[U-Boot] [PATCH v4] Add support for KMC KZM-ARM11-01 board
This patch adds support for KMC KZM-ARM11-01. It was rebased to "next" branch.
Regards, Tomohiro
Signed-off-by: Atsuo Igarashi atsuo_igarashi@tripeaks.co.jp Signed-off-by: Tomohiro Masubuchi tomohiro_masubuchi@tripeaks.co.jp ---- Add support for KMC KZM-ARM11-01 board.
MAKEALL | 1 + Makefile | 3 + board/kzm_arm11_01/Makefile | 49 +++++++ board/kzm_arm11_01/config.mk | 1 + board/kzm_arm11_01/kzm_arm11_01.c | 84 +++++++++++ board/kzm_arm11_01/lowlevel_init.S | 281 ++++++++++++++++++++++++++++++++++++ board/kzm_arm11_01/u-boot.lds | 72 +++++++++ include/configs/kzm_arm11_01.h | 184 +++++++++++++++++++++++ 8 files changed, 675 insertions(+), 0 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 9ccb9ac..22f65ed 100755 --- a/MAKEALL +++ b/MAKEALL @@ -522,6 +522,7 @@ LIST_ARM11=" \ apollon \ imx31_litekit \ imx31_phycore \ + kzm_arm11_01 \ mx31ads \ smdk6400 \ " diff --git a/Makefile b/Makefile index 017e4db..f334c57 100644 --- a/Makefile +++ b/Makefile @@ -2805,6 +2805,9 @@ imx31_litekit_config : unconfig imx31_phycore_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 imx31_phycore NULL mx31
+kzm_arm11_01_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm1136 kzm_arm11_01 NULL mx31 + mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
diff --git a/board/kzm_arm11_01/Makefile b/board/kzm_arm11_01/Makefile new file mode 100644 index 0000000..7e2f8ca --- /dev/null +++ b/board/kzm_arm11_01/Makefile @@ -0,0 +1,49 @@ +# +# Derived from mx31ads +# +# Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := kzm_arm11_01.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/kzm_arm11_01/config.mk b/board/kzm_arm11_01/config.mk new file mode 100644 index 0000000..d34dc02 --- /dev/null +++ b/board/kzm_arm11_01/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x87f00000 diff --git a/board/kzm_arm11_01/kzm_arm11_01.c b/board/kzm_arm11_01/kzm_arm11_01.c new file mode 100644 index 0000000..ed253d7 --- /dev/null +++ b/board/kzm_arm11_01/kzm_arm11_01.c @@ -0,0 +1,84 @@ +/* + * Derived from mx31ads + * + * Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mx31.h> +#include <asm/arch/mx31-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init (void) +{ + int i; + + /* CS0 & CS1: Nor Flash */ + /* + * CS0L, CS0A and CS0U values are from the RedBoot sources. + */ + __REG(CSCR_U(0)) = 0x00001801; + __REG(CSCR_L(0)) = 0x45450D01; + __REG(CSCR_A(0)) = 0x00450000; + + __REG(CSCR_U(1)) = 0x00001801; + __REG(CSCR_L(1)) = 0x45450D01; + __REG(CSCR_A(1)) = 0x00450000; + + /* setup pins for UART1 */ + mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX); + mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX); + mx31_gpio_mux(MUX_RTS1__UART1_RTS_B); + mx31_gpio_mux(MUX_CTS1__UART1_CTS_B); + + /* SPI2 */ + mx31_gpio_mux(MUX_CSPI2_SS2__CSPI2_SS2_B); + mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); + mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B); + mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI); + mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO); + mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B); + mx31_gpio_mux(MUX_CSPI2_SS1__CSPI2_SS1_B); + + /* start SPI2 clock */ + __REG(CCM_CGR2) = __REG(CCM_CGR2) | (3 << 4); + + gd->bd->bi_arch_number = MACH_TYPE_KZM_ARM11_01;/* board id for linux */ + gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */ + + return 0; +} + +int checkboard (void) +{ + printf("Board: KZM-ARM11-01\n"); + return 0; +} diff --git a/board/kzm_arm11_01/lowlevel_init.S