[U-Boot] [PATCH 1/1] cfi fix for Spansion and MB->MiB
I ran into a problem with the Spansion S29GL064N flash chip in that it returns a manufacturer ID of 0 and it also requires the AMD geometry fixup.
Additionally, I modified a few print statements to use KiB/MiB instead of kB/MB.
-Aaron Williams
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index dd394a8..105eb3f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1162,10 +1162,10 @@ void flash_print_info (flash_info_t * info) info->name, (info->portwidth << 3), (info->chipwidth << 3)); if (info->size < 1024*1024) - printf (" Size: %ld kB in %d Sectors\n", + printf (" Size: %ld KiB in %d Sectors\n", info->size >> 10, info->sector_count); else - printf (" Size: %ld MB in %d Sectors\n", + printf (" Size: %ld MiB in %d Sectors\n", info->size >> 20, info->sector_count); printf (" "); switch (info->vendor) { @@ -1924,6 +1924,7 @@ ulong flash_get_size (phys_addr_t base, int banknum)
/* Do manufacturer-specific fixups */ switch (info->manufacturer_id) { + case 0x0000: case 0x0001: flash_fixup_amd(info, &qry); break;
On Tue, Jan 25, 2011 at 19:56, Aaron Williams Aaron.Williams@caviumnetworks.com wrote:
-Aaron Williams
- printf (" Size: %ld KiB in %d Sectors\n",
- printf (" Size: %ld MiB in %d Sectors\n",
- case 0x0000:
I think something is wrong here. You shouldn't get a manufacturer ID of 0000 from a Spansion part. cmdset_amd_read_jedec_ids() should be where it's coming from, reading the datasheet is pretty clear that these parts return an 0001 or 01 depending on the BYTE# pin. I've used other parts in the series GL128N, GL256N, GL256P that have the same command set and not seen this.
Dear Aaron Williams,
Please split into two separate, independent patches.
And don't forget to add your signed-off-by line.
Aaron Williams
Andrew Dyer
