[U-Boot] [PATCH v3] sun50i: a64: Add initial Banana Pi M64 support
BPI-M64 is a 64-bit quad-core mini single board computer using the Allwinner A64 SOC.
BPI-M64 features - 1.2 Ghz Quad-Core ARM Cortex A53 - 2GB DDR3 SDRAM with 733MHz - MicroSD/eMMC(8GB) - 10/100/1000Mbps ethernet (Realtek RTL8211E/D) - Wifi + BT - IR receiver - Audio In/Out - Video In/Out - 5V 2A DC power-supply
For dts file, Sync with Linux commit 4879b7ae("Merge tag 'dmaengine-4.12-rc1'").
Boot from MMC: ------------- U-Boot SPL 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 18:28:27, May 24 2017 NOTICE: Configuring AXP PMIC NOTICE: PMIC: setup successful INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31 +0000) Allwinner Technology
CPU: Allwinner A64 (SUN50I) Model: BananaPi-M64 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - Droped CONSOLE_MUX, bcz it is enabled by default - Sync with Linux dts file Changes for v2: - Update email-id - Tested on BPI-M64 - Added MMC Slot 2 CONFIG_
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-bananapi-m64.dts | 121 +++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/bananapi_m64_defconfig | 17 +++++ 4 files changed, 144 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-bananapi-m64.dts create mode 100644 configs/bananapi_m64_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d121a62..de54481 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -318,6 +318,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-prime.dtb \ sun50i-h5-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ + sun50i-a64-bananapi-m64.dtb \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts new file mode 100644 index 0000000..02db114 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -0,0 +1,121 @@ +/* + * Copyright (c) 2016 ARM Ltd. + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "BananaPi-M64"; + compatible = "sinovoip,bananapi-m64", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; +}; + +&i2c1_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 43757be..602181b 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -114,6 +114,11 @@ S: Maintained F: configs/Bananapi_M2_Ultra_defconfig F: arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts
+BANANAPI M64 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/bananapi_m64_defconfig + COLOMBUS BOARD M: Maxime Ripard maxime.ripard@free-electrons.com S: Maintained diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig new file mode 100644 index 0000000..3908d42 --- /dev/null +++ b/configs/bananapi_m64_defconfig @@ -0,0 +1,17 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-bananapi-m64" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
BPI-M64 features
- MicroSD/eMMC(8GB)
- Wifi + BT
- IR receiver
- Audio In/Out
- Video In/Out
Boot from MMC:
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
On Thu, Jun 1, 2017 at 2:23 AM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
BPI-M64 features
- MicroSD/eMMC(8GB)
- Wifi + BT
- IR receiver
- Audio In/Out
- Video In/Out
Boot from MMC:
Applied to u-boot-sunxi/master
thanks!
Jagan Teki
Jagan Teki
Maxime Ripard
