[PATCH 03/16] mips: mtmips: add predefined i-cache/d-cache size and linesize
Both mt7620 and mt7628 has the same cache configuration. There is no need to use CONFIG_SYS_CACHE_SIZE_AUTO to probe it at runtime.
Add them into Kconfig to reduce some code size.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/mach-mtmips/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index c8dcf19c0d..8e10719b27 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -7,6 +7,18 @@ config SYS_MALLOC_F_LEN config SYS_SOC default "mt7628" if SOC_MT7628
+config SYS_DCACHE_SIZE + default 32768 + +config SYS_DCACHE_LINE_SIZE + default 32 + +config SYS_ICACHE_SIZE + default 65536 + +config SYS_ICACHE_LINE_SIZE + default 32 + choice prompt "MediaTek MIPS SoC select"
Thanks, Stefan
Stefan Roese
Weijie Gao
