[U-Boot] [PATCH 0/4] Add support for PRTLVT2 boards
The following patches add support for PRTLVT2 based boards (i.MX515 SoC).
[PATCH 1/4] MX51: iomux: Added support for mxc_iomux_set_input() [PATCH 2/4] MX51: Added missing pin definition [PATCH 3/4] mc13982 driver: corrected/added some definitions according to latest user-manual [PATCH 4/4] Added initial support for PRTLVT2-based boards.
Signed-off-by: David Jander david@protonic.nl
Signed-off-by: David Jander david@protonic.nl --- arch/arm/cpu/armv7/mx51/iomux.c | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx51/iomux.c b/arch/arm/cpu/armv7/mx51/iomux.c index 62b2954..fb48f1c 100644 --- a/arch/arm/cpu/armv7/mx51/iomux.c +++ b/arch/arm/cpu/armv7/mx51/iomux.c @@ -34,7 +34,7 @@ enum iomux_reg_addr { IOMUXSW_MUX_CTL = IOMUXC_BASE_ADDR, IOMUXSW_MUX_END = IOMUXC_BASE_ADDR + MUX_I_END, IOMUXSW_PAD_CTL = IOMUXC_BASE_ADDR + PAD_I_START, - IOMUXSW_INPUT_CTL = IOMUXC_BASE_ADDR, + IOMUXSW_INPUT_CTL = IOMUXC_BASE_ADDR + INPUT_CTL_START, };
#define MUX_PIN_NUM_MAX (((MUX_I_END - MUX_I_START) >> 2) + 1) @@ -164,3 +164,9 @@ unsigned int mxc_iomux_get_pad(iomux_pin_name_t pin) u32 pad_reg = get_pad_reg(pin); return readl(pad_reg); } + +void mxc_iomux_set_input(iomux_input_select_t input, u32 config) +{ + u32 pad_reg = IOMUXSW_INPUT_CTL+(input*4); + writel(config, pad_reg); +}
Signed-off-by: David Jander david@protonic.nl --- arch/arm/include/asm/arch-mx51/mx51_pins.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx51/mx51_pins.h b/arch/arm/include/asm/arch-mx51/mx51_pins.h index ca26f41..c443f13 100644 --- a/arch/arm/include/asm/arch-mx51/mx51_pins.h +++ b/arch/arm/include/asm/arch-mx51/mx51_pins.h @@ -320,6 +320,7 @@ enum iomux_pins { MX51_PIN_DISP1_DAT22 = _MXC_BUILD_NON_GPIO_PIN(0x324, 0x724), MX51_PIN_DISP1_DAT23 = _MXC_BUILD_NON_GPIO_PIN(0x328, 0x728), MX51_PIN_DI1_PIN3 = _MXC_BUILD_NON_GPIO_PIN(0x32C, 0x72C), + MX51_PIN_DI1_DISP_CLK = _MXC_BUILD_NON_GPIO_PIN(0, 0x730), /* No MUX register!! */ MX51_PIN_DI1_PIN2 = _MXC_BUILD_NON_GPIO_PIN(0x330, 0x734), MX51_PIN_DI_GP1 = _MXC_BUILD_NON_GPIO_PIN(0x334, 0x73C), MX51_PIN_DI_GP2 = _MXC_BUILD_NON_GPIO_PIN(0x338, 0x740),
Signed-off-by: David Jander david@protonic.nl --- include/fsl_pmic.h | 2 +- include/mc13892.h | 41 +++++++++++++++++++++++++++++++++-------- 2 files changed, 34 insertions(+), 9 deletions(-)
diff --git a/include/fsl_pmic.h b/include/fsl_pmic.h index e3abde6..2f2aa7d 100644 --- a/include/fsl_pmic.h +++ b/include/fsl_pmic.h @@ -112,7 +112,7 @@ enum { #define GPO4STBY (1 << 13) #define PWGT1SPIEN (1 << 15) #define PWGT2SPIEN (1 << 16) -#define PWUP (1 << 21) +#define GPO4ADIN (1 << 21)
/* Power Control 0 */ #define COINCHEN (1 << 23) diff --git a/include/mc13892.h b/include/mc13892.h index b291757..4eea6af 100644 --- a/include/mc13892.h +++ b/include/mc13892.h @@ -29,29 +29,51 @@
/* REG_CHARGE */
-#define VCHRG0 0 +#define VCHRG0 (1 << 0) #define VCHRG1 (1 << 1) #define VCHRG2 (1 << 2) #define ICHRG0 (1 << 3) #define ICHRG1 (1 << 4) #define ICHRG2 (1 << 5) #define ICHRG3 (1 << 6) -#define ICHRGTR0 (1 << 7) -#define ICHRGTR1 (1 << 8) -#define ICHRGTR2 (1 << 9) +#define TREN (1 << 7) +#define ACKLPB (1 << 8) +#define THCHKB (1 << 9) #define FETOVRD (1 << 10) #define FETCTRL (1 << 11) #define RVRSMODE (1 << 13) -#define OVCTRL0 (1 << 15) -#define OVCTRL1 (1 << 16) -#define UCHEN (1 << 17) +#define PLIM0 (1 << 15) +#define PLIM1 (1 << 16) +#define PLIMDIS (1 << 17) #define CHRGLEDEN (1 << 18) -#define CHRGRAWPDEN (1 << 19) +#define CHGTMRRST (1 << 19) #define CHGRESTART (1 << 20) #define CHGAUTOB (1 << 21) #define CYCLB (1 << 22) #define CHGAUTOVIB (1 << 23)
+ +/* Power Control 2 (reg 15) */ +#define RESTARTEN (1 << 0) +#define PWRON1RSTEN (1 << 1) +#define PWRON2RSTEN (1 << 2) +#define PWRON3RSTEN (1 << 3) +#define PWRON1DBNC0 (1 << 4) +#define PWRON1DBNC1 (1 << 5) +#define PWRON2DBNC0 (1 << 6) +#define PWRON2DBNC1 (1 << 7) +#define PWRON3DBNC0 (1 << 8) +#define PWRON3DBNC1 (1 << 9) +#define STANDBYINV (1 << 10) +#define STANDBYSECINV (1 << 11) +#define WDIRESET (1 << 12) +#define SPIDRV0 (1 << 13) +#define SPIDRV1 (1 << 14) +#define CLK32KDRV0 (1 << 17) +#define CLK32KDRV1 (1 << 18) +#define STBYDLY0 (1 << 22) +#define STBYDLY1 (1 << 23) + /* REG_SETTING_0/1 */ #define VO_1_20V 0 #define VO_1_30V 1 @@ -84,6 +106,9 @@ #define SWMODE_PFM_PFM 15 #define SWMODE_MASK 0x0F
+/* Switchers 4 (reg 28) */ +#define SWILIMB (1 << 22) + #define SWMODE1_SHIFT 0 #define SWMODE2_SHIFT 10 #define SWMODE3_SHIFT 0
Signed-off-by: David Jander david@protonic.nl --- board/Protonic/prtlvt2/Makefile | 48 ++++ board/Protonic/prtlvt2/config.mk | 25 ++ board/Protonic/prtlvt2/imximage.cfg | 171 ++++++++++++ board/Protonic/prtlvt2/prtlvt2.c | 513 +++++++++++++++++++++++++++++++++++ board/Protonic/prtlvt2/prtlvt2.h | 50 ++++ boards.cfg | 1 + include/configs/prtlvt2.h | 203 ++++++++++++++ 7 files changed, 1011 insertions(+), 0 deletions(-) create mode 100644 board/Protonic/prtlvt2/Makefile create mode 100644 board/Protonic/prtlvt2/config.mk create mode 100644 board/Protonic/prtlvt2/imximage.cfg create mode 100644 board/Protonic/prtlvt2/prtlvt2.c create mode 100644 board/Protonic/prtlvt2/prtlvt2.h create mode 100644 include/configs/prtlvt2.h
