[U-Boot] [PATCH v3 0/5] subject: efi_loader: add HII database protocol
HII database protocol is the last missing (major?) piece of code so that we can run unmodified EDKII's shell and UEFI SCT on EFI-enabled u-boot.
The original code was initially written by Leif and Rob a year ago[1], and now I'm reworking it. The implementation has not been much enhanced from the original, but I tried to give it clearer implementation to be able to add more functionality easily later on. I also addressed the comments by Alex[2] and added a self test on request of Heinrich.
HII configuration routing protocol and access protocol have only a skeleton and should be implemented when we need to have *drivers* that require configuration mechanism.
# Please note that a bunch of warnings are generated by checkpatch.pl, # but there are also good reasons for not fixing them.
Changes in v3 (Jan 21, 2019) * drope v2's patch#1("lib: add u16_strcpy/strdup functions") as it has been merged * define a "key" value as u32 in efi_key_descriptor * simplify "if" condition in export_package_lists() * access "packed" structures of HII packages through get_unaligned_xx() * implement GetSecondaryLanguages() * compare a language in case-insensitive way in GetString() & GetLanguages() * cosmetic changes (including variable/struct member names)
Changes in v2 (Nov 16, 2018) * add some descriptions to newly added functions * rename EFI_HII_PACKAGE_[TYPE|LEN]_* to __EFI_HII_PACKAGE_[TYPE|LEN]_* as they are of internal use only * cast a return value (of efi_status_t) to "unsigned int" for printing
[1] https://lists.denx.de/pipermail/u-boot/2017-October/308999.html [2] https://lists.denx.de/pipermail/u-boot/2017-October/309116.html
AKASHI Takahiro (4): efi: hii: add guid package support efi: hii: add keyboard layout package support efi: hii: add HII config routing/access protocols efi_selftest: add HII database protocols test
Leif Lindholm (1): efi_loader: Initial HII database protocols
include/efi_api.h | 421 ++++++++- include/efi_loader.h | 8 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_boottime.c | 18 + lib/efi_loader/efi_hii.c | 1095 ++++++++++++++++++++++ lib/efi_loader/efi_hii_config.c | 146 +++ lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_hii.c | 1046 +++++++++++++++++++++ lib/efi_selftest/efi_selftest_hii_data.c | 453 +++++++++ 9 files changed, 3188 insertions(+), 1 deletion(-) create mode 100644 lib/efi_loader/efi_hii.c create mode 100644 lib/efi_loader/efi_hii_config.c create mode 100644 lib/efi_selftest/efi_selftest_hii.c create mode 100644 lib/efi_selftest/efi_selftest_hii_data.c
This patch provides enough implementation of the following protocols to run EDKII's Shell.efi and UEFI SCT:
* EfiHiiDatabaseProtocol * EfiHiiStringProtocol
Not implemented are: * ExportPackageLists() * RegisterPackageNotify()/UnregisterPackageNotify() * SetKeyboardLayout() (i.e. *current* keyboard layout)
HII database protocol in this patch series can handle only: * GUID package * string package * keyboard layout package (The other packages, except Device path package, will be necessary for interactive and graphical UI.)
Cc: Leif Lindholm leif.lindholm@linaro.org Signed-off-by: Rob Clark robdclark@gmail.com Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_api.h | 245 ++++++++- include/efi_loader.h | 4 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_boottime.c | 12 + lib/efi_loader/efi_hii.c | 922 ++++++++++++++++++++++++++++++++++ 5 files changed, 1183 insertions(+), 1 deletion(-) create mode 100644 lib/efi_loader/efi_hii.c
diff --git a/include/efi_api.h b/include/efi_api.h index aef77b6319de..67c3753de0b1 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -17,6 +17,7 @@ #define _EFI_API_H
#include <efi.h> +#include <charset.h>
#ifdef CONFIG_EFI_LOADER #include <asm/setjmp.h> @@ -34,7 +35,10 @@ enum efi_timer_delay {
#define efi_intn_t ssize_t #define efi_uintn_t size_t -typedef uint16_t *efi_string_t; +typedef void *efi_hii_handle_t; +typedef u16 *efi_string_t; +typedef u16 efi_string_id_t; +typedef u32 efi_hii_font_style_t;
#define EVT_TIMER 0x80000000 #define EVT_RUNTIME 0x40000000 @@ -697,6 +701,245 @@ struct efi_device_path_utilities_protocol { uint16_t node_length); };
+/* + * Human Interface Infrastructure (HII) + */ +struct efi_hii_package_list_header { + efi_guid_t package_list_guid; + u32 package_length; +} __packed; + +/** + * struct efi_hii_package_header - EFI HII package header + * + * @fields: 'fields' replaces the bit-fields defined in the EFI + * specification to to avoid possible compiler incompatibilities:: + * + * u32 length:24; + * u32 type:8; + */ +struct efi_hii_package_header { + u32 fields; +} __packed; + +#define __EFI_HII_PACKAGE_LEN_SHIFT 0 +#define __EFI_HII_PACKAGE_TYPE_SHIFT 24 +#define __EFI_HII_PACKAGE_LEN_MASK 0xffffff +#define __EFI_HII_PACKAGE_TYPE_MASK 0xff + +#define EFI_HII_PACKAGE_TYPE_ALL 0x00 +#define EFI_HII_PACKAGE_TYPE_GUID 0x01 +#define EFI_HII_PACKAGE_FORMS 0x02 +#define EFI_HII_PACKAGE_STRINGS 0x04 +#define EFI_HII_PACKAGE_FONTS 0x05 +#define EFI_HII_PACKAGE_IMAGES 0x06 +#define EFI_HII_PACKAGE_SIMPLE_FONTS 0x07 +#define EFI_HII_PACKAGE_DEVICE_PATH 0x08 +#define EFI_HII_PACKAGE_KEYBOARD_LAYOUT 0x09 +#define EFI_HII_PACKAGE_ANIMATIONS 0x0A +#define EFI_HII_PACKAGE_END 0xDF +#define EFI_HII_PACKAGE_TYPE_SYSTEM_BEGIN 0xE0 +#define EFI_HII_PACKAGE_TYPE_SYSTEM_END 0xFF + +/* + * HII string package + */ +struct efi_hii_strings_package { + struct efi_hii_package_header header; + u32 header_size; + u32 string_info_offset; + u16 language_window[16]; + efi_string_id_t language_name; + u8 language[]; +} __packed; + +struct efi_hii_string_block { + u8 block_type; + /* u8 block_body[]; */ +} __packed; + +#define EFI_HII_SIBT_END 0x00 +#define EFI_HII_SIBT_STRING_SCSU 0x10 +#define EFI_HII_SIBT_STRING_SCSU_FONT 0x11 +#define EFI_HII_SIBT_STRINGS_SCSU 0x12 +#define EFI_HII_SIBT_STRINGS_SCSU_FONT 0x13 +#define EFI_HII_SIBT_STRING_UCS2 0x14 +#define EFI_HII_SIBT_STRING_UCS2_FONT 0x15 +#define EFI_HII_SIBT_STRINGS_UCS2 0x16 +#define EFI_HII_SIBT_STRINGS_UCS2_FONT 0x17 +#define EFI_HII_SIBT_DUPLICATE 0x20 +#define EFI_HII_SIBT_SKIP2 0x21 +#define EFI_HII_SIBT_SKIP1 0x22 +#define EFI_HII_SIBT_EXT1 0x30 +#define EFI_HII_SIBT_EXT2 0x31 +#define EFI_HII_SIBT_EXT4 0x32 +#define EFI_HII_SIBT_FONT 0x40 + +struct efi_hii_sibt_string_ucs2_block { + struct efi_hii_string_block header; + u16 string_text[]; +} __packed; + +static inline struct efi_hii_string_block * +efi_hii_sibt_string_ucs2_block_next(struct efi_hii_sibt_string_ucs2_block *blk) +{ + return ((void *)blk) + sizeof(*blk) + + (u16_strlen(blk->string_text) + 1) * 2; +} + +/* + * HII keyboard package + */ +typedef enum { + EFI_KEY_LCTRL, EFI_KEY_A0, EFI_KEY_LALT, EFI_KEY_SPACE_BAR, + EFI_KEY_A2, EFI_KEY_A3, EFI_KEY_A4, EFI_KEY_RCTRL, EFI_KEY_LEFT_ARROW, + EFI_KEY_DOWN_ARROW, EFI_KEY_RIGHT_ARROW, EFI_KEY_ZERO, + EFI_KEY_PERIOD, EFI_KEY_ENTER, EFI_KEY_LSHIFT, EFI_KEY_B0, + EFI_KEY_B1, EFI_KEY_B2, EFI_KEY_B3, EFI_KEY_B4, EFI_KEY_B5, EFI_KEY_B6, + EFI_KEY_B7, EFI_KEY_B8, EFI_KEY_B9, EFI_KEY_B10, EFI_KEY_RSHIFT, + EFI_KEY_UP_ARROW, EFI_KEY_ONE, EFI_KEY_TWO, EFI_KEY_THREE, + EFI_KEY_CAPS_LOCK, EFI_KEY_C1, EFI_KEY_C2, EFI_KEY_C3, EFI_KEY_C4, + EFI_KEY_C5, EFI_KEY_C6, EFI_KEY_C7, EFI_KEY_C8, EFI_KEY_C9, + EFI_KEY_C10, EFI_KEY_C11, EFI_KEY_C12, EFI_KEY_FOUR, EFI_KEY_FIVE, + EFI_KEY_SIX, EFI_KEY_PLUS, EFI_KEY_TAB, EFI_KEY_D1, EFI_KEY_D2, + EFI_KEY_D3, EFI_KEY_D4, EFI_KEY_D5, EFI_KEY_D6, EFI_KEY_D7, EFI_KEY_D8, + EFI_KEY_D9, EFI_KEY_D10, EFI_KEY_D11, EFI_KEY_D12, EFI_KEY_D13, + EFI_KEY_DEL, EFI_KEY_END, EFI_KEY_PG_DN, EFI_KEY_SEVEN, EFI_KEY_EIGHT, + EFI_KEY_NINE, EFI_KEY_E0, EFI_KEY_E1, EFI_KEY_E2, EFI_KEY_E3, + EFI_KEY_E4, EFI_KEY_E5, EFI_KEY_E6, EFI_KEY_E7, EFI_KEY_E8, EFI_KEY_E9, + EFI_KEY_E10, EFI_KEY_E11, EFI_KEY_E12, EFI_KEY_BACK_SPACE, + EFI_KEY_INS, EFI_KEY_HOME, EFI_KEY_PG_UP, EFI_KEY_NLCK, EFI_KEY_SLASH, + EFI_KEY_ASTERISK, EFI_KEY_MINUS, EFI_KEY_ESC, EFI_KEY_F1, EFI_KEY_F2, + EFI_KEY_F3, EFI_KEY_F4, EFI_KEY_F5, EFI_KEY_F6, EFI_KEY_F7, EFI_KEY_F8, + EFI_KEY_F9, EFI_KEY_F10, EFI_KEY_F11, EFI_KEY_F12, EFI_KEY_PRINT, + EFI_KEY_SLCK, EFI_KEY_PAUSE, +} efi_key; + +struct efi_key_descriptor { + u32 key; + u16 unicode; + u16 shifted_unicode; + u16 alt_gr_unicode; + u16 shifted_alt_gr_unicode; + u16 modifier; + u16 affected_attribute; +} __packed; + +struct efi_hii_keyboard_layout { + u16 layout_length; + efi_guid_t guid; + u32 layout_descriptor_string_offset; + u8 descriptor_count; + struct efi_key_descriptor descriptors[]; +} __packed; + +/* + * HII protocols + */ +#define EFI_HII_STRING_PROTOCOL_GUID \ + EFI_GUID(0x0fd96974, 0x23aa, 0x4cdc, \ + 0xb9, 0xcb, 0x98, 0xd1, 0x77, 0x50, 0x32, 0x2a) + +struct efi_font_info { + efi_hii_font_style_t font_style; + u16 font_size; + u16 font_name[1]; +}; + +struct efi_hii_string_protocol { + efi_status_t(EFIAPI *new_string)( + const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + efi_string_id_t *string_id, + const u8 *language, + const u16 *language_name, + const efi_string_t string, + const struct efi_font_info *string_font_info); + efi_status_t(EFIAPI *get_string)( + const struct efi_hii_string_protocol *this, + const u8 *language, + efi_hii_handle_t package_list, + efi_string_id_t string_id, + efi_string_t string, + efi_uintn_t *string_size, + struct efi_font_info **string_font_info); + efi_status_t(EFIAPI *set_string)( + const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + efi_string_id_t string_id, + const u8 *language, + const efi_string_t string, + const struct efi_font_info *string_font_info); + efi_status_t(EFIAPI *get_languages)( + const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + u8 *languages, + efi_uintn_t *languages_size); + efi_status_t(EFIAPI *get_secondary_languages)( + const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + const u8 *primary_language, + u8 *secondary_languages, + efi_uintn_t *secondary_languages_size); +}; + +#define EFI_HII_DATABASE_PROTOCOL_GUID \ + EFI_GUID(0xef9fc172, 0xa1b2, 0x4693, \ + 0xb3, 0x27, 0x6d, 0x32, 0xfc, 0x41, 0x60, 0x42) + +struct efi_hii_database_protocol { + efi_status_t(EFIAPI *new_package_list)( + const struct efi_hii_database_protocol *this, + const struct efi_hii_package_list_header *package_list, + const efi_handle_t driver_handle, + efi_hii_handle_t *handle); + efi_status_t(EFIAPI *remove_package_list)( + const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle); + efi_status_t(EFIAPI *update_package_list)( + const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle, + const struct efi_hii_package_list_header *package_list); + efi_status_t(EFIAPI *list_package_lists)( + const struct efi_hii_database_protocol *this, + u8 package_type, + const efi_guid_t *package_guid, + efi_uintn_t *handle_buffer_length, + efi_hii_handle_t *handle); + efi_status_t(EFIAPI *export_package_lists)( + const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle, + efi_uintn_t *buffer_size, + struct efi_hii_package_list_header *buffer); + efi_status_t(EFIAPI *register_package_notify)( + const struct efi_hii_database_protocol *this, + u8 package_type, + const efi_guid_t *package_guid, + const void *package_notify_fn, + efi_uintn_t notify_type, + efi_handle_t *notify_handle); + efi_status_t(EFIAPI *unregister_package_notify)( + const struct efi_hii_database_protocol *this, + efi_handle_t notification_handle + ); + efi_status_t(EFIAPI *find_keyboard_layouts)( + const struct efi_hii_database_protocol *this, + u16 *key_guid_buffer_length, + efi_guid_t *key_guid_buffer); + efi_status_t(EFIAPI *get_keyboard_layout)( + const struct efi_hii_database_protocol *this, + efi_guid_t *key_guid, + u16 *keyboard_layout_length, + struct efi_hii_keyboard_layout *keyboard_layout); + efi_status_t(EFIAPI *set_keyboard_layout)( + const struct efi_hii_database_protocol *this, + efi_guid_t *key_guid); + efi_status_t(EFIAPI *get_package_list_handle)( + const struct efi_hii_database_protocol *this, + efi_hii_handle_t package_list_handle, + efi_handle_t *driver_handle); +}; + #define EFI_GOP_GUID \ EFI_GUID(0x9042a9de, 0x23dc, 0x4a38, \ 0x96, 0xfb, 0x7a, 0xde, 0xd0, 0x80, 0x51, 0x6a) diff --git a/include/efi_loader.h b/include/efi_loader.h index 6323686f9d37..18384a8caf5c 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -106,6 +106,8 @@ extern const struct efi_device_path_utilities_protocol /* Implementation of the EFI_UNICODE_COLLATION_PROTOCOL */ extern const struct efi_unicode_collation_protocol efi_unicode_collation_protocol; +extern const struct efi_hii_database_protocol efi_hii_database; +extern const struct efi_hii_string_protocol efi_hii_string;
