[U-Boot] [PATCH 1/4] ARM926EJS: Implement cache operations
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/cache.c | 66 ++++++++++++++++++++++++++++++++------- 1 files changed, 54 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 504f604..5b23e3a 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -23,29 +23,71 @@ #include <common.h>
#ifndef CONFIG_SYS_DCACHE_OFF -static inline void dcache_noop(void) + +#ifndef CONFIG_SYS_CACHELINE_SIZE +#define CONFIG_SYS_CACHELINE_SIZE 32 +#endif + +void invalidate_dcache_all(void) { - if (dcache_status()) { - puts("WARNING: cache operations are not implemented!\n" - "WARNING: disabling D-Cache now, you can re-enable it" - "later with 'dcache on' command\n"); - dcache_disable(); - } + asm volatile("mcr p15, 0, %0, c7, c6, 0\n"::"r"(0)); }
-void invalidate_dcache_all(void) +void flush_dcache_all(void) { - dcache_noop(); + asm volatile( + "0:" + "mrc p15, 0, r15, c7, c14, 3\n" + "bne 0b\n" + "mcr p15, 0, %0, c7, c10, 4\n" + ::"r"(0):"memory" + ); +} + +static int check_cache_range(unsigned long start, unsigned long stop) +{ + int ok = 1; + + if (start & (CONFIG_SYS_CACHELINE_SIZE - 1)) + ok = 0; + + if (stop & (CONFIG_SYS_CACHELINE_SIZE - 1)) + ok = 0; + + if (!ok) + printf("CACHE: Misaligned operation at range [%08lx, %08lx]\n", + start, stop); + + return ok; }
void invalidate_dcache_range(unsigned long start, unsigned long stop) { - dcache_noop(); + if (!check_cache_range(start, stop)) + return; + + while (start < stop) { + asm volatile("mcr p15, 0, %0, c7, c6, 1\n"::"r"(start)); + start += CONFIG_SYS_CACHELINE_SIZE; + } }
void flush_dcache_range(unsigned long start, unsigned long stop) { - dcache_noop(); + if (!check_cache_range(start, stop)) + return; + + while (start < stop) { + asm volatile("mcr p15, 0, %0, c7, c14, 1\n"::"r"(start)); + start += CONFIG_SYS_CACHELINE_SIZE; + } + + asm("mcr p15, 0, %0, c7, c10, 4\n"::"r"(0)); +} + +void flush_cache(unsigned long start, unsigned long size) +{ + flush_dcache_range(start, start + size); } #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) @@ -64,7 +106,7 @@ void flush_dcache_range(unsigned long start, unsigned long stop) { }
-void flush_cache(unsigned long start, unsigned long size) +void flush_cache(unsigned long start, unsigned long size) { } #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mx28/mx28.c | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 9bfd83b..cf6d4e9 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -63,6 +63,16 @@ void reset_cpu(ulong ignored) ; }
+void enable_caches(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF + icache_enable(); +#endif +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} + int mx28_wait_mask_set(struct mx28_register_32 *reg, uint32_t mask, int timeout) { while (--timeout) {
The desc_append() now flushes descriptors into RAM.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- drivers/dma/apbh_dma.c | 23 ++++++++++++++++++++++- 1 files changed, 22 insertions(+), 1 deletions(-)
diff --git a/drivers/dma/apbh_dma.c b/drivers/dma/apbh_dma.c index e85f5fe..c086629 100644 --- a/drivers/dma/apbh_dma.c +++ b/drivers/dma/apbh_dma.c @@ -93,6 +93,21 @@ static int mxs_dma_read_semaphore(int channel) return tmp; }
+#ifndef CONFIG_SYS_DCACHE_OFF +void mxs_dma_flush_desc(struct mxs_dma_desc *desc) +{ + uint32_t addr; + uint32_t size; + + addr = (uint32_t)desc; + size = roundup(sizeof(struct mxs_dma_desc), MXS_DMA_ALIGNMENT); + + flush_dcache_range(addr, addr + size); +} +#else +inline void mxs_dma_flush_desc(struct mxs_dma_desc *desc) {} +#endif + /* * Enable a DMA channel. * @@ -329,8 +344,10 @@ static int mxs_dma_release(int channel) struct mxs_dma_desc *mxs_dma_desc_alloc(void) { struct mxs_dma_desc *pdesc; + uint32_t size;
- pdesc = memalign(MXS_DMA_ALIGNMENT, sizeof(struct mxs_dma_desc)); + size = roundup(sizeof(struct mxs_dma_desc), MXS_DMA_ALIGNMENT); + pdesc = memalign(MXS_DMA_ALIGNMENT, size);