diff --git a/board/Protonic/prtlvt2/Makefile b/board/Protonic/prtlvt2/Makefile new file mode 100644 index 0000000..e1f1157 --- /dev/null +++ b/board/Protonic/prtlvt2/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2009 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := prtlvt2.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/Protonic/prtlvt2/config.mk b/board/Protonic/prtlvt2/config.mk new file mode 100644 index 0000000..af70ec2 --- /dev/null +++ b/board/Protonic/prtlvt2/config.mk @@ -0,0 +1,25 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. All Rights Reserved. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +LDSCRIPT = $(CPUDIR)/$(SOC)/u-boot.lds +TEXT_BASE = 0x97800000 +IMX_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/imximage.cfg diff --git a/board/Protonic/prtlvt2/imximage.cfg b/board/Protonic/prtlvt2/imximage.cfg new file mode 100644 index 0000000..a89168e --- /dev/null +++ b/board/Protonic/prtlvt2/imximage.cfg @@ -0,0 +1,171 @@ +# +# (C Copyright 2009 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# Boot Device : one of +# spi, sd (the board has no nand neither onenand) + +# BOOT_FROM spi +BOOT_FROM sd + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +# Setting IOMUXC + +# DS = Drive Strength +# SR = Slew Rate + +# DDR Input mode: DDR +DATA 4 0x73FA88a0 0x200 + +# SDODT0/1: 100k Pull-Down, DS-high, SR-fast +DATA 4 0x73FA8510 0x20c5 +DATA 4 0x73FA850c 0x20c5 + +# DDR A0...A7: DS-medium +DATA 4 0x73FA883c 0x2 + +# DDR A8...A14, SDBA0...SDBA2: DS-medium +DATA 4 0x73FA8848 0x2 + +# DDR SDCLK: 100k Pull-Up, DS-max, SR-fast +DATA 4 0x73FA84b8 0xe7 + +# DDR DQS0...DQS3: No pull/keeper, DS-high, SR-fast +DATA 4 0x73FA84bc 0x45 +DATA 4 0x73FA84c0 0x45 +DATA 4 0x73FA84c4 0x45 +DATA 4 0x73FA84c8 0x45 + +# DDR: Disable pull/keeper on all data lines +DATA 4 0x73FA8820 0x0 + +# DDR RAS, CAS: DS-medium, SR-fast +DATA 4 0x73FA84a4 0x3 +DATA 4 0x73FA84a8 0x3 + +# DDR WE, SDCKE0, SDCKE1: 100k Pull-Up, DS-medium, SR-fast +DATA 4 0x73FA84ac 0xe3 +DATA 4 0x73FA84b0 0xe3 +DATA 4 0x73FA84b4 0xe3 + +# DDR CS0, CS1: 100k Pull-Up, DS-medium, SR-fast +DATA 4 0x73FA84cc 0xe3 +DATA 4 0x73FA84d0 0xe2 + +# DDR Data D24...D31, D0...D23: DS-high +DATA 4 0x73FA882c 0x5 +DATA 4 0x73FA88a4 0x5 +DATA 4 0x73FA88ac 0x5 +DATA 4 0x73FA88b8 0x5 + +# Setting DDR for micron +# 13 Rows, 10 Cols, 32 bit, SREF=4 Micron Model +# CAS=3 BL=4 +# ESDCTL_ESDCTL0: Enable, No refresh, 13-bit ROW, +# DBL_tRFC, 10-bit COL, 32-bit data, Run mode. +# ESDCTL_ESDCTL1: idem. +DATA 4 0x83FD9000 0x82a20000 +DATA 4 0x83FD9008 0x82a20000 + +# ESDCTL_ESDMISC: ODT off, A10 is precharge, +# Diff_DQS, AUTO_DLL_PAUSE, Bank-interleave, RALAT=1, +# 8-bank, DDR2_EN +DATA 4 0x83FD9010 0x000ad0d0 + +# ESDCTL_ESDCFG0: tRFC=13ck, tXSR=28ck, tXP=2ck, +# tWTR=2ck, tRP=3ck, tMRD=2ck, tRAS=8ck, tRRD=2ck, +# tWR=3ck, tRCD=3ck, tRC=11ck +# ESDCTL_ESDCFG1: idem. +DATA 4 0x83FD9004 0x333574aa +DATA 4 0x83FD900C 0x333574aa + +# Init DRAM on CS0 +# ESDCTL_ESDSCR +# 1. Precharge ALL +DATA 4 0x83FD9014 0x04008008 +# 2. LMR EMR2: 1x Refresh (0...85C) +DATA 4 0x83FD9014 0x0000801a +# 3. LMR EMR3: Clear EMR3 (not used) +DATA 4 0x83FD9014 0x0000801b +# 4. LMR EMR: Rtt = 50 Ohm, Diff-DQS +DATA 4 0x83FD9014 0x00448019 +# 5. LMR MR: BL=4, Seq, CL3, WR4, DLL-reset +DATA 4 0x83FD9014 0x07328018 +# 6. Precharge ALL +DATA 4 0x83FD9014 0x04008008 +# 7. Auto Refresh +DATA 4 0x83FD9014 0x00008010 +# 8. Auto Refresh +DATA 4 0x83FD9014 0x00008010 +# 9. LMR MR: BL=4, Seq, CL3, WR4 +DATA 4 0x83FD9014 0x06328018 +# 10. LMR EMR: Load OCD defaults +DATA 4 0x83FD9014 0x03808019 +# 11. LMR EMR: Rtt = 150 Ohm, Diff-DQS, Reduced DS +DATA 4 0x83FD9014 0x00428019 +# 12. NOP +DATA 4 0x83FD9014 0x00008000 + +# Init DRAM on CS1 +# Same sequence as for CS0, only CS=1. +DATA 4 0x83FD9014 0x0400800c +DATA 4 0x83FD9014 0x0000801e +DATA 4 0x83FD9014 0x0000801f +DATA 4 0x83FD9014 0x0000801d +DATA 4 0x83FD9014 0x0732801c +DATA 4 0x83FD9014 0x0400800c +DATA 4 0x83FD9014 0x00008014 +DATA 4 0x83FD9014 0x00008014 +DATA 4 0x83FD9014 0x0632801c +DATA 4 0x83FD9014 0x0380801d +DATA 4 0x83FD9014 0x0042801d +DATA 4 0x83FD9014 0x00008004 + +# ESDCTL_ESDCTL0: Enable, SREFR=7.81us, 13-bit ROW, +# DBL_tRFC, 10-bit COL, 32-bit data, Run mode. +# ESDCTL_ESDCTL1: idem. +DATA 4 0x83FD9000 0xb2a20000 +DATA 4 0x83FD9008 0xb2a20000 + +# ESDMISC: ODT off, A10 is precharge, +# Diff_DQS, AUTO_DLL_PAUSE, Bank-interleave, RALAT=1, +# 8-bank, MIF3-mode = 3, DDR2_EN +DATA 4 0x83FD9010 0x000ad6d0 + +# ESDCTL_ESDGPR: DQS-in gating on, 1/2 cycle. +DATA 4 0x83FD9034 0x90000000 + +# ESDCTL_ESDSCR: Normal operation. +DATA 4 0x83FD9014 0x00000000 diff --git a/board/Protonic/prtlvt2/prtlvt2.c b/board/Protonic/prtlvt2/prtlvt2.c new file mode 100644 index 0000000..7853a03 --- /dev/null +++ b/board/Protonic/prtlvt2/prtlvt2.c @@ -0,0 +1,513 @@ +/* + * Copyright (c) 2010 Protonic Holland + * + * Author: David Jander david@protonic.nl + * + * Based on: mx51evk.c + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx51_pins.h> +#include <asm/arch/iomux.h> +#include <asm/errno.