uint16_t *efi_dp_str(struct efi_device_path *dp);
@@ -139,6 +141,8 @@ extern const efi_guid_t efi_file_system_info_guid; extern const efi_guid_t efi_guid_device_path_utilities_protocol; /* GUID of the Unicode collation protocol */ extern const efi_guid_t efi_guid_unicode_collation_protocol; +extern const efi_guid_t efi_guid_hii_database_protocol; +extern const efi_guid_t efi_guid_hii_string_protocol;
extern unsigned int __efi_runtime_start, __efi_runtime_stop; extern unsigned int __efi_runtime_rel_start, __efi_runtime_rel_stop; diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index a7bba58d4126..dc8bc1461cb9 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -24,6 +24,7 @@ obj-y += efi_device_path.o obj-y += efi_device_path_to_text.o obj-y += efi_device_path_utilities.o obj-y += efi_file.o +obj-y += efi_hii.o obj-y += efi_image_loader.o obj-y += efi_memory.o obj-y += efi_root_node.o diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index cc9efbb0cbfd..ba2e1f652afe 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1558,6 +1558,18 @@ efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, if (ret != EFI_SUCCESS) goto failure;
+ ret = efi_add_protocol(&obj->header, + &efi_guid_hii_string_protocol, + (void *)&efi_hii_string); + if (ret != EFI_SUCCESS) + goto failure; + + ret = efi_add_protocol(&obj->header, + &efi_guid_hii_database_protocol, + (void *)&efi_hii_database); + if (ret != EFI_SUCCESS) + goto failure; + return ret; failure: printf("ERROR: Failure to install protocols for loaded image\n"); diff --git a/lib/efi_loader/efi_hii.c b/lib/efi_loader/efi_hii.c new file mode 100644 index 000000000000..d6dba5719cdb --- /dev/null +++ b/lib/efi_loader/efi_hii.c @@ -0,0 +1,922 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * EFI Human Interface Infrastructure ... database and packages + * + * Copyright (c) 2017 Leif Lindholm + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#include <common.h> +#include <efi_loader.h> +#include <malloc.h> +#include <asm/unaligned.h> + +const efi_guid_t efi_guid_hii_database_protocol + = EFI_HII_DATABASE_PROTOCOL_GUID; +const efi_guid_t efi_guid_hii_string_protocol = EFI_HII_STRING_PROTOCOL_GUID; + +static LIST_HEAD(efi_package_lists); + +struct efi_hii_packagelist { + struct list_head link; + // TODO should there be an associated efi_object? + efi_handle_t driver_handle; + u32 max_string_id; + struct list_head string_tables; /* list of efi_string_table */ + + /* we could also track fonts, images, etc */ +}; + +static int efi_hii_packagelist_exists(efi_hii_handle_t package_list) +{ + struct efi_hii_packagelist *hii; + int found = 0; + + list_for_each_entry(hii, &efi_package_lists, link) { + if (hii == package_list) { + found = 1; + break; + } + } + + return found; +} + +static u32 efi_hii_package_type(struct efi_hii_package_header *header) +{ + u32 fields; + + fields = get_unaligned_le32(&header->fields); + + return (fields >> __EFI_HII_PACKAGE_TYPE_SHIFT) + & __EFI_HII_PACKAGE_TYPE_MASK; +} + +static u32 efi_hii_package_len(struct efi_hii_package_header *header) +{ + u32 fields; + + fields = get_unaligned_le32(&header->fields); + + return (fields >> __EFI_HII_PACKAGE_LEN_SHIFT) + & __EFI_HII_PACKAGE_LEN_MASK; +} + +struct efi_string_info { + efi_string_t string; + /* we could also track font info, etc */ +}; + +struct efi_string_table { + struct list_head link; + efi_string_id_t language_name; + char *language; + u32 nstrings; + /* + * NOTE: + * string id starts at 1 so value is stbl->strings[id-1], + * and strings[] is a array of stbl->nstrings elements + */ + struct efi_string_info *strings; +}; + +static void free_strings_table(struct efi_string_table *stbl) +{ + int i; + + for (i = 0; i < stbl->nstrings; i++) + free(stbl->strings[i].string); + free(stbl->strings); + free(stbl->language); + free(stbl); +} + +static void remove_strings_package(struct efi_hii_packagelist *hii) +{ + while (!list_empty(&hii->string_tables)) { + struct efi_string_table *stbl; + + stbl = list_first_entry(&hii->string_tables, + struct efi_string_table, link); + list_del(&stbl->link); + free_strings_table(stbl); + } +} + +static efi_status_t +add_strings_package(struct efi_hii_packagelist *hii, + struct efi_hii_strings_package *strings_package) +{ + struct efi_hii_string_block *block; + void *end; + u32 nstrings = 0, idx = 0; + struct efi_string_table *stbl = NULL; + efi_status_t ret; + + debug("header_size: %08x\n", + get_unaligned_le32(&strings_package->header_size)); + debug("string_info_offset: %08x\n", + get_unaligned_le32(&strings_package->string_info_offset)); + debug("language_name: %u\n", + get_unaligned_le16(&strings_package->language_name)); + debug("language: %s\n", strings_package->language); + + /* count # of string entries: */ + end = ((void *)strings_package) + + efi_hii_package_len(&strings_package->header); + block = ((void *)strings_package) + + get_unaligned_le32(&strings_package->string_info_offset); + + while ((void *)block < end) { + switch (block->block_type) { + case EFI_HII_SIBT_STRING_UCS2: { + struct efi_hii_sibt_string_ucs2_block *ucs2; + + ucs2 = (void *)block; + nstrings++; + block = efi_hii_sibt_string_ucs2_block_next(ucs2); + break; + } + case EFI_HII_SIBT_END: + block = end; + break; + default: + debug("unknown HII string block type: %02x\n", + block->block_type); + return EFI_INVALID_PARAMETER; + } + } + + stbl = calloc(sizeof(*stbl), 1); + if (!stbl) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + stbl->strings = calloc(sizeof(stbl->strings[0]), nstrings); + if (!stbl->strings) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + stbl->language_name = + get_unaligned_le16(&strings_package->language_name); + stbl->language = strdup((char *)strings_package->language); + if (!stbl->language) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + stbl->nstrings = nstrings; + + /* and now parse string entries and populate efi_string_table */ + block = ((void *)strings_package) + + get_unaligned_le32(&strings_package->string_info_offset); + + while ((void *)block < end) { + switch (block->block_type) { + case EFI_HII_SIBT_STRING_UCS2: { + struct efi_hii_sibt_string_ucs2_block *ucs2; + + ucs2 = (void *)block; + debug("%4u: "%ls"\n", idx + 1, ucs2->string_text); + stbl->strings[idx].string = + u16_strdup(ucs2->string_text); + if (!stbl->strings[idx].string) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + idx++; + /* FIXME: accessing u16 * here */ + block = efi_hii_sibt_string_ucs2_block_next(ucs2); + break; + } + case EFI_HII_SIBT_END: + goto out; + default: + debug("unknown HII string block type: %02x\n", + block->block_type); + ret = EFI_INVALID_PARAMETER; + goto error; + } + } + +out: + list_add(&stbl->link, &hii->string_tables); + if (hii->max_string_id < nstrings) + hii->max_string_id = nstrings; + + return EFI_SUCCESS; + +error: + if (stbl) { + free(stbl->language); + if (idx > 0) + while (--idx >= 0) + free(stbl->strings[idx].string); + free(stbl->strings); + } + free(stbl); + + return ret; +} + +static struct efi_hii_packagelist *new_packagelist(void) +{ + struct efi_hii_packagelist *hii; + + hii = malloc(sizeof(*hii)); + hii->max_string_id = 0; + INIT_LIST_HEAD(&hii->string_tables); + + return hii; +} + +static void free_packagelist(struct efi_hii_packagelist *hii) +{ + remove_strings_package(hii); + + list_del(&hii->link); + free(hii); +} + +static efi_status_t +add_packages(struct efi_hii_packagelist *hii, + const struct efi_hii_package_list_header *package_list) +{ + struct efi_hii_package_header *package; + void *end; + efi_status_t ret = EFI_SUCCESS; + + end = ((void *)package_list) + + get_unaligned_le32(&package_list->package_length); + + debug("package_list: %pUl (%u)\n", &package_list->package_list_guid, + get_unaligned_le32(&package_list->package_length)); + + package = ((void *)package_list) + sizeof(*package_list); + while ((void *)package < end) { + debug("package=%p, package type=%x, length=%u\n", package, + efi_hii_package_type(package), + efi_hii_package_len(package)); + + switch (efi_hii_package_type(package)) { + case EFI_HII_PACKAGE_TYPE_GUID: + printf("\tGuid package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_FORMS: + printf("\tForm package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_STRINGS: + ret = add_strings_package(hii, + (struct efi_hii_strings_package *)package); + break; + case EFI_HII_PACKAGE_FONTS: + printf("\tFont package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_IMAGES: + printf("\tImage package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_SIMPLE_FONTS: + printf("\tSimple font package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_DEVICE_PATH: + printf("\tDevice path package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: + printf("\tKeyboard layout package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_ANIMATIONS: + printf("\tAnimation package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_END: + goto out; + case EFI_HII_PACKAGE_TYPE_SYSTEM_BEGIN: + case EFI_HII_PACKAGE_TYPE_SYSTEM_END: + default: + break; + } + + if (ret != EFI_SUCCESS) + return ret; + + package = (void *)package + efi_hii_package_len(package); + } +out: + // TODO in theory there is some notifications that should be sent.. + return EFI_SUCCESS; +} + +/* + * EFI_HII_DATABASE_PROTOCOL + */ + +static efi_status_t EFIAPI +new_package_list(const struct efi_hii_database_protocol *this, + const struct efi_hii_package_list_header *package_list, + const efi_handle_t driver_handle, + efi_hii_handle_t *handle) +{ + struct efi_hii_packagelist *hii; + efi_status_t ret; + + EFI_ENTRY("%p, %p, %p, %p", this, package_list, driver_handle, handle); + + if (!package_list || !handle) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + hii = new_packagelist(); + if (!hii) + return EFI_EXIT(EFI_OUT_OF_RESOURCES); + + ret = add_packages(hii, package_list); + if (ret != EFI_SUCCESS) { + free_packagelist(hii); + return EFI_EXIT(ret); + } + + hii->driver_handle = driver_handle; + list_add_tail(&hii->link, &efi_package_lists); + *handle = hii; + + return EFI_EXIT(EFI_SUCCESS); +} + +static efi_status_t EFIAPI +remove_package_list(const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle) +{ + struct efi_hii_packagelist *hii = handle; + + EFI_ENTRY("%p, %p", this, handle); + + if (!handle || !efi_hii_packagelist_exists(handle)) + return EFI_EXIT(EFI_NOT_FOUND); + + free_packagelist(hii); + + return EFI_EXIT(EFI_SUCCESS); +} + +static efi_status_t EFIAPI +update_package_list(const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle, + const struct efi_hii_package_list_header *package_list) +{ + struct efi_hii_packagelist *hii = handle; + struct efi_hii_package_header *package; + void *end; + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p, %p, %p", this, handle, package_list); + + if (!handle || !efi_hii_packagelist_exists(handle)) + return EFI_EXIT(EFI_NOT_FOUND); + + if (!package_list) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + debug("package_list: %pUl (%u)\n", &package_list->package_list_guid, + get_unaligned_le32(&package_list->package_length)); + + package = ((void *)package_list) + sizeof(*package_list); + end = ((void *)package_list) + + get_unaligned_le32(&package_list->package_length); + + while ((void *)package < end) { + debug("package=%p, package type=%x, length=%u\n", package, + efi_hii_package_type(package), + efi_hii_package_len(package)); + + switch (efi_hii_package_type(package)) { + case EFI_HII_PACKAGE_TYPE_GUID: + printf("\tGuid package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_FORMS: + printf("\tForm package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_STRINGS: + remove_strings_package(hii); + break; + case EFI_HII_PACKAGE_FONTS: + printf("\tFont package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_IMAGES: + printf("\tImage package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_SIMPLE_FONTS: + printf("\tSimple font package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_DEVICE_PATH: + printf("\tDevice path package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: + printf("\tKeyboard layout package not supported\n"); + break; + case EFI_HII_PACKAGE_ANIMATIONS: + printf("\tAnimation package not supported\n"); + ret = EFI_INVALID_PARAMETER; + break; + case EFI_HII_PACKAGE_END: + goto out; + case EFI_HII_PACKAGE_TYPE_SYSTEM_BEGIN: + case EFI_HII_PACKAGE_TYPE_SYSTEM_END: + default: + break; + } + + /* TODO: already removed some packages */ + if (ret != EFI_SUCCESS) + return EFI_EXIT(ret); + + package = ((void *)package) + + efi_hii_package_len(package); + } +out: + ret = add_packages(hii, package_list); + + return EFI_EXIT(ret); +} + +static efi_status_t EFIAPI +list_package_lists(const struct efi_hii_database_protocol *this, + u8 package_type, + const efi_guid_t *package_guid, + efi_uintn_t *handle_buffer_length, + efi_hii_handle_t *handle) +{ + struct efi_hii_packagelist *hii = + (struct efi_hii_packagelist *)handle; + int package_cnt, package_max; + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p, %u, %pUl, %p, %p", this, package_type, package_guid, + handle_buffer_length, handle); + + if (!handle_buffer_length || + (*handle_buffer_length && !handle)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + if ((package_type != EFI_HII_PACKAGE_TYPE_GUID && package_guid) || + (package_type == EFI_HII_PACKAGE_TYPE_GUID && !package_guid)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + debug("package type=%x, guid=%pUl, length=%lu\n", (int)package_type, + package_guid, *handle_buffer_length); + + package_cnt = 0; + package_max = *handle_buffer_length / sizeof(*handle); + list_for_each_entry(hii, &efi_package_lists, link) { + switch (package_type) { + case EFI_HII_PACKAGE_TYPE_ALL: + break; + case EFI_HII_PACKAGE_TYPE_GUID: + printf("\tGuid package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_FORMS: + printf("\tForm package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_STRINGS: + if (!list_empty(&hii->string_tables)) + break; + continue; + case EFI_HII_PACKAGE_FONTS: + printf("\tFont package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_IMAGES: + printf("\tImage package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_SIMPLE_FONTS: + printf("\tSimple font package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_DEVICE_PATH: + printf("\tDevice path package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: + printf("\tKeyboard layout package not supported\n"); + continue; + case EFI_HII_PACKAGE_ANIMATIONS: + printf("\tAnimation package not supported\n"); + ret = EFI_INVALID_PARAMETER; + continue; + case EFI_HII_PACKAGE_END: + case EFI_HII_PACKAGE_TYPE_SYSTEM_BEGIN: + case EFI_HII_PACKAGE_TYPE_SYSTEM_END: + default: + continue; + } + + package_cnt++; + if (package_cnt <= package_max) + *handle++ = hii; + else + ret = EFI_BUFFER_TOO_SMALL; + } + *handle_buffer_length = package_cnt * sizeof(*handle); + + return EFI_EXIT(ret); +} + +static efi_status_t EFIAPI +export_package_lists(const struct efi_hii_database_protocol *this, + efi_hii_handle_t handle, + efi_uintn_t *buffer_size, + struct efi_hii_package_list_header *buffer) +{ + EFI_ENTRY("%p, %p, %p, %p", this, handle, buffer_size, buffer); + + if (!buffer_size || !buffer) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +register_package_notify(const struct efi_hii_database_protocol *this, + u8 package_type, + const efi_guid_t *package_guid, + const void *package_notify_fn, + efi_uintn_t notify_type, + efi_handle_t *notify_handle) +{ + EFI_ENTRY("%p, %u, %pUl, %p, %zu, %p", this, package_type, + package_guid, package_notify_fn, notify_type, + notify_handle); + + if (!notify_handle) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + if ((package_type != EFI_HII_PACKAGE_TYPE_GUID && package_guid) || + (package_type == EFI_HII_PACKAGE_TYPE_GUID && !package_guid)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +unregister_package_notify(const struct efi_hii_database_protocol *this, + efi_handle_t notification_handle) +{ + EFI_ENTRY("%p, %p", this, notification_handle); + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +find_keyboard_layouts(const struct efi_hii_database_protocol *this, + u16 *key_guid_buffer_length, + efi_guid_t *key_guid_buffer) +{ + EFI_ENTRY("%p, %p, %p", this, key_guid_buffer_length, key_guid_buffer); + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +get_keyboard_layout(const struct efi_hii_database_protocol *this, + efi_guid_t *key_guid, + u16 *keyboard_layout_length, + struct efi_hii_keyboard_layout *keyboard_layout) +{ + EFI_ENTRY("%p, %pUl, %p, %p", this, key_guid, keyboard_layout_length, + keyboard_layout); + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +set_keyboard_layout(const struct efi_hii_database_protocol *this, + efi_guid_t *key_guid) +{ + EFI_ENTRY("%p, %pUl", this, key_guid); + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +get_package_list_handle(const struct efi_hii_database_protocol *this, + efi_hii_handle_t package_list_handle, + efi_handle_t *driver_handle) +{ + struct efi_hii_packagelist *hii; + + EFI_ENTRY("%p, %p, %p", this, package_list_handle, driver_handle); + + if (!driver_handle) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + list_for_each_entry(hii, &efi_package_lists, link) { + if (hii == package_list_handle) { + *driver_handle = hii->driver_handle; + return EFI_EXIT(EFI_SUCCESS); + } + } + + return EFI_EXIT(EFI_NOT_FOUND); +} + +const struct efi_hii_database_protocol efi_hii_database = { + .new_package_list = new_package_list, + .remove_package_list = remove_package_list, + .update_package_list = update_package_list, + .list_package_lists = list_package_lists, + .export_package_lists = export_package_lists, + .register_package_notify = register_package_notify, + .unregister_package_notify = unregister_package_notify, + .find_keyboard_layouts = find_keyboard_layouts, + .get_keyboard_layout = get_keyboard_layout, + .set_keyboard_layout = set_keyboard_layout, + .get_package_list_handle = get_package_list_handle +}; + +/* + * EFI_HII_STRING_PROTOCOL + */ + +static bool language_match(char *language, char *languages) +{ + size_t n; + + n = strlen(language); + /* match primary language? */ + if (!strncasecmp(language, languages, n) && + (languages[n] == ';' || languages[n] == '\0')) + return true; + + return false; +} + +static efi_status_t EFIAPI +new_string(const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + efi_string_id_t *string_id, + const u8 *language, + const u16 *language_name, + const efi_string_t string, + const struct efi_font_info *string_font_info) +{ + struct efi_hii_packagelist *hii = package_list; + struct efi_string_table *stbl; + + EFI_ENTRY("%p, %p, %p, "%s", %p, "%ls", %p", this, package_list, + string_id, language, language_name, string, + string_font_info); + + if (!package_list || !efi_hii_packagelist_exists(package_list)) + return EFI_EXIT(EFI_NOT_FOUND); + + if (!string_id || !language || !string) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + list_for_each_entry(stbl, &hii->string_tables, link) { + if (language_match((char *)language, stbl->language)) { + efi_string_id_t new_id; + void *buf; + efi_string_t str; + + new_id = ++hii->max_string_id; + if (stbl->nstrings < new_id) { + buf = realloc(stbl->strings, + sizeof(stbl->strings[0]) + * new_id); + if (!buf) + return EFI_EXIT(EFI_OUT_OF_RESOURCES); + + memset(&stbl->strings[stbl->nstrings], 0, + (new_id - stbl->nstrings) + * sizeof(stbl->strings[0])); + stbl->strings = buf; + stbl->nstrings = new_id; + } + + str = u16_strdup(string); + if (!str) + return EFI_EXIT(EFI_OUT_OF_RESOURCES); + + stbl->strings[new_id - 1].string = str; + *string_id = new_id; + + return EFI_EXIT(EFI_SUCCESS); + } + } + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +get_string(const struct efi_hii_string_protocol *this, + const u8 *language, + efi_hii_handle_t package_list, + efi_string_id_t string_id, + efi_string_t string, + efi_uintn_t *string_size, + struct efi_font_info **string_font_info) +{ + struct efi_hii_packagelist *hii = package_list; + struct efi_string_table *stbl; + + EFI_ENTRY("%p, "%s", %p, %u, %p, %p, %p", this, language, + package_list, string_id, string, string_size, + string_font_info); + + if (!package_list || !efi_hii_packagelist_exists(package_list)) + return EFI_EXIT(EFI_NOT_FOUND); + + list_for_each_entry(stbl, &hii->string_tables, link) { + if (language_match((char *)language, stbl->language)) { + efi_string_t str; + size_t len; + + if (stbl->nstrings < string_id) + return EFI_EXIT(EFI_NOT_FOUND); + + str = stbl->strings[string_id - 1].string; + if (str) { + len = (u16_strlen(str) + 1) * sizeof(u16); + if (*string_size < len) { + *string_size = len; + + return EFI_EXIT(EFI_BUFFER_TOO_SMALL); + } + memcpy(string, str, len); + *string_size = len; + } else { + return EFI_EXIT(EFI_NOT_FOUND); + } + + return EFI_EXIT(EFI_SUCCESS); + } + } + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +set_string(const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + efi_string_id_t string_id, + const u8 *language, + const efi_string_t string, + const struct efi_font_info *string_font_info) +{ + struct efi_hii_packagelist *hii = package_list; + struct efi_string_table *stbl; + + EFI_ENTRY("%p, %p, %u, "%s", "%ls", %p", this, package_list, + string_id, language, string, string_font_info); + + if (!package_list || !efi_hii_packagelist_exists(package_list)) + return EFI_EXIT(EFI_NOT_FOUND); + + if (string_id > hii->max_string_id) + return EFI_EXIT(EFI_NOT_FOUND); + + if (!string || !language) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + list_for_each_entry(stbl, &hii->string_tables, link) { + if (language_match((char *)language, stbl->language)) { + efi_string_t str; + + if (hii->max_string_id < string_id) + return EFI_EXIT(EFI_NOT_FOUND); + + if (stbl->nstrings < string_id) { + void *buf; + + buf = realloc(stbl->strings, + string_id + * sizeof(stbl->strings[0])); + if (!buf) + return EFI_EXIT(EFI_OUT_OF_RESOURCES); + + memset(&stbl->strings[string_id - 1], 0, + (string_id - stbl->nstrings) + * sizeof(stbl->strings[0])); + stbl->strings = buf; + } + + str = u16_strdup(string); + if (!str) + return EFI_EXIT(EFI_OUT_OF_RESOURCES); + + free(stbl->strings[string_id - 1].string); + stbl->strings[string_id - 1].string = str; + + return EFI_EXIT(EFI_SUCCESS); + } + } + + return EFI_EXIT(EFI_NOT_FOUND); +} + +static efi_status_t EFIAPI +get_languages(const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + u8 *languages, + efi_uintn_t *languages_size) +{ + struct efi_hii_packagelist *hii = package_list; + struct efi_string_table *stbl; + size_t len = 0; + char *p; + + EFI_ENTRY("%p, %p, %p, %p", this, package_list, languages, + languages_size); + + if (!package_list || !efi_hii_packagelist_exists(package_list)) + return EFI_EXIT(EFI_NOT_FOUND); + + if (!languages_size || + (*languages_size && !languages)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* figure out required size: */ + list_for_each_entry(stbl, &hii->string_tables, link) { + len += strlen((char *)stbl->language) + 1; + } + + if (*languages_size < len) { + *languages_size = len; + + return EFI_EXIT(EFI_BUFFER_TOO_SMALL); + } + + p = (char *)languages; + list_for_each_entry(stbl, &hii->string_tables, link) { + if (p != (char *)languages) + *p++ = ';'; + strcpy(p, stbl->language); + p += strlen((char *)stbl->language); + } + *p = '\0'; + + debug("languages: %s\n", languages); + + return EFI_EXIT(EFI_SUCCESS); +} + +static efi_status_t EFIAPI +get_secondary_languages(const struct efi_hii_string_protocol *this, + efi_hii_handle_t package_list, + const u8 *primary_language, + u8 *secondary_languages, + efi_uintn_t *secondary_languages_size) +{ + struct efi_hii_packagelist *hii = package_list; + struct efi_string_table *stbl; + bool found = false; + + EFI_ENTRY("%p, %p, "%s", %p, %p", this, package_list, + primary_language, secondary_languages, + secondary_languages_size); + + if (!package_list || !efi_hii_packagelist_exists(package_list)) + return EFI_EXIT(EFI_NOT_FOUND); + + if (!secondary_languages_size || + (*secondary_languages_size && !secondary_languages)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + list_for_each_entry(stbl, &hii->string_tables, link) { + if (language_match((char *)primary_language, stbl->language)) { + found = true; + break; + } + } + if (!found) + return EFI_EXIT(EFI_INVALID_LANGUAGE); + + /* + * TODO: What is secondary language? + * *secondary_languages = '\0'; + * *secondary_languages_size = 0; + */ + + return EFI_EXIT(EFI_NOT_FOUND); +} + +const struct efi_hii_string_protocol efi_hii_string = { + .new_string = new_string, + .get_string = get_string, + .set_string = set_string, + .get_languages = get_languages, + .get_secondary_languages = get_secondary_languages +};