b/board/kzm_arm11_01/lowlevel_init.S new file mode 100644 index 0000000..f2032a5 --- /dev/null +++ b/board/kzm_arm11_01/lowlevel_init.S @@ -0,0 +1,281 @@ +/* + * Derived from mx31ads + * + * Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/mx31-regs.h> + +.macro REG reg, val + ldr r2, =\reg + ldr r3, =\val + str r3, [r2] +.endm + +.macro REG8 reg, val + ldr r2, =\reg + ldr r3, =\val + strb r3, [r2] +.endm + +.macro DELAY loops + ldr r2, =\loops +1: + subs r2, r2, #1 + nop + bcs 1b +.endm + +/* RedBoot: AIPS setup - Only setup MPROTx registers. + * The PACR default values are good.*/ +.macro init_aips + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + ldr r0, =0x43F00000 + ldr r1, =0x77777777 + str r1, [r0, #0x00] + str r1, [r0, #0x04] + ldr r0, =0x53F00000 + str r1, [r0, #0x00] + str r1, [r0, #0x04] + + /* + * Clear the on and off peripheral modules Supervisor Protect bit + * for SDMA to access them. Did not change the AIPS control registers + * (offset 0x20) access type + */ + ldr r0, =0x43F00000 + ldr r1, =0x0 + str r1, [r0, #0x40] + str r1, [r0, #0x44] + str r1, [r0, #0x48] + str r1, [r0, #0x4C] + ldr r1, [r0, #0x50] + and r1, r1, #0x00FFFFFF + str r1, [r0, #0x50] + + ldr r0, =0x53F00000 + ldr r1, =0x0 + str r1, [r0, #0x40] + str r1, [r0, #0x44] + str r1, [r0, #0x48] + str r1, [r0, #0x4C] + ldr r1, [r0, #0x50] + and r1, r1, #0x00FFFFFF + str r1, [r0, #0x50] +.endm /* init_aips */ + +/* RedBoot: MAX (Multi-Layer AHB Crossbar Switch) setup */ +.macro init_max + ldr r0, =0x43F04000 + /* MPR - priority is M4 > M2 > M3 > M5 > M0 > M1 */ + ldr r1, =0x00302154 + str r1, [r0, #0x000] /* for S0 */ + str r1, [r0, #0x100] /* for S1 */ + str r1, [r0, #0x200] /* for S2 */ + str r1, [r0, #0x300] /* for S3 */ + str r1, [r0, #0x400] /* for S4 */ + /* SGPCR - always park on last master */ + ldr r1, =0x10 + str r1, [r0, #0x010] /* for S0 */ + str r1, [r0, #0x110] /* for S1 */ + str r1, [r0, #0x210] /* for S2 */ + str r1, [r0, #0x310] /* for S3 */ + str r1, [r0, #0x410] /* for S4 */ + /* MGPCR - restore default values */ + ldr r1, =0x0 + str r1, [r0, #0x800] /* for M0 */ + str r1, [r0, #0x900] /* for M1 */ + str r1, [r0, #0xA00] /* for M2 */ + str r1, [r0, #0xB00] /* for M3 */ + str r1, [r0, #0xC00] /* for M4 */ + str r1, [r0, #0xD00] /* for M5 */ +.endm /* init_max */ + +/* RedBoot: M3IF setup */ +.macro init_m3if + /* Configure M3IF registers */ + ldr r1, =0xB8003000 + /* + * M3IF Control Register (M3IFCTL) + * MRRP[0] = L2CC0 not on priority list (0 << 0) = 0x00000000 + * MRRP[1] = L2CC1 not on priority list (0 << 0) = 0x00000000 + * MRRP[2] = MBX not on priority list (0 << 0) = 0x00000000 + * MRRP[3] = MAX1 not on priority list (0 << 0) = 0x00000000 + * MRRP[4] = SDMA not on priority list (0 << 0) = 0x00000000 + * MRRP[5] = MPEG4 not on priority list (0 << 0) = 0x00000000 + * MRRP[6] = IPU1 on priority list (1 << 6) = 0x00000040 + * MRRP[7] = IPU2 not on priority list (0 << 0) = 0x00000000 + * ------------ + * 0x00000040 + */ + ldr r0, =0x00000040 + str r0, [r1] /* M3IF control reg */ +.endm /* init_m3if */ + +/* RedBoot: To support 133MHz DDR */ +.macro init_drive_strength + /* + * Disable maximum drive strength SDRAM/DDR lines by clearing DSE1 bits + * in SW_PAD_CTL registers + */ + + /* SDCLK */ + ldr r1, =0x43FAC200 + ldr r0, [r1, #0x6C] + bic r0, r0, #(1 << 12) + str r0, [r1, #0x6C] + + /* CAS */ + ldr r0, [r1, #0x70] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x70] + + /* RAS */ + ldr r0, [r1, #0x74] + bic r0, r0, #(1 << 2) + str r0, [r1, #0x74] + + /* CS2 (CSD0) */ + ldr r0, [r1, #0x7C] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x7C] + + /* DQM3 */ + ldr r0, [r1, #0x84] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x84] + + /* DQM2, DQM1, DQM0, SD31-SD0, A25-A0, MA10 (0x288..0x2DC) */ + ldr r2, =22 /* (0x2E0 - 0x288) / 4 = 22 */ +pad_loop: + ldr r0, [r1, #0x88] + bic r0, r0, #(1 << 22) + bic r0, r0, #(1 << 12) + bic r0, r0, #(1 << 2) + str r0, [r1, #0x88] + add r1, r1, #4 + subs r2, r2, #0x1 + bne pad_loop +.endm /* init_drive_strength */ + +/* CPLD on CS4 setup */ +.macro init_cs4 + ldr r0, =WEIM_BASE + ldr r1, =0x00001003 + str r1, [r0, #0x40] + ldr r1, =0x74741B01 + str r1, [r0, #0x44] + ldr r1, =0x00740000 + str r1, [r0, #0x48] +.endm /* init_cs4 */ + +/* LAN on CS5 setup */ +.macro init_cs5 + ldr r0, =WEIM_BASE + ldr r1, =0x00001403 + str r1, [r0, #0x50] + ldr r1, =0x44340D01 + str r1, [r0, #0x54] + ldr r1, =0x00340000 + str r1, [r0, #0x58] +.endm /* init_cs5 */ + +.globl lowlevel_init +lowlevel_init: + + /* Redboot initializes very early AIPS, what for? + * Then it also initializes Multi-Layer AHB Crossbar Switch, + * M3IF */ + /* Also setup the Peripheral Port Remap register inside the core */ + ldr r0, =0x40000015 /* start from AIPS 2GB region */ + mcr p15, 0, r0, c15, c2, 4 + + init_aips + + init_max + + init_m3if + + init_drive_strength + + init_cs4 + + /* Image Processing Unit: */ + /* Too early to switch display on? */ + REG IPU_CONF, IPU_CONF_DI_EN /* Switch on Display Interface */ + /* Clock Control Module: */ + REG CCM_CCMR, 0x074B0BF5 /* Use CKIH, MCU PLL off */ + + DELAY 0x40000 + + REG CCM_CCMR, 0x074B0BF5 | CCMR_MPE /* MCU PLL on */ + REG CCM_CCMR, (0x074B0BF5 | CCMR_MPE) & ~CCMR_MDS /* Switch to MCU PLL */ + + /* 532-133-66.5 */ + ldr r0, =CCM_BASE + ldr r1, =0xFF872660 + /* PDR0 */ + str r1, [r0, #0x4] + ldreq r1, MPCTL_PARAM_532 + ldrne r1, MPCTL_PARAM_532_27 + /* MPCTL */ + str r1, [r0, #0x10] + + ldreq r1, UPCTL_PARAM_240 + ldrne r1, UPCTL_PARAM_240_27 + /* UPCTL */ + str r1, [r0, #0x14] + /* default CLKO to 1/8 of the ARM core */ + mov r1, #0x000002C0 + add r1, r1, #0x00000006 + /* COSR */ + str r1, [r0, #0x1c] + + /* Default: 1, 4, 12, 1 */ + REG CCM_SPCTL, PLL_PD(1) | PLL_MFD(4) | PLL_MFI(12) | PLL_MFN(1) + + /* B8xxxxxx - NAND, 8xxxxxxx - CSD0 RAM */ + REG 0xB8001010, 0x00000004 + REG 0xB8001004, 0x0079d72a + REG 0xB8001000, 0x92100000 + REG 0x80000f00, 0x12344321 + REG 0xB8001000, 0xa2100000 + REG 0x80000000, 0x12344321 + REG 0x80000000, 0x12344321 + REG 0xB8001000, 0xb2100000 + REG8 0x81000020, 0x00 + REG8 0x80000033, 0xda + REG 0xB8001000, 0x82226080 + REG 0x80000000, 0xDEADBEEF + REG 0xB8001010, 0x0000000c + + init_cs5 + + mov pc, lr + +MPCTL_PARAM_532: + .word (((1-1) << 26) + ((52-1) << 16) + (10 << 10) + (12 << 0)) +MPCTL_PARAM_532_27: + .word (((1-1) << 26) + ((15-1) << 16) + (9 << 10) + (13 << 0)) +UPCTL_PARAM_240: + .word (((2-1) << 26) + ((13-1) << 16) + (9 << 10) + (3 << 0)) +UPCTL_PARAM_240_27: + .word (((2-1) << 26) + ((9 -1) << 16) + (8 << 10) + (8 << 0)) diff --git a/board/kzm_arm11_01/u-boot.lds b/board/kzm_arm11_01/u-boot.lds new file mode 100644 index 0000000..aa87fcb --- /dev/null +++ b/board/kzm_arm11_01/u-boot.lds @@ -0,0 +1,72 @@ +/* + * Derived from mx31ads + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/arm1136/start.o (.text) + board/kzm_arm11_01/libkzm_arm11_01.a (.text) + lib_arm/libarm.a (.text) + net/libnet.a (.text) + drivers/mtd/libmtd.a (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o(.text) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/configs/kzm_arm11_01.h