[U-Boot-Users] [PATCH] JFFS2 command support on OneNAND
JFFS2 command support on OneNAND Next time it will be more optimized and clean-up.
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/common/cmd_jffs2.c b/common/cmd_jffs2.c index 1b67e73..959306f 100644 --- a/common/cmd_jffs2.c +++ b/common/cmd_jffs2.c @@ -51,7 +51,7 @@ * mtdids=<idmap>[,<idmap>,...] * * <idmap> := <dev-id>=<mtd-id> - * <dev-id> := 'nand'|'nor'<dev-num> + * <dev-id> := 'nand'|'nor'|'onenand'<dev-num> * <dev-num> := mtd device number, 0... * <mtd-id> := unique device tag used by linux kernel to find mtd device (mtd->name) * @@ -103,6 +103,13 @@ #include <nand.h> #endif /* !CFG_NAND_LEGACY */ #endif + +#if defined(CONFIG_CMD_ONENAND) +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <onenand_uboot.h> +#endif + /* enable/disable debugging messages */ #define DEBUG_JFFS #undef DEBUG_JFFS @@ -401,6 +408,43 @@ static int part_validate_nand(struct mtdids *id, struct part_info *part) }
/** + * Performs sanity check for supplied OneNAND flash partition. + * Table of existing OneNAND flash devices is searched and partition device + * is located. Alignment with the granularity of nand erasesize is verified. + * + * @param id of the parent device + * @param part partition to validate + * @return 0 if partition is valid, 1 otherwise + */ +static int part_validate_onenand(struct mtdids *id, struct part_info *part) +{ +#if defined(CONFIG_CMD_ONENAND) + /* info for OneNAND chips */ + struct mtd_info *mtd; + + mtd = &onenand_mtd; + + if ((unsigned long)(part->offset) % mtd->erasesize) { + printf("%s%d: partition (%s) start offset" + "alignment incorrect\n", + MTD_DEV_TYPE(id->type), id->num, part->name); + return 1; + } + + if (part->size % mtd->erasesize) { + printf("%s%d: partition (%s) size alignment incorrect\n", + MTD_DEV_TYPE(id->type), id->num, part->name); + return 1; + } + + return 0; +#else + return 1; +#endif +} + + +/** * Performs sanity check for supplied partition. Offset and size are verified * to be within valid range. Partition type is checked and either * parts_validate_nor() or parts_validate_nand() is called with the argument @@ -436,6 +480,8 @@ static int part_validate(struct mtdids *id, struct part_info *part) return part_validate_nand(id, part); else if (id->type == MTD_DEV_TYPE_NOR) return part_validate_nor(id, part); + else if (id->type == MTD_DEV_TYPE_ONENAND) + return part_validate_onenand(id, part); else DEBUGF("part_validate: invalid dev type\n");
@@ -755,7 +801,15 @@ static int device_validate(u8 type, u8 num, u32 *size) #else printf("support for NAND devices not present\n"); #endif - } + } else if (type == MTD_DEV_TYPE_ONENAND) { +#if defined(CONFIG_CMD_ONENAND) + *size = onenand_mtd.size; + return 0; +#else + printf("support for OneNAND devices not present\n"); +#endif + } else + printf("Unknown defice type %d\n", type);
return 1; } @@ -1065,8 +1119,8 @@ static struct mtdids* id_find_by_mtd_id(const char *mtd_id, unsigned int mtd_id_ #endif /* #ifdef CONFIG_JFFS2_CMDLINE */