Allow for handling GUID package in HII database protocol.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_api.h | 9 ++++++++ lib/efi_loader/efi_hii.c | 48 +++++++++++++++++++++++++++++++++++----- 2 files changed, 51 insertions(+), 6 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 67c3753de0b1..b2e77832a756 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -741,6 +741,15 @@ struct efi_hii_package_header { #define EFI_HII_PACKAGE_TYPE_SYSTEM_BEGIN 0xE0 #define EFI_HII_PACKAGE_TYPE_SYSTEM_END 0xFF
+/* + * HII GUID package + */ +struct efi_hii_guid_package { + struct efi_hii_package_header header; + efi_guid_t guid; + char data[]; +} __packed; + /* * HII string package */ diff --git a/lib/efi_loader/efi_hii.c b/lib/efi_loader/efi_hii.c index d6dba5719cdb..d7cd0c4f0fc6 100644 --- a/lib/efi_loader/efi_hii.c +++ b/lib/efi_loader/efi_hii.c @@ -23,6 +23,7 @@ struct efi_hii_packagelist { efi_handle_t driver_handle; u32 max_string_id; struct list_head string_tables; /* list of efi_string_table */ + struct list_head guid_list;
/* we could also track fonts, images, etc */ }; @@ -80,6 +81,11 @@ struct efi_string_table { struct efi_string_info *strings; };
+struct efi_guid_data { + struct list_head link; + struct efi_hii_guid_package package; +}; + static void free_strings_table(struct efi_string_table *stbl) { int i; @@ -218,6 +224,35 @@ error: return ret; }
+static void remove_guid_package(struct efi_hii_packagelist *hii) +{ + struct efi_guid_data *data; + + while (!list_empty(&hii->guid_list)) { + data = list_first_entry(&hii->guid_list, + struct efi_guid_data, link); + list_del(&data->link); + free(data); + } +} + +static efi_status_t +add_guid_package(struct efi_hii_packagelist *hii, + struct efi_hii_guid_package *package) +{ + struct efi_guid_data *data; + + data = calloc(sizeof(*data), 1); + if (!data) + return EFI_OUT_OF_RESOURCES; + + /* TODO: we don't know any about data field */ + memcpy(&data->package, package, sizeof(*package)); + list_add_tail(&data->link, &hii->guid_list); + + return EFI_SUCCESS; +} + static struct efi_hii_packagelist *new_packagelist(void) { struct efi_hii_packagelist *hii; @@ -225,6 +260,7 @@ static struct efi_hii_packagelist *new_packagelist(void) hii = malloc(sizeof(*hii)); hii->max_string_id = 0; INIT_LIST_HEAD(&hii->string_tables); + INIT_LIST_HEAD(&hii->guid_list);
return hii; } @@ -232,6 +268,7 @@ static struct efi_hii_packagelist *new_packagelist(void) static void free_packagelist(struct efi_hii_packagelist *hii) { remove_strings_package(hii); + remove_guid_package(hii);
list_del(&hii->link); free(hii); @@ -259,8 +296,8 @@ add_packages(struct efi_hii_packagelist *hii,
switch (efi_hii_package_type(package)) { case EFI_HII_PACKAGE_TYPE_GUID: - printf("\tGuid package not supported\n"); - ret = EFI_INVALID_PARAMETER; + ret = add_guid_package(hii, + (struct efi_hii_guid_package *)package); break; case EFI_HII_PACKAGE_FORMS: printf("\tForm package not supported\n"); @@ -395,8 +432,7 @@ update_package_list(const struct efi_hii_database_protocol *this,
switch (efi_hii_package_type(package)) { case EFI_HII_PACKAGE_TYPE_GUID: - printf("\tGuid package not supported\n"); - ret = EFI_INVALID_PARAMETER; + remove_guid_package(hii); break; case EFI_HII_PACKAGE_FORMS: printf("\tForm package not supported\n"); @@ -482,8 +518,8 @@ list_package_lists(const struct efi_hii_database_protocol *this, case EFI_HII_PACKAGE_TYPE_ALL: break; case EFI_HII_PACKAGE_TYPE_GUID: - printf("\tGuid package not supported\n"); - ret = EFI_INVALID_PARAMETER; + if (!list_empty(&hii->guid_list)) + break; continue; case EFI_HII_PACKAGE_FORMS: printf("\tForm package not supported\n");
Allow for handling keyboard layout package in HII database protocol.
A package can be added or deleted in HII database protocol, but we don't set 'current' keyboard layout as there is no driver that requests a keyboard layout.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_api.h | 6 ++ lib/efi_loader/efi_hii.c | 147 +++++++++++++++++++++++++++++++++++++-- 2 files changed, 148 insertions(+), 5 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index b2e77832a756..46a86535a83d 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -842,6 +842,12 @@ struct efi_hii_keyboard_layout { struct efi_key_descriptor descriptors[]; } __packed;
+struct efi_hii_keyboard_package { + struct efi_hii_package_header header; + u16 layout_count; + struct efi_hii_keyboard_layout layout[]; +} __packed; + /* * HII protocols */ diff --git a/lib/efi_loader/efi_hii.c b/lib/efi_loader/efi_hii.c index d7cd0c4f0fc6..89e1a6c2369c 100644 --- a/lib/efi_loader/efi_hii.c +++ b/lib/efi_loader/efi_hii.c @@ -16,6 +16,7 @@ const efi_guid_t efi_guid_hii_database_protocol const efi_guid_t efi_guid_hii_string_protocol = EFI_HII_STRING_PROTOCOL_GUID;
static LIST_HEAD(efi_package_lists); +static LIST_HEAD(efi_keyboard_layout_list);
struct efi_hii_packagelist { struct list_head link; @@ -24,6 +25,7 @@ struct efi_hii_packagelist { u32 max_string_id; struct list_head string_tables; /* list of efi_string_table */ struct list_head guid_list; + struct list_head keyboard_packages;
/* we could also track fonts, images, etc */ }; @@ -86,6 +88,17 @@ struct efi_guid_data { struct efi_hii_guid_package package; };
+struct efi_keyboard_layout_data { + struct list_head link; /* in package */ + struct list_head link_sys; /* in global list */ + struct efi_hii_keyboard_layout keyboard_layout; +}; + +struct efi_keyboard_package_data { + struct list_head link; /* in package_list */ + struct list_head keyboard_layout_list; +}; + static void free_strings_table(struct efi_string_table *stbl) { int i; @@ -253,6 +266,78 @@ add_guid_package(struct efi_hii_packagelist *hii, return EFI_SUCCESS; }
+static void free_keyboard_layouts(struct efi_keyboard_package_data *package) +{ + struct efi_keyboard_layout_data *layout_data; + + while (!list_empty(&package->keyboard_layout_list)) { + layout_data = list_first_entry(&package->keyboard_layout_list, + struct efi_keyboard_layout_data, + link); + list_del(&layout_data->link); + list_del(&layout_data->link_sys); + free(layout_data); + } +} + +static void remove_keyboard_package(struct efi_hii_packagelist *hii) +{ + struct efi_keyboard_package_data *package; + + while (!list_empty(&hii->keyboard_packages)) { + package = list_first_entry(&hii->keyboard_packages, + struct efi_keyboard_package_data, + link); + free_keyboard_layouts(package); + list_del(&package->link); + free(package); + } +} + +static efi_status_t +add_keyboard_package(struct efi_hii_packagelist *hii, + struct efi_hii_keyboard_package *keyboard_package) +{ + struct efi_keyboard_package_data *package_data; + struct efi_hii_keyboard_layout *layout; + struct efi_keyboard_layout_data *layout_data; + u16 layout_count, layout_length; + int i; + + package_data = malloc(sizeof(*package_data)); + if (!package_data) + return EFI_OUT_OF_RESOURCES; + INIT_LIST_HEAD(&package_data->link); + INIT_LIST_HEAD(&package_data->keyboard_layout_list); + + layout = &keyboard_package->layout[0]; + layout_count = get_unaligned_le16(&keyboard_package->layout_count); + for (i = 0; i < layout_count; i++) { + layout_length = get_unaligned_le16(&layout->layout_length); + layout_data = malloc(sizeof(*layout_data) + layout_length); + if (!layout_data) + goto out; + + memcpy(&layout_data->keyboard_layout, layout, layout_length); + list_add_tail(&layout_data->link, + &package_data->keyboard_layout_list); + list_add_tail(&layout_data->link_sys, + &efi_keyboard_layout_list); + + layout += layout_length; + } + + list_add_tail(&package_data->link, &hii->keyboard_packages); + + return EFI_SUCCESS; + +out: + free_keyboard_layouts(package_data); + free(package_data); + + return EFI_OUT_OF_RESOURCES; +} + static struct efi_hii_packagelist *new_packagelist(void) { struct efi_hii_packagelist *hii; @@ -261,6 +346,7 @@ static struct efi_hii_packagelist *new_packagelist(void) hii->max_string_id = 0; INIT_LIST_HEAD(&hii->string_tables); INIT_LIST_HEAD(&hii->guid_list); + INIT_LIST_HEAD(&hii->keyboard_packages);
return hii; } @@ -269,6 +355,7 @@ static void free_packagelist(struct efi_hii_packagelist *hii) { remove_strings_package(hii); remove_guid_package(hii); + remove_keyboard_package(hii);
list_del(&hii->link); free(hii); @@ -324,8 +411,8 @@ add_packages(struct efi_hii_packagelist *hii, ret = EFI_INVALID_PARAMETER; break; case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: - printf("\tKeyboard layout package not supported\n"); - ret = EFI_INVALID_PARAMETER; + ret = add_keyboard_package(hii, + (struct efi_hii_keyboard_package *)package); break; case EFI_HII_PACKAGE_ANIMATIONS: printf("\tAnimation package not supported\n"); @@ -458,7 +545,7 @@ update_package_list(const struct efi_hii_database_protocol *this, ret = EFI_INVALID_PARAMETER; break; case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: - printf("\tKeyboard layout package not supported\n"); + remove_keyboard_package(hii); break; case EFI_HII_PACKAGE_ANIMATIONS: printf("\tAnimation package not supported\n"); @@ -546,7 +633,8 @@ list_package_lists(const struct efi_hii_database_protocol *this, ret = EFI_INVALID_PARAMETER; continue; case EFI_HII_PACKAGE_KEYBOARD_LAYOUT: - printf("\tKeyboard layout package not supported\n"); + if (!list_empty(&hii->keyboard_packages)) + break; continue; case EFI_HII_PACKAGE_ANIMATIONS: printf("\tAnimation package not supported\n"); @@ -620,9 +708,30 @@ find_keyboard_layouts(const struct efi_hii_database_protocol *this, u16 *key_guid_buffer_length, efi_guid_t *key_guid_buffer) { + struct efi_keyboard_layout_data *layout_data; + int package_cnt, package_max; + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p, %p, %p", this, key_guid_buffer_length, key_guid_buffer);
- return EFI_EXIT(EFI_NOT_FOUND); + if (!key_guid_buffer_length || + (*key_guid_buffer_length && !key_guid_buffer)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + package_cnt = 0; + package_max = *key_guid_buffer_length / sizeof(*key_guid_buffer); + list_for_each_entry(layout_data, &efi_keyboard_layout_list, link_sys) { + package_cnt++; + if (package_cnt <= package_max) + memcpy(key_guid_buffer++, + &layout_data->keyboard_layout.guid, + sizeof(*key_guid_buffer)); + else + ret = EFI_BUFFER_TOO_SMALL; + } + *key_guid_buffer_length = package_cnt * sizeof(*key_guid_buffer); + + return EFI_EXIT(ret); }
static efi_status_t EFIAPI @@ -631,10 +740,38 @@ get_keyboard_layout(const struct efi_hii_database_protocol *this, u16 *keyboard_layout_length, struct efi_hii_keyboard_layout *keyboard_layout) { + struct efi_keyboard_layout_data *layout_data; + u16 layout_length; + EFI_ENTRY("%p, %pUl, %p, %p", this, key_guid, keyboard_layout_length, keyboard_layout);
+ if (!keyboard_layout_length || + (*keyboard_layout_length && !keyboard_layout)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* TODO: no notion of current keyboard layout */ + if (!key_guid) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + list_for_each_entry(layout_data, &efi_keyboard_layout_list, link_sys) { + if (!guidcmp(&layout_data->keyboard_layout.guid, key_guid)) + goto found; + } + return EFI_EXIT(EFI_NOT_FOUND); + +found: + layout_length = + get_unaligned_le16(&layout_data->keyboard_layout.layout_length); + if (*keyboard_layout_length < layout_length) { + *keyboard_layout_length = layout_length; + return EFI_EXIT(EFI_BUFFER_TOO_SMALL); + } + + memcpy(keyboard_layout, &layout_data->keyboard_layout, layout_length); + + return EFI_EXIT(EFI_SUCCESS); }
