[U-Boot] Build error for PowerPPC using GCC 5.2 toolchain
Hello,
At Yocto Project I sent the upgrade for the 2015.10 release, of U-Boot, however it is failing badly:
http://errors.yoctoproject.org/Errors/Details/21468/
Does someone has any idea how to fix it?
Otavio Salvador otavio.salvador@ossystems.com.br writes:
Hello,
The problem is the use of "extern inline" function definitions. GCC 5 defaults to the standard C99 semantics for this whereas earlier versions favoured the historical GNU semantics.
The quick fix is to add the -fgnu89-inline compiler flag which requests the old behaviour.
The proper fix is to replace all "extern inline" with "static inline" which is what they should have been all along.
Måns Rullgård
Otavio Salvador
