[U-Boot-Users] U-Boot does not compile for tb0229
Hello all,
I always get the following error when trying to compile U-Boot for the tb0229 board. Like stated in the readme, I do the following
$ make tb0229_config $ make CROSS_COMPILE=mips-linux-
Then I get this at the end of the build
make[1]: Leaving directory `/home/fille/bootloader/u-boot-1.1.1/common' UNDEF_SYM=`mips-linux-objdump -x lib_generic/libgeneric.a board/tb0229/libtb0229.a cpu/mips/libmips.a lib_mips/libmips.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a net/libnet.a disk/libdisk.a rtc/librtc.a dtt/libdtt.a drivers/libdrivers.a drivers/sk98lin/libsk98lin.a post/libpost.a post/cpu/libcpu.a common/libcommon.a |sed -n -e 's/.*(__u_boot_cmd_.*)/-u\1/p'|sort|uniq`;\ mipsel-linux-ld -Bstatic -T /home/fille/bootloader/u-boot-1.1.1/board/tb0229/u-boot.lds -Ttext 0xBFC00000 $UNDEF_SYM cpu/mips/start.o \ --start-group lib_generic/libgeneric.a board/tb0229/libtb0229.a cpu/mips/libmips.a lib_mips/libmips.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a net/libnet.a disk/libdisk.a rtc/librtc.a dtt/libdtt.a drivers/libdrivers.a drivers/sk98lin/libsk98lin.a post/libpost.a post/cpu/libcpu.a common/libcommon.a --no-warn-mismatch -L /opt/brcm/hndtools-mips-linux-3.2.3/lib/gcc-lib/mips-linux/3.2.3 -lgcc --end-group \ -Map u-boot.map -o u-boot cpu/mips/start.o: In function `reset': cpu/mips/start.o(.text+0x670): undefined reference to `_GLOBAL_OFFSET_TABLE_' make: *** [u-boot] Error 139
The symbol is in the library of my cross-compiler (actually I tried several.)
thanks,
Philippe
| Philippe De Swert -GNU/linux - uClinux freak- | | Stag developer http://stag.mind.be/ | Emdebian developer: http://www.emdebian.org | | Please do not send me documents in a closed format. (*.doc,*.xls,*.ppt) | Use the open alternatives. (*.pdf,*.ps,*.html,*.txt) | Why? http://pallieter.is-a-geek.org:7832/~johan/word/english/
------------------------------------------------------- NOTE! My email address is changing to ... @scarlet.be Please make the necessary changes in your address book.
Philippe De Swert