This patch is a place holder for HII configuration routing protocol and HII configuration access protocol.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/efi_api.h | 161 ++++++++++++++++++++++++++++++++ include/efi_loader.h | 4 + lib/efi_loader/Makefile | 2 +- lib/efi_loader/efi_boottime.c | 6 ++ lib/efi_loader/efi_hii_config.c | 146 +++++++++++++++++++++++++++++ 5 files changed, 318 insertions(+), 1 deletion(-) create mode 100644 lib/efi_loader/efi_hii_config.c
diff --git a/include/efi_api.h b/include/efi_api.h index 46a86535a83d..09c4320f1ac8 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -39,6 +39,9 @@ typedef void *efi_hii_handle_t; typedef u16 *efi_string_t; typedef u16 efi_string_id_t; typedef u32 efi_hii_font_style_t; +typedef u16 efi_question_id_t; +typedef u16 efi_image_id_t; +typedef u16 efi_form_id_t;
#define EVT_TIMER 0x80000000 #define EVT_RUNTIME 0x40000000 @@ -796,6 +799,101 @@ efi_hii_sibt_string_ucs2_block_next(struct efi_hii_sibt_string_ucs2_block *blk) (u16_strlen(blk->string_text) + 1) * 2; }
+/* + * HII forms package + * TODO: full scope of definitions + */ +struct efi_hii_time { + u8 hour; + u8 minute; + u8 second; +}; + +struct efi_hii_date { + u16 year; + u8 month; + u8 day; +}; + +struct efi_hii_ref { + efi_question_id_t question_id; + efi_form_id_t form_id; + efi_guid_t form_set_guid; + efi_string_id_t device_path; +}; + +union efi_ifr_type_value { + u8 u8; // EFI_IFR_TYPE_NUM_SIZE_8 + u16 u16; // EFI_IFR_TYPE_NUM_SIZE_16 + u32 u32; // EFI_IFR_TYPE_NUM_SIZE_32 + u64 u64; // EFI_IFR_TYPE_NUM_SIZE_64 + bool b; // EFI_IFR_TYPE_BOOLEAN + struct efi_hii_time time; // EFI_IFR_TYPE_TIME + struct efi_hii_date date; // EFI_IFR_TYPE_DATE + efi_string_id_t string; // EFI_IFR_TYPE_STRING, EFI_IFR_TYPE_ACTION + struct efi_hii_ref ref; // EFI_IFR_TYPE_REF + // u8 buffer[]; // EFI_IFR_TYPE_BUFFER +}; + +#define EFI_IFR_TYPE_NUM_SIZE_8 0x00 +#define EFI_IFR_TYPE_NUM_SIZE_16 0x01 +#define EFI_IFR_TYPE_NUM_SIZE_32 0x02 +#define EFI_IFR_TYPE_NUM_SIZE_64 0x03 +#define EFI_IFR_TYPE_BOOLEAN 0x04 +#define EFI_IFR_TYPE_TIME 0x05 +#define EFI_IFR_TYPE_DATE 0x06 +#define EFI_IFR_TYPE_STRING 0x07 +#define EFI_IFR_TYPE_OTHER 0x08 +#define EFI_IFR_TYPE_UNDEFINED 0x09 +#define EFI_IFR_TYPE_ACTION 0x0A +#define EFI_IFR_TYPE_BUFFER 0x0B +#define EFI_IFR_TYPE_REF 0x0C +#define EFI_IFR_OPTION_DEFAULT 0x10 +#define EFI_IFR_OPTION_DEFAULT_MFG 0x20 + +#define EFI_IFR_ONE_OF_OPTION_OP 0x09 + +struct efi_ifr_op_header { + u8 opCode; + u8 length:7; + u8 scope:1; +}; + +struct efi_ifr_one_of_option { + struct efi_ifr_op_header header; + efi_string_id_t option; + u8 flags; + u8 type; + union efi_ifr_type_value value; +}; + +typedef efi_uintn_t efi_browser_action_t; + +#define EFI_BROWSER_ACTION_REQUEST_NONE 0 +#define EFI_BROWSER_ACTION_REQUEST_RESET 1 +#define EFI_BROWSER_ACTION_REQUEST_SUBMIT 2 +#define EFI_BROWSER_ACTION_REQUEST_EXIT 3 +#define EFI_BROWSER_ACTION_REQUEST_FORM_SUBMIT_EXIT 4 +#define EFI_BROWSER_ACTION_REQUEST_FORM_DISCARD_EXIT 5 +#define EFI_BROWSER_ACTION_REQUEST_FORM_APPLY 6 +#define EFI_BROWSER_ACTION_REQUEST_FORM_DISCARD 7 +#define EFI_BROWSER_ACTION_REQUEST_RECONNECT 8 + +typedef efi_uintn_t efi_browser_action_request_t; + +#define EFI_BROWSER_ACTION_CHANGING 0 +#define EFI_BROWSER_ACTION_CHANGED 1 +#define EFI_BROWSER_ACTION_RETRIEVE 2 +#define EFI_BROWSER_ACTION_FORM_OPEN 3 +#define EFI_BROWSER_ACTION_FORM_CLOSE 4 +#define EFI_BROWSER_ACTION_SUBMITTED 5 +#define EFI_BROWSER_ACTION_DEFAULT_STANDARD 0x1000 +#define EFI_BROWSER_ACTION_DEFAULT_MANUFACTURING 0x1001 +#define EFI_BROWSER_ACTION_DEFAULT_SAFE 0x1002 +#define EFI_BROWSER_ACTION_DEFAULT_PLATFORM 0x2000 +#define EFI_BROWSER_ACTION_DEFAULT_HARDWARE 0x3000 +#define EFI_BROWSER_ACTION_DEFAULT_FIRMWARE 0x4000 + /* * HII keyboard package */ @@ -955,6 +1053,69 @@ struct efi_hii_database_protocol { efi_handle_t *driver_handle); };
+#define EFI_HII_CONFIG_ROUTING_PROTOCOL_GUID \ + EFI_GUID(0x587e72d7, 0xcc50, 0x4f79, \ + 0x82, 0x09, 0xca, 0x29, 0x1f, 0xc1, 0xa1, 0x0f) + +struct efi_hii_config_routing_protocol { + efi_status_t(EFIAPI *extract_config)( + const struct efi_hii_config_routing_protocol *this, + const efi_string_t request, + efi_string_t *progress, + efi_string_t *results); + efi_status_t(EFIAPI *export_config)( + const struct efi_hii_config_routing_protocol *this, + efi_string_t *results); + efi_status_t(EFIAPI *route_config)( + const struct efi_hii_config_routing_protocol *this, + const efi_string_t configuration, + efi_string_t *progress); + efi_status_t(EFIAPI *block_to_config)( + const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_request, + const uint8_t *block, + const efi_uintn_t block_size, + efi_string_t *config, + efi_string_t *progress); + efi_status_t(EFIAPI *config_to_block)( + const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_resp, + const uint8_t *block, + const efi_uintn_t *block_size, + efi_string_t *progress); + efi_status_t(EFIAPI *get_alt_config)( + const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_resp, + const efi_guid_t *guid, + const efi_string_t name, + const struct efi_device_path *device_path, + const efi_string_t alt_cfg_id, + efi_string_t *alt_cfg_resp); +}; + +#define EFI_HII_CONFIG_ACCESS_PROTOCOL_GUID \ + EFI_GUID(0x330d4706, 0xf2a0, 0x4e4f, \ + 0xa3, 0x69, 0xb6, 0x6f, 0xa8, 0xd5, 0x43, 0x85) + +struct efi_hii_config_access_protocol { + efi_status_t(EFIAPI *extract_config_access)( + const struct efi_hii_config_access_protocol *this, + const efi_string_t request, + efi_string_t *progress, + efi_string_t *results); + efi_status_t(EFIAPI *route_config_access)( + const struct efi_hii_config_access_protocol *this, + const efi_string_t configuration, + efi_string_t *progress); + efi_status_t(EFIAPI *form_callback)( + const struct efi_hii_config_access_protocol *this, + efi_browser_action_t action, + efi_question_id_t question_id, + u8 type, + union efi_ifr_type_value *value, + efi_browser_action_request_t *action_request); +}; + #define EFI_GOP_GUID \ EFI_GUID(0x9042a9de, 0x23dc, 0x4a38, \ 0x96, 0xfb, 0x7a, 0xde, 0xd0, 0x80, 0x51, 0x6a) diff --git a/include/efi_loader.h b/include/efi_loader.h index 18384a8caf5c..dd68cfce5c65 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -106,6 +106,8 @@ extern const struct efi_device_path_utilities_protocol /* Implementation of the EFI_UNICODE_COLLATION_PROTOCOL */ extern const struct efi_unicode_collation_protocol efi_unicode_collation_protocol; +extern const struct efi_hii_config_routing_protocol efi_hii_config_routing; +extern const struct efi_hii_config_access_protocol efi_hii_config_access; extern const struct efi_hii_database_protocol efi_hii_database; extern const struct efi_hii_string_protocol efi_hii_string;
@@ -141,6 +143,8 @@ extern const efi_guid_t efi_file_system_info_guid; extern const efi_guid_t efi_guid_device_path_utilities_protocol; /* GUID of the Unicode collation protocol */ extern const efi_guid_t efi_guid_unicode_collation_protocol; +extern const efi_guid_t efi_guid_hii_config_routing_protocol; +extern const efi_guid_t efi_guid_hii_config_access_protocol; extern const efi_guid_t efi_guid_hii_database_protocol; extern const efi_guid_t efi_guid_hii_string_protocol;
diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index dc8bc1461cb9..3ba539314aee 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -24,7 +24,7 @@ obj-y += efi_device_path.o obj-y += efi_device_path_to_text.o obj-y += efi_device_path_utilities.o obj-y += efi_file.o -obj-y += efi_hii.o +obj-y += efi_hii.o efi_hii_config.o obj-y += efi_image_loader.o obj-y += efi_memory.o obj-y += efi_root_node.o diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index ba2e1f652afe..291bc1bd35f9 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1570,6 +1570,12 @@ efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, if (ret != EFI_SUCCESS) goto failure;
+ ret = efi_add_protocol(&obj->header, + &efi_guid_hii_config_routing_protocol, + (void *)&efi_hii_config_routing); + if (ret != EFI_SUCCESS) + goto failure; + return ret; failure: printf("ERROR: Failure to install protocols for loaded image\n"); diff --git a/lib/efi_loader/efi_hii_config.c b/lib/efi_loader/efi_hii_config.c new file mode 100644 index 000000000000..f4b1f026c1bd --- /dev/null +++ b/lib/efi_loader/efi_hii_config.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * EFI Human Interface Infrastructure ... Configuration + * + * Copyright (c) 2017 Leif Lindholm + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#include <common.h> +#include <efi_loader.h> + +const efi_guid_t efi_guid_hii_config_routing_protocol + = EFI_HII_CONFIG_ROUTING_PROTOCOL_GUID; +const efi_guid_t efi_guid_hii_config_access_protocol + = EFI_HII_CONFIG_ACCESS_PROTOCOL_GUID; + +/* + * EFI_HII_CONFIG_ROUTING_PROTOCOL + */ + +static efi_status_t EFIAPI +extract_config(const struct efi_hii_config_routing_protocol *this, + const efi_string_t request, + efi_string_t *progress, + efi_string_t *results) +{ + EFI_ENTRY("%p, "%ls", %p, %p", this, request, progress, results); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +export_config(const struct efi_hii_config_routing_protocol *this, + efi_string_t *results) +{ + EFI_ENTRY("%p, %p", this, results); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +route_config(const struct efi_hii_config_routing_protocol *this, + const efi_string_t configuration, + efi_string_t *progress) +{ + EFI_ENTRY("%p, "%ls", %p", this, configuration, progress); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +block_to_config(const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_request, + const u8 *block, + const efi_uintn_t block_size, + efi_string_t *config, + efi_string_t *progress) +{ + EFI_ENTRY("%p, "%ls", %p, %zu, %p, %p", this, config_request, + block, block_size, config, progress); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +config_to_block(const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_resp, + const u8 *block, + const efi_uintn_t *block_size, + efi_string_t *progress) +{ + EFI_ENTRY("%p, "%ls", %p, %p, %p", this, config_resp, + block, block_size, progress); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +static efi_status_t EFIAPI +get_alt_config(const struct efi_hii_config_routing_protocol *this, + const efi_string_t config_resp, + const efi_guid_t *guid, + const efi_string_t name, + const struct efi_device_path *device_path, + const efi_string_t alt_cfg_id, + efi_string_t *alt_cfg_resp) +{ + EFI_ENTRY("%p, "%ls", %pUl, "%ls", %p, "%ls", %p", + this, config_resp, guid, name, device_path, + alt_cfg_id, alt_cfg_resp); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +} + +/* + * EFI_HII_ACCESS_PROTOCOL + */ + +efi_status_t EFIAPI +extract_config_access(const struct efi_hii_config_access_protocol *this, + const efi_string_t request, + efi_string_t *progress, + efi_string_t *results) +{ + EFI_ENTRY("%p, "%ls", %p, %p", this, request, progress, results); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +}; + +efi_status_t EFIAPI +route_config_access(const struct efi_hii_config_access_protocol *this, + const efi_string_t configuration, + efi_string_t *progress) +{ + EFI_ENTRY("%p, "%ls", %p", this, configuration, progress); + + return EFI_EXIT(EFI_OUT_OF_RESOURCES); +}; + +efi_status_t EFIAPI +form_callback(const struct efi_hii_config_access_protocol *this, + efi_browser_action_t action, + efi_question_id_t question_id, + u8 type, + union efi_ifr_type_value *value, + efi_browser_action_request_t *action_request) +{ + EFI_ENTRY("%p, 0x%lx, 0x%x, 0x%x, %p, %p", this, action, + question_id, type, value, action_request); + + return EFI_EXIT(EFI_DEVICE_ERROR); +}; + +const struct efi_hii_config_routing_protocol efi_hii_config_routing = { + .extract_config = extract_config, + .export_config = export_config, + .route_config = route_config, + .block_to_config = block_to_config, + .config_to_block = config_to_block, + .get_alt_config = get_alt_config +}; + +const struct efi_hii_config_access_protocol efi_hii_config_access = { + .extract_config_access = extract_config_access, + .route_config_access = route_config_access, + .form_callback = form_callback +};
