[U-Boot] [PATCH v2] mx5: add iomux-mx51.h include
Allow usage of the imx-common/iomux-v3.h framework by including pad settings for the i.MX51. The content of the file is taken from Linux kernel at commit 5d23b39 plus the required changes to make it work in U-Boot.
The contained pad settings are the minimum required to make an Efika MX boot and get all the currently-implemented peripherals working in U-Boot.
It is recommended that this file not be just a dumping ground for pins but only contain the settings required for all the boards using it.
Changes for v2: * reference commit id from Linux kernel * additionally roll in the USB pads * removed GPIO_NUMBER define
Signed-off-by: Matt Sealey matt@genesi-usa.com --- arch/arm/include/asm/arch-mx5/iomux-mx51.h | 164 ++++++++++++++++++++++++++++ 1 file changed, 164 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx5/iomux-mx51.h
diff --git a/arch/arm/include/asm/arch-mx5/iomux-mx51.h b/arch/arm/include/asm/arch-mx5/iomux-mx51.h new file mode 100644 index 0000000..4f37295 --- /dev/null +++ b/arch/arm/include/asm/arch-mx5/iomux-mx51.h @@ -0,0 +1,164 @@ +/* + * Copyright (C) 2009-2010 Amit Kucheria amit.kucheria@canonical.com + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * Copyright (C) 2009-2012 Genesi USA, Inc. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +/* + * The vast majority of this file is taken from the Linux kernel at + * commit 5d23b39 + */ + +#ifndef __IOMUX_MX51_H__ +#define __IOMUX_MX51_H__ + +#include <asm/imx-common/iomux-v3.h> + +#define PAD_CTL_DVS (1 << 13) +#define PAD_CTL_INPUT_DDR (1 << 9) +#define PAD_CTL_HYS (1 << 8) + +#define PAD_CTL_PKE (1 << 7) +#define PAD_CTL_PUE (1 << 6 | PAD_CTL_PKE) +#define PAD_CTL_PUS_100K_DOWN (0 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_47K_UP (1 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_100K_UP (2 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_22K_UP (3 << 4 | PAD_CTL_PUE) + +#define PAD_CTL_ODE (1 << 3) + +#define PAD_CTL_DSE_LOW (0 << 1) +#define PAD_CTL_DSE_MED (1 << 1) +#define PAD_CTL_DSE_HIGH (2 << 1) +#define PAD_CTL_DSE_MAX (3 << 1) + +#define PAD_CTL_SRE_FAST (1 << 0) +#define PAD_CTL_SRE_SLOW (0 << 0) + +/* Pad control groupings */ +#define MX51_UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_DSE_HIGH | \ + PAD_CTL_HYS | PAD_CTL_SRE_FAST) +#define MX51_I2C_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_ODE | \ + PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_HYS) +#define MX51_ESDHC_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_ODE | \ + PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_HYS) +#define MX51_USBH1_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_SRE_FAST | \ + PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_HYS | PAD_CTL_PUE) +#define MX51_ECSPI_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_HYS | \ + PAD_CTL_DSE_HIGH | PAD_CTL_SRE_FAST) +#define MX51_SDHCI_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_DSE_HIGH | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_PUE | \ + PAD_CTL_SRE_FAST | PAD_CTL_DVS) +#define MX51_GPIO_PAD_CTRL (PAD_CTL_DSE_HIGH | PAD_CTL_PKE | PAD_CTL_SRE_FAST) + +#define __NA_ 0x000 + +/* + * The naming convention for the pad modes is MX51_PAD_<padname>__<padmode> + * If <padname> or <padmode> refers to a GPIO, it is named GPIO<unit>_<num> + * See also iomux-v3.h + */ + +/* PAD MUX ALT INPSE PATH PADCTRL */ +enum { + MX51_PAD_EIM_D16__USBH2_DATA0 = IOMUX_PAD(0x3f0, 0x05c, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D17__USBH2_DATA1 = IOMUX_PAD(0x3f4, 0x060, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D18__USBH2_DATA2 = IOMUX_PAD(0x3f8, 0x064, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D19__USBH2_DATA3 = IOMUX_PAD(0x3fc, 0x068, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D20__USBH2_DATA4 = IOMUX_PAD(0x400, 0x06c, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D21__USBH2_DATA5 = IOMUX_PAD(0x404, 0x070, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D22__USBH2_DATA6 = IOMUX_PAD(0x408, 