[U-Boot] [PATCH] mmc: socfpga_dw_mmc: Move drvsel and smplsel to dts
socfpga_dw_mmc driver will obtain the drvsel and smplsel value from device tree instead of definition in config header file.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/socfpga_cyclone5.dtsi | 2 ++ drivers/mmc/socfpga_dw_mmc.c | 24 ++++++++++++++++++++++-- include/configs/socfpga_common.h | 2 -- 3 files changed, 24 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/socfpga_cyclone5.dtsi b/arch/arm/dts/socfpga_cyclone5.dtsi index de36209..040b236 100644 --- a/arch/arm/dts/socfpga_cyclone5.dtsi +++ b/arch/arm/dts/socfpga_cyclone5.dtsi @@ -25,6 +25,8 @@ bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; + drvsel = <3>; + smplsel = <0>; };
sysmgr@ffd08000 { diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 8076761..2cd7a51 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -19,18 +19,25 @@ static const struct socfpga_clock_manager *clock_manager_base = static const struct socfpga_system_manager *system_manager_base = (void *)SOCFPGA_SYSMGR_ADDRESS;
+/* socfpga implmentation specific drver private data */ +struct dwmci_socfpga_priv_data { + unsigned int drvsel; + unsigned int smplsel; +}; + static void socfpga_dwmci_clksel(struct dwmci_host *host) { unsigned int drvsel; unsigned int smplsel; + struct dwmci_socfpga_priv_data *priv = host->priv;
/* Disable SDMMC clock. */ clrbits_le32(&clock_manager_base->per_pll.en, CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK);
/* Configures drv_sel and smpl_sel */ - drvsel = CONFIG_SOCFPGA_DWMMC_DRVSEL; - smplsel = CONFIG_SOCFPGA_DWMMC_SMPSEL; + drvsel = priv->drvsel; + smplsel = priv->smplsel;
debug("%s: drvsel %d smplsel %d\n", __func__, drvsel, smplsel); writel(SYSMGR_SDMMC_CTRL_SET(smplsel, drvsel), @@ -50,8 +57,10 @@ static int socfpga_dwmci_of_probe(const void *blob, int node, const int idx) const unsigned long clk = cm_get_mmc_controller_clk_hz();
struct dwmci_host *host; + struct dwmci_socfpga_priv_data *priv; fdt_addr_t reg_base; int bus_width, fifo_depth; + unsigned int drvsel, smplsel;
if (clk == 0) { printf("DWMMC%d: MMC clock is zero!", idx); @@ -78,11 +87,19 @@ static int socfpga_dwmci_of_probe(const void *blob, int node, const int idx) return -EINVAL; }
+ drvsel = fdtdec_get_uint(blob, node, "drvsel", 0); + smplsel = fdtdec_get_uint(blob, node, "smplsel", 0); + /* Allocate the host */ host = calloc(1, sizeof(*host)); if (!host) return -ENOMEM;
+ /* Allocate the priv */ + priv = calloc(1, sizeof(*priv)); + if (!priv) + return -ENOMEM; + host->name = "SOCFPGA DWMMC"; host->ioaddr = (void *)reg_base; host->buswidth = bus_width; @@ -92,6 +109,9 @@ static int socfpga_dwmci_of_probe(const void *blob, int node, const int idx) host->bus_hz = clk; host->fifoth_val = MSIZE(0x2) | RX_WMARK(fifo_depth / 2 - 1) | TX_WMARK(fifo_depth / 2); + priv->drvsel = drvsel; + priv->smplsel = smplsel; + host->priv = priv;
return add_dwmci(host, host->bus_hz, 400000); } diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index f6808b5..b661cc2 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -153,8 +153,6 @@ #define CONFIG_DWMMC #define CONFIG_SOCFPGA_DWMMC #define CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH 1024 -#define CONFIG_SOCFPGA_DWMMC_DRVSEL 3 -#define CONFIG_SOCFPGA_DWMMC_SMPSEL 0 /* FIXME */ /* using smaller max blk cnt to avoid flooding the limited stack we have */ #define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 /* FIXME -- SPL only? */
Hi!
- drvsel = fdtdec_get_uint(blob, node, "drvsel", 0);
The default value here should be 3, otherwise this won't preserve the original behavior of the driver in case the nodes in DT are missing.
if (!priv)
return -ENOMEM;
If this call fails, you're leaking memory, since you calloc() some stuff before.
- host->name = "SOCFPGA DWMMC"; host->ioaddr = (void *)reg_base; host->buswidth = bus_width;
- priv->drvsel = drvsel;
- priv->smplsel = smplsel;
- host->priv = priv;
You can move the fdtdec_get_uint() calls here directly, no need to introduce ad-hoc variable and then just assign it into the private data.
Hi Marek,
Hi!
Nice thinking, will update this.
if (!priv)
return -ENOMEM;
Oops, yup, this need to be fixed
Let me enhance this too
Thanks Chin Liang
Chin Liang See
clsee