This efi_selftest tests HII database protocol and HII string protocol.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_hii.c | 1046 ++++++++++++++++++++++ lib/efi_selftest/efi_selftest_hii_data.c | 453 ++++++++++ 3 files changed, 1500 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_hii.c create mode 100644 lib/efi_selftest/efi_selftest_hii_data.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 743b48204493..5cd8a757a3eb 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -25,6 +25,7 @@ efi_selftest_exception.o \ efi_selftest_exitbootservices.o \ efi_selftest_fdt.o \ efi_selftest_gop.o \ +efi_selftest_hii.o \ efi_selftest_loaded_image.o \ efi_selftest_manageprotocols.o \ efi_selftest_memory.o \ diff --git a/lib/efi_selftest/efi_selftest_hii.c b/lib/efi_selftest/efi_selftest_hii.c new file mode 100644 index 000000000000..16d7b608297e --- /dev/null +++ b/lib/efi_selftest/efi_selftest_hii.c @@ -0,0 +1,1046 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * efi_selftest_hii + * + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + * + * Test HII database protocols + */ + +#include <efi_selftest.h> +#include <malloc.h> +#include "efi_selftest_hii_data.c" + +#define PRINT_TESTNAME efi_st_printf("%s:\n", __func__) + +static struct efi_boot_services *boottime; + +static const efi_guid_t hii_database_protocol_guid = + EFI_HII_DATABASE_PROTOCOL_GUID; +static const efi_guid_t hii_string_protocol_guid = + EFI_HII_STRING_PROTOCOL_GUID; + +static struct efi_hii_database_protocol *hii_database_protocol; +static struct efi_hii_string_protocol *hii_string_protocol; + +/* + * Setup unit test. + * + * @handle: handle of the loaded image + * @systable: system table + * + * @return: EFI_ST_SUCCESS for success + */ +static int setup(const efi_handle_t handle, + const struct efi_system_table *systable) +{ + efi_status_t ret; + + boottime = systable->boottime; + + /* HII database protocol */ + ret = boottime->locate_protocol(&hii_database_protocol_guid, NULL, + (void **)&hii_database_protocol); + if (ret != EFI_SUCCESS) { + hii_database_protocol = NULL; + efi_st_error("HII database protocol is not available.\n"); + return EFI_ST_FAILURE; + } + + /* HII string protocol */ + ret = boottime->locate_protocol(&hii_string_protocol_guid, NULL, + (void **)&hii_string_protocol); + if (ret != EFI_SUCCESS) { + hii_string_protocol = NULL; + efi_st_error("HII string protocol is not available.\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +/* + * HII database protocol tests + */ + +/** + * test_hii_database_new_package_list() - test creation and removal of + * package list + * + * This test adds a new package list and then tries to remove it using + * the provided handle. + * + * @Return: status code + */ +static int test_hii_database_new_package_list(void) +{ + efi_hii_handle_t handle; + efi_status_t ret; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + ret = hii_database_protocol->remove_package_list(hii_database_protocol, + handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +/** + * test_hii_database_update_package_list() - test update of package list + * + * This test adds a new package list and then tries to update it using + * another package list. + * + * @Return: status code + */ +static int test_hii_database_update_package_list(void) +{ + efi_hii_handle_t handle = NULL; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + ret = hii_database_protocol->update_package_list(hii_database_protocol, + handle, + (struct efi_hii_package_list_header *)packagelist2); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +/** + * test_hii_database_list_package_lists() - test listing of package lists + * + * This test adds two package lists and then tries to enumerate them + * against different package types. We will get an array of handles. + * + * @Return: status code + */ +static int test_hii_database_list_package_lists(void) +{ + efi_hii_handle_t handle1 = NULL, handle2 = NULL, *handles; + efi_uintn_t handles_size; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle1); + if (ret != EFI_SUCCESS || !handle1) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist2, + NULL, &handle2); + if (ret != EFI_SUCCESS || !handle2) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + /* TYPE_ALL */ + handles = NULL; + handles_size = 0; + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_TYPE_ALL, NULL, + &handles_size, handles); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + goto out; + } + handles = malloc(handles_size); + if (!handles) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_TYPE_ALL, NULL, + &handles_size, handles); + if (ret != EFI_SUCCESS) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + goto out; + } + efi_st_printf("list_package_lists returned %ld handles\n", + handles_size / sizeof(*handles)); + free(handles); + + /* STRINGS */ + handles = NULL; + handles_size = 0; + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_STRINGS, NULL, + &handles_size, handles); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + handles = malloc(handles_size); + if (!handles) { + efi_st_error("malloc failed\n"); + ret = EFI_ST_FAILURE; + goto out; + } + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_STRINGS, NULL, + &handles_size, handles); + if (ret != EFI_SUCCESS) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + efi_st_printf("list_package_lists returned %ld strings handles\n", + handles_size / sizeof(*handles)); + free(handles); + + /* GUID */ + handles = NULL; + handles_size = 0; + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_TYPE_GUID, &package_guid, + &handles_size, handles); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + handles = malloc(handles_size); + if (!handles) { + efi_st_error("malloc failed\n"); + ret = EFI_ST_FAILURE; + goto out; + } + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_TYPE_GUID, &package_guid, + &handles_size, handles); + if (ret != EFI_SUCCESS) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + efi_st_printf("list_package_lists returned %ld guid handles\n", + handles_size / sizeof(*handles)); + free(handles); + + /* KEYBOARD_LAYOUT */ + handles = NULL; + handles_size = 0; + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_KEYBOARD_LAYOUT, NULL, + &handles_size, handles); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + handles = malloc(handles_size); + if (!handles) { + efi_st_error("malloc failed\n"); + ret = EFI_ST_FAILURE; + goto out; + } + ret = hii_database_protocol->list_package_lists(hii_database_protocol, + EFI_HII_PACKAGE_KEYBOARD_LAYOUT, NULL, + &handles_size, handles); + if (ret != EFI_SUCCESS) { + efi_st_error("list_package_lists returned %u\n", + (unsigned int)ret); + ret = EFI_ST_FAILURE; + goto out; + } + efi_st_printf("list_package_lists returned %ld keyboard layout handles\n", + handles_size / sizeof(*handles)); + free(handles); + + result = EFI_ST_SUCCESS; + +out: + if (handle1) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle1); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + if (handle2) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle2); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + + return result; +} + +/** + * test_hii_database_export_package_lists() - test export of package lists + * + * @Return: status code + */ +static int test_hii_database_export_package_lists(void) +{ + PRINT_TESTNAME; + /* export_package_lists() not implemented yet */ + return EFI_ST_SUCCESS; +} + +/** + * test_hii_database_register_package_notify() - test registration of + * notification function + * + * @Return: status code + */ +static int test_hii_database_register_package_notify(void) +{ + PRINT_TESTNAME; + /* register_package_notify() not implemented yet */ + return EFI_ST_SUCCESS; +} + +/** + * test_hii_database_unregister_package_notify() - test removal of + * notification function + * + * @Return: status code + */ +static int test_hii_database_unregister_package_notify(void) +{ + PRINT_TESTNAME; + /* unregsiter_package_notify() not implemented yet */ + return EFI_ST_SUCCESS; +} + +/** + * test_hii_database_find_keyboard_layouts() - test listing of + * all the keyboard layouts in the system + * + * This test adds two package lists, each of which has two keyboard layouts + * and then tries to enumerate them. We will get an array of handles. + * + * @Return: status code + */ +static int test_hii_database_find_keyboard_layouts(void) +{ + efi_hii_handle_t handle1 = NULL, handle2 = NULL; + efi_guid_t *guids; + u16 guids_size; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle1); + if (ret != EFI_SUCCESS || !handle1) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist2, + NULL, &handle2); + if (ret != EFI_SUCCESS || !handle2) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + guids = NULL; + guids_size = 0; + ret = hii_database_protocol->find_keyboard_layouts( + hii_database_protocol, &guids_size, guids); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("find_keyboard_layouts returned %u\n", + (unsigned int)ret); + goto out; + } + guids = malloc(guids_size); + if (!guids) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_database_protocol->find_keyboard_layouts( + hii_database_protocol, &guids_size, guids); + if (ret != EFI_SUCCESS) { + efi_st_error("find_keyboard_layouts returned %u\n", + (unsigned int)ret); + goto out; + } + free(guids); + + efi_st_printf("find_keyboard_layouts returned %ld guids\n", + guids_size / sizeof(*guids)); + + result = EFI_ST_SUCCESS; + +out: + if (handle1) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle1); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + if (handle2) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle2); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + + return result; +} + +/** + * test_hii_database_get_keyboard_layout() - test retrieval of keyboard layout + * + * This test adds two package lists, each of which has two keyboard layouts + * and then tries to get a handle to keyboard layout with a specific guid + * and the current one. + * + * @Return: status code + */ +static int test_hii_database_get_keyboard_layout(void) +{ + efi_hii_handle_t handle1 = NULL, handle2 = NULL; + struct efi_hii_keyboard_layout *kb_layout; + u16 kb_layout_size; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle1); + if (ret != EFI_SUCCESS || !handle1) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist2, + NULL, &handle2); + if (ret != EFI_SUCCESS || !handle2) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + goto out; + } + + /* specific keyboard_layout(guid11) */ + kb_layout = NULL; + kb_layout_size = 0; + ret = hii_database_protocol->get_keyboard_layout(hii_database_protocol, + &kb_layout_guid11, &kb_layout_size, kb_layout); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("get_keyboard_layout returned %u\n", + (unsigned int)ret); + goto out; + } + kb_layout = malloc(kb_layout_size); + if (!kb_layout) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_database_protocol->get_keyboard_layout(hii_database_protocol, + &kb_layout_guid11, &kb_layout_size, kb_layout); + if (ret != EFI_SUCCESS) { + efi_st_error("get_keyboard_layout returned %u\n", + (unsigned int)ret); + goto out; + } + free(kb_layout); + + /* current */ + kb_layout = NULL; + kb_layout_size = 0; + ret = hii_database_protocol->get_keyboard_layout(hii_database_protocol, + NULL, &kb_layout_size, kb_layout); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("get_keyboard_layout returned %u\n", + (unsigned int)ret); + goto out; + } + + result = EFI_ST_SUCCESS; + +out: + if (handle1) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle1); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + if (handle2) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle2); + if (ret != EFI_SUCCESS) + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + } + + return result; +} + +/** + * test_hii_database_set_keyboard_layout() - test change of + * current keyboard layout + * + * @Return: status code + */ +static int test_hii_database_set_keyboard_layout(void) +{ + PRINT_TESTNAME; + /* set_keyboard_layout() not implemented yet */ + return EFI_ST_SUCCESS; +} + +/** + * test_hii_database_get_package_list_handle() - test retrieval of + * driver associated with a package list + * + * This test adds a package list, and then tries to get a handle to driver + * which is associated with a package list. + * + * @Return: status code + */ +static int test_hii_database_get_package_list_handle(void) +{ + efi_hii_handle_t handle = NULL; + efi_handle_t driver_handle; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + driver_handle = (efi_handle_t)0x12345678; /* dummy */ + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + driver_handle, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + driver_handle = NULL; + ret = hii_database_protocol->get_package_list_handle( + hii_database_protocol, handle, &driver_handle); + if (ret != EFI_SUCCESS || driver_handle != (efi_handle_t)0x12345678) { + efi_st_error("get_package_list_handle returned %u, driver:%p\n", + (unsigned int)ret, driver_handle); + goto out; + } + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +static int test_hii_database_protocol(void) +{ + int ret; + + ret = test_hii_database_new_package_list(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_update_package_list(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_list_package_lists(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_export_package_lists(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_register_package_notify(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_unregister_package_notify(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_find_keyboard_layouts(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_get_keyboard_layout(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_set_keyboard_layout(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_database_get_package_list_handle(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + return EFI_ST_SUCCESS; +} + +/* + * HII string protocol tests + */ + +/** + * test_hii_string_new_string() - test creation of a new string entry + * + * This test adds a package list, and then tries to add a new string + * entry for a specific language. + * + * @Return: status code + */ +static int test_hii_string_new_string(void) +{ + efi_hii_handle_t handle = NULL; + efi_string_id_t id; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + ret = hii_string_protocol->new_string(hii_string_protocol, handle, + &id, (u8 *)"en-US", + L"Japanese", L"Japanese", NULL); + if (ret != EFI_SUCCESS) { + efi_st_error("new_string returned %u\n", + (unsigned int)ret); + goto out; + } + efi_st_printf("new string id is %u\n", id); + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +/** + * test_hii_string_get_string() - test retrieval of a string entry + * + * This test adds a package list, create a new string entry and then tries + * to get it with its string id. + * + * @Return: status code + */ +static int test_hii_string_get_string(void) +{ + efi_hii_handle_t handle = NULL; + efi_string_id_t id; + efi_string_t string; + efi_uintn_t string_len; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + ret = hii_string_protocol->new_string(hii_string_protocol, handle, + &id, (u8 *)"en-US", + L"Japanese", L"Japanese", NULL); + if (ret != EFI_SUCCESS) { + efi_st_error("new_string returned %u\n", + (unsigned int)ret); + goto out; + } + + string = NULL; + string_len = 0; + ret = hii_string_protocol->get_string(hii_string_protocol, + (u8 *)"en-US", handle, id, string, &string_len, NULL); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("get_string returned %u\n", + (unsigned int)ret); + goto out; + } + string_len += sizeof(u16); + string = malloc(string_len); + if (!string) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_string_protocol->get_string(hii_string_protocol, + (u8 *)"en-US", handle, id, string, &string_len, NULL); + if (ret != EFI_SUCCESS) { + efi_st_error("get_string returned %u\n", + (unsigned int)ret); + goto out; + } + +#if 1 + u16 *c1, *c2; + + for (c1 = string, c2 = L"Japanese"; *c1 == *c2; c1++, c2++) + ; + if (!*c1 && !*c2) + result = EFI_ST_SUCCESS; + else + result = EFI_ST_FAILURE; +#else + /* TODO: %ls */ + efi_st_printf("got string is %s (can be wrong)\n", string); +#endif + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +/** + * test_hii_string_set_string() - test change of a string entry + * + * This test adds a package list, create a new string entry and then tries + * to modify it. + * + * @Return: status code + */ +static int test_hii_string_set_string(void) +{ + efi_hii_handle_t handle = NULL; + efi_string_id_t id; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + ret = hii_string_protocol->new_string(hii_string_protocol, handle, + &id, (u8 *)"en-US", + L"Japanese", L"Japanese", NULL); + if (ret != EFI_SUCCESS) { + efi_st_error("new_string returned %u\n", + (unsigned int)ret); + goto out; + } + + ret = hii_string_protocol->set_string(hii_string_protocol, handle, + id, (u8 *)"en-US", + L"Nihongo", NULL); + if (ret != EFI_SUCCESS) { + efi_st_error("set_string returned %u\n", + (unsigned int)ret); + goto out; + } + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +/** + * test_hii_string_get_languages() - test listing of languages + * + * This test adds a package list, and then tries to enumerate languages + * in it. We will get an string of language names. + * + * @Return: status code + */ +static int test_hii_string_get_languages(void) +{ + efi_hii_handle_t handle = NULL; + u8 *languages; + efi_uintn_t languages_len; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + languages = NULL; + languages_len = 0; + ret = hii_string_protocol->get_languages(hii_string_protocol, handle, + languages, &languages_len); + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("get_languages returned %u\n", + (unsigned int)ret); + goto out; + } + languages = malloc(languages_len); + if (!languages) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_string_protocol->get_languages(hii_string_protocol, handle, + languages, &languages_len); + if (ret != EFI_SUCCESS) { + efi_st_error("get_languages returned %u\n", + (unsigned int)ret); + goto out; + } + + efi_st_printf("got languages are %s\n", languages); + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +/** + * test_hii_string_get_secondary_languages() - test listing of secondary + * languages + * + * This test adds a package list, and then tries to enumerate secondary + * languages with a specific language. We will get an string of language names. + * + * @Return: status code + */ +static int test_hii_string_get_secondary_languages(void) +{ + efi_hii_handle_t handle = NULL; + u8 *languages; + efi_uintn_t languages_len; + efi_status_t ret; + int result = EFI_ST_FAILURE; + + PRINT_TESTNAME; + ret = hii_database_protocol->new_package_list(hii_database_protocol, + (struct efi_hii_package_list_header *)packagelist1, + NULL, &handle); + if (ret != EFI_SUCCESS || !handle) { + efi_st_error("new_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + + languages = NULL; + languages_len = 0; + ret = hii_string_protocol->get_secondary_languages(hii_string_protocol, + handle, (u8 *)"en-US", languages, &languages_len); + if (ret == EFI_NOT_FOUND) { + efi_st_printf("no secondary languages\n"); + result = EFI_ST_SUCCESS; + goto out; + } + if (ret != EFI_BUFFER_TOO_SMALL) { + efi_st_error("get_secondary_languages returned %u\n", + (unsigned int)ret); + goto out; + } + languages = malloc(languages_len); + if (!languages) { + efi_st_error("malloc failed\n"); + goto out; + } + ret = hii_string_protocol->get_secondary_languages(hii_string_protocol, + handle, (u8 *)"en-US", languages, &languages_len); + if (ret != EFI_SUCCESS) { + efi_st_error("get_secondary_languages returned %u\n", + (unsigned int)ret); + goto out; + } + + efi_st_printf("got secondary languages are %s\n", languages); + + result = EFI_ST_SUCCESS; + +out: + if (handle) { + ret = hii_database_protocol->remove_package_list( + hii_database_protocol, handle); + if (ret != EFI_SUCCESS) { + efi_st_error("remove_package_list returned %u\n", + (unsigned int)ret); + return EFI_ST_FAILURE; + } + } + + return result; +} + +static int test_hii_string_protocol(void) +{ + int ret; + + ret = test_hii_string_new_string(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_string_get_string(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_string_set_string(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_string_get_languages(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + ret = test_hii_string_get_secondary_languages(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + return EFI_ST_SUCCESS; +} + +/* + * Execute unit test. + * + * @return: EFI_ST_SUCCESS for success, EFI_ST_FAILURE for failure + */ +static int execute(void) +{ + int ret; + + /* HII database protocol */ + ret = test_hii_database_protocol(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + /* HII string protocol */ + ret = test_hii_string_protocol(); + if (ret != EFI_ST_SUCCESS) + return EFI_ST_FAILURE; + + return EFI_ST_SUCCESS; +} + +EFI_UNIT_TEST(hii) = { + .name = "HII database protocols", + .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, +}; diff --git a/lib/efi_selftest/efi_selftest_hii_data.c b/lib/efi_selftest/efi_selftest_hii_data.c new file mode 100644 index 000000000000..d19f0682afd0 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_hii_data.c @@ -0,0 +1,453 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * This file's test data is derived from UEFI SCT. + * The original copyright is attached below. + */ + +/* + * Copyright 2006 - 2016 Unified EFI, Inc.<BR> + * Copyright (c) 2010 - 2016, Intel Corporation. All rights reserved.<BR> + * + * This program and the accompanying materials + * are licensed and made available under the terms and conditions of the BSD + * License which accompanies this distribution. The full text of the license + * may be found at + * http://opensource.org/licenses/bsd-license.php + * + * THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS, + * WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED. + */ + +#include <efi.h> + +#ifdef NOT_USED +/* + * TODO: These macro's are not used as they appear only in + * "#ifdef NOT_USED" clauses. In the future, define them elsewhere. + */ + +/* HII form */ +#define EFI_IFR_AND_OP 0x15 +#define EFI_IFR_END_OP 0x29 +#define EFI_IFR_BITWISE_AND_OP 0x35 + +/* HII image */ +#define EFI_HII_IIBT_END 0x00 +#define EFI_HII_IIBT_IMAGE_1BIT 0x10 +#endif + +/* HII keyboard layout */ +#define EFI_NULL_MODIFIER 0x0000 + +u8 packagelist1[] = { + // EFI_HII_PACKAGE_LIST_HEADER, length = 20 + // SimpleFont, Font, GUID, Form, String, Image, DevicePath, + // (74) (110) 20 (8) 78 (67) (8) + // KeyboardLayout, End + // 192 4 + + 0x89, 0xcd, 0xab, 0x03, 0xf4, 0x03, 0x44, 0x70, + 0x81, 0xde, 0x99, 0xb1, 0x81, 0x20, 0xf7, 0x68, //16: guid + 0x3a, 0x01, 0x00, 0x00, // 4: total 314(0x13a) +#ifdef NOT_USED /* TODO: simple font package not implemented yet */ + // + // Simple Font Package 1, length = 74 + // + 0x4A, 0x00, 0x00, + EFI_HII_PACKAGE_SIMPLE_FONTS, + 1, 0, + 1, 0, + 0x55, 0x0, 0x1, + 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, + 0x77, 0x0, 0x2, + 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, + 3, 4, 5, + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 0, 0, 0, + // + // Font Package 1, length = 110 + // + 0x6e, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_FONTS, // 1 + 0x5c, 0x00, 0x00, 0x00, // 4: size of header + 0x5c, 0x00, 0x00, 0x00, // 4: offset + 0xf1, 0x00, 0xf2, 0x00, 0xf3, 0x00, 0xf4, 0x00, + 0xf5, 0x00, 0xec, 0xec, //10+2(pads) + 0xff, 0x33, 0xff, 0x44, // 4: font style + 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x66, //64 + // + // Glyph block 1, length = 18 + // + EFI_HII_GIBT_GLYPH_DEFAULT, // 