[U-Boot] [PATCH] YAFFS2: Fix compiler errors preventing successful build
These warnings still persist:
yaffs_guts.c: In function ‘yaffs_check_chunk_erased’: yaffs_guts.c:324:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function ‘yaffs_verify_chunk_written’: yaffs_guts.c:352:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function ‘yaffs_grab_chunk_cache’: yaffs_guts.c:1488:6: warning: variable ‘pushout’ set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function ‘yaffs_check_obj_details_loaded’: yaffs_guts.c:3180:6: warning: variable ‘alloc_failed’ set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function ‘yaffs_update_oh’: yaffs_guts.c:3288:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function ‘yaffs_get_obj_name’: yaffs_guts.c:4447:7: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function ‘yaffs_summary_read’: yaffs_summary.c:194:6: warning: variable ‘sum_tags_bytes’ set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function ‘yaffs_verify_file’: yaffs_verify.c:227:6: warning: variable ‘actual_depth’ set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function ‘yaffs1_scan’: yaffs_yaffs1.c:26:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function ‘yaffs2_scan_chunk’: yaffs_yaffs2.c:949:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function ‘yaffs2_scan_backwards’: yaffs_yaffs2.c:1352:6: warning: variable ‘deleted’ set but not used [-Wunused-but-set-variable] yaffs_mtdif2.c: In function ‘nandmtd2_write_chunk_tags’: yaffs_mtdif2.c:51:5: warning: unused variable ‘local_spare’ [-Wunused-variable]
Signed-off-by: Marek Vasut marex@denx.de Cc: Charles Manning cdhmanning@gmail.com Cc: Wolfgang Denk wd@denx.de --- fs/yaffs2/ydirectenv.h | 13 ++++--------- 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/fs/yaffs2/ydirectenv.h b/fs/yaffs2/ydirectenv.h index df0b8fb..85538ad 100644 --- a/fs/yaffs2/ydirectenv.h +++ b/fs/yaffs2/ydirectenv.h @@ -26,10 +26,12 @@ #include "yaffs_osglue.h" #include "yaffs_hweight.h"
-void yaffs_bug_fn(const char *file_name, int line_no); +#include <malloc.h> +#include <linux/compat.h>
-#define BUG() do { yaffs_bug_fn(__FILE__, __LINE__); } while (0) +void yaffs_bug_fn(const char *file_name, int line_no);
+#define GFP_NOFS 1
#define YCHAR char #define YUCHAR unsigned char @@ -47,8 +49,6 @@ void yaffs_bug_fn(const char *file_name, int line_no); #define yaffs_strncmp(a, b, c) strncmp(a, b, c) #endif
-#define hweight8(x) yaffs_hweight8(x) -#define hweight32(x) yaffs_hweight32(x)
void yaffs_qsort(void *aa, size_t n, size_t es, int (*cmp)(const void *, const void *)); @@ -63,11 +63,6 @@ void yaffs_qsort(void *aa, size_t n, size_t es, #define inline __inline__ #endif
-#define kmalloc(x, flags) yaffsfs_malloc(x) -#define kfree(x) yaffsfs_free(x) -#define vmalloc(x) yaffsfs_malloc(x) -#define vfree(x) yaffsfs_free(x) - #define cond_resched() do {} while (0)
#define yaffs_trace(msk, fmt, ...) do { \
While I appreciate this, I would prefer the use the patch I submitted today which also gets rid of the yaffs hweight code too.
-- CHarles
Dear Charles Manning,
Thanks Charles ... I'll review it in a bit.
-- CHarles
Best regards, Marek Vasut
Charles Manning