/** - * Parse device id string <dev-id> := 'nand'|'nor'<dev-num>, return device - * type and number. + * Parse device id string <dev-id> := 'nand'|'nor'|'onenand'<dev-num>, + * return device type and number. * * @param id string describing device id * @param ret_id output pointer to next char after parse completes (output) @@ -1085,6 +1139,9 @@ int id_parse(const char *id, const char **ret_id, u8 *dev_type, u8 *dev_num) } else if (strncmp(p, "nor", 3) == 0) { *dev_type = MTD_DEV_TYPE_NOR; p += 3; + } else if (strncmp(p, "onenand", 7) == 0) { + *dev_type = MTD_DEV_TYPE_ONENAND; + p += 7; } else { printf("incorrect device type in %s\n", id); return 1; @@ -1489,7 +1546,7 @@ static int parse_mtdids(const char *const ids) while(p && (*p != '\0')) {
ret = 1; - /* parse 'nor'|'nand'<dev-num> */ + /* parse 'nor'|'nand'|'onenand'<dev-num> */ if (id_parse(p, &p, &type, &num) != 0) break;
diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index d1423c1..88b8f64 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -271,6 +271,107 @@ static void put_fl_mem_nand(void *buf) } #endif
+#if defined(CONFIG_CMD_ONENAND) + +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <onenand_uboot.h> + +#define ONENAND_PAGE_SIZE 2048 +#define ONENAND_PAGE_SHIFT 11 +#define ONENAND_PAGE_MASK (~(ONENAND_PAGE_SIZE-1)) + +#ifndef ONENAND_CACHE_PAGES +#define ONENAND_CACHE_PAGES 4 +#endif +#define ONENAND_CACHE_SIZE (ONENAND_CACHE_PAGES*ONENAND_PAGE_SIZE) + +static u8* onenand_cache; +static u32 onenand_cache_off = (u32)-1; + +static int read_onenand_cached(u32 off, u32 size, u_char *buf) +{ + u32 bytes_read = 0; + size_t retlen; + int cpy_bytes; + + while (bytes_read < size) { + if ((off + bytes_read < onenand_cache_off) || + (off + bytes_read >= onenand_cache_off + ONENAND_CACHE_SIZE)) { + onenand_cache_off = (off + bytes_read) & ONENAND_PAGE_MASK; + if (!onenand_cache) { + /* This memory never gets freed but 'cause + it's a bootloader, nobody cares */ + onenand_cache = malloc(ONENAND_CACHE_SIZE); + if (!onenand_cache) { + printf("read_onenand_cached: can't alloc cache size %d bytes\n", + ONENAND_CACHE_SIZE); + return -1; + } + } + + retlen = ONENAND_CACHE_SIZE; + if (onenand_read(&onenand_mtd, onenand_cache_off, retlen, + &retlen, onenand_cache) != 0 || + retlen != ONENAND_CACHE_SIZE) { + printf("read_onenand_cached: error reading nand off %#x size %d bytes\n", + onenand_cache_off, ONENAND_CACHE_SIZE); + return -1; + } + } + cpy_bytes = onenand_cache_off + ONENAND_CACHE_SIZE - (off + bytes_read); + if (cpy_bytes > size - bytes_read) + cpy_bytes = size - bytes_read; + memcpy(buf + bytes_read, + onenand_cache + off + bytes_read - onenand_cache_off, + cpy_bytes); + bytes_read += cpy_bytes; + } + return bytes_read; +} + +static void *get_fl_mem_onenand(u32 off, u32 size, void *ext_buf) +{ + u_char *buf = ext_buf ? (u_char *)ext_buf : (u_char *)malloc(size); + + if (NULL == buf) { + printf("get_fl_mem_onenand: can't alloc %d bytes\n", size); + return NULL; + } + if (read_onenand_cached(off, size, buf) < 0) { + if (!ext_buf) + free(buf); + return NULL; + } + + return buf; +} + +static void *get_node_mem_onenand(u32 off) +{ + struct jffs2_unknown_node node; + void *ret = NULL; + + if (NULL == get_fl_mem_onenand(off, sizeof(node), &node)) + return NULL; + + ret = get_fl_mem_onenand(off, node.magic == + JFFS2_MAGIC_BITMASK ? node.totlen : sizeof(node), + NULL); + if (!ret) { + printf("off = %#x magic %#x type %#x node.totlen = %d\n", + off, node.magic, node.nodetype, node.totlen); + } + return ret; +} + + +static void put_fl_mem_onenand(void *buf) +{ + free(buf); +} +#endif +
