[U-Boot] [PATCH] nios2: convert ioremap to use dm cpu data
Convert ioremap() to use io_region_base in dm cpu global data.
Also remove three unused io functions, which have style issue and are replaced by macros already.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/include/asm/io.h | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index 2200dab..d0adf08 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -44,13 +44,10 @@ static inline phys_addr_t virt_to_phys(void * vaddr)
static inline void *ioremap(unsigned long physaddr, unsigned long size) { - return (void *)(IO_REGION_BASE | physaddr); + DECLARE_GLOBAL_DATA_PTR; + return (void *)(gd->arch.io_region_base | physaddr); }
-extern unsigned char inb (unsigned char *port); -extern unsigned short inw (unsigned short *port); -extern unsigned inl (unsigned port); - #define __raw_writeb(v,a) (*(volatile unsigned char *)(a) = (v)) #define __raw_writew(v,a) (*(volatile unsigned short *)(a) = (v)) #define __raw_writel(v,a) (*(volatile unsigned int *)(a) = (v))
Applied to u-boot-nios.
- DECLARE_GLOBAL_DATA_PTR;
- return (void *)(gd->arch.io_region_base | physaddr); }
Thomas Chou
