[U-Boot] [PATCH 1/2] davinci: da850evm: Make EEPROM MAC code configurable
There was a check for CONFIG_MAC_ADDR_IN_EEPROM and a check for CONFIG_MAC_ADDR_IN_SPIFLASH, however some of the EEPROM related code wasn't encapsulated inside the #if defined statement so the EEPROM code could get executed even when it wasn't explicitly enabled or wanted.
Signed-off-by: Adam Ford aford173@gmail.com --- board/davinci/da8xxevm/da850evm.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index c2d2e8e..516d86d 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -133,6 +133,8 @@ int misc_init_r(void)
enetaddr_found = eth_env_get_enetaddr("ethaddr", env_enetaddr);
+#endif + #ifdef CONFIG_MAC_ADDR_IN_SPIFLASH int spi_mac_read; uchar buff[6]; @@ -167,7 +169,8 @@ int misc_init_r(void) "with the MAC address in the environment\n"); printf("Default using MAC address from environment\n"); } -#endif + +#elif defined(CONFIG_MAC_ADDR_IN_EEPROM) uint8_t enetaddr[8]; int eeprom_mac_read;
This converts the following to Kconfig: CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_ADDR_IN_EEPROM
Signed-off-by: Adam Ford aford173@gmail.com --- board/davinci/da8xxevm/Kconfig | 24 ++++++++++++++++++++++++ configs/da850_am18xxevm_defconfig | 3 ++- configs/da850evm_defconfig | 1 - configs/da850evm_direct_nor_defconfig | 2 +- scripts/config_whitelist.txt | 2 -- 5 files changed, 27 insertions(+), 5 deletions(-)
diff --git a/board/davinci/da8xxevm/Kconfig b/board/davinci/da8xxevm/Kconfig index 0935abf..6e51ce4 100644 --- a/board/davinci/da8xxevm/Kconfig +++ b/board/davinci/da8xxevm/Kconfig @@ -9,6 +9,30 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "da850evm"
+menuconfig DA850_MAC + bool "Use MAC Address" + default y + +if DA850_MAC +config MAC_ADDR_IN_SPIFLASH + bool "MAC address in SPI Flash" + default y + help + The OMAP-L138 and AM1808 SoM are programmed with + their MAC address in SPI Flash from the factory + Enable this option to read the MAC from SPI Flash + +config MAC_ADDR_IN_EEPROM + bool "MAC address in EEPROM" + help + The DA850 EVM comes with SoM are programmed with + their MAC address in SPI Flash from the factory, + but the kit has an optional expansion board with + EEPROM available. Enable this option to read the + MAC from the EEPROM + +endif + endif
if TARGET_OMAPL138_LCDK diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index cb3726d..ad9c66c 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -1,12 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y +CONFIG_MAC_ADDR_IN_EEPROM=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" +CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="mem=32M console=ttyS2,115200n8 root=/dev/mtdblock2 rw noinitrd ip=dhcp" diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index ac54235..3193bbd 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="mem=32M console=ttyS2,115200n8 root=/dev/mtdblock2 rw noinitrd ip=dhcp" diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 9c1ae37..ec31e7c 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y -CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="mem=32M console=ttyS2,115200n8 root=/dev/mtdblock2 rw noinitrd ip=dhcp" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9ce0c3f..5dc69ea 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1360,8 +1360,6 @@ CONFIG_MACH_SPECIFIC CONFIG_MACH_TYPE CONFIG_MACH_TYPE_COMPAT_REV CONFIG_MACRESET_TIMEOUT -CONFIG_MAC_ADDR_IN_EEPROM -CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MALLOC_F_ADDR CONFIG_MALTA CONFIG_MARCO_MEMSET
Adam Ford