#if defined(CONFIG_CMD_FLASH) /* @@ -316,6 +417,11 @@ static inline void *get_fl_mem(u32 off, u32 size, void *ext_buf) return get_fl_mem_nand(off, size, ext_buf); #endif
+#if defined(CONFIG_CMD_ONENAND) + if (id->type == MTD_DEV_TYPE_ONENAND) + return get_fl_mem_onenand(off, size, ext_buf); +#endif + printf("get_fl_mem: unknown device type, using raw offset!\n"); return (void*)off; } @@ -335,6 +441,11 @@ static inline void *get_node_mem(u32 off) return get_node_mem_nand(off); #endif
+#if defined(CONFIG_CMD_ONENAND) + if (id->type == MTD_DEV_TYPE_ONENAND) + return get_node_mem_onenand(off); +#endif + printf("get_node_mem: unknown device type, using raw offset!\n"); return (void*)off; } @@ -348,6 +459,13 @@ static inline void put_fl_mem(void *buf) if (id->type == MTD_DEV_TYPE_NAND) return put_fl_mem_nand(buf); #endif + +#if defined(CONFIG_CMD_ONENAND) + struct mtdids *id = current_part->dev->id; + + if (id->type == MTD_DEV_TYPE_ONENAND) + return put_fl_mem_onenand(buf); +#endif }
/* Compression names */ diff --git a/include/jffs2/load_kernel.h b/include/jffs2/load_kernel.h index 882a80e..b46eca3 100644 --- a/include/jffs2/load_kernel.h +++ b/include/jffs2/load_kernel.h @@ -28,9 +28,14 @@ #include <linux/list.h>
/* mtd device types */ -#define MTD_DEV_TYPE_NOR 0x0001 -#define MTD_DEV_TYPE_NAND 0x0002 -#define MTD_DEV_TYPE(type) ((type == MTD_DEV_TYPE_NAND) ? "nand" : "nor") +enum { + MTD_DEV_TYPE_NOR, + MTD_DEV_TYPE_NAND, + MTD_DEV_TYPE_ONENAND, +}; + +#define MTD_DEV_TYPE(type) ((type == MTD_DEV_TYPE_NAND) ? "nand" : \ + (type == MTD_DEV_TYPE_ONENAND) ? "onenand" : "nor")
struct mtd_device { struct list_head link; diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 4b0c2df..5bc905e 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -17,6 +17,7 @@ /* Note: The header order is impoertant */ #include <onenand_uboot.h>
+#include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
#define MAX_BUFFERRAM 2 diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index 4449f98..24ace2a 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -27,6 +27,8 @@ typedef int wait_queue_head_t; struct mtd_info; struct erase_info;
+extern struct mtd_info onenand_mtd; + /* Functions */ extern void onenand_init(void); extern int onenand_read(struct mtd_info *mtd, loff_t from, size_t len,
- /* info for OneNAND chips */
- struct mtd_info *mtd;
- mtd = &onenand_mtd;
- if ((unsigned long)(part->offset) % mtd->erasesize) {
return 1;
- if (part->size % mtd->erasesize) {
return 1;
+#else
- return 1;
+#endif +}
This looks like a duplicate of part_validate_nand (note that nand_info_t is just an obfuscatory alias of struct mtd_info).
- u32 bytes_read = 0;
- size_t retlen;
- int cpy_bytes;
- while (bytes_read < size) {
return -1;
return -1;
cpy_bytes);
- return bytes_read;
I really would rather not duplicate all of this, which looks extremely similar to regular NAND. Is there reason why we don't use the mtd_info function pointer interface?
-Scott
mtd = &onenand_mtd;
return 1;
return 1;
+#else
return 1;
+#endif +}
u32 bytes_read = 0;
size_t retlen;
int cpy_bytes;
return -1;
return -1;
cpy_bytes);
return bytes_read;
Agreed, It's almost same as NAND code. Now nand code uses two modes, legacy and mtd. Because I don't want to break the NAND code , I used the duplicated code. Basically it should be used the common mtd style code except legacy.