0x074, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D23__USBH2_DATA7 = IOMUX_PAD(0x40c, 0x078, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_D27__GPIO2_9 = IOMUX_PAD(0x41c, 0x088, 1, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_EIM_A24__USBH2_CLK = IOMUX_PAD(0x450, 0x0bc, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_A25__USBH2_DIR = IOMUX_PAD(0x454, 0x0c0, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_A26__GPIO2_20 = IOMUX_PAD(0x458, 0x0c4, 1, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_EIM_A26__USBH2_STP = IOMUX_PAD(0x458, 0x0c4, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_A27__USBH2_NXT = IOMUX_PAD(0x45c, 0x0c8, 2, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_EIM_CS0__GPIO2_25 = IOMUX_PAD(0x474, 0x0e0, 1, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_EIM_CS2__SD1_CD = IOMUX_PAD(0x47c, 0x0e8, 1, __NA_, 0, MX51_ESDHC_PAD_CTRL), + MX51_PAD_EIM_CS3__GPIO2_28 = IOMUX_PAD(0x480, 0x0ec, 1, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_EIM_CS4__GPIO2_29 = IOMUX_PAD(0x484, 0x0f0, 1, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_NANDF_WE_B__PATA_DIOW = IOMUX_PAD(0x4e4, 0x108, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_RE_B__PATA_DIOR = IOMUX_PAD(0x4e8, 0x10c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_ALE__PATA_BUFFER_EN = IOMUX_PAD(0x4ec, 0x110, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CLE__PATA_RESET_B = IOMUX_PAD(0x4f0, 0x114, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_WP_B__PATA_DMACK = IOMUX_PAD(0x4f4, 0x118, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_RB0__PATA_DMARQ = IOMUX_PAD(0x4f8, 0x11c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_RB1__PATA_IORDY = IOMUX_PAD(0x4fc, 0x120, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_GPIO_NAND__PATA_INTRQ = IOMUX_PAD(0x514, 0x12c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CS2__PATA_CS_0 = IOMUX_PAD(0x520, 0x138, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CS3__PATA_CS_1 = IOMUX_PAD(0x524, 0x13c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CS4__PATA_DA_0 = IOMUX_PAD(0x528, 0x140, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CS5__PATA_DA_1 = IOMUX_PAD(0x52c, 0x144, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_CS6__PATA_DA_2 = IOMUX_PAD(0x530, 0x148, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D15__PATA_DATA15 = IOMUX_PAD(0x53c, 0x154, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D14__PATA_DATA14 = IOMUX_PAD(0x540, 0x158, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D13__PATA_DATA13 = IOMUX_PAD(0x544, 0x15c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D12__PATA_DATA12 = IOMUX_PAD(0x548, 0x160, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D11__PATA_DATA11 = IOMUX_PAD(0x54c, 0x164, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D10__PATA_DATA10 = IOMUX_PAD(0x550, 0x168, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D9__PATA_DATA9 = IOMUX_PAD(0x554, 0x16c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D8__PATA_DATA8 = IOMUX_PAD(0x558, 0x170, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D7__PATA_DATA7 = IOMUX_PAD(0x55c, 0x174, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D6__PATA_DATA6 = IOMUX_PAD(0x560, 0x178, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D5__PATA_DATA5 = IOMUX_PAD(0x564, 0x17c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D4__PATA_DATA4 = IOMUX_PAD(0x568, 0x180, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D3__PATA_DATA3 = IOMUX_PAD(0x56c, 0x184, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D2__PATA_DATA2 = IOMUX_PAD(0x570, 0x188, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D1__PATA_DATA1 = IOMUX_PAD(0x574, 0x18c, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_NANDF_D0__PATA_DATA0 = IOMUX_PAD(0x578, 0x190, 1, __NA_, 0, NO_PAD_CTRL), + MX51_PAD_CSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x600, 0x210, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL), + MX51_PAD_CSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x604, 0x214, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL), + MX51_PAD_CSPI1_SS0__GPIO4_24 = IOMUX_PAD(0x608, 0x218, 3, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_CSPI1_SS1__GPIO4_25 = IOMUX_PAD(0x60c, 0x21c, 3, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_CSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x614, 0x224, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL), + MX51_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x618, 0x228, 0, 0x9e4, 0, MX51_UART_PAD_CTRL), + MX51_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x61c, 0x22c, 0, __NA_, 0, MX51_UART_PAD_CTRL), + MX51_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x620, 0x230, 0, 0x9e0, 0, MX51_UART_PAD_CTRL), + MX51_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x624, 0x234, 0, __NA_, 0, MX51_UART_PAD_CTRL), + MX51_PAD_USBH1_CLK__USBH1_CLK = IOMUX_PAD(0x678, 0x278, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DIR__USBH1_DIR = IOMUX_PAD(0x67c, 0x27c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_STP__USBH1_STP = IOMUX_PAD(0x680, 0x280, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_STP__GPIO1_27 = IOMUX_PAD(0x680, 0x280, 2, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_USBH1_NXT__USBH1_NXT = IOMUX_PAD(0x684, 0x284, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA0__USBH1_DATA0 = IOMUX_PAD(0x688, 0x288, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA1__USBH1_DATA1 = IOMUX_PAD(0x68c, 0x28c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA2__USBH1_DATA2 = IOMUX_PAD(0x690, 0x290, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA3__USBH1_DATA3 = IOMUX_PAD(0x694, 0x294, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA4__USBH1_DATA4 = IOMUX_PAD(0x698, 0x298, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA5__USBH1_DATA5 = IOMUX_PAD(0x69c, 0x29c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA6__USBH1_DATA6 = IOMUX_PAD(0x6a0, 0x2a0, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_USBH1_DATA7__USBH1_DATA7 = IOMUX_PAD(0x6a4, 0x2a4, 0, __NA_, 0, MX51_USBH1_PAD_CTRL), + MX51_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x79c, 0x394, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x7a0, 0x398, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS), + MX51_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x7a4, 0x39c, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x7a8, 0x3a0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x7ac, 0x3a4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x7b0, 0x3a8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_GPIO1_0__SD1_CD = IOMUX_PAD(0x7b4, 0x3ac, 0, __NA_, 0, MX51_ESDHC_PAD_CTRL), + MX51_PAD_GPIO1_1__SD1_WP = IOMUX_PAD(0x7b8, 0x3b0, 0, __NA_, 0, MX51_ESDHC_PAD_CTRL), + MX51_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x7bc, 0x3b4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x7c0, 0x3b8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS), + MX51_PAD_SD2_DATA0__SD2_DATA0 = IOMUX_PAD(0x7c4, 0x3bc, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD2_DATA1__SD2_DATA1 = IOMUX_PAD(0x7c8, 0x3c0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD2_DATA2__SD2_DATA2 = IOMUX_PAD(0x7cc, 0x3c4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_SD2_DATA3__SD2_DATA3 = IOMUX_PAD(0x7d0, 0x3c8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), + MX51_PAD_GPIO1_3__GPIO1_3 = IOMUX_PAD(0x7d8, 0x3d0, 0, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_GPIO1_5__GPIO1_5 = IOMUX_PAD(0x808, 0x3dc, 0, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_GPIO1_6__GPIO1_6 = IOMUX_PAD(0x80c, 0x3e0, 0, __NA_, 0, MX51_GPIO_PAD_CTRL), + MX51_PAD_GPIO1_7__SD2_WP = IOMUX_PAD(0x810, 0x3e4, 6, __NA_, 0, MX51_ESDHC_PAD_CTRL), + MX51_PAD_GPIO1_8__SD2_CD = IOMUX_PAD(0x814, 0x3e8, 6, __NA_, 0, MX51_ESDHC_PAD_CTRL), +}; + +#endif /* __IOMUX_MX51_H__ */
Hi Matt,
Changes for v2:
- reference commit id from Linux kernel
- additionally roll in the USB pads
- removed GPIO_NUMBER define
- Copyright (C) 2009-2010 Amit Kucheria amit.kucheria@canonical.com
- Copyright (C) 2010 Freescale Semiconductor, Inc.
- Copyright (C) 2009-2012 Genesi USA, Inc.
- The code contained herein is licensed under the GNU General Public
- License. You may obtain a copy of the GNU General Public License
- Version 2 or later at the following locations:
- The vast majority of this file is taken from the Linux kernel at
- commit 5d23b39
PAD_CTL_HYS)
PAD_CTL_HYS)
- The naming convention for the pad modes is MX51_PAD_<padname>__<padmode>
- If <padname> or <padmode> refers to a GPIO, it is named GPIO<unit>_<num>
- See also iomux-v3.h
- MX51_PAD_EIM_D16__USBH2_DATA0 = IOMUX_PAD(0x3f0, 0x05c, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D17__USBH2_DATA1 = IOMUX_PAD(0x3f4, 0x060, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D18__USBH2_DATA2 = IOMUX_PAD(0x3f8, 0x064, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D19__USBH2_DATA3 = IOMUX_PAD(0x3fc, 0x068, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D20__USBH2_DATA4 = IOMUX_PAD(0x400, 0x06c, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D21__USBH2_DATA5 = IOMUX_PAD(0x404, 0x070, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D22__USBH2_DATA6 = IOMUX_PAD(0x408, 0x074, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D23__USBH2_DATA7 = IOMUX_PAD(0x40c, 0x078, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_D27__GPIO2_9 = IOMUX_PAD(0x41c, 0x088, 1, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_EIM_A24__USBH2_CLK = IOMUX_PAD(0x450, 0x0bc, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_A25__USBH2_DIR = IOMUX_PAD(0x454, 0x0c0, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_A26__GPIO2_20 = IOMUX_PAD(0x458, 0x0c4, 1, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_EIM_A26__USBH2_STP = IOMUX_PAD(0x458, 0x0c4, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_A27__USBH2_NXT = IOMUX_PAD(0x45c, 0x0c8, 2, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_EIM_CS0__GPIO2_25 = IOMUX_PAD(0x474, 0x0e0, 1, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_EIM_CS2__SD1_CD = IOMUX_PAD(0x47c, 0x0e8, 1, __NA_, 0, MX51_ESDHC_PAD_CTRL),
- MX51_PAD_EIM_CS3__GPIO2_28 = IOMUX_PAD(0x480, 0x0ec, 1, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_EIM_CS4__GPIO2_29 = IOMUX_PAD(0x484, 0x0f0, 1, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_NANDF_WE_B__PATA_DIOW = IOMUX_PAD(0x4e4, 0x108, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_RE_B__PATA_DIOR = IOMUX_PAD(0x4e8, 0x10c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_ALE__PATA_BUFFER_EN = IOMUX_PAD(0x4ec, 0x110, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CLE__PATA_RESET_B = IOMUX_PAD(0x4f0, 0x114, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_WP_B__PATA_DMACK = IOMUX_PAD(0x4f4, 0x118, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_RB0__PATA_DMARQ = IOMUX_PAD(0x4f8, 0x11c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_RB1__PATA_IORDY = IOMUX_PAD(0x4fc, 0x120, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_GPIO_NAND__PATA_INTRQ = IOMUX_PAD(0x514, 0x12c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CS2__PATA_CS_0 = IOMUX_PAD(0x520, 0x138, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CS3__PATA_CS_1 = IOMUX_PAD(0x524, 0x13c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CS4__PATA_DA_0 = IOMUX_PAD(0x528, 0x140, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CS5__PATA_DA_1 = IOMUX_PAD(0x52c, 0x144, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_CS6__PATA_DA_2 = IOMUX_PAD(0x530, 0x148, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D15__PATA_DATA15 = IOMUX_PAD(0x53c, 0x154, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D14__PATA_DATA14 = IOMUX_PAD(0x540, 0x158, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D13__PATA_DATA13 = IOMUX_PAD(0x544, 0x15c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D12__PATA_DATA12 = IOMUX_PAD(0x548, 0x160, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D11__PATA_DATA11 = IOMUX_PAD(0x54c, 0x164, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D10__PATA_DATA10 = IOMUX_PAD(0x550, 0x168, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D9__PATA_DATA9 = IOMUX_PAD(0x554, 0x16c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D8__PATA_DATA8 = IOMUX_PAD(0x558, 0x170, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D7__PATA_DATA7 = IOMUX_PAD(0x55c, 0x174, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D6__PATA_DATA6 = IOMUX_PAD(0x560, 0x178, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D5__PATA_DATA5 = IOMUX_PAD(0x564, 0x17c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D4__PATA_DATA4 = IOMUX_PAD(0x568, 0x180, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D3__PATA_DATA3 = IOMUX_PAD(0x56c, 0x184, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D2__PATA_DATA2 = IOMUX_PAD(0x570, 0x188, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D1__PATA_DATA1 = IOMUX_PAD(0x574, 0x18c, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_NANDF_D0__PATA_DATA0 = IOMUX_PAD(0x578, 0x190, 1, __NA_, 0, NO_PAD_CTRL),