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <fsl_pmic.h> +#include <mc13892.h> +#include "prtlvt2.h" + +DECLARE_GLOBAL_DATA_PTR; + +static u32 system_rev; +struct io_board_ctrl *mx51_io_board; + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg[1] = { + {MMC_SDHC2_BASE_ADDR, 1}, +}; +#endif + +typedef struct { + int pin; + int muxconf; + int padconf; + int input; + int inconf; +} ioconf_t; + +#define POUT_HS (PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST) +#define POUT_MS (PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST) +#define POUT_LS (PAD_CTL_DRV_MEDIUM) +#define PIN_HYS (PAD_CTL_HYS_ENABLE) +#define PIN_HYS_PULL (PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL) +#define PIN_HYS_KEEP (PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE) +#define PIO_OD (PIN_HYS_PULL | PAD_CTL_22K_PU | PAD_CTL_ODE_OPENDRAIN_ENABLE | PAD_CTL_DRV_MEDIUM) + +static const ioconf_t const other_io_conf[] = { + /* ITU656 Video Input */ + {MX51_PIN_CSI1_D12, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D13, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D14, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D15, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D16, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D17, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D18, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_D19, IOMUX_CONFIG_SION, PIN_HYS, -1, -1}, + {MX51_PIN_CSI1_PIXCLK, -1, PIN_HYS, -1, -1}, + + /* nPCTS_INT: GPIO11 on USBH1_DATA0 */ + {MX51_PIN_USBH1_DATA0, IOMUX_CONFIG_ALT2, PIN_HYS_PULL, -1, -1}, + + /* SCL_2V8, SDA_2V8 on KEY_COL4 and KEY_COL5 */ + {MX51_PIN_KEY_COL4, IOMUX_CONFIG_ALT3, PIO_OD, MUX_IN_I2C2_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH1}, + {MX51_PIN_KEY_COL5, IOMUX_CONFIG_ALT3, PIO_OD, MUX_IN_I2C2_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH1}, + + /* SCL_1V8, SDA_1V8 on EIM_D16 and EIM_D19 */ + {MX51_PIN_EIM_D16, IOMUX_CONFIG_ALT4, PIO_OD, MUX_IN_I2C1_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH0}, + {MX51_PIN_EIM_D19, IOMUX_CONFIG_ALT4, PIO_OD, MUX_IN_I2C1_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH0}, + + /* GPIO1 group */ + {MX51_PIN_GPIO1_0, IOMUX_CONFIG_ALT1, PIN_HYS_PULL | PAD_CTL_22K_PU, -1, -1}, /* CAN1_nINT */ + {MX51_PIN_GPIO1_1, IOMUX_CONFIG_ALT1, POUT_LS, -1, -1}, /* CAN1_TERM */ + {MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT0, POUT_LS, -1, -1}, /* BLEN */ + {MX51_PIN_GPIO1_3, IOMUX_CONFIG_ALT0, PIN_HYS_PULL | PAD_CTL_22K_PU, -1, -1}, /* CAN2_nINT */ + {MX51_PIN_GPIO1_4, IOMUX_CONFIG_ALT2, POUT_LS, -1, -1}, /* WDOG */ + {MX51_PIN_GPIO1_5, IOMUX_CONFIG_ALT0, PIN_HYS_PULL | PAD_CTL_22K_PU, -1, -1}, /* nLVDS_PDN */ + {MX51_PIN_GPIO1_6, IOMUX_CONFIG_ALT0, PIN_HYS_PULL | PAD_CTL_22K_PU, -1, -1}, /* nUSD_CD */ + {MX51_PIN_GPIO1_7, IOMUX_CONFIG_ALT0, POUT_LS, -1, -1}, /* nITU656_PDN */ + {MX51_PIN_GPIO1_8, IOMUX_CONFIG_ALT0, PIN_HYS, -1, -1}, /* PMIC_INT */ + {MX51_PIN_GPIO1_9, IOMUX_CONFIG_ALT0, PIN_HYS_PULL | PAD_CTL_22K_PU, -1, -1}, /* JN4148_INT */ + + /* LCD Display */ + {MX51_PIN_DI1_DISP_CLK, -1, POUT_MS, -1, -1}, + + { -1, -1, -1, -1, -1} +}; + +u32 get_board_rev(void) +{ + return system_rev; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); + return 0; +} + +static void setup_iomux_uart(void) +{ + unsigned int pad = PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_DRV_HIGH; + + /* Uart1 */ + mxc_request_iomux(MX51_PIN_UART1_RXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_RXD, pad | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_UART1_TXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_TXD, pad | PAD_CTL_SRE_FAST); + + /* Uart2 */ + mxc_request_iomux(MX51_PIN_UART2_RXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART2_RXD, pad | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_UART2_TXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART2_TXD, pad | PAD_CTL_SRE_FAST); +} + +static void setup_iomux_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX51_PIN_DI2_PIN3, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI2_PIN3, + PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH /* | PAD_CTL_ODE_OPENDRAIN_ENABLE */ | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); /* OD, 22k-PU */ + mxc_iomux_set_input(MUX_IN_FEC_FEC_MDI_SELECT_INPUT, INPUT_CTL_PATH1); + + /*FEC_MDC*/ + mxc_request_iomux(MX51_PIN_DI2_PIN2, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI2_PIN2, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC RDATA[3] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT0, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT0, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RDATA_3_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RDATA[2] */ + mxc_request_iomux(MX51_PIN_DI_GP4, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI_GP4, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RDATA_2_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RDATA[1] */ + mxc_request_iomux(MX51_PIN_DI2_DISP_CLK, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI2_DISP_CLK, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RDATA_1_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RDATA[0] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT14, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT14, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RDATA_0_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC TDATA[3] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT8, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT8, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TDATA[2] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT7, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT7, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TDATA[1] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT6, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT6, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TDATA[0] */ + mxc_request_iomux(MX51_PIN_DISP2_DAT15, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT15, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TX_EN */ + mxc_request_iomux(MX51_PIN_DISP2_DAT9, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT9, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TX_ER */ + mxc_request_iomux(MX51_PIN_DI_GP3, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI_GP3, PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* FEC TX_CLK */ + mxc_request_iomux(MX51_PIN_DISP2_DAT13, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT13, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_TX_CLK_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC TX_COL */ + mxc_request_iomux(MX51_PIN_DISP2_DAT10, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT10, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_COL_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RX_CLK */ + mxc_request_iomux(MX51_PIN_DISP2_DAT11, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT11, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RX_CLK_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RX_CRS */ + mxc_request_iomux(MX51_PIN_DI2_PIN4, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DI2_PIN4, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_CRS_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RX_ER */ + mxc_request_iomux(MX51_PIN_DISP2_DAT1, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT1, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RX_ER_SELECT_INPUT, INPUT_CTL_PATH1); + + /* FEC RX_DV */ + mxc_request_iomux(MX51_PIN_DISP2_DAT12, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_DISP2_DAT12, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE); + mxc_iomux_set_input(MUX_IN_FEC_FEC_RX_DV_SELECT_INPUT, INPUT_CTL_PATH1); +} + +#ifdef CONFIG_MXC_SPI +static void setup_iomux_spi(void) +{ + /* 000: Select mux mode: ALT0 mux port: MOSI of instance: ecspi1 */ + mxc_request_iomux(MX51_PIN_CSPI1_MOSI, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_MOSI, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* 000: Select mux mode: ALT0 mux port: MISO of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_MISO, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_MISO, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* Select mux mode: ALT0 mux port: of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_SS1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SS1, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* 000: Select mux mode: ALT0 mux port: SS0 ecspi1 */ + mxc_request_iomux(MX51_PIN_CSPI1_SS0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SS0, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* 000: Select mux mode: ALT0 mux port: RDY of instance: ecspi1. */ + // mxc_request_iomux(MX51_PIN_CSPI1_RDY, IOMUX_CONFIG_ALT0); + // mxc_iomux_set_pad(MX51_PIN_CSPI1_RDY, 0x180); + + /* 000: Select mux mode: ALT0 mux port: SCLK of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_SCLK, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SCLK, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* CSPI1_SS2 on DI1_PIN11 : ALT7 */ + mxc_request_iomux(MX51_PIN_DI1_PIN11, IOMUX_CONFIG_ALT7); + mxc_iomux_set_pad(MX51_PIN_DI1_PIN11, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); + + /* CSPI1_SS3 on USBH1_DATA7 : ALT1 */ + mxc_request_iomux(MX51_PIN_USBH1_DATA7, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_USBH1_DATA7, PAD_CTL_HYS_ENABLE | PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH); +} +#endif + +static void setup_iomux_ac97(void) +{ + /* AC97_BCLK: AUD5_RXC on pad SD1_CLK */ + mxc_request_iomux(MX51_PIN_SD1_CLK, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_SD1_CLK, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_100K_PU); + mxc_iomux_set_input(MUX_IN_AUDMUX_P5_INPUT_RXCLK_AMX_SELECT_INPUT, INPUT_CTL_PATH1); + + /* AC97_TXD: AUD5_TXD on pad SD1_DATA0 */ + mxc_request_iomux(MX51_PIN_SD1_DATA0, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA0, PAD_CTL_PKE_ENABLE | PAD_CTL_DRV_HIGH); + + /* AC97_RXD: AUD5_RXD on pad SD1_DATA1 */ + mxc_request_iomux(MX51_PIN_SD1_DATA1, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA1, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_100K_PU); + mxc_iomux_set_input(MUX_IN_AUDMUX_P5_INPUT_DA_AMX_SELECT_INPUT, INPUT_CTL_PATH2); + + /* AC97_SYNC: AUD5_TXFS on pad SD1_DATA3 */ + mxc_request_iomux(MX51_PIN_SD1_DATA3, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA3, PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_100K_PU); + mxc_iomux_set_input(MUX_IN_AUDMUX_P5_INPUT_TXFS_AMX_SELECT_INPUT, INPUT_CTL_PATH2); +} + +static void power_init(void) +{ + unsigned int val; + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)MXC_CCM_BASE; + + /* First of all, set SWILIMB (MC13892 errata 8690 & 8732) */ + val = pmic_reg_read(REG_SW_4); + val |= SWILIMB; + pmic_reg_write(REG_SW_4, val); + + /* Disable Power Gate 2: Enable 1V8 peripheral power */ + val = pmic_reg_read(REG_POWER_MISC); + val &= ~PWGT2SPIEN; + pmic_reg_write(REG_POWER_MISC, val); + + /* Write needed to update Charger 0 */ + /* Charge voltage=4.2V, Current=full-on, Plim=800mW, charger sw, battfet off */ + pmic_reg_write(REG_CHARGE, VCHRG0 | VCHRG1 /*| VCHRG2 */ | + ICHRG0 | ICHRG1 | ICHRG2 | ICHRG3 | FETOVRD | + PLIM0 /* | PLIM1 */ | + CHRGLEDEN | CHGAUTOB | CYCLB); + + /* Configure Power Control, enable PWRON switches */ + pmic_reg_write(REG_POWER_CTL2, RESTARTEN | + PWRON1RSTEN | PWRON2RSTEN | PWRON3RSTEN | + PWRON1DBNC0 | PWRON2DBNC0 | PWRON3DBNC0 | + WDIRESET | STBYDLY0); + + /* power up the system first */ + // FIXME: Is this bit still there in rev 2? + // This bit was called PWUP?? + pmic_reg_write(REG_POWER_MISC, GPO4ADIN); + + /* Set core voltage to 1.1V */ + val = pmic_reg_read(REG_SW_0); + val = (val & (~0x80001F)) | 0x14; + pmic_reg_write(REG_SW_0, val); + + /* Setup VCC (SW2) to 1.225 */ + val = pmic_reg_read(REG_SW_1); + val = (val & (~0x80001F)) | 0x19; + pmic_reg_write(REG_SW_1, val); + + /* Setup 1V2_DIG1 (SW3) to 1.2 */ + val = pmic_reg_read(REG_SW_2); + val = (val & (~0x80001F)) | 0x18; + pmic_reg_write(REG_SW_2, val); + udelay(50); + + /* Raise the core frequency to 800MHz */ + /* printf("Core at 400 MHz!\n"); */ + /* writel(0x1, &mxc_ccm->cacrr); */ + writel(0x0, &mxc_ccm->cacrr); + + /* Set switchers in Auto in NORMAL mode & STANDBY mode */ + /* Setup the switcher mode for SW1 & SW2*/ + val = pmic_reg_read(REG_SW_4); + val = (val & ~((SWMODE_MASK << SWMODE1_SHIFT) | + (SWMODE_MASK << SWMODE2_SHIFT))); + val |= (SWMODE_AUTO_AUTO << SWMODE1_SHIFT) | + (SWMODE_AUTO_AUTO << SWMODE2_SHIFT); + pmic_reg_write(REG_SW_4, val); + + /* Setup the switcher mode for SW3 & SW4 */ + val = pmic_reg_read(REG_SW_5); + val = (val & ~((SWMODE_MASK << SWMODE3_SHIFT) | + (SWMODE_MASK << SWMODE4_SHIFT) | (1<<20))); // SWBSTEN=0 ! + val |= (SWMODE_AUTO_AUTO << SWMODE3_SHIFT) | + (SWMODE_AUTO_AUTO << SWMODE4_SHIFT) | SWILIMB; + pmic_reg_write(REG_SW_5, val); + +#if 0 /* FIXME: This shouldn't be changed for PRTLVT2 */ + /* Set VDIG to 1.25V, VGEN3 to 1.8V, VCAM to 2.6V */ + val = pmic_reg_read(REG_SETTING_0); + val &= ~(VCAM_MASK | VGEN3_MASK | VDIG_MASK); + val |= VDIG_1_25 | VGEN3_1_8 | VCAM_2_6; + pmic_reg_write(REG_SETTING_0, val); +#endif + + /* Set VVIDEO and VAUDIO to 2.775V */ + val = pmic_reg_read(REG_SETTING_1); + val &= ~(VVIDEO_MASK | VAUDIO_MASK); + val |= VAUDIO_2_775 | VVIDEO_2_775; + pmic_reg_write(REG_SETTING_1, val); + udelay(200); + + /* Enable VAUDIO, VVIDEO regulators */ + /* FIXME: Standby mode ? */ + val = VVIDEOEN | VAUDIOEN; + pmic_reg_write(REG_MODE_1, val); + udelay(500); + + /* Turn on backlight */ + val = readl(GPIO1_BASE_ADDR + 0x0); + val |= 0x00000004; /* Make GPIO1_2 high (BLEN) */ + writel(val, GPIO1_BASE_ADDR + 0x0); + + val = readl(GPIO1_BASE_ADDR + 0x4); + val |= 0x00000004; /* configure GPIO line as output */ + writel(val, GPIO1_BASE_ADDR + 0x4); +} + +#ifdef CONFIG_FSL_ESDHC +int board_mmc_getcd(u8 *cd, struct mmc *mmc) +{ + *cd = readl(GPIO1_BASE_ADDR) & 0x40; + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + s32 status = 0; + + mxc_request_iomux(MX51_PIN_SD2_CMD, IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD2_CLK, IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD2_DATA0, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA1, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA2, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA3, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_SD2_CMD, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_iomux_set_pad(MX51_PIN_SD2_CLK, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA0, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA1, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA2, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA3, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_PUE_PULL | PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | PAD_CTL_DRV_MAX); + mxc_request_iomux(MX51_PIN_GPIO1_6, IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_6, PAD_CTL_HYS_ENABLE); + status = fsl_esdhc_initialize(bis, &esdhc_cfg[0]); + + return status; +} +#endif + +int board_init(void) +{ + int t; + system_rev = get_cpu_rev(); + + gd->bd->bi_arch_number = MACH_TYPE_PRTLVT2; + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + setup_iomux_uart(); + setup_iomux_fec(); + setup_iomux_ac97(); + + /* Setup other io's */ + for(t=0; other_io_conf[t].pin>=0; t++) { + mxc_iomux_set_pad(other_io_conf[t].pin, other_io_conf[t].padconf); + if(other_io_conf[t].muxconf>=0) + mxc_request_iomux(other_io_conf[t].pin, other_io_conf[t].muxconf); + if(other_io_conf[t].input>=0) + mxc_iomux_set_input(other_io_conf[t].input, other_io_conf[t].inconf); + } + + return 0; +} + +#ifdef BOARD_LATE_INIT +int board_late_init(void) +{ +#ifdef CONFIG_MXC_SPI + setup_iomux_spi(); + power_init(); +#endif + return 0; +} +#endif + +int checkboard(void) +{ + puts("Board: PRTLVT2 "); + + switch (system_rev & 0xff) { + case CHIP_REV_3_0: + puts("3.0 ["); + break; + case CHIP_REV_2_5: + puts("2.5 ["); + break; + case CHIP_REV_2_0: + puts("2.0 ["); + break; + case CHIP_REV_1_1: + puts("1.1 ["); + break; + case CHIP_REV_1_0: + default: + puts("1.0 ["); + break; + } + + switch (__raw_readl(SRC_BASE_ADDR + 0x8)) { + case 0x0001: + puts("POR"); + break; + case 0x0009: + puts("RST"); + break; + case 0x0010: + case 0x0011: + puts("WDOG"); + break; + default: + puts("unknown"); + } + puts("]\n"); + return 0; +} diff --git a/board/Protonic/prtlvt2/prtlvt2.h b/board/Protonic/prtlvt2/prtlvt2.h new file mode 100644 index 0000000..2854e71 --- /dev/null +++ b/board/Protonic/prtlvt2/prtlvt2.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __BOARD_FREESCALE_MX51_EVK_H__ +#define __BOARD_FREESCALE_MX51_EVK_H__ + +#ifndef __ASSEMBLY__ +struct io_board_ctrl { + u16 led_ctrl; /* 0x00 */ + u16 resv1[0x03]; + u16 sb_stat; /* 0x08 */ + u16 resv2[0x03]; + u16 int_stat; /* 0x10 */ + u16 resv3[0x07]; + u16 int_rest; /* 0x20 */ + u16 resv4[0x0B]; + u16 int_mask; /* 0x38 */ + u16 resv5[0x03]; + u16 id1; /* 0x40 */ + u16 resv6[0x03]; + u16 id2; /* 0x48 */ + u16 resv7[0x03]; + u16 version; /* 0x50 */ + u16 resv8[0x03]; + u16 id3; /* 0x58 */ + u16 resv9[0x03]; + u16 sw_reset; /* 0x60 */ +}; +#endif + +#endif diff --git a/boards.cfg b/boards.cfg index b82f530..f3f9f02 100644 --- a/boards.cfg +++ b/boards.cfg @@ -46,6 +46,7 @@ pm9263 arm arm926ejs - ronetix at91 suen3 arm arm926ejs km_arm keymile kirkwood rd6281a arm arm926ejs - Marvell kirkwood mx51evk arm armv7 mx51evk freescale mx51 +prtlvt2 arm armv7 prtlvt2 Protonic mx51 actux1 arm ixp actux2 arm ixp actux3 arm ixp diff --git a/include/configs/prtlvt2.h b/include/configs/prtlvt2.h new file mode 100644 index 0000000..bef65b1 --- /dev/null +++ b/include/configs/prtlvt2.h @@ -0,0 +1,203 @@ +/* + * Copyright (C) 2010, Protonic Holland + * + * Author: David Jander david@protonic.nl + * + * Based on mx51evk.h: Configuration settings for the MX51EVK Board + * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + + + /* High Level Configuration Options */ + +#define CONFIG_MX51 /* in a mx51 */ +#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_MX51_HCLK_FREQ 24000000 /* RedBoot says 26MHz */ +#define CONFIG_MX51_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_L2_OFF + +/* + * Disabled for now due to build problems under Debian and a significant + * increase in the final file size: 144260 vs. 109536 Bytes. + */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_REVISION_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define BOARD_LATE_INIT + +/* + * Hardware drivers + */ +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX51_UART1 + +/* + * SPI Configs + * */ +#define CONFIG_CMD_SPI + +#define CONFIG_MXC_SPI + +#define CONFIG_FSL_PMIC +#define CONFIG_FSL_PMIC_BUS 0 +#define CONFIG_FSL_PMIC_CS 3 +#define CONFIG_FSL_PMIC_CLK 2500000 +#define CONFIG_FSL_PMIC_MODE (SPI_CPOL | SPI_CS_HIGH) + +/* + * MMC Configs + * */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 1 + +#define CONFIG_MMC + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* + * Eth Configs + */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1F + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_PRIME "FEC0" + +#define CONFIG_LOADADDR 0x90800000 /* loadaddr env var */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "uboot_addr=0xa0000000\0" \ + "uboot=u-boot.bin\0" \ + "loadaddr=0x90800000\0" \ + "bootargs_base=setenv bootargs console=tty "\ + "console=ttymxc0,${baudrate}\0"\ + "bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs "\ + "ip=${ipaddr} nfsroot=${nfsserverip}:${nfsroot},v3,tcp\0"\ + "bootcmd_net=run bootargs_base bootargs_nfs; " \ + "tftpboot ${loadaddr} ${kernel}; bootm\0" \ + "bootcmd_SD=run bootcmd_SD1 bootcmd_SD2\0" \ + "bootcmd_SD1=run bootargs_base bootargs_SD\0" \ + "bootcmd_SD2=mmc read 0 ${loadaddr} 0x800 0x1280; bootm ${loadaddr}\0" \ + "bootargs_SD=setenv bootargs ${bootargs} mitsubishi_xga " \ + "video=mxcfb:1024x768-16M@60,bpp=16 root=/dev/mmcblk0p1 rootfstype=ext4 rootdelay=2\0" \ + "ethaddr=00:00:00:00:00:00\0" \ + "ipaddr=192.168.1.244\0" \ + "serverip=192.168.1.132\0" \ + "nfsserverip=192.168.1.160\0" \ + "nfsroot=/srv/home/david/Devel/Sandboxes/LEL/XDH/nfsroot\0" \ + "kernel=linux-2.6.31-prtlvt2.uImage\0" \ + "bootcmd=run bootcmd_SD1; tftpboot ${loadaddr} ${kernel}; bootm\0" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x90000000 +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024) + +#define CONFIG_SYS_DDR_CLKSEL 0 +#define CONFIG_SYS_CLKTL_CBCDR 0x59E35100 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_IS_NOWHERE + +#endif
Dear David Jander,
In message 00b6eb8822a36b67a5e6154fd256e51e605fe47a.1282213859.git.david@protonic.nl you wrote:
Entry to MAINTAINERS missing.