So first it added the current code, next time it tries to use the common interface and some code clean up.
Thank you, Kyungmin Park
In message 9c9fda240807111847i73d45e97had293c5aba98180a@mail.gmail.com you wrote:
I understand that you will submit a cleaned up patch later?
As it is right now, you can't have jffs2 command support on both NAND and OneNAND. Dunno if you could have this case (both NAND and OneNAND enabled) but it will fail to build: In file included from /u-boot-1.3.3/include/linux/mtd/onenand.h:21,
from jffs2_1pass.c:279:
/u-boot-1.3.3/include/linux/mtd/bbm.h:49: error: redefinition of 'struct nand_bbt_descr' In file included from jffs2_1pass.c:279:
/u-boot-1.3.3/include/linux/mtd/onenand.h:36: error: redeclaration of enumerator 'FL_READY' /u-boot-1.3.3/include/linux/mtd/nand.h:212: error: previous definition of 'FL_READY' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:37: error: redeclaration of enumerator 'FL_READING' /u-boot-1.3.3/include/linux/mtd/nand.h:213: error: previous definition of 'FL_READING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:38: error: redeclaration of enumerator 'FL_WRITING' /u-boot-1.3.3/include/linux/mtd/nand.h:214: error: previous definition of 'FL_WRITING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:39: error: redeclaration of enumerator 'FL_ERASING' /u-boot-1.3.3/include/linux/mtd/nand.h:215: error: previous definition of 'FL_ERASING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:40: error: redeclaration of enumerator 'FL_SYNCING' /u-boot-1.3.3/include/linux/mtd/nand.h:216: error: previous definition of 'FL_SYNCING' was here jffs2_1pass.c: In function 'put_fl_mem':
jffs2_1pass.c:466: error: redefinition of 'id'
jffs2_1pass.c:459: error: previous definition of 'id' was here
make[1]: *** [jffs2_1pass.o] Error 1
cheers,
Fathi
As it is right now, you can't have jffs2 command support on both NAND and OneNAND. Dunno if you could have this case (both NAND and OneNAND enabled) but it will fail to build: In file included from /u-boot-1.3.3/include/linux/mtd/onenand.h:21, from jffs2_1pass.c:279: /u-boot-1.3.3/include/linux/mtd/bbm.h:49: error: redefinition of 'struct nand_bbt_descr' In file included from jffs2_1pass.c:279: /u-boot-1.3.3/include/linux/mtd/onenand.h:36: error: redeclaration of enumerator 'FL_READY' /u-boot-1.3.3/include/linux/mtd/nand.h:212: error: previous definition of 'FL_READY' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:37: error: redeclaration of enumerator 'FL_READING' /u-boot-1.3.3/include/linux/mtd/nand.h:213: error: previous definition of 'FL_READING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:38: error: redeclaration of enumerator 'FL_WRITING' /u-boot-1.3.3/include/linux/mtd/nand.h:214: error: previous definition of 'FL_WRITING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:39: error: redeclaration of enumerator 'FL_ERASING' /u-boot-1.3.3/include/linux/mtd/nand.h:215: error: previous definition of 'FL_ERASING' was here /u-boot-1.3.3/include/linux/mtd/onenand.h:40: error: redeclaration of enumerator 'FL_SYNCING' /u-boot-1.3.3/include/linux/mtd/nand.h:216: error: previous definition of 'FL_SYNCING' was here jffs2_1pass.c: In function 'put_fl_mem': jffs2_1pass.c:466: error: redefinition of 'id' jffs2_1pass.c:459: error: previous definition of 'id' was here make[1]: *** [jffs2_1pass.o] Error 1
Yes, you're right. it's complicit. However it's not related with this patch. It happens always at current source. Next time it will fix it.
Fathi Boudra
Kyungmin Park
Scott Wood
