[U-Boot] Regarding source code of u-boot
Sir, I have download the source of u-boot,but there is one problem when I installing cross complier there are many dependency of assembly code I try to remove it but not working correctly so,sir please send some command or source code.
Thanks & Regards Kirti D Kumbhar.
Did you tried the latest? [1] are you creating cross compiler manually or took it from sourcery bench? Once you have a proper cross compiler in your host these are the steps for building
export PATH=/to/cross_compler_patch/../bin:$PATH export CROSS_COMPILE=arm-none-linux-gnueabi-
$ make *_defconfig; make
[1] http://git.denx.de/?p=u-boot.git;a=summary
thanks!
Jagan Teki
kirti kumbhar