- MX51_PAD_CSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x600, 0x210, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL),
- MX51_PAD_CSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x604, 0x214, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL),
- MX51_PAD_CSPI1_SS0__GPIO4_24 = IOMUX_PAD(0x608, 0x218, 3, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_CSPI1_SS1__GPIO4_25 = IOMUX_PAD(0x60c, 0x21c, 3, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_CSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x614, 0x224, 0, __NA_, 0, MX51_ECSPI_PAD_CTRL),
- MX51_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x618, 0x228, 0, 0x9e4, 0, MX51_UART_PAD_CTRL),
- MX51_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x61c, 0x22c, 0, __NA_, 0, MX51_UART_PAD_CTRL),
- MX51_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x620, 0x230, 0, 0x9e0, 0, MX51_UART_PAD_CTRL),
- MX51_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x624, 0x234, 0, __NA_, 0, MX51_UART_PAD_CTRL),
- MX51_PAD_USBH1_CLK__USBH1_CLK = IOMUX_PAD(0x678, 0x278, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DIR__USBH1_DIR = IOMUX_PAD(0x67c, 0x27c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_STP__USBH1_STP = IOMUX_PAD(0x680, 0x280, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_STP__GPIO1_27 = IOMUX_PAD(0x680, 0x280, 2, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_USBH1_NXT__USBH1_NXT = IOMUX_PAD(0x684, 0x284, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA0__USBH1_DATA0 = IOMUX_PAD(0x688, 0x288, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA1__USBH1_DATA1 = IOMUX_PAD(0x68c, 0x28c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA2__USBH1_DATA2 = IOMUX_PAD(0x690, 0x290, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA3__USBH1_DATA3 = IOMUX_PAD(0x694, 0x294, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA4__USBH1_DATA4 = IOMUX_PAD(0x698, 0x298, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA5__USBH1_DATA5 = IOMUX_PAD(0x69c, 0x29c, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA6__USBH1_DATA6 = IOMUX_PAD(0x6a0, 0x2a0, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_USBH1_DATA7__USBH1_DATA7 = IOMUX_PAD(0x6a4, 0x2a4, 0, __NA_, 0, MX51_USBH1_PAD_CTRL),
- MX51_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x79c, 0x394, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x7a0, 0x398, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS),
- MX51_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x7a4, 0x39c, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x7a8, 0x3a0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x7ac, 0x3a4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x7b0, 0x3a8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_GPIO1_0__SD1_CD = IOMUX_PAD(0x7b4, 0x3ac, 0, __NA_, 0, MX51_ESDHC_PAD_CTRL),
- MX51_PAD_GPIO1_1__SD1_WP = IOMUX_PAD(0x7b8, 0x3b0, 0, __NA_, 0, MX51_ESDHC_PAD_CTRL),
- MX51_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x7bc, 0x3b4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x7c0, 0x3b8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS),
- MX51_PAD_SD2_DATA0__SD2_DATA0 = IOMUX_PAD(0x7c4, 0x3bc, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD2_DATA1__SD2_DATA1 = IOMUX_PAD(0x7c8, 0x3c0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD2_DATA2__SD2_DATA2 = IOMUX_PAD(0x7cc, 0x3c4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_SD2_DATA3__SD2_DATA3 = IOMUX_PAD(0x7d0, 0x3c8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
- MX51_PAD_GPIO1_3__GPIO1_3 = IOMUX_PAD(0x7d8, 0x3d0, 0, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_GPIO1_5__GPIO1_5 = IOMUX_PAD(0x808, 0x3dc, 0, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_GPIO1_6__GPIO1_6 = IOMUX_PAD(0x80c, 0x3e0, 0, __NA_, 0, MX51_GPIO_PAD_CTRL),
- MX51_PAD_GPIO1_7__SD2_WP = IOMUX_PAD(0x810, 0x3e4, 6, __NA_, 0, MX51_ESDHC_PAD_CTRL),
- MX51_PAD_GPIO1_8__SD2_CD = IOMUX_PAD(0x814, 0x3e8, 6, __NA_, 0, MX51_ESDHC_PAD_CTRL),
IMHO it looks good.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Changes for v2:
Applied to u-boot-imx, thanks.
Matt Sealey
Stefano Babic
