[PATCH] ddr: marvell: a38x: llow boards to specify CK_DELAY parameter
For some layouts it is necessary to adjust the CK_DELAY parameter to successfully complete DDR training. Add the ability to specify the CK_DELAY in the mv_ddr_topology_map.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
board/alliedtelesis/x530/x530.c | 6 +++++- drivers/ddr/marvell/a38x/ddr3_init.c | 5 +++++ drivers/ddr/marvell/a38x/ddr_topology_def.h | 3 +++ drivers/ddr/marvell/a38x/mv_ddr_topology.c | 10 ++++++++++ drivers/ddr/marvell/a38x/mv_ddr_topology.h | 1 + 5 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/board/alliedtelesis/x530/x530.c b/board/alliedtelesis/x530/x530.c index e0fa8067c1c5..04b053dc20e4 100644 --- a/board/alliedtelesis/x530/x530.c +++ b/board/alliedtelesis/x530/x530.c @@ -66,7 +66,11 @@ static struct mv_ddr_topology_map board_topology_map = { BUS_MASK_32BIT_ECC, /* subphys mask */ MV_DDR_CFG_DEFAULT, /* ddr configuration data source */ { {0} }, /* raw spd data */ - {0} /* timing parameters */ + {0}, /* timing parameters */ + { {0} }, /* electrical configuration */ + {0}, /* electrical parameters */ + 0, /* Clock enable mask */ + 160 /* Clock delay */ };
struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) diff --git a/drivers/ddr/marvell/a38x/ddr3_init.c b/drivers/ddr/marvell/a38x/ddr3_init.c index 22c8f9ca54e5..a971cc155a01 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.c +++ b/drivers/ddr/marvell/a38x/ddr3_init.c @@ -106,8 +106,10 @@ static int mv_ddr_training_params_set(u8 dev_num) struct tune_train_params params; int status; u32 cs_num; + int ck_delay;
cs_num = mv_ddr_cs_num_get(); + ck_delay = mv_ddr_ck_delay_get();
/* NOTE: do not remove any field initilization */ params.ck_delay = TUNE_TRAINING_PARAMS_CK_DELAY; @@ -131,6 +133,9 @@ static int mv_ddr_training_params_set(u8 dev_num) params.g_odt_config = TUNE_TRAINING_PARAMS_ODT_CONFIG_2CS; }
+ if (ck_delay > 0) + params.ck_delay = ck_delay; + status = ddr3_tip_tune_training_params(dev_num, ¶ms); if (MV_OK != status) { printf("%s Training Sequence - FAILED\n", ddr_type); diff --git a/drivers/ddr/marvell/a38x/ddr_topology_def.h b/drivers/ddr/marvell/a38x/ddr_topology_def.h index 950f296ff984..34196b166287 100644 --- a/drivers/ddr/marvell/a38x/ddr_topology_def.h +++ b/drivers/ddr/marvell/a38x/ddr_topology_def.h @@ -127,6 +127,9 @@ struct mv_ddr_topology_map {
/* Clock enable mask */ u32 clk_enable; + + /* Clock delay */ + int ck_delay; };
enum mv_ddr_iface_mode { diff --git a/drivers/ddr/marvell/a38x/mv_ddr_topology.c b/drivers/ddr/marvell/a38x/mv_ddr_topology.c index ef3b658a7899..09840b1e70f1 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_topology.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_topology.c @@ -229,6 +229,16 @@ int mv_ddr_is_ecc_ena(void) return 0; }
+int mv_ddr_ck_delay_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + + if (tm->ck_delay) + return tm->ck_delay; + + return -1; +} + /* translate topology map definition to real memory size in bits */ static unsigned int mem_size[] = { ADDR_SIZE_512MB, diff --git a/drivers/ddr/marvell/a38x/mv_ddr_topology.h b/drivers/ddr/marvell/a38x/mv_ddr_topology.h index 766f25db5733..4fca47689f11 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_topology.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_topology.h @@ -319,6 +319,7 @@ unsigned short mv_ddr_bus_bit_mask_get(void); unsigned int mv_ddr_if_bus_width_get(void); unsigned int mv_ddr_cs_num_get(void); int mv_ddr_is_ecc_ena(void); +int mv_ddr_ck_delay_get(void); unsigned long long mv_ddr_mem_sz_per_cs_get(void); unsigned long long mv_ddr_mem_sz_get(void); unsigned int mv_ddr_rtt_nom_get(void);
Chris Packham