b/include/configs/kzm_arm11_01.h new file mode 100644 index 0000000..72f7b5a --- /dev/null +++ b/include/configs/kzm_arm11_01.h @@ -0,0 +1,184 @@ +/* + * Derived from mx31ads + * + * Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de + * + * Configuration settings for the KMC KZM-ARM11-01 board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/mx31-regs.h> + + /* High Level Configuration Options */ +#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ +#define CONFIG_MX31 1 /* in a mx31 */ +#define CONFIG_MX31_HCLK_FREQ 26000000 /* RedBoot says 26MHz */ +#define CONFIG_MX31_CLK32 32768 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +/* + * Hardware drivers + */ + +#define CONFIG_MX31_UART 1 +#define CONFIG_SYS_MX31_UART1 1 + +#define CONFIG_HARD_SPI 1 +#define CONFIG_MXC_SPI 1 +#define CONFIG_DEFAULT_SPI_BUS 1 +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_SPI +#define CONFIG_CMD_FLASH + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "uboot_addr=0xa0000000\0" \ + "uboot=kzm-arm11/u-boot.bin\0" \ + "kernel=kzm-arm11/uImage\0" \ + "nfsroot=${serverip}:${rootpath}\0" \ + "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_nfs; " \ + "tftpboot ${loadaddr} ${kernel}; bootm\0" \ + "prg_uboot=tftpboot ${loadaddr} ${uboot}; " \ + "protect off ${uboot_addr} 0xa007ffff; " \ + "erase ${uboot_addr} 0xa007ffff; " \ + "cp.b ${loadaddr} ${uboot_addr} ${filesize}; " \ + "setenv filesize; saveenv\0" + +#define CONFIG_DRIVER_SMC911X 1 +#define CONFIG_DRIVER_SMC911X_BASE 0xb6020300 +#define CONFIG_DRIVER_SMC911X_32_BIT 1 + +/* + * The KZM-ARM11-01 board seems to have a hardware "peculiarity" confirmed under + * U-Boot, RedBoot and Linux: the ethernet Rx signal is reaching the SMC9118 + * controller inverted. The controller is capable of detecting and correcting + * this, but it needs a few hundred milliseconds wait for that after the + * initialization. Which means, at startup, you will not receive answers + * during the first few hundred milliseconds, unless there have been some + * broadcasts on the network, or your board is on a hub. Reducing the ARP + * timeout from default 5 seconds to 200ms we speed up the initial TFTP + * transfer, should the user wish one, significantly. + */ +#define CONFIG_ARP_TIMEOUT 200UL + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING 1 + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE +#define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_SYS_FLASH_BASE CS0_BASE +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at beginning of flash */ +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256KiB */ + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +/* S29GL512N NOR flash has 512 128KiB big sectors. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_ENV_SECT_SIZE) + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +#define CONFIG_SYS_FLASH_CFI 1 /* Flash memory is CFI compliant */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* Use drivers/cfi_flash.c */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* Use buffered writes (~10x faster) */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use hardware sector protection */ + +/* + * JFFS2 partitions + */ +#undef CONFIG_JFFS2_CMDLINE +#define CONFIG_JFFS2_DEV "nor0" + +#endif /* __CONFIG_H */
Dear Tomohiro Masubuchi,
Long time ago Jean-Christophe asked you to rebase your code, but we never saw a reply. If you are still interested in pushing this code upstream, please repost an updated patch. Thanks.
Tomohiro Masubuchi
