[U-Boot] [PATCH] net: macb: add gmac multi-queue support
This patch refer to linux kernel commit: d8b763e1e79f net/macb: add TX multiqueue support for gem by: Cyrille Pitchen
1. macb driver will check the register to find how many queues support for this chip.
2. Then as we only use queue0 for tx, so we will set up all other queues use a dummy descriptor, which USED bit is set. So those queues are not used.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
drivers/net/macb.c | 33 +++++++++++++++++++++++++++++++++ drivers/net/macb.h | 9 +++++++++ 2 files changed, 42 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index f949161..a5c1880 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -54,6 +54,7 @@ struct macb_dma_desc { #define DMA_DESC_BYTES(n) (n * sizeof(struct macb_dma_desc)) #define MACB_TX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_TX_RING_SIZE)) #define MACB_RX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_RX_RING_SIZE)) +#define MACB_TX_DUMMY_DMA_DESC_SIZE (DMA_DESC_BYTES(1))
#define RXADDR_USED 0x00000001 #define RXADDR_WRAP 0x00000002 @@ -93,6 +94,9 @@ struct macb_device { unsigned long rx_ring_dma; unsigned long tx_ring_dma;
+ struct macb_dma_desc *dummy_desc; + unsigned long dummy_desc_dma; + const struct device *dev; struct eth_device netdev; unsigned short phy_addr; @@ -525,6 +529,30 @@ static int macb_phy_init(struct macb_device *macb) return 1; }
+static int gmac_init_multi_queues(struct macb_device *macb) +{ + int i, num_queues = 1; + u32 queue_mask; + + /* bit 0 is never set but queue 0 always exists */ + queue_mask = gem_readl(macb, DCFG6) & 0xff; + queue_mask |= 0x1; + + for (i = 1; i < MACB_MAX_QUEUES; i++) + if (queue_mask & (1 << i)) + num_queues++; + + macb->dummy_desc->ctrl = TXBUF_USED; + macb->dummy_desc->addr = 0; + flush_dcache_range(macb->dummy_desc_dma, macb->dummy_desc_dma + + MACB_TX_DUMMY_DMA_DESC_SIZE); + + for (i = 1; i < num_queues; i++) + gem_writel_queue_TBQP(macb, macb->dummy_desc_dma, i - 1); + + return 0; +} + static int macb_init(struct eth_device *netdev, bd_t *bd) { struct macb_device *macb = to_macb(netdev); @@ -565,6 +593,9 @@ static int macb_init(struct eth_device *netdev, bd_t *bd) macb_writel(macb, TBQP, macb->tx_ring_dma);
if (macb_is_gem(macb)) { + /* Check the multi queue and initialize the queue for tx */ + gmac_init_multi_queues(macb); + /* * When the GMAC IP with GE feature, this bit is used to * select interface between RGMII and GMII. @@ -712,6 +743,8 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr) &macb->rx_ring_dma); macb->tx_ring = dma_alloc_coherent(MACB_TX_DMA_DESC_SIZE, &macb->tx_ring_dma); + macb->dummy_desc = dma_alloc_coherent(MACB_TX_DUMMY_DMA_DESC_SIZE, + &macb->dummy_desc_dma);
/* TODO: we need check the rx/tx_ring_dma is dcache line aligned */
diff --git a/drivers/net/macb.h b/drivers/net/macb.h index 06f7c66..5bb48f4 100644 --- a/drivers/net/macb.h +++ b/drivers/net/macb.h @@ -60,6 +60,13 @@
/* GEM specific register offsets */ #define GEM_DCFG1 0x0280 +#define GEM_DCFG6 0x0294 + +#define MACB_MAX_QUEUES 8 + +/* GEM specific multi queues register offset */ +/* hw_q can be 0~7 */ +#define GEM_TBQP(hw_q) (0x0440 + ((hw_q) << 2))
/* Bitfields in NCR */ #define MACB_LB_OFFSET 0 @@ -309,5 +316,7 @@ readl((port)->regs + GEM_##reg) #define gem_writel(port, reg, value) \ writel((value), (port)->regs + GEM_##reg) +#define gem_writel_queue_TBQP(port, value, queue_num) \ + writel((value), (port)->regs + GEM_TBQP(queue_num))
#endif /* __DRIVERS_MACB_H__ */
Hi Josh,
- macb driver will check the register to find how many queues support for
this chip.
- Then as we only use queue0 for tx, so we will set up all other queues
Hi, Joe
On 8/12/2015 2:29 AM, Joe Hershberger wrote:
Hi Josh,
this chip.
Thank you. Joe. Would you take this commit to your tree?
Best Regards, Josh Wu
Hi Josh,
On Tue, Aug 11, 2015 at 10:44 PM, Josh Wu josh.wu@atmel.com wrote:
Hi, Joe
Hi Josh,
for this chip.
Yes, I'm doing testing on all the patches now.
Thanks, -Joe
Hi Josh,
this chip.
Applied to u-boot-net, thanks! -Joe
Joe Hershberger
Josh Wu