1 + 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x99, + 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, //16: BitMapData + EFI_HII_GIBT_END, // 1 +#endif + // + // Guid Package 1, length = 20 + // + 0x14, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_TYPE_GUID, // 1 + 0x5a, 0xc9, 0x87, 0x03, 0x3, 0xd7, 0x46, 0x23, + 0xb2, 0xab, 0xd0, 0xc7, 0xdd, 0x90, 0x44, 0xf8, //16: guid +#ifdef NOT_USED /* TODO: form package not implemented yet */ + // + // EFI_HII_PACKAGE_FORMS, length = 8 + // + 0x08, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_FORMS, // 1 + // + // Opcode 1, length = 4 + // + EFI_IFR_AND_OP, + 0x82, + EFI_IFR_END_OP, + 0x02, + // +#endif + // EFI_HII_PACKAGE_STRINGS, length = 78 + // + 0x4e, 0x00, 0x00, // 3: length(header) + EFI_HII_PACKAGE_STRINGS, // 1: type(header) + 0x3c, 0x00, 0x00, 0x00, // 4: header_size + 0x3c, 0x00, 0x00, 0x00, // 4: string_offset + 0x00, 0x00, 0x11, 0x22, 0x44, 0x55, 0x77, 0x89, //32: language_window + 0x11, 0x00, 0x11, 0x22, 0x44, 0x55, 0x87, 0x89, + 0x22, 0x00, 0x11, 0x22, 0x44, 0x55, 0x77, 0x89, + 0x33, 0x00, 0x11, 0x22, 0x44, 0x55, 0x77, 0x89, + 0x01, 0x00, // 2: language name + 0x65, 0x6e, 0x2d, 0x55, 0x53, 0x3b, 0x7a, 0x68, //14: language + 0x2d, 0x48, 0x61, 0x6e, 0x74, 0x00, // "en-US;zh-Hant" + EFI_HII_SIBT_STRING_UCS2, // 1 + 0x45, 0x00, 0x6E, 0x00, 0x67, 0x00, 0x6C, 0x00, + 0x69, 0x00, 0x73, 0x00, 0x68, 0x00, 0x00, 0x00, //16: "English" + EFI_HII_SIBT_END, // 1 +#ifdef NOT_USED /* TODO: image package not implemented yet */ + // + // EFI_HII_PACKAGE_IMAGES, length = 67 + // + 0x43, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_IMAGES, // 1 + 0x0c, 0x00, 0x00, 0x00, // 4: image info offset + 0x39, 0x00, 0x00, 0x00, // 4: palette info offset + EFI_HII_IIBT_IMAGE_1BIT, // 1 + 0x01, + 0x0b, 0x00, + 0x13, 0x00, + 0x80, 0x00, + 0xc0, 0x00, + 0xe0, 0x00, + 0xf0, 0x00, + 0xf8, 0x00, + 0xfc, 0x00, + 0xfe, 0x00, + 0xff, 0x00, + 0xff, 0x80, + 0xff, 0xc0, + 0xff, 0xe0, + 0xfe, 0x00, + 0xef, 0x00, + 0xcf, 0x00, + 0x87, 0x80, + 0x07, 0x80, + 0x03, 0xc0, + 0x03, 0xc0, + 0x01, 0x80, //43 + EFI_HII_IIBT_END, // 1 + 0x01, 0x00, + 0x06, 0x00, + 0x00, 0x00, 0x00, + 0xFF, 0xFF, 0xFF, //10 + // + // EFI_HII_PACKAGE_DEVICE_PATH, length = 8 + // + 0x08, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_DEVICE_PATH, // 1 + 0x01, 0x23, 0x45, 0x66, // 4: dummy device path protocol + // instance address +#endif + // + // Keyboard layout package 1, length = 192 + 0xc0, 0x00, 0x00, // 3: length(header) + EFI_HII_PACKAGE_KEYBOARD_LAYOUT, // 1: type(header) + 0x02, 0x00, // 2: LayoutCount + // + // Layout 1, length = 93 + // + 0x5d, 0x00, // 2: layout_length + 0x95, 0xe4, 0x40, 0x8d, 0xaa, 0xe2, 0x6f, 0x4c, + 0x89, 0x70, 0x68, 0x85, 0x09, 0xee, 0xc7, 0xd2, //16: guid + 0x37, 0x00, 0x00, 0x00, // 4: layout_descriptor_ + // string_offset + 0x02, // 1: descriptor_count + // + // Descriptor 1, length = 16 + // + 49, 0x00, 0x00, 0x00, // 4: key (EfiKeyD1) + 'q', 0x00, // 2: unicode + 'Q', 0x00, // 2: shifted_unicode + 0x00, 0x00, // 2: alt_gr_unicode + 0x00, 0x00, // 2: shifted_alt_gr_unicode + EFI_NULL_MODIFIER, 0x00, // 2: modifier + 0x03, 0x00, // 2: affected_attribute + // + // Descriptor 2, length = 16 + // + 50, 0x00, 0x00, 0x00, // 4: key (EfiKeyD2) + 'w', 0x00, // 2: unicode + 'W', 0x00, // 2: shifted_unicode + 0x00, 0x00, // 2: alt_gr_unicode + 0x00, 0x00, // 2: shifted_alt_gr_unicode + EFI_NULL_MODIFIER, 0x00, // 2: modifier + 0x3, 0x0, // 2: affected_attribute + // + // EFI_DESCRIPTOR_STRING_BUNDLE, length = 38 + // + 0x01, 0x00, // 2: DescriptionCount + 'e', 0x0, 'n', 0x0, '-', 0x0, 'U', 0x0, 'S', 0x0, + //10: RFC3066 language code + ' ', 0x0, // 2: Space + 'S', 0x0, 'i', 0x0, 'm', 0x0, 'p', 0x0, 'l', 0x0, 'e', 0x0, + '1', 0x0, 'o', 0x0, 'n', 0x0, 'l', 0x0, 'y', 0x0, '\0', 0x0, + //24: DescriptionString + // + // Layout 2, length = 93 + // + 0x5d, 0x00, // 2: layout_length + 0x3e, 0x0b, 0xe6, 0x2a, 0xd6, 0xb9, 0xd8, 0x49, + 0x9a, 0x16, 0xc2, 0x48, 0xf1, 0xeb, 0xa8, 0xdb, //16: guid + 0x37, 0x00, 0x00, 0x00, // 4: layout_descriptor_ + // string_offset + 0x02, // 1 Descriptor count + // + // Descriptor 1, length = 16 + // + 51, 0x0, 0x0, 0x0, // 4: key (EfiKeyD3) + 'e', 0x00, // 2: unicode + 'E', 0x00, // 2: shifted_unicode + 0x00, 0x00, // 2: alt_gr_unicode + 0x00, 0x00, // 2: shifted_alt_gr_unicode + EFI_NULL_MODIFIER, 0x0, // 2: modifier + 0x3, 0x0, // 2: affected_attribute + // + // Descriptor 2, length = 16 + // + 52, 0x0, 0x0, 0x0, // 4: key (EfiKeyD4) + 'r', 0x00, // 2: unicode + 'R', 0x00, // 2: shifted_unicode + 0x00, 0x00, // 2: alt_gr_unicode + 0x00, 0x00, // 2: shifted_alt_gr_unicode + EFI_NULL_MODIFIER, 0x0, // 2: modifier + 0x3, 0x0, // 2: affected_attribute + // + // EFI_DESCRIPTOR_STRING_BUNDLE, length = 38 + // + 0x01, 0x00, // 2: DescriptionCount + 'e', 0x0, 'n', 0x0, '-', 0x0, 'U', 0x0, 'S', 0x0, + //10: RFC3066 language code + ' ', 0x0, // 2: Space + 'S', 0x0, 'i', 0x0, 'm', 0x0, 'p', 0x0, 'l', 0x0, 'e', 0x0, + '2', 0x0, 'o', 0x0, 'n', 0x0, 'l', 0x0, 'y', 0x0, '\0', 0x0, + //24: DescriptionString + // + // End of package list, length = 4 + // + 0x4, 0x00, 0x00, + EFI_HII_PACKAGE_END +}; + +u8 packagelist2[] = { + // EFI_HII_PACKAGE_LIST_HEADER, length = 20 + // SimpleFont, Font, GUID, KeyboardLayout, Form, End + // (74) (122) 20 192 (8) 4 + 0xd3, 0xde, 0x85, 0x86, 0xce, 0x1b, 0xf3, 0x43, + 0xa2, 0x0c, 0xa3, 0x06, 0xec, 0x69, 0x72, 0xdd, //16 + 0xec, 0x00, 0x00, 0x00, // 4: total 236(0xec) + +#ifdef NOT_USED /* TODO: simple font package not implemented yet */ + // + // Simple Font Package 2, length = 74 + // + 0x4A, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_SIMPLE_FONTS, // 1 + 1, 0, // 2 + 1, 0, // 2 + 0x33, 0x0, 0, 1, 2, 3, 4, 5, 0, 7, 8, 9, + 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, //22 + 0x44, 0x0, 0x2, 2, 3, 4, 5, 6, 0, 8, 9, + 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, //22 + 3, 4, 5, 6, 7, 8, 9, 10, 11, 9, 13, + 14, 15, 16, 17, 18, 19, 20, 21, 0, 0, 0, //22 + // + // Font Package 2, length = 122 + // + 0x7A, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_FONTS, // 1 + 0x5C, 0x00, 0x00, 0x00, // 4: size of header + 0x5C, 0x00, 0x00, 0x00, // 4: dummy offset + 0xf1, 0x00, 0xf2, 0x00, 0xf3, 0x00, 0xf4, 0x00, + 0xf5, 0x00, 0xec, 0xec, //10+2(pads) + 0xff, 0x11, 0xff, 0x22, // 4: font style + 0x99, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88, //64 + // + // Glyph block 1, length = 30 + // + EFI_HII_GIBT_GLYPH, // 1 + 0xf1, 0x00, 0xf2, 0x00, 0xf3, 0x00, 0xf4, 0x00, + 0xf5, 0x00, //10 + 0xff, 0x01, // 2 + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, //16: BitMapData + EFI_HII_GIBT_END, // 1 +#endif + // + // Guid Package 1, length = 20 + // + 0x14, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_TYPE_GUID, // 1 + 0x5a, 0xc9, 0x87, 0x03, 0x3, 0xd7, 0x46, 0x23, + 0xb2, 0xab, 0xd0, 0xc7, 0xdd, 0x90, 0x44, 0xf8, //16: guid + // + // Keyboard layout package 2, length = 192 + 0xc0, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_KEYBOARD_LAYOUT, // 1 + 0x02, 0x00, //0xec, 0xec, // 2: LayoutCount + // + // Layout 1, length = 93 + // + 0x5d, 0x00, // 2: layout_length + 0x1f, 0x6a, 0xf5, 0xe0, 0x6b, 0xdf, 0x7e, 0x4a, + 0xa3, 0x9a, 0xe7, 0xa5, 0x19, 0x15, 0x45, 0xd6,//16: guid + 0x37, 0x00, 0x00, 0x00, // 4: layout_descriptor + // string offset + 0x02, // 1: descriptor_count + // + // Descriptor 1, length = 16 + // + 32, 0x00, 0x00, 0x00, // 4: key (EfiKeyC1) + 'a', 0x00, // 2: unicode + 'A', 0x00, // 2: shifted_unicode + 0x00, 0x00, // 2: alt_gr_unicode + 0x00, 0x00, // 2: shifted_alt_gr_unic + EFI_NULL_MODIFIER, 0x00, // 2: modifier + 0x03, 0x00, // 2: affected_attribute + // + // Descriptor 2, length = 16 + // + 33 /*EfiKeyC2*/, 0x00, 0x00, 0x00, + 's', 0x00, + 'S', 0x00, + 0x00, 0x00, + 0x00, 0x00, + EFI_NULL_MODIFIER, 0x00, + 0x3, 0x0, + // + // EFI_DESCRIPTOR_STRING_BUNDLE, length = 38 + // + 0x01, 0x00, // 2: DescriptionCount + 'e', 0x0, 'n', 0x0, '-', 0x0, 'U', 0x0, 'S', 0x0, + //10: RFC3066 language code + ' ', 0x0, // 2: Space + 'S', 0x0, 'i', 0x0, 'm', 0x0, 'p', 0x0, 'l', 0x0, 'e', 0x0, + '3', 0x0, 'o', 0x0, 'n', 0x0, 'l', 0x0, 'y', 0x0, '\0', 0x0, + //24: DescriptionString + // + // Layout 2, length = 93 + // + 0x5d, 0x00, // 2: layout_length + 0xc9, 0x6a, 0xbe, 0x47, 0xcc, 0x54, 0xf9, 0x46, + 0xa2, 0x62, 0xd5, 0x3b, 0x25, 0x6a, 0xc, 0x34, //16: guid + 0x37, 0x00, 0x00, 0x00, // 4: layout_descriptor + // string_offset + 0x02, // 1: descriptor_count + // + // Descriptor 1, length = 16 + // + 34 /*EfiKeyC3*/, 0x0, 0x0, 0x0, + 'd', 0x00, + 'D', 0x00, + 0x00, 0x00, + 0x00, 0x00, + EFI_NULL_MODIFIER, 0x0, + 0x3, 0x0, + // + // Descriptor 2, length = 16 + // + 35 /*EfiKeyC4*/, 0x0, 0x0, 0x0, + 'e', 0x00, + 'E', 0x00, + 0x00, 0x00, + 0x00, 0x00, + EFI_NULL_MODIFIER, 0x0, + 0x3, 0x0, + // + // EFI_DESCRIPTOR_STRING_BUNDLE, length = 38 + // + 0x01, 0x00, // 2: DescriptionCount + 'e', 0x0, 'n', 0x0, '-', 0x0, 'U', 0x0, 'S', 0x0, + //10: RFC3066 language code + ' ', 0x0, // 2: Space + 'S', 0x0, 'i', 0x0, 'm', 0x0, 'p', 0x0, 'l', 0x0, 'e', 0x0, + '4', 0x0, 'o', 0x0, 'n', 0x0, 'l', 0x0, 'y', 0x0, '\0', 0x0, + //24: DescriptionString +#ifdef NOT_USED /* TODO: form package not implemented yet */ + // + // EFI_HII_PACKAGE_FORMS, length = 8 + // + 0x08, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_FORMS, // 1 + // + // Opcode 1 + // + EFI_IFR_BITWISE_AND_OP, // 1 + 0x02, // 1 + EFI_IFR_END_OP, // 1 + 0x02, // 1 +#endif + // + // End of package list, length = 4 + // + 0x4, 0x00, 0x00, // 3 + EFI_HII_PACKAGE_END // 1 +}; + +efi_guid_t packagelist_guid1 = + EFI_GUID(0x03abcd89, 0x03f4, 0x7044, + 0x81, 0xde, 0x99, 0xb1, 0x81, 0x20, 0xf7, 0x68); + +efi_guid_t packagelist_guid2 = + EFI_GUID(0x8685ded3, 0x1bce, 0x43f3, + 0xa2, 0x0c, 0xa3, 0x06, 0xec, 0x69, 0x72, 0xdd); + +efi_guid_t kb_layout_guid11 = + EFI_GUID(0x8d40e495, 0xe2aa, 0x4c6f, + 0x89, 0x70, 0x68, 0x85, 0x09, 0xee, 0xc7, 0xd2); + +efi_guid_t kb_layout_guid12 = + EFI_GUID(0x2ae60b3e, 0xb9d6, 0x49d8, + 0x9a, 0x16, 0xc2, 0x48, 0xf1, 0xeb, 0xa8, 0xdb); + +efi_guid_t kb_layout_guid21 = + EFI_GUID(0xe0f56a1f, 0xdf6b, 0x4a7e, + 0xa3, 0x9a, 0xe7, 0xa5, 0x19, 0x15, 0x45, 0xd6); + +efi_guid_t kb_layout_guid22 = + EFI_GUID(0x47be6ac9, 0x54cc, 0x46f9, + 0xa2, 0x62, 0xd5, 0x3b, 0x25, 0x6a, 0x0c, 0x34); + +efi_guid_t package_guid = + EFI_GUID(0x0387c95a, 0xd703, 0x2346, + 0xb2, 0xab, 0xd0, 0xc7, 0xdd, 0x90, 0x44, 0xf8);
On 21.01.19 04:12, AKASHI Takahiro wrote:
HII database protocol is the last missing (major?) piece of code so that we can run unmodified EDKII's shell and UEFI SCT on EFI-enabled u-boot.
The original code was initially written by Leif and Rob a year ago[1], and now I'm reworking it. The implementation has not been much enhanced from the original, but I tried to give it clearer implementation to be able to add more functionality easily later on. I also addressed the comments by Alex[2] and added a self test on request of Heinrich.
HII configuration routing protocol and access protocol have only a skeleton and should be implemented when we need to have *drivers* that require configuration mechanism.
Reviewed-by: Alexander Graf agraf@suse.de
But I'll wait for Heinrich's ok as well :)
Alex
Alex
I have seen that Takahiro has integrated my recent suggestions.
Currently I am still trying to understand what is wrong with GetNextVariableName().
So let's go with your review.
Best regards
Heinrich
Heinrich,
Alex
Thank you for finding and investigating this issue. I almost all of my time test my patches on arm64 primarily :)
-Takahiro Akashi
Best regards
Heinrich
Am 23.01.2019 um 06:11 schrieb AKASHI Takahiro takahiro.akashi@linaro.org:
Heinrich,
On 21.01.19 04:12, AKASHI Takahiro wrote: HII database protocol is the last missing (major?) piece of code so that we can run unmodified EDKII's shell and UEFI SCT on EFI-enabled u-boot.
Alex
Please always push your patch queues as braches to github and enable travis there. It will tell you quite conclusive test results, so that you don't break others targets by accident :).
Alex
-Takahiro Akashi
Best regards
Heinrich
AKASHI Takahiro
Alexander Graf