- /* SCL_2V8, SDA_2V8 on KEY_COL4 and KEY_COL5 */
- {MX51_PIN_KEY_COL4, IOMUX_CONFIG_ALT3, PIO_OD, MUX_IN_I2C2_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH1},
- {MX51_PIN_KEY_COL5, IOMUX_CONFIG_ALT3, PIO_OD, MUX_IN_I2C2_IPP_SCL_IN_SELECT_INPUT, INPUT_CTL_PATH1},
Lines too long, please fix globally.
- /* Write needed to update Charger 0 */
- /* Charge voltage=4.2V, Current=full-on, Plim=800mW, charger sw, battfet off */
Incorrect multiline comment format, please fix globally.
- pmic_reg_write(REG_CHARGE, VCHRG0 | VCHRG1 /*| VCHRG2 */ |
- /* Configure Power Control, enable PWRON switches */
- pmic_reg_write(REG_POWER_CTL2, RESTARTEN |
- /* power up the system first */
- // FIXME: Is this bit still there in rev 2?
- // This bit was called PWUP??
No C++ comments, please!
- pmic_reg_write(REG_POWER_MISC, GPO4ADIN);
It would really be great if someone cold clean up this mess in "include/fsl_pmic.h"
Using an "enum" for register definitions is just horrible.
I am well aware that you did not introduce this code, but reading this feels is if my nails are rolling up.
- /* Set core voltage to 1.1V */
- val = pmic_reg_read(REG_SW_0);
- val = (val & (~0x80001F)) | 0x14;
- pmic_reg_write(REG_SW_0, val);
- /* Setup VCC (SW2) to 1.225 */
- val = pmic_reg_read(REG_SW_1);
- val = (val & (~0x80001F)) | 0x19;
- pmic_reg_write(REG_SW_1, val);
- /* Setup 1V2_DIG1 (SW3) to 1.2 */
- val = pmic_reg_read(REG_SW_2);
- val = (val & (~0x80001F)) | 0x18;
- pmic_reg_write(REG_SW_2, val);
- udelay(50);
Don't you feel the need to intr=oduce some readable symbolic constants for all these magic numbers here?
- /* Raise the core frequency to 800MHz */
- /* printf("Core at 400 MHz!\n"); */
- /* writel(0x1, &mxc_ccm->cacrr); */
Please remove dead code.
- /* Set VDIG to 1.25V, VGEN3 to 1.8V, VCAM to 2.6V */
- val = pmic_reg_read(REG_SETTING_0);
- val &= ~(VCAM_MASK | VGEN3_MASK | VDIG_MASK);
- val |= VDIG_1_25 | VGEN3_1_8 | VCAM_2_6;
- pmic_reg_write(REG_SETTING_0, val);
- /* Turn on backlight */
- val = readl(GPIO1_BASE_ADDR + 0x0);
- val |= 0x00000004; /* Make GPIO1_2 high (BLEN) */
- writel(val, GPIO1_BASE_ADDR + 0x0);
- val = readl(GPIO1_BASE_ADDR + 0x4);
- val |= 0x00000004; /* configure GPIO line as output */
- writel(val, GPIO1_BASE_ADDR + 0x4);
We don't accept register base plus offset notation any more. Please use a C struct to describe the register layout. Please fix globally.
"netdev=eth0\0" \
Indentation by TAB only, please. [Check & fix globally, please.]
NAK!!
We do not allow network parameters in the default environment (and especially not broken/incorrect MAC addresses.
Do you think it makes any sense to your customers to encode your local settings like "/srv/home/david/Devel/Sandboxes/LEL/XDH/nfsroot" in the default environment?
I doubt that.
Is this really needed on your hardware?
Please use TABs for vertical alignment.
Dear Wolfgang,
Oops. Thanks for pointing out. Will add maintainer info.
Ok. Will fix that.
battfet off */
Ok.
Yes, but fixing it will probably break a lot of other code. Am I supposed to do that and fix everything that I can find breaking and hope for the rest (which I can't test myself)?
I agree.
I agree. Should I propose a fix first (could be a lot of work)?
- udelay(50);
Yes I do. It was copied almost literally from the MX51EVK code, and somehow I think this should go elsewhere anyway.... I'll see what I can come up with.
Ok.
Ok.
Again, this is copy/pasted from MX51EVK code somewhere. Will try to improve this.
"netdev=eth0\0" \
Ok.
NAK!!
