandan Pillai mani.pillai@ti.com + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * Configuration settings for the CompuLab CM-T35 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_CM_T35 1 /* working with CM_T35 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +/* DDR type - Micron */ +#define CONFIG_OMAP3_MICRON_DDR 1 + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* Size of malloc() pool */ +#define CONFIG_ENV_SIZE (128 << 10) /* Total Size Environment */ + /* Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (512 << 10)) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ + /* initial data */ +/* NS16550 Configuration */ +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 /* UART3 */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_YAFFS2 /* YAFFS2 Support */ +#define CONFIG_CMD_UBI /* UBI Support */ +#define CONFIG_CMD_MTDPARTS + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* TWL4030 */ +#define CONFIG_TWL4030_POWER 1 + +/* Board NAND Info. */ +#define CONFIG_NAND_OMAP_GPMC 1 +#define GPMC_NAND_ECC_LP_x8_LAYOUT 1 +#define OMAP34XX_GPMC_NAND_SMNAND 1 + +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +/* JFFS2 */ +#define CONFIG_JFFS2_NAND +#define CONFIG_JFFS2_DEV "nand0" +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +/* ubi/ubifs related definitions */ +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS + +/* Environment information */ +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_BOOTFILE uImage + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "baudrate=115200\0"\ + "console=ttyS2,115200n8\0" \ + "autoload=no\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "onenand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc init; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi" + +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:512k(xloader)," \ + "1920k(u-boot)," \ + "256k(env)," \ + "4m(kernel)," \ + "-(fs)," + +#define CONFIG_AUTO_COMPLETE 1 +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "CM-T35 # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command */ + /* args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0 + 0x01000000) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + 0x08000000) + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ + /* address */ + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack */ +#endif + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* CS1 may not be populated on CM-T35 */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 meg */ + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/* PISMO support */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ + /* on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_SYS_FLASH_BASE boot_flash_base + +/* Monitor at start of flash */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +#define CONFIG_ENV_IS_IN_NAND 1 + +/* environment */ +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR boot_flash_env_addr + +#ifndef __ASSEMBLY__ +extern struct gpmc *gpmc_cfg; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +/* SMSC9220 Ethernet */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_32_BIT +#define CM_T35_SMC911X_BASE 0x2C000000 +#define SB_T35_SMC911X_BASE (CM_T35_SMC911X_BASE + (16 << 20)) +#endif /* (CONFIG_CMD_NET) */ + +#define CONFIG_OMAP3_GPIO_6 1 + +#endif /* __CONFIG_H */
-- v2 changes:
v3 changes:
v4 changes:
Tom,
Looks like all outstanding comments have been addressed. If its OK with you I'm going to do 2 things
1) merge my next with my master because the next branch has the OMAP3 DDR patches which created some issue before. 2) apply this patch to my master after the merge because it was made against the u-boot-ti/next branch.
Sandeep
Please add more description of the board.
-- v2 changes:
Wolfgang had made this comment on V2 that has not been addressed.
diff --git a/include/configs/cm-t35.h b/include/configs/cm-t35.h new file mode 100755
index 0000000..b881112 --- /dev/null +++ b/include/configs/cm-t35.h
These should not be needed in your board config file. Please move to a more appropriate header.
Please do not push this change.
Tom
Tom,
-- v2 changes:
As I've already answered Wolfgang ([1]), this is what _all_ other omap3 board do... Moving these requires rework of common omap3 code and updates to all omap3 boards.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71466
Tom
Mike Rapoport wrote:
Tom,
-- v2 changes:
Yes this change would apply to all the omap3 boards. But it looks like they are are all the same change.
The change per board, would be to delete these externs once the first code change is made.
Since this is a code movement change, it can be verified by running MAKEALL arm before and after the change.
Tom
Tom,
-- v2 changes:
The problem here, that just moving these externs to e.g. include/arm-arm/arch-omap3/mem.h is not enough. All omap3 boards set environment related defines to these externs, and therefore without them common/env_nand does not build. It seems that all the board_flash_* variables can be completely removed completely, but I really don't know what was the original author intention about those variables.
Tom
<snip>
I have posted a patch for the first part of this problem with gpmc. I am testing a change now to remove the board_flash_* variables. After that I think we will be ok.
Tom
Dear Mike Rapoport,
Quoting a (or several) bad examples does not make the thing better. Sorry that this has slipped through previous reviews, but now we caught it and want to see it cleaned up.
Dear Mike Rapoport,
Would it be possible to rename this into cm_t35? I would like to avoid characters in board names (and thus make targets etc. that are not legal in shell/Make/C variable names.
Dear Wolfgang,
Wolfgang Denk wrote:
Dear Mike Rapoport,
No problem.
-- v2 changes:
v3 changes:
v4 changes:
<snip>
- struct ctrl *ctrl_base = (struct ctrl *)OMAP34XX_CTRL_BASE;
- enable_gpmc_cs_config(gpmc_net_config, &gpmc_cfg->cs[5],
- enable_gpmc_cs_config(gpmc_net_config, &gpmc_cfg->cs[4],
- /* Enable off mode for NWE in PADCONF_GPMC_NWE register */
- writew(readw(&ctrl_base->gpmc_nwe) | 0x0E00, &ctrl_base->gpmc_nwe);
- /* Enable off mode for NOE in PADCONF_GPMC_NADV_ALE register */
- writew(readw(&ctrl_base->gpmc_noe) | 0x0E00, &ctrl_base->gpmc_noe);
- /* Enable off mode for ALE in PADCONF_GPMC_NADV_ALE register */
- writew(readw(&ctrl_base->gpmc_nadv_ale) | 0x0E00,
- /* Reset the ethernet controller via TPS65930 GPIO */
- /* Set GPIO1 of TPS65930 as output */
- twl4030_i2c_write_u8(TWL4030_CHIP_GPIO, 0x02,
- /* Send a pulse on the GPIO pin */
- udelay(1);
- udelay(1);
- Routine: board_init
- Description: Early hardware init.
- gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
- /* board id for Linux */
- gd->bd->bi_arch_number = MACH_TYPE_CM_T35;
- /* boot param addr */
- gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
- Routine: misc_init_r
- Description: Init ethernet (done here so udelay works)
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
- setup_net_chip();
Net setup should be dependent on i2c initialization. The setup_net_chip uses i2c read/write
- dieid_num_r();
Tom
Mike Rapoport
Paulraj, Sandeep
Tom