if (pdesc == NULL) return NULL; @@ -415,12 +432,16 @@ int mxs_dma_desc_append(int channel, struct mxs_dma_desc *pdesc)
last->cmd.next = mxs_dma_cmd_address(pdesc); last->cmd.data |= MXS_DMA_DESC_CHAIN; + + mxs_dma_flush_desc(last); } pdesc->flags |= MXS_DMA_DESC_READY; if (pdesc->flags & MXS_DMA_DESC_FIRST) pchan->pending_num++; list_add_tail(&pdesc->node, &pchan->active);
+ mxs_dma_flush_desc(pdesc); + return ret; }
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- drivers/mtd/nand/mxs_nand.c | 53 ++++++++++++++++++++++++++++++++++++++++-- 1 files changed, 50 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index ce2a326..4b1297a 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -50,6 +50,7 @@ struct mxs_nand_info { int cur_chip;
uint32_t cmd_queue_len; + uint32_t data_buf_size;
uint8_t *cmd_buf; uint8_t *data_buf; @@ -73,6 +74,36 @@ struct mxs_nand_info {
struct nand_ecclayout fake_ecc_layout;
+/* + * Cache management functions + */ +#ifndef CONFIG_SYS_DCACHE_OFF +static void mxs_nand_flush_data_buf(struct mxs_nand_info *info) +{ + uint32_t addr = (uint32_t)info->data_buf; + + flush_dcache_range(addr, addr + info->data_buf_size); +} + +static void mxs_nand_inval_data_buf(struct mxs_nand_info *info) +{ + uint32_t addr = (uint32_t)info->data_buf; + + invalidate_dcache_range(addr, addr + info->data_buf_size); +} + +static void mxs_nand_flush_cmd_buf(struct mxs_nand_info *info) +{ + uint32_t addr = (uint32_t)info->cmd_buf; + + flush_dcache_range(addr, addr + MXS_NAND_COMMAND_BUFFER_SIZE); +} +#else +static inline void mxs_nand_flush_data_buf(struct mxs_nand_info *info) {} +static inline void mxs_nand_inval_data_buf(struct mxs_nand_info *info) {} +static inline void mxs_nand_flush_cmd_buf(struct mxs_nand_info *info) {} +#endif + static struct mxs_dma_desc *mxs_nand_get_dma_desc(struct mxs_nand_info *info) { struct mxs_dma_desc *desc; @@ -286,6 +317,9 @@ static void mxs_nand_cmd_ctrl(struct mtd_info *mtd, int data, unsigned int ctrl)
mxs_dma_desc_append(channel, d);
+ /* Flush caches */ + mxs_nand_flush_cmd_buf(nand_info); + /* Execute the DMA chain. */ ret = mxs_dma_go(channel); if (ret) @@ -435,6 +469,9 @@ static void mxs_nand_read_buf(struct mtd_info *mtd, uint8_t *buf, int length) goto rtn; }
+ /* Invalidate caches */ + mxs_nand_inval_data_buf(nand_info); + memcpy(buf, nand_info->data_buf, length);
rtn: @@ -484,6 +521,9 @@ static void mxs_nand_write_buf(struct mtd_info *mtd, const uint8_t *buf,
+ /* Flush caches */ + mxs_nand_flush_data_buf(nand_info); + /* Execute the DMA chain. */ ret = mxs_dma_go(channel); if (ret) @@ -600,6 +640,9 @@ static int mxs_nand_ecc_read_page(struct mtd_info *mtd, struct nand_chip *nand, goto rtn; }
+ /* Invalidate caches */ + mxs_nand_inval_data_buf(nand_info); + /* Read DMA completed, now do the mark swapping. */ mxs_nand_swap_block_mark(mtd, nand_info->data_buf, nand_info->oob_buf);
@@ -687,6 +730,9 @@ static void mxs_nand_ecc_write_page(struct mtd_info *mtd,
+ /* Flush caches */ + mxs_nand_flush_data_buf(nand_info); + /* Execute the DMA chain. */ ret = mxs_dma_go(channel); if (ret) { @@ -978,18 +1024,19 @@ int mxs_nand_alloc_buffers(struct mxs_nand_info *nand_info) uint8_t *buf; const int size = NAND_MAX_PAGESIZE + NAND_MAX_OOBSIZE;
+ nand_info->data_buf_size = roundup(size, MXS_DMA_ALIGNMENT); + /* DMA buffers */ - buf = memalign(MXS_DMA_ALIGNMENT, size); + buf = memalign(MXS_DMA_ALIGNMENT, nand_info->data_buf_size); if (!buf) { printf("MXS NAND: Error allocating DMA buffers\n"); return -ENOMEM; }
- memset(buf, 0, size); + memset(buf, 0, nand_info->data_buf_size);
nand_info->data_buf = buf; nand_info->oob_buf = buf + NAND_MAX_PAGESIZE; - /* Command buffers */ nand_info->cmd_buf = memalign(MXS_DMA_ALIGNMENT, MXS_NAND_COMMAND_BUFFER_SIZE);
Dear Stefano Babic,
Can you pick this series?
Best regards, Marek Vasut