Ooops. This wasn't meant to be here :-( Anyway, I am currently working on implementing access to SPI-NOR-flash, and this was there only for convinience while developing on one board. It was meant to be removed, though. Btw, I am also trying to fix the awfully broken mxc_spi driver. The spi_xfer() function assumes 32-bit word transfers (because the hardware does it like this, and FSL didn't bother adapting the driver to linux/u-boot spi conventions), so I need to introduce a second spi_xfer_fsl() function for all existing, but broken device drivers that assume fsl-byte-ordering (like the PMIC driver) and fix the original spi_xfer(). Is that acceptable?
This also wasn't supposed to be here....
Honestly I didn't even know what this is for. It's from MX51EVK.
Excuse this dumb question about u-boot coding-style: Are tabs supposed to be used 8-spaces wide?
And I thought my version was much cleaner than the MX51EVK BSP which is already in u-boot.... :-(
Hi Wolfgang,
Well, that's me ! I am aware it sounds crazy. However, the registers on the pmic are not memory mapped and the access is done via SPI. The pmic manuals (MC13783, MC13892,) describe the SPI frame (ok, frame is probably a big word..it is only a 32 bit) and one of the field is the internal register number.
Using a structure looks like to me even stranger. We have to use some kind of offsetof() to get the index number back and put it inside the SPI data.
Best regards, Stefano Babic
Hi David,
in addition to Wolfgang's comments:
Structure is not used, and probably does not match your board. You should drop it.
Consider to put these defines in include/asm/arch-mx51/iomux.h. They could be usefult for other boards, too.
- writel(0x0, &mxc_ccm->cacrr);
Comment is misleading. Remove what is not needed.
- /* Setup other io's */
- for(t=0; other_io_conf[t].pin>=0; t++) {
Add spaces when needed.
Probably it is better (and in mx51evk, too) to remove the #ifdef, because we need to initialize the pmic, else some functionalities cannot work. It is mandatory that power_init is called.
diff --git a/board/Protonic/prtlvt2/prtlvt2.h b/board/Protonic/prtlvt2/prtlvt2.h +#ifndef __BOARD_FREESCALE_MX51_EVK_H__ +#define __BOARD_FREESCALE_MX51_EVK_H__
- u16 led_ctrl; /* 0x00 */
- u16 resv1[0x03];
- u16 sb_stat; /* 0x08 */
- u16 resv2[0x03];
- u16 int_stat; /* 0x10 */
- u16 resv3[0x07];
- u16 int_rest; /* 0x20 */
- u16 resv4[0x0B];
- u16 int_mask; /* 0x38 */
- u16 resv5[0x03];
- u16 id1; /* 0x40 */
- u16 resv6[0x03];
- u16 id2; /* 0x48 */
- u16 resv7[0x03];
- u16 version; /* 0x50 */
- u16 resv8[0x03];
- u16 id3; /* 0x58 */
- u16 resv9[0x03];
- u16 sw_reset; /* 0x60 */
+}; +#endif
Is this structure really used ? I have not seen in code. Or does it come only from mx51evk ? You can remove the whole file, if it is not needed.
On Friday 20 August 2010 11:51:18 am Stefano Babic wrote:
Hi David,
Ok, I was already wondering what this did here.... I'll just remove it.
Hmmm. In that case they should have other names, and one should probably make the set complete with all combinations, and I doubt it'll make sense anymore then.... This subset of possibilities is too specific to our board I fear. I had already been complaining about some seemingly arbitrary combinations of IO-pad settings being used in SoC-driver code in the linux kernel. IMHO, one should never choose a specific combination of settings without excactly knowing it is electrically correct for that specific pin on that specific board... not only because it works, but also from EMC considerations. I also think, that in theory this would make the kernel board-specific in that case... not something one would want I believe. For that reason, I keep thinking that correct and thorough IO-pad setup specific for each board should be done in the boot-loader.... never in the kernel.
OTOH, maybe one could come up with some commonly-used combinations... but which ones?
Sorry, I was too lazy to make a configuration option out of this... will fix it.
Ok.
I agree. I had always been "about to remove it" ;-)
- u16 resv1[0x03];
- u16 resv2[0x03];
- u16 resv3[0x07];
- u16 resv4[0x0B];
- u16 resv5[0x03];
- u16 resv6[0x03];
- u16 resv7[0x03];
- u16 resv8[0x03];
- u16 resv9[0x03];
+}; +#endif
No idea what it does. It's copied from MX51EVK. I will try removing it.
Ok, I understand. I have thought it coul be easier to other one to use the same set of combinations.
This structure comes from older Freescale's source and makes sense only on another board. I have already merged a patch to drop the usage of the structure inside the board functions, but rather the mx51evk.h is still in mainline. I will cleanup in mx51evk, too.
- MX51_PIN_DI1_DISP_CLK = _MXC_BUILD_NON_GPIO_PIN(0, 0x730), /* No MUX register!! */
Line too long.
register!! */
Line too long.
Ok, will fix.
Hi Dave,
Probably iut is better you set a more useful comment in your commit. Instead of "Added support for mxc_iomux_set_input()", you can explain which is the new feature you provide. Something to explain you add a utility for the "daisy chain" pins, to control the input path to a module when the module can be connected to more as one pin.
The patch is part of a series. However, I can see only the first two patches. Is there something missing ? I do not see any relation between these two patches, too.
- u32 pad_reg = IOMUXSW_INPUT_CTL+(input*4);
Code styling, you should add spaces:
u32 pad_reg = IOMUXSW_INPUT_CTL + (input * 4);
- writel(config, pad_reg);
Hi Stefano,
On Friday 20 August 2010 10:10:49 am Stefano Babic wrote:
Hi Dave,
Hmmm. I thought it was a trivial and obviously missing function to make iomux.c complete. Someone just needed to write it. I didn't think it needed any more explaining than that, but I'll do it in the next version of the patch set (will take a while).
I sent 4 patches and received them all on the mailing-list. Are you sure you miss two of them? The first three patches introduce some minimal fixes/additions in order to implement the BSP for PRTLVT2 boards (patch 4/4).
Ok.
David Jander wrote:
Hi Stefano,
Hi David,
Not everybody works with the MX51, and if we do not write some additional info it is difficult to find a relation in the reference manual ;-).
I have found them on gmane now, thanks.
David Jander
David Jander
Stefano Babic
