[PATCH] poplar: add myself as co-maintainer
Add myself as co-maintainer for Poplar board, as I'm currently working on it (re-testing releases, addressing issues etc).
CC: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com CC: Shawn Guo shawn.guo@linaro.org Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io ---
board/hisilicon/poplar/MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/hisilicon/poplar/MAINTAINERS b/board/hisilicon/poplar/MAINTAINERS index bfd4a9be66b..01efc96b0d3 100644 --- a/board/hisilicon/poplar/MAINTAINERS +++ b/board/hisilicon/poplar/MAINTAINERS @@ -1,6 +1,7 @@ Poplar BOARD M: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com M: Shawn Guo shawn.guo@linaro.org +M: Igor Opaniuk igor.opaniuk@gmail.com S: Maintained F: board/hisilicon/poplar F: doc/board/hisilicon/poplar.rst
Acked-by: Shawn Guo shawn.guo@linaro.org
I'm not actively working on poplar any more, so maybe remove me in the meantime.
Shawn
hi Igor,
Yes please go ahead and thanks for offering.
I'll sync with you later next week (I found my Poplar in storage, so maybe we cam improve things a little) Also it would be good if we knew there are still users.
Acked-by: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com
Shawn
hi Igor,
Hi, everyone. I'm working on a set-top box with a Hi3798MV200 SoC. It is very similar to the Hi3798CV200 SoC and many peripherals and drivers can be reused. I think you can try moving arch/arm/include/asm/arch-hi3798cv200 to arch/arm/mach-histb and let's maintain all HiSTB series SoCs/boards under it altogether? The same thing also applies to TF-A. Currently upstream code refers to poplar everywhere but actually the port is portable enough to handle a lot of other Hi3798-series SoCs such as Hi3798MV2x, Hi3798MV3x etc..
Shawn
hi Igor,
There are some patches i sent pending for review. They are mostly originally sent just for Hi3798MV200, but the framework(such as drivers/clk/hisilicon) can be also used for poplar too. I hope you guys can take a look at them[1] and give your opinions about them(RBs and Acks are welcomed).
[1] HiSi clk framework: https://lore.kernel.org/u-boot/20240119-b4-hisi-clk-v1-0-279e38c95ca2@outloo...
Shawn
Hi Yang,
hi Igor,
Sure, I'll take a look during this week .
Shawn
hi Igor,
Sure, if this is indeed a family we should do that (documentation was scarce back them when I did the initial port).
maybe you'd like to take a stab Igor?
Shawn
hi Igor,
About docs, I've got some. But still, some critical datasheets are missing. Most peripherals are the common ones, like DWC3(USB), PL061(GPIO), DWMMC(eMMC/SD), PL011(serial), SP905(watchdog). But there are some cores that are difficult to find docs. e.g. USB2 INNO PHY, USB3 nano PHY, PMU, TZPC/TZASC, HDMI etc..
Please ping me if you find some documents about them. Especially PMU and USB PHYs, it's quite hard to write a mainline driver for them without datasheets.
Shawn
CC: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com CC: Shawn Guo shawn.guo@linaro.org Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io Acked-by: Shawn Guo shawn.guo@linaro.org Acked-by: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com
participants (5)
Igor Opaniuk
Shawn Guo
Yang Xiwen